vishaljo
Pre/Post Screening - Vishal Jolapara
Sun Jul 29, 2012 7:50 am
http://www.airliners.net/addphotos/r..._z1342712938.4318img_3495_edit.jpg
Rejected for:
Quality
Soft
A comment from the screener regarding this upload:
"Too big for quality"
I didnt quite understand the meaning of the Screener's remark
You want the image to be toned-down to a smaller size?
And if you can pls tell me where all & what this image suffers from?
Thanks - Vishal
dlowwa
RE: Pre/Post Screening - Vishal Jolapara
Sun Jul 29, 2012 9:02 am
Quoting vishaljo (Thread starter):
Yes, the image is not even close to having the quality for 1400 pix. It might be ok at 1024, but even then only maybe.
I would have rejected it for blurry, grainy, oversharpened, and quality.
vishaljo
Sun Jul 29, 2012 10:07 am
Quoting dlowwa (Reply 1):
Alrright
Dana you would've rejected it for Oversharpened when it was rejected for "Soft"¿
It was shot from close range with a 7D & 100-400L.
Its tack sharp at full-res, just for my knowledge, where does it appear blurry?
Does this re-worked image look better?
http://www.airliners.net/addphotos/b...q1343548559.5513img_3495_1200x.jpg
Thanks for the reply Dana
dazbo5
Sun Jul 29, 2012 10:20 am
Quoting vishaljo (Reply 2):
I think the original rejection was wrong in my opinion. There seems to be a lot of inconsistant rejections at the moment, but that's for another day. I would agree with Dana, it should have been rejected for blurry rather than soft. To me, it looks like you've had to apply quite a lot of sharpening in order to compensate for the photo being slightly blurry, hence it's oversharp and lacks quality. Soft is incorrect in my opinion.
Not really, it's still slightly blurry. There's not a lot you can do to compensate for that as it's a problem with the original photo. You can't edit it out. As Dana suggested, try 1024 pixels rather than 1200 or 1400 to see if that masks the blur. I don't think it will but it's worth a try.
I'm more than happy to have a look at the original for you and give it an edit. Equipment used doesn't make much difference really, blurry is blurry. I would be surprised if it's tack sharp at full res given the blur that's visible in your edits, but by all means send me an email through my profile and I'll take a look if you like.
Darren
dlowwa
Sun Jul 29, 2012 10:27 am
Yes. Image looks like it was blurry/soft and oversharpened to compensate.
If that's really the case, you've done a poor job with the processing.
The whole underside of the aircraft is quite soft, and the gear looks blurry. I said I would have rejected for blurry to avoid confusion with oversharpened being mentioned as well, but really there's a point where blurry and very soft start to overlap. Take your pick for which one applies to this image.
Not quite as bad as the first. I would probably remove 'quality' from the rejection reasons, but I would keep the others.
