Kaphias
Post/Pre-Screening: Level, Motive, Quality
Sun Apr 15, 2012 4:47 pm
Trying to get caught up on stuff from the last few months:
1. Rejected two separate times with the message "needs CW rotation". I'm clearly not seeing it, so if you could give an idea of how much more it needs, I'd appreciate it.
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N394NS-PAJN-11-09-2011-3.jpg
2. I'm pretty sure the quality isn't there, but for future reference on this spot, is the motive ok with respect to distance and center? I was trying to frame the mountains. I really love this shot and can't wait to have another go at it with a real camera.  http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N791AS-PAJN-01-15-2012-1.jpg
3. Rejected for soft with the comment "Over saturated too. Also, portions of the AC are soft." I now realize that the drastic lighting variations are probably the problem with this one, but I think the shot is unique because the tail has been taken off the aircraft. Any use in trying this one again? What portions of the plane are soft?
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N337AK-PAJN-01-15-2012-2.jpg
4. I've got one sunset shot in before, not sure if these two are too dark.
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N5972E-PAJN-04-08-2012.jpg
5.
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N88412-PAJN-04-08-2012.jpg
6. Something doesn't feel right on this one. More contrast maybe?
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N337AK-PAJN-04-13-2012.jpg
7. Backlit for sure, but I was hoping the fact that it would be new to the database, shows 3 in one frame, and is a rare occurrence at this airport (yearly at best) might help.
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-90-00189-PAJN-04-13-2012.jpg
Thanks very much, as always.
Matthew
dazbo5
RE: Post/Pre-Screening: Level, Motive, Quality
Sun Apr 15, 2012 5:06 pm
Quoting Kaphias (Thread starter):
Use the fence on the left of the frame for reference, it's leaning to the left and therefore needs some CW rotation.
I think that's a great composition showing the aircraft departing, the airport and surrounding scenery. It might not work for here though and as you suggest, distance and motive may be given.
The rear of the aircraft and the floats apear soft on my screen.
They don't look dark on my screen, but could do with a little more contrast.
Looks fine to me, possibly a little sharp though.
Backlit for sure
Good attempt, but the lighting was against you that day.
Darren
dlowwa
Sun Apr 15, 2012 8:15 pm
The second will need a tighter crop. Both it and the third have very noisy skies as well, so that would need to taken care of. The fourth and fifth are flat, and have strong banding in the sky. The sky quality issues might not be fixable, as I seem to recall you were using a point and shoot, which would cause the issues seen here. The sixth is actually not too bad, just a little flat & yellow, and should be fixable.
Soaring1972
Sun Apr 15, 2012 9:21 pm
In my eyes the first one does not need any rotation! Sorry, but this fence is not the first fence in the world which is not vertical!!!! Whatch the small wodden house! And look to the rotor-mast, in my eyes this mast is also vertical!
If you take a vertikal line and put this to the left side of the house we can discuss if the picture needs 0,1 deg cw!!!
But I have had the same discussion with no success with one of my pictures!
The second one is a beautyfull picture without any chance in this database. If you crop this one it will loose the panoramic aspect of the mountains and you loose the reflection in the lake!!!
Thanks to all ONE-Star voters just to push a photograph down!!!
JakTrax
Sun Apr 15, 2012 9:43 pm
Given that the helicopter shot is most likely taken with a wide-angle lens at a short focal length , I would expect that fence to lean slightly to the left. Perhaps not as much as it is, but natural lens distortion must be considered with this type of shot. I had a few rejections recently where 'level' was cited as one of the rejection reasons (there were others so I couldn't appeal), so with the reupload I just put a note explaining that it was a wide-angle shot and therefore distortion will have an effect.
Karl
dlowwa
Mon Apr 16, 2012 10:28 am
Quoting JakTrax (Reply 4):
Wide angle lenses usually have barrel distortion, which causes the edges to lean toward the center, not away (that would be pincushion distortion). Following your argument, the fence should be leaning right, which goes to show just how much the image is unlevel.
Quoting Soaring1972 (Reply 3):
Yes, it's leaning left = cw rotation needed.
Soaring1972
Mon Apr 16, 2012 7:06 pm
"Yes, it's leaning left = cw rotation needed."
http://s1.directupload.net/file/d/2862/c5swcm5h_jpg.htm
JakTrax
Mon Apr 16, 2012 7:27 pm
Quoting dlowwa (Reply 5):
Sorry, I meant likely taken with a telephoto at a short focal length. But like I said, perhaps the fence shouldn't lean quite as much as it does. My point was simply that possible lens distortions should be taken into account when screening. If I spot distortions in my images these days I just leave an explanatory note. Not had any trouble since.
Karl
dlowwa
Quoting Soaring1972 (Reply 6):
Nice work, but a) we don't magnify to 500% or use a graph to check level, and b) even at 500% the shed is still leaning left, so your nice little diagram reinforces what I said, thanks!
Soaring1972
Mon Apr 16, 2012 7:42 pm
@ Dlowwa
Interesting answer! No other comment is needed!
Kaphias
Mon Apr 16, 2012 11:27 pm
Getting closer?
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N394NS-PAJN-11-09-2011-4.jpg
Matthew
dlowwa
Mon Apr 16, 2012 11:52 pm
Quoting Kaphias (Reply 10):
Getting closer?
A little too much, I'd say.
Kaphias
Tue Apr 17, 2012 2:36 am
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N394NS-PAJN-11-09-2011-5.jpg
Corrected the yellow cast, brought the contrast up a bit.
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N337AK-PAJN-04-13-2012-2.jpg
Matthew
dlowwa
Tue Apr 17, 2012 4:03 am
Quoting Kaphias (Reply 12):
A bit better, but still needs to be somewhere between this one and the original.
Not bad, but still looks a bit yellow.
Kaphias
Tue Apr 17, 2012 4:31 am
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N394NS-PAJN-11-09-2011-6.jpg
http://i174.photobucket.com/albums/w95/Kaphias/Kaphias-N337AK-PAJN-04-13-2012-3.jpg
Matthew
dlowwa
Tue Apr 17, 2012 5:02 am
First should be ok, second still a bit yellow, but might be passable.
Kaphias
Tue Apr 17, 2012 6:15 am
Quoting dlowwa (Reply 15):
Great! Thanks very much Dana, Jan, Darren, and Karl.
Matthew
Kaphias
Sat Apr 28, 2012 3:59 am
So oddly enough the second got accepted and nearly made it to the front page, while the first got rejected for quality, motive, and contrast with the comment "flat contrast, glare on cabin distracting". Contrast I can fix, but there was no mention from anyone in this topic about the quality (which is always borderline with my shots, I know) or the glare being an issue. I figured that it would be better to ask for advice here before going on, whether that be an appeal, or editing and trying again if it's worth it.
Matthew
dlowwa
Sat Apr 28, 2012 6:44 am
If it were just for the glare, I would say appeal. The contrast is passable imho, but the overall quality I have to admit is borderline. Your call if you want to appeal - it is a new reg. so that might help just a bit.
Kaphias
Sat Apr 28, 2012 9:22 pm
Appeal successful, thanks again Dana!
Photo © Kaphias
Photo © Kaphias
Matthew
