dlowwa
RE: Pre-Screening (Gianni Deligny)
Mon Jul 16, 2012 1:38 pm
First should be ok; middle three are borderline for the light; last is soft.
AviatorG
Mon Jul 16, 2012 1:41 pm
Thanks very much Dana!
AviatorG
Mon Jul 16, 2012 4:47 pm
dlowwa
Mon Jul 16, 2012 5:55 pm
Quoting AviatorG (Reply 3):
Re-upload (High In Frame):
Should be ok.
AviatorG
Thu Jul 19, 2012 7:02 pm
Does this one stand a chance?
http://www.airliners.net/addphotos/b....3451bgi_07jul2012_0736_edited.jpg
Thanks in advance.
dlowwa
Thu Jul 19, 2012 8:23 pm
Bit dark, but quality looks ok otherwise.
AviatorG
Sat Jul 21, 2012 8:24 pm
Very tough light with this one, however a rare shot. Anything I could do to help it into the database?
http://www.airliners.net/addphotos/b....5132anu_25jan2010_1258_edited.jpg
dlowwa
Sun Jul 22, 2012 8:20 am
Quoting AviatorG (Reply 7):
A bit soft, and as you say pretty poor light. Not much you can do to make its chances better than borderline at best.
AviatorG
Tue Jul 31, 2012 9:33 pm
dlowwa
Tue Jul 31, 2012 10:27 pm
Quoting AviatorG (Reply 9):
How does this one look?
A touch dark, but otherwise ok.
AviatorG
Tue Jul 31, 2012 10:55 pm
Thanks very much as always Dana
I'll try brighten it up a little before I upload.
http://www.airliners.net/addphotos/b....7964sdq_22jul2012_1310_edited.jpg
dlowwa
Wed Aug 01, 2012 4:42 am
Quoting AviatorG (Reply 11):
Also harsh light, but otherwise ok.
AviatorG
Fri Aug 10, 2012 10:32 pm
Your opinions on the below photo are most welcome..
http://www.airliners.net/addphotos/b....6673bgi_08aug2012_1722_edited.jpg
Gasman
Sat Aug 11, 2012 1:47 am
Awesome panning, but I suspect the contrasty lighting will probably preclude it from being accepted.
dlowwa
Sat Aug 11, 2012 2:56 pm
Quoting AviatorG (Reply 13):
Bit soft in places, but otherwise should be ok.
Quoting gasman (Reply 14):
No, it won't.
AviatorG
Sat Aug 11, 2012 5:22 pm
Thanks for the great opinions! Especially for your honest input as always Dana
I had a query regarding the following recent rejections.
Initially rejected for SOFT:
http://www.airliners.net/addphotos/r....4423bgi_17jul2012_1705_edited.jpg
Photo was carefully sharpened with USM & re-uploaded. Sadly rejected for DARK:
http://www.airliners.net/addphotos/r....9632bgi_17jul2012_1705_edited.jpg
I haven't touched the contrast/levels in the 2nd image after the initial rejection. Should I appeal?
Gasman
Sat Aug 11, 2012 8:45 pm
Quoting AviatorG (Reply 16):
I think you've beautifully reflected the prevailing lighting conditions at the time. That said, I do agree the picture would look even better with about 0.25 of a stop more exposure.
They seem harsh on dark. I had this one rejected for dark (also for being too common, which is why I'm not going to resubmit)
dlowwa
Mon Aug 13, 2012 12:25 am
No, it probably should have been rejected for dark the first time as well. Sorry it was missed.
AviatorG
Tue Aug 14, 2012 3:35 pm
dlowwa
Tue Aug 14, 2012 6:04 pm
First is a bit flat, but no major flaws.
Quoting AviatorG (Reply 19):
Re-upload (DARK)
Still dark/poor light.
(Still Grainy?)
Noise looks ok, but as with above, looks a little dark.
AviatorG
Tue Aug 14, 2012 11:27 pm
Quoting dlowwa (Reply 20):
After a re-edit   :
http://www.airliners.net/addphotos/b....2497bgi_17jul2012_1705_edited.jpg
The backlit angle certainly made this one fairly tricky to save. Tried to brighen it one last time before it ends up in the archives  .
http://www.airliners.net/addphotos/b....8631bgi_07jul2012_0736_edited.jpg
G
dlowwa
Wed Aug 15, 2012 12:41 am
Quoting AviatorG (Reply 21):
After a re-edit
Not much chance, the contrast is quite harsh.
Better, but still borderline dark.
AviatorG
Wed Aug 15, 2012 2:06 am
dlowwa
Wed Aug 15, 2012 2:09 am
Quoting AviatorG (Reply 23):
Different angle for JetBlue:
Better; still not great.
Also:
Also a bit dark/contrasty.
AviatorG
Wed Aug 15, 2012 7:24 pm
dlowwa
Thu Aug 16, 2012 9:06 pm
Quoting AviatorG (Reply 25):
Re-edited the JetStream:
Also:
Neither have great light, but that shouldn't be an immediate rejection.
AviatorG
Fri Aug 31, 2012 9:19 pm
Tough light, but any opinions on this one?
http://www.airliners.net/addphotos/b....6456geo_08aug2012_1510_edited.jpg
Gianni Deligny
dlowwa
Sat Sep 01, 2012 12:20 am
Quoting AviatorG (Reply 27):
It would be rejected for dark.
dazbo5
Sun Sep 02, 2012 7:14 am
Quoting AviatorG (Reply 29):
How are these?
1. Looks good on my screen.
2. It's a little noisy (for a.net), especially in the blue areas of the sky.
3. Great panning, only problem I see is a little noise in the sky (for a.net standards)
4. As No3.
Darren
AviatorG
Mon Sep 03, 2012 6:39 pm
Thanks for your honest opinion Darren! Always appreciated
How does this one look to you?
http://www.airliners.net/addphotos/b....2202slu_31aug2012_1444_edited.jpg
Recently ungraded my 50D to a 7D & I've seen a noticeable increase in my acceptance ratio (also much thanks to imput from you all in the forum! &nbsp . I've been using 'levels' quite a bit recently trying to enhance some shots I may have taken in relatively tough light. In time with practice & gettin' used to the new camera in different settings, hope to share some good material here!
dazbo5
Mon Sep 03, 2012 7:43 pm
Quoting AviatorG (Reply 31):
It's pretty good but maybe not quite as sharp as it could be. Was the originally a tiny bit blurry? The scenery looks familar, is that on approach to Castries?
I can safely say you've been doing that for some time!
Darren
AviatorG
Mon Sep 03, 2012 8:54 pm
Quoting dazbo5 (Reply 32):
It Is.
A shot I've been able to finally get as I'm on vacation, a short walk from my home in St. Lucia. BWA recently started sending their new ATR (3 in all to date) on a new service from Piarco (TTPP).
The original image itself seemed sharp to me. Went over it a couple times with USM layers at .2 x 20%, then again at .1 x 20% which may have softened it a bit too much. Not sure what chances it stands to get in as is..
dazbo5
Mon Sep 03, 2012 10:09 pm
Quoting AviatorG (Reply 33):
It Is.
Brings back happy memories although there was very little traffic the last time I was there.
I wouldn't have though much as it is. I normally use more agressive sharpening setting than that. I'd normally use 300-500, 0.2, 0 (PSE7, USM). It's not far off, but just seems a little soft on my screen.
Darren
AviatorG
Wed Sep 05, 2012 11:23 pm
dlowwa
Wed Sep 05, 2012 11:40 pm
Quoting AviatorG (Reply 35):
Opinions on this photograph?
I would drop the contrast a bit, so the background doesn't look quite as dark.
AviatorG
Wed Sep 05, 2012 11:58 pm
dlowwa
Wed Sep 19, 2012 10:39 pm
Quoting AviatorG (Reply 38):
How are these guys?
Poor light, especially the first. Likely a dark rejection.
AviatorG
Wed Sep 19, 2012 10:51 pm
Thanks Dana!
AviatorG
Mon Oct 01, 2012 4:20 pm
Any visible issues with this photo?
http://www.airliners.net/addphotos/b....3342anu_18sep2012_1510_edited.jpg
G
dlowwa
Mon Oct 01, 2012 10:40 pm
Quoting AviatorG (Reply 41):
Maybe slight issues with noise & sharpening (a little too much of both), but pretty close as-is.
AviatorG
Tue Oct 02, 2012 2:53 am
Thanks Dana, I've done some work to adjust those ares & notice a huge improvement (which is always great!)
Would like to know what your opinions are on this one shot in very little light (sun below the horizon). Particularly, is the sky too noisy, sharpness etc.?
http://www.airliners.net/addphotos/b....9421atl_27may2012_1837_edited.jpg
Best regards.
dlowwa
Tue Oct 02, 2012 6:35 am
Quoting AviatorG (Reply 43):
A bit noisy and soft, maybe blurry.
A388
Wed Oct 03, 2012 3:48 pm
Nice photos Giann0. A bit off topic but KLM is phasing out their MD11 so should you want to photograph it, you can do that in CUR on mondays when the second KLM flights leaves just after the LIAT flight arrives. Those KLM MD11's will be gone soon!!! Plan a flight to CUR
A388
AviatorG
Thu Oct 11, 2012 4:23 pm
Thanks buddy! I will try get down there on my next off days!
A388
Fri Oct 12, 2012 12:55 pm
Quoting AviatorG (Reply 46):
G
You're welcome my friend but hurry up. You now have only two chances to photograph these rare MD11's (which is on mondays).
A388
AviatorG
Sun Oct 21, 2012 2:42 am
Does this photo have a red / magenta cast? Any other visible issues?
http://www.airliners.net/addphotos/b....7873stt_03jan2012_1402_edited.jpg
dlowwa
Sun Oct 21, 2012 7:15 am
Slight red cast, yes, but probably should be fine.
