• 1
  • 2
  • 3
  • 4
  • 5
  • 7
Boing
Pre Screening
Wed Feb 29, 2012 9:35 pm
hello, your help
What do you think of this picture??
thanks
http://img24.imageshack.us/img24/8986/30698052.jpg
dlowwa
RE: Pre Screening
Thu Mar 01, 2012 12:05 am
Quoting boing (Thread starter):
Soft and taken in very poor light.
You do not need to start a new thread for every image/question. If you have any new images or questions related to them, keep them in this thread.
Boing
RE: Pre Screening
Thu Mar 01, 2012 6:57 am
Sorry, but soft to fix the problem what to do?? photo taken in backlight.
If I can give advice to solve the soft, I do not understand how to do (my photos are always soft)
thanks
vikkyvik
RE: Pre Screening
Thu Mar 01, 2012 7:01 am
Quoting boing (Reply 2):
You would have to sharpen it in Photoshop or a similar editing program.
However, given this:
There's not much point in editing it for A.net.
dlowwa
RE: Pre Screening
Thu Mar 01, 2012 8:53 am
It is very difficult to get backlit photos accepted here without the proper motivation. The best thing for you to do is wait for better conditions (i.e. clear skies and sun at your back), and then try again. We can worry about sharpening at that time. I don't think any editing will help you save the photo above.
Boing
RE: Pre Screening
Thu Mar 01, 2012 9:16 pm
What do you think,
I've improved it soft?
thanks
http://img638.imageshack.us/img638/3232/bisdsc2945.jpg
dlowwa
RE: Pre Screening
Thu Mar 01, 2012 10:11 pm
Quoting boing (Reply 5):
What do you think,
It's a little oversharpened and noisy, but should be fixable.
Boing
RE: Pre Screening
Thu Mar 01, 2012 10:25 pm
now it improved??
thanks
http://img4.imageshack.us/img4/9898/airlinersdsc2945.jpg
Boing
RE: Pre Screening
Thu Mar 01, 2012 10:32 pm
sorry, I did not notice and I mistakenly deleted the previous
dlowwa
RE: Pre Screening
Thu Mar 01, 2012 11:08 pm
Sharpening is better, but it appears there is some heat haze. You can try to hide it by submitting at 1024, but that may or may not work.
Boing
RE: Pre Screening
Fri Mar 02, 2012 9:21 pm
thanks
to put more photos
continued here
Boing
RE: Pre Screening
Sat Mar 03, 2012 9:30 pm
thanks
http://img23.imageshack.us/img23/5674/srilankanairlinersdsc41.jpg
cargolex
RE: Pre Screening
Sat Mar 03, 2012 9:43 pm
It's below the minimum size requirement, so it's hard to evaluate. It would be rejected for size if uploaded at those dimensions.
Boing
RE: Pre Screening
Sat Mar 03, 2012 9:49 pm
sorry I was wrong
http://img11.imageshack.us/img11/5674/srilankanairlinersdsc41.jpg
vikkyvik
RE: Pre Screening
Sat Mar 03, 2012 10:49 pm
Looks a bit oversharpened to me.
dlowwa
RE: Pre Screening
Sun Mar 04, 2012 6:01 am
Also has some editing halos around the aircraft that you should take care of.
Boing
RE: Pre Screening
Mon Mar 05, 2012 8:50 pm
an opinion on this photo
thanks
http://img535.imageshack.us/img535/9781/saudid.jpg
dlowwa
RE: Pre Screening
Tue Mar 06, 2012 1:26 am
Noisy, and VERY oversharpened.
teopilot
RE: Pre Screening
Tue Mar 06, 2012 2:46 pm
I agree with what Dana said... (and how can he be wrong?! LOL)
You've applied too much USM, thus probably ending up into grain (because I don't know if the picture was already grainy by itself, but the USM usually make things worse...).
Also, I see some grain in the sky, probably due to the fact that you didn't use the USM selectively (there's a quick how-to-do guide for this on A.net photo editing guide)
A general rule: exceeding never pays off... and, also in this case, by exceeding with the USM you have got a picture that seems quite "unreal" to me, because of its excessive sharpening.
I'll give you a word of advice, basing on my experience: generally I apply USM three times...
1. 200%, 0.2, 0
2. 200%, 0.2, 0
3. 100%, 0.2, 0
This technique works almost perfectly for my combos, both 70-200L and 15-85 on my 450D.
But there are not general rules when it comes to sharpening... you can be given advice, but you have to try and try until you find the perfect settings.
But what I think you're missing too is a quick pass with NR tool: USM generally makes some grain come out... with a "soft" NR pass, you can benefit a lot (at least, this works with me!).
I can see lots of jaggies on your last picture too.
It's better to apply USM on a duplicated layer and then to use the eraser tool to erase them. (Jaggies are those "white lines" that came to be noticeable with strong USM passes).
Hope it helps!
Boing
RE: Pre Screening
Tue Mar 06, 2012 9:21 pm
hours as it goes,
I selected the aircraft and unsharp mask 90, 0.5, 0
anyway you advise me to select only one aircraft to apply sharpening.
Thanks for your valuable advice
http://img577.imageshack.us/img577/7756/webdsc1596.jpg
teopilot
RE: Pre Screening
Tue Mar 06, 2012 9:34 pm
Well, to be honest, I see it better if compared to the previous one.
But it is still soft to my eye... I'd go with several further USM passes. Don't be harsh in applying it... and use the same method: duplicate layer, select the aircraft, USM, eraser tool, Noise reducion and flatten image.
That's all!
Boing
RE: Pre Screening
Tue Mar 06, 2012 9:57 pm
sorry but I have not quite clear how to use the eraser
Can you explain it to me since you're so kind
thanks
applied two mask steps as you said 200,0.2,0
thanks
http://img7.imageshack.us/img7/3707/2webdsc1596.jpg
dlowwa
RE: Pre Screening
Wed Mar 07, 2012 2:11 am
Quoting boing (Reply 21):
Still quite oversharpened.
Boing
RE: Pre Screening
Wed Mar 07, 2012 9:07 pm
back again
so could go, almost nothing usm
thanks,
unfortunately I can not see the marks that you say or you say the lines ....
http://img824.imageshack.us/img824/3161/saudy3dsc1596.jpg
dlowwa
RE: Pre Screening
Thu Mar 08, 2012 1:38 am
Quoting boing (Reply 23):
back again
Best one so far, though just a little too soft now. It looks like heat haze might be present, and if that is the case, you will not be able to fix the image.
Boing
RE: Pre Screening
Thu Mar 08, 2012 5:18 pm
although I really like,
changing image.
How about this
thanks
http://img267.imageshack.us/img267/4466/layonairweb.jpg
[Edited 2012-03-08 09:23:25]
dlowwa
RE: Pre Screening
Thu Mar 08, 2012 6:34 pm
Quoting boing (Reply 25):
How about this
Not too bad, though there seems to be a fair amount of compression. Because of that hard to say for sure if it's too noisy/os.
teopilot
RE: Pre Screening
Thu Mar 08, 2012 8:43 pm
Quoting dlowwa (Reply 24):
I agree that heat haze is always a pain in the neck as it is not fixable in any way... but I can still remember a word of advice someone (probably Dana himself) here gave me some time ago: to try with a resize.
I think that in this case it worth a try, since the image should be around 1200px wide... So, if I were you, I'd have a go with a 1024px resize and see what it looks like.
Maybe I remmber wrong... but I used it at times and it seems to work properly when heat haze is not so incisive!
Boing
RE: Pre Screening
Thu Mar 08, 2012 9:48 pm
We tried again in 1024 what do you say thanks
I love this photo!!
http://img826.imageshack.us/img826/293/saudy3eiezl1024.jpg
and also put this occasion.
Thanks to all
http://img856.imageshack.us/img856/4029/cargowebdsc2952.jpg
vikkyvik
RE: Pre Screening
Fri Mar 09, 2012 3:02 am
Quoting boing (Reply 28):
I love this photo!!
It is a nice photo, but just might not be what A.net is looking for. Acceptance or rejection here isn't necessarily a judgment on your photographic skills, or even on the particular photo. It's worth keeping that in mind.
Even at 1024, your photo looks quite soft in parts, yet almost oversharpened in others. I think heat haze is probably the killer for this one.
It's soft and a bit high in the frame for my taste (Dana may disagree), but the major obstacle (no pun intended) is the blockage of the gear and engine by the taxiway signs. That will likely result in a motive rejection.
dlowwa
RE: Pre Screening
Fri Mar 09, 2012 9:06 am
Quoting vikkyvik (Reply 29):
Yes, probably best to give up on this one.
No, you are correct on both counts Vik.
Boing
RE: Pre Screening
Fri Mar 09, 2012 4:25 pm
I understand it, the obstacles that are seen close to the wheels
and the motor are cause for rejection.
thanks
ok
I know abandonment,
try again with more photos
thanks
Boing
RE: Pre Screening
Fri Mar 09, 2012 10:04 pm
How about this
thanks
http://img688.imageshack.us/img688/8898/iranairepibl.jpg
dlowwa
RE: Pre Screening
Sat Mar 10, 2012 12:09 am
Quoting boing (Reply 32):
How about this
A little flat and noisy, but otherwise ok.
Boing
RE: Pre Screening
Mon Mar 12, 2012 4:08 pm
I was rejected because soft
What do you think?
http://img189.imageshack.us/img189/4426/airlinersdsc1024.jpg
cargolex
RE: Pre Screening
Mon Mar 12, 2012 4:52 pm
It looks like a fair rejection to me - it does look soft overall to me. Selective sharpening might help. If you're working in photoshop, try selecting individual areas of the aircraft and copying them into a new layer, then applying unsharp mask (I realize you may already have done this).
I get a significant number of soft rejections and I have to tell you, sharpening is probably the most difficult and frustrating aspect of working on my images - so take my opinion with a grain of salt.
Boing
RE: Pre Screening
Mon Mar 12, 2012 6:25 pm
Quoting Cargolex (Reply 35):
I selected only the plane and I applied unsharp mask.
I can better explain what it means to select individual parts of the plane (what you mean by parts?)
thanks
dlowwa
RE: Pre Screening
Tue Mar 13, 2012 9:20 am
Quoting boing (Reply 34):
What do you think?
I think what I said in reply 9 is still true. There is some heat haze, and you weren't able to hide it even at the smaller size. You probably cannot fix this image for here.
Boing
RE: Pre Screening
Tue Mar 13, 2012 8:59 pm
ok, I just wanted to understand what needs to be done to solve the problem "soft"
thanks
while I post this.
Give me good news .....
http://img651.imageshack.us/img651/8584/austrialianoelnndsc4836.jpg
dlowwa
RE: Pre Screening
Tue Mar 13, 2012 9:23 pm
Quoting boing (Reply 38):
while I post this.
A little oversharpened. Might be acceptable with a better edit.
Boing
RE: Pre Screening
Tue Mar 13, 2012 10:20 pm
Quoting dlowwa (Reply 39):
recommendations?
less sharpening!
thanks
dlowwa
RE: Pre Screening
Wed Mar 14, 2012 10:21 am
Hard to tell without seeing the original. I can take a look if you would like and tell you if the quality is there to make it worth another attempt.
Boing
RE: Pre Screening
Wed Mar 14, 2012 10:01 pm
original image, reduced to 1200
thanks waiting for news
http://img41.imageshack.us/img41/9828/dsc4836t.jpg
dlowwa
RE: Pre Screening
Wed Mar 14, 2012 10:05 pm
Quoting boing (Reply 42):
Reduced to 1200 defeats the purpose. Contact me privately, and then I can give you an address where you can send the original full-size file.
Boing
RE: Pre Screening
Wed Mar 14, 2012 10:37 pm
Quoting dlowwa (Reply 43):
I sent the mail
thanks
Boing
RE: Pre Screening
Sun Mar 18, 2012 9:01 pm
Hello, I'm back,
so can fit?
thanks
dlowwa
RE: Pre Screening
Sun Mar 18, 2012 10:41 pm
Quoting boing (Reply 45):
Hello, I'm back,
so can fit?
Hi, it's soft, dark, and poorly centered.
Boing
RE: Pre Screening
Mon Mar 19, 2012 10:46 am
Quoting dlowwa (Reply 26):
but it is possible that I was rejected for the following reason
Reject reason: soft oversharpened
or are the subjects that are not interesting??
if not, asks advice sucome solve this problem
thanks
dlowwa
RE: Pre Screening
Mon Mar 19, 2012 7:15 pm
Quoting boing (Reply 47):
Yes, it does have that look... Personally, I try to never give soft and oversharpened as reasons for a single image as I can see how confusing/contradictory that can seem, but there are certainly are cases when it could happen. If your image is quite soft to start and you apply too much sharpening to compensate, that would be the result. I can't say if that's exactly what happened with your image, but like I said, it does have that look.
Boing
RE: Pre Screening
Mon Mar 19, 2012 8:34 pm
ok, but at least when the place can tell me please the image
be accepted, so I avoid long waits and then .....
thanks always very kind
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
