Bogac
Pre-Screening / My Images From Ltba
Sun Sep 16, 2012 9:43 pm
As I want to have some contribution to the db badly, I am uploading many photos and ask your precious feedback. I decided I should have them in one topic rather than starting several new topics.
Here is the first one. Thanks a lot for your comments.
http://img407.imageshack.us/img407/1963/20120908ltbatcjnd0139.jpg
[Edited 2012-09-16 14:45:13]
[Edited 2012-09-16 14:55:09]
evall95
RE: Pre-Screening / My Images From Ltba
Sun Sep 16, 2012 10:39 pm
Thats a pretty good first shot although has some issues to keep it from being accepted. Firstly the shot is back lit meaning that the light is not shining directly on the side of the the aircraft that you are shooting at and the aircraft is way too low in the frame. I will let a screener comment on the quality.
dlowwa
Sun Sep 16, 2012 10:41 pm
The bad angle of the light pretty much cancels out any other concern. You're unlikely to get backlit images accepted unless the subject is very rare, or the backlighting is intentional to achieve an effect. Neither is the case here.
Bogac
Mon Sep 17, 2012 9:19 pm
OK, thanks a lot for the feedback. Actually I was pretty sure that photo would get positive comments and I am surprised. But these comments definitely will change the way I look into aviation photography and I will pay more attention to detail for sure.
Here's another one.
http://img14.imageshack.us/img14/2585/20120908ltba4kaz810014.jpg
vikkyvik
Mon Sep 17, 2012 9:45 pm
Quoting Bogac (Reply 3):
There's nothing wrong with the photo - it doesn't meet A.net criteria, but personally I think it's a nice photo.
However, with that one and the Azerbaijan shot, it looks to me like you're using a heck of a lot of noise reduction - probably far more than is necessary.
Bogac
Mon Sep 17, 2012 9:50 pm
Yes, your right. I use a lot of Noise Reduction cause I get a lot of "soft" criticism and I still do not know how to decide what amount is appropriate and how much is too much.
Of course I respect high quality standarts of a.net, but I still wonder in which aspect that image would be considered "not good enough" and is there anything that can be done for this image to edit better.
Thanks a lot for your appreciation and feedback.
Bogac
Mon Sep 17, 2012 9:54 pm
Oh... I now see that I misunderstood. A330 shot is backlit and that's a rejection. I get that.
What about the Azerbaijan shot? Do you think that might be accepted with a better edit?
Best.
dlowwa
Tue Sep 18, 2012 12:42 am
Quoting Bogac (Reply 6):
Possibly, but can't say for sure without seeing that better edit. Color looks a bit off as well.
vikkyvik
Tue Sep 18, 2012 2:45 am
Quoting Bogac (Reply 5):
You're starting at the wrong end. Start with NO noise reduction, then add if necessary.
The less, the better. Too much NR erases detail, and gives a photo a sort of plastic look. It's the first thing I noticed when I opened your Azerbaijan shot.
Plus, noise reduction softens the image. It doesn't make it less soft.
Bogac
Tue Sep 18, 2012 3:55 am
Thanks for the feedback. I used the word "soft" instead of oversharpened. It seems I have a tendency towards oversharpening and was trying to overcome this by noise reduction. Its obvious I need to edit better.
[Edited 2012-09-17 20:57:06]
vikkyvik
Tue Sep 18, 2012 7:00 am
Quoting Bogac (Reply 9):
Ah, gotcha. Don't worry, there's a steep learning curve when you first start uploading here.
But yeah, the less processing you have to do, the better. So instead of "de-sharpening" through NR, just don't sharpen as much in the first place.
Bogac
Wed Sep 19, 2012 8:48 pm
How about this one?
http://img525.imageshack.us/img525/2585/20120908ltba4kaz810014.jpg
[Edited 2012-09-19 14:07:35]
frankc
Wed Sep 19, 2012 9:06 pm
Hi,
I think I can see oversharpening (for example, check the space between the wing and the extended flaps), and there's a dust spot visible under both the left-and righthand engine areas.
[Edited 2012-09-19 14:12:13]
Bogac
Wed Sep 19, 2012 9:10 pm
Thanks a lot for the feedback, franc. I reloaded the image. Any ideas for cleaning dust spots?
frankc
Wed Sep 19, 2012 9:16 pm
Hi Bogac
The dustspots can be eliminated relatively easy in Photoshop by using the Clone Tool.
PS there are dustspots under both the engine areas in the photo - I overlooked the other initially
Frank
Bogac
Wed Sep 19, 2012 9:22 pm
It seems I have lots of spots. Hope noone else sees them. Reedited...
http://img259.imageshack.us/img259/2585/20120908ltba4kaz810014.jpg
dlowwa
Wed Sep 19, 2012 10:38 pm
Quoting Bogac (Reply 15):
Reedited...
This would be rejected for soft, editing (halos), and dirty.
Bogac
Thu Sep 20, 2012 7:40 pm
Still trying:
http://img822.imageshack.us/img822/2585/20120908ltba4kaz810014.jpg
Bogac
Thu Sep 20, 2012 7:44 pm
and this is a 1024 px version of the above.
http://img855.imageshack.us/img855/1413/20120908ltba4kaz8100141.jpg
Bogac
Fri Sep 21, 2012 9:03 am
Any ideas on whether the last two are OK or not?
dlowwa
Sat Sep 22, 2012 1:02 am
Quoting Bogac (Reply 18):
Would be rejected for grainy, editing (halos) and soft.
Bogac
Sat Sep 22, 2012 10:10 am
İ am a little frustrated. İ even cant see the differences with the accepted ones.
Bogac
Sat Sep 22, 2012 11:04 am
How about this:
http://imageshack.us/a/img827/7605/20120908ltbatcath0016.jpg
dlowwa
Sat Sep 22, 2012 2:30 pm
Quoting Bogac (Reply 22):
How about this:
Dirty and a little soft.
Bogac
Sat Sep 22, 2012 2:37 pm
Any advice on how to understand when it becomes clean? I clean them up using the spot healing tool and clone tool in ps but dont know how much would be considered clean.
frankc
Sat Sep 22, 2012 4:07 pm
Hi,
There's a darker area immediately below the exhaust of the RH engine (viewer's viewpoint). Probably a remainder of the editing proces.
It's quite visibly - even without equalizing the image (check the Editing page on this website).
In general, equalizing your image will pop up the dust spots and other artifacts.
Frank
Bogac
Sat Sep 22, 2012 7:16 pm
Here's another one:
http://imageshack.us/a/img9/1610/20120908ltbaylbbo0177.jpg
Bogac
Sat Sep 22, 2012 8:40 pm
Thanks a lot for the info, Franc.
dlowwa
Sun Sep 23, 2012 12:40 am
Quoting Bogac (Reply 26):
Here's another one:
A little soft/heat hazed, and looks like you applied a fair amount of noise reduction. Also no need for a 4:3 ratio in this in instance (3:2 would be better), but that would not be a rejection reason.
Bogac
Sun Sep 23, 2012 8:19 pm
Reedited:
http://img708.imageshack.us/img708/7605/20120908ltbatcath0016.jpg
Bogac
Sun Sep 23, 2012 9:06 pm
And here's the other:
http://img194.imageshack.us/img194/1610/20120908ltbaylbbo0177.jpg
vikkyvik
Sun Sep 23, 2012 9:27 pm
Quoting Bogac (Reply 29):
Reedited:
Aside from sharpness and dust spot, I'd say the previous edit was better. The new one has halos, colors are weird (compare it to the previous edit), and looks like a lot of NR again. Still a bit soft.
I'd suggest you try some edits without any NR and see how they look.
Quoting Bogac (Reply 30):
Previous edit looked sharper than this one.
Bogac
Sun Sep 23, 2012 9:42 pm
Well, actually I wasn't happy with the new one but I couldn't delete it. Started working from scratch. I guess I need to stop editing for some time and return to my FSX.
dlowwa
Sun Sep 23, 2012 10:14 pm
Reedited
As noted, still soft and obvious editing halos.
Editing better, but still soft/heat hazed.
Bogac
Mon Sep 24, 2012 5:20 am
Thanks a lot for the info. Would you please tell me where do you see the halos? Still trying to learn what not to do... these last two don't have any NR and I didn't expected to hear about halos. Probably I am looking for something else.
dlowwa
Mon Sep 24, 2012 5:39 am
Quoting Bogac (Reply 34):
Like I said, don't see a problem with the editing of the second; the first has soft halos around the whole of the aircraft. If you're not applying NR, then perhaps it has something to do with the masking you are doing.
I've indicated how far the halo extends from the fuselage; you can see the sky is a different color for a few pixels extending from the fuselage.
http://imageshack.us/a/img26/7605/20120908ltbatcath0016.jpg
Bogac
Mon Sep 24, 2012 6:06 pm
Still trying:
http://img853.imageshack.us/img853/3539/20120908ltbaylbbo0176.jpg
Bogac
Mon Sep 24, 2012 7:33 pm
I am not so sure about the YL-BBO but I feel I am very close for the TC-ATH (AtlasJet) below. Please use words such as magnificient, nail, brilliant etc, but not soft, halo, edit...
Thanks.
http://imageshack.us/a/img210/7605/20120908ltbatcath0016.jpg
dlowwa
Tue Sep 25, 2012 4:34 am
Quoting Bogac (Reply 37):
Both still slightly soft, though I don't see any halos on the latest version of the Atlasjet.
Bogac
Tue Sep 25, 2012 5:12 am
Does "slightly soft" counts as acceptable?
At least I had some progress...
vikkyvik
Tue Sep 25, 2012 5:15 am
Quoting Bogac (Reply 39):
My guess is no. It certainly wouldn't hurt to add a bit of sharpening.....
Bogac
Tue Sep 25, 2012 5:26 am
All right. As these were my closest images to "acceptable", I don't want to mess up :P. Cause you know, there's a pretty thin line between slightly soft and oversharpened.
Sadly I am at work now and I'll have to wait until I go back home.
Bogac
Tue Sep 25, 2012 5:21 pm
Here they are, with just a hint of sharpening.
Shall I take my place in the queue?
http://www.bogacerkan.net/bogac/images/20120908-LTBA-TC-ATH-0016.jpg
http://www.bogacerkan.net/bogac/images/20120908-LTBA-YL-BBO-0176.jpg
dlowwa
Wed Sep 26, 2012 11:07 am
Quoting Bogac (Reply 42):
Atlastjet might have a chance, the Baltic will always been borderline because you can't really fix heat haze with sharpening.
Bogac
Sun Oct 07, 2012 9:13 pm
Atlasjet got rejected with "quality soft overexposed colour" and Baltic was accepted.
dlowwa
Sun Oct 07, 2012 11:29 pm
Quoting Bogac (Reply 44):
I can see soft and color being an issue, but not really quality over overexposed.
