Patich
Post Screening: Help - Over Sharp And Compression
Sat Sep 29, 2012 7:35 pm
Hello guys,
Need help here,
This one was reject for uality, Oversharp, Compression and had a message "lots of heat haze".
I dont understand the Compression part, because I don´t change any setting regarding this.
Also, I see the jetwash of the engines I don´t see heat haze on the airplane.
The over-sharp part I can´t change, but the other two are anoying me.
Can you help?
http://www.airliners.net/procphotos/...ame=x1348936241.6104img_1204-1.jpg
[Edited 2012-09-29 13:04:38]
vikkyvik
RE: Post Screening: Help - Over Sharp And Compression
Sun Sep 30, 2012 3:47 am
I don't see what I would call "lots of heat haze". Maybe a bit, but I would have thought it was passable.
I do see some compression, though. Make sure you're saving at the highest quality.
Quoting Patich (Thread starter):
Why? Just do a new edit and sharpen it a bit less. Doesn't look hugely oversharpened.
Patich
Sun Sep 30, 2012 9:02 am
vikkyvik , Thank you for your reply
Ahhh, right. Correction: I ment "The over-sharp part I can change..."
I will look my exporting setting and see was it wrong.
dlowwa
Mon Oct 01, 2012 12:21 pm
Can see a little heat haze, but not 'lots' - at least we see much worse than that. Does seem to be oversharpened a bit, and there is some compression/noise, can't tell exactly which.
Patich
Mon Oct 01, 2012 7:09 pm
dlowwa, thank you for you reply
Well, I decide to give it another go.
I had quality expots at 90%, set it at 100%
Reduced sharp and NR
Does it look better know?
http://www.airliners.net/addphotos/b...ady/b1349118291.6906img_1204-2.jpg
dlowwa
Mon Oct 01, 2012 10:33 pm
Still a bit oversharpened, most notably on the titles.
Patich
Tue Oct 02, 2012 8:35 pm
Dana, apreciate your pacience
Reduced sharp, but now I´m only one click away of having no sharp ajust at all.
http://www.airliners.net/addphotos/b...ady/e1349209793.1376img_1204-3.jpg
dlowwa
Wed Oct 03, 2012 12:56 am
Quoting Patich (Reply 6):
Reduced sharp,
Should be passable.
