baldwin8
Newbie Help
Sat Sep 08, 2012 1:29 pm
rejected = quality, motive, color, soft
I am really at odds in seeing what is wrong with the rejection. I do understand the motive rejection "motive" they don't want too many just tail shots.
But soft and color? I'm just not getting it. I changed the color temp to 2100 as it got rid of the yellow ramp lighting, but I didn't go beyond that. I used unsharpen mask set very low and repeated.
I have good access for aircraft as I work on the ramp but this processing is eluding me.
http://www.airliners.net/addphotos/r...338775.3518expressjet26545nite.jpg
MaximLezin
RE: Newbie Help
Sat Sep 08, 2012 2:10 pm
Quoting baldwin8 (Thread starter):
Hi, Well first of all the most probable reason there was a motive rejection included was because you cut off the tail a little bit. It should be completely visible as there is no apparent reason for it not to be.
The quality rejection may have been because you reduced the image size to rapidly, or expanded it too much. Although there can be other reasons.
I cant comment about the colour. Show us the original image and perhaps its salvagable, since this is quite a nice shot!
baldwin8
RE: Newbie Help
Sat Sep 08, 2012 2:24 pm
Here is the original after only reducing color temp, convert to jpeg and just size reduction to post here.
I appreciate any suggestions.
2126avaforum by the_saint8, on Flickr
vikkyvik
RE: Newbie Help
Sat Sep 08, 2012 4:40 pm
It's tough to tell much about quality from a resized original, but your edit looks way overprocessed compared to the original.
It looks both soft and oversharpened to me. Did you use a fair amount of noise reduction or anything?
There's also noise visible, especially in the sky on the lower left.
Max covered the motive.
Color, I'm not entirely sure, maybe a bit red? The airplanes in the background look quite red.
baldwin8
RE: Newbie Help
Sat Sep 08, 2012 8:04 pm
Quoting vikkyvik (Reply 3):
I have noise reduction set on in the camera settings and when I save to jpg I use best quality. The tail was cut off during the edit as after looking at some tail shots I seen it is sometimes done. As I wanted to focus the attention on the engine nacelle and vertical tail. A judgement call on my part.
Thanks to everyone.
dlowwa
RE: Newbie Help
Sun Sep 09, 2012 3:15 am
Quoting baldwin8 (Reply 2):
As Vik mentioned, the quality of the submitted image is much worse than this. You are obviously doing something wrong when editing. I would worry about the crop/motive only after you figure where you're going wrong with the editing.
baldwin8
RE: Newbie Help
Mon Sep 10, 2012 12:22 pm
Thanks to everyone who replied and took time to view this topic.
Some more research on my part led me to converting the RAW to TIFF format and then to JPEG only after all editing was done. This took care of the noise (I think).
As for the color of some of the background aircraft, I'll try and play with this. I did have another image shot at the same time but with a bigger F stop number which helps.
baldwin8
RE: Newbie Help
Tue Sep 11, 2012 12:55 pm
Here is a re-edit of the original. This time RAW to TIFF to JPEG. I feel the noise is reduced and of course now fully visible. I would greatly appreciate critique before I re-submit.
As well I did not receive any email notification of the rejection, so I don't know if the screener had additional comments. Apparently others have not received email notification.
2126update1 by the_saint8, on Flickr
Soaring1972
RE: Newbie Help
Tue Sep 11, 2012 1:47 pm
It looks quiet unlevel.
Thanks to all ONE-Star voters just to push a photograph down!!!
baldwin8
RE: Newbie Help
Tue Sep 11, 2012 2:15 pm
Quoting Soaring1972 (Reply 8):
Yes I see it now, although I know the left side of the ramp is unlit which exaggerates the effect. If that is all you see, I feel it's an accomplishment. I'll see what anyone else responds with and correct said levelness.
vikkyvik
RE: Newbie Help
Tue Sep 11, 2012 3:28 pm
A bit off-level, oversharpened, still some slight noise in the sky, color still looks off (I think too red), and it's a bit low in the frame.
dlowwa
RE: Newbie Help
Tue Sep 11, 2012 3:39 pm
Level should not be an issue. Verticals in center are fine, and edges should slope inward for an UWA shot. Otherwise, Vik's comments are accurate: slightly low, os, and a touch yellow. Just needs minor adjustments.
baldwin8
RE: Newbie Help
Tue Sep 11, 2012 3:43 pm
Quoting vikkyvik (Reply 10):
Level, oversharpened and low in frame, I can fix although I felt it was more centered. Noise I have trouble seeing (no pun intended). And I will reduce the red.
I admit I have trouble with colours, as when I view the rejection guidelines and examples I can not see the differences in too blue, red and yellow!?!?!?!
Again everyone's critique is appreciated.
baldwin8
RE: Newbie Help
Tue Sep 18, 2012 5:24 pm
I have been going through some files and found this and I would welcome some critique. It is linked from Flickr which I don't know if it degrades much quality.
fgznftest by the_saint8, on Flickr
dlowwa
RE: Newbie Help
Tue Sep 18, 2012 9:59 pm
Seems to get a bit soft towards the nose, and there are several large dust spots in the sky. Other than that, no major issues.
baldwin8
RE: Newbie Help
Wed Sep 19, 2012 12:36 am
Quoting dlowwa (Reply 14):
Thanks dlowwa. I have PS Elements now for editing which makes following the "how to" section much easier. I have several more in this taxi that there might be a better one. My biggest challenge is judging colour cast.
It's appreciated.
baldwin8
RE: Newbie Help
Wed Sep 26, 2012 6:59 pm
After an upgrade in camera lens and some PS Elements edit, I would like some critique. The colour cast is an area I struggle with the most. As my work is spent with many hours working on the aircraft under the "orange" lighting, figuring which way to go with the adjustment is sometimes hard.
The aircraft is a light blue as used on the Air Canada fleet.
Thanks for looking.
georgian1test by the_saint8, on Flickr
dlowwa
RE: Newbie Help
Wed Sep 26, 2012 11:27 pm
Quoting baldwin8 (Reply 16):
Sky is noisy, and yes, you will need to adjust the color further. It is too magenta/orange now.
baldwin8
RE: Newbie Help
Thu Sep 27, 2012 12:45 am
Quoting dlowwa (Reply 17):
Yes I can understand the magenta/orange comment, but noisy sky? Shot with 100 ISO and of course around 7 second exposure. Any suggestions on reducing noise? Aircraft and area below horizon was the only area sharpened.
Thanks.
dlowwa
RE: Newbie Help
Thu Sep 27, 2012 2:02 am
Quoting baldwin8 (Reply 18):
Maybe trying some noise reduction? It's not terrible, but it is noticeable.
vikkyvik
RE: Newbie Help
Thu Sep 27, 2012 2:30 am
Quoting dlowwa (Reply 19):
Unfortunately, at least for me, I've found that NR on dark skies like that works terribly. Just makes it look different, but still noisy.
I actually don't have a good solution, so I'd be interested to hear if others do....I've struggled with night skies myself, even at ISO100. Overexposing a bit would help, but obviously you don't want to blow out other parts of the image....
baldwin8
RE: Newbie Help
Sun Oct 07, 2012 5:40 pm
I have a rejection for color "magenta tint" which is hopefully fixed in the edit, and Compression which I assume is noise in the sky.
Yes the Color issue I've tried and hopefully corrected. But the noise issue is difficult. I've done some reading on reducing noise in night skies and used another image that had reduced increased shutter speed which supposedly helps noise reduction. I've also tinkered a bit more with the PS Elements noise reduction settings and I think has helped it somewhat.
Can someone tell me if the noise issue is looks better as I am putting a lot of effort taking the night shots and not yet ready to unload several thousand dollars for top line equipment.
rejection
http://www.airliners.net/addphotos/r...0121007_s1348771191.0464cgvga1.jpg
and the re-edit
cgvga2 by the_saint8, on Flickr
Thank you for reading and input.
dlowwa
RE: Newbie Help
Sun Oct 07, 2012 6:05 pm
Quoting baldwin8 (Reply 21):
Color looks better, but I think you're confusing (digital) noise and compression (jpeg artifacts). They are not the same thing, although the can look similar at times. I think the noise in the rejected version looks fine, but if you notice around the wing and tail especially, there is some visible compression artifacts. The good news is this is almost certainly just something you've done when editing, perhaps not saving the image at full quality, and should be fixable. Hard to tell about the compression on the revised shot, as Flickr typically applies a fair amount of compression on upload anyway.
baldwin8
RE: Newbie Help
Sun Oct 07, 2012 6:28 pm
Quoting dlowwa (Reply 22):
When sharpening, I use the "quick selection tool A" and then increase the pixel size by "1" before the first pass of USM and then another increase of "1" before a final USM. The jpeg is saved as "12" Highest Quality. And of course I am working from a RAW format to start.
Since my using the new lens, my USM is usually 200/.2/0 and final of 50/.2/0 . I find my new lens extremely sharp compared to the kit lens.
I assume your speaking of arifacts where the wing/tail meet the background sky?
Thank you Dana for all of you efforts. Highly appreciated.
dlowwa
RE: Newbie Help
Sun Oct 07, 2012 11:38 pm
Quoting baldwin8 (Reply 23):
Saving at anything other than highest quality can often lead to visible compression, especially when you save multiple times, but if you save only once at max, then that's not likely the cause. Working from a RAW file won't affect that, as the compression is introduced later.
It could be I'm making the same mistake I ascribed to you above; namely, confusing noise for compression artifacts. Given how it appears to be localized around the transition areas between colors and straight lines (where you'd expect to se compression) I discounted it being noise, but it could be a bad masking job if you've applied any noise reduction in the sky. I don't think sharpening would have caused it.
baldwin8
RE: Newbie Help
Mon Oct 08, 2012 5:03 pm
Quoting dlowwa (Reply 24):
I'm using a 15 inch laptop with 1280 x 800 res for my editing with PSE 11. My 50+ years of age requires the use of reading glasses and I am having trouble seeing these "artifacts". I'm not doubting what your seeing but all I really see are the lights reflecting off parts of the tail and mostly under wing at where the surface meets the background sky. The ramp was wet from rainfall and there is a lot of reflection from the many lights on the horizon.
I will re-edit and not expand the selected area. The horizontal part of the tailplane could not be selected for sharpening as it would just include too much of the sky. Maybe there are some settings I still need to adjust. I am using 3px settings for "Quick Selection Tool A" .
Thanks again for the input.
dlowwa
RE: Newbie Help
Mon Oct 08, 2012 8:24 pm
Quoting baldwin8 (Reply 25):
Better if you post the re-edit when you have it in the queue because Flickr can introduce its own compression.
baldwin8
RE: Newbie Help
Tue Oct 16, 2012 12:43 am
Here is my latest night shot. Didn't want to start another thread so I am using the existing one.
I would appreciate critiquing and comments. My problem now is discerning the color casts. It was just uploaded so there is time to edit if neccesary.
http://www.airliners.net/addphotos/b...ready/n1350347968.3437n13969_1.jpg
dlowwa
RE: Newbie Help
Tue Oct 16, 2012 1:33 am
Color looks slightly off, but workable. A bigger problem will be the uneven distribution of light. The nose is already starting to look a little blown out, while the rest of the fuselage is still dark. Not sure you will be able to fix that.
baldwin8
RE: Newbie Help
Thu Nov 01, 2012 5:18 pm
I would just like to take a moment to thank everyone for there input and especially dlowwa, as he answers so many posts in this forum.
With giving my own images a critical look, I have now had more images uploaded on airliners.net. I've concentrated on night ramp shots which seem more of a challenge in editing. My investment in a new lens and software are paying off in personal satisfaction.
Thanks again.
dlowwa
RE: Newbie Help
Thu Nov 01, 2012 8:29 pm
Night shots are definitely tricky to get right, so by starting off with the hard stuff, hopefully it will be mostly downhill for you (in terms of difficulty that is).
Users browsing this forum: Elmdon and 4 guests
