Patich
Pre And Post Screening (Patich)
Wed Oct 03, 2012 10:24 pm
Hello
I've just submitted this one:
1 - http://www.airliners.net/addphotos/b...ady/w1349301897.8369img_1257-1.jpg
2 - http://www.airliners.net/addphotos/b...eady/r1349303336.986img_1222-1.jpg
Would like your feedback about it and it´s chances of acceptance.
Thx
[Edited 2012-10-03 15:30:21]
dazbo5
RE: Pre And Post Screening (Patich)
Wed Oct 03, 2012 10:44 pm
Quoting Patich (Thread starter):
1. This looks oversharp on my screen towards the rear of the aircraft while the nose looks a little soft.
2. Possibly a little heat hazed and oversharp trying to compensate for it?
Darren
dlowwa
Thu Oct 04, 2012 12:14 am
Agree with Darren both slightly os, but I think should be passable
Patich
Thu Oct 04, 2012 7:20 pm
Thank you both for your inputs and glad that you think they are passable.
Photo 1 has no sharp added, except the export sharp.
Photo 2 had just a little bit, but way less then what I used to use.
Something definitly changed with my photos this couple of months to be nedding no sharp.
[Edited 2012-10-04 13:00:13]
Patich
Fri Oct 05, 2012 10:56 am
Hello
Please comment on these two. One is a pre-screening and the other a post-screening
Pre-screening:
Following the OS issue I had, this one is the first time i use the sharp slider to the left.
1 - http://www.airliners.net/addphotos/b.../q1349386153.6948img_1176-1-24.jpg
Post- screening:
Rejected by Grainy and Category "Not dark category"
http://www.airliners.net/addphotos/r...001_k1348264662.4461img_0926-3.jpg
Changed the NR, Masking and a little twick on the exposure. However I still have a doubt: Should the Dark category be selected, as the photo was taken after the sunset?
2 - http://www.airliners.net/addphotos/b...ady/a1349433919.6988img_0926-1.jpg
[Edited 2012-10-05 03:59:59]
[Edited 2012-10-05 04:00:22]
dlowwa
Fri Oct 05, 2012 1:20 pm
Quoting Patich (Reply 4):
Pre-screening:
Still a touch os, but might be passable.
Post- screening:
If the sun was below the horizon, then 'Dark' was the correct category to select. New version looks a bit dark/soft.
Patich
Fri Oct 05, 2012 1:54 pm
Thanks Dana
Pre-screening:
Trying to get it right. Reduced sharp little bit more:
1 - http://www.airliners.net/addphotos/b.../q1349444972.2349img_1176-4-18.jpg
Post-screening
Went back to the 1st version and increased Masking and a bit NR.
2 - http://www.airliners.net/addphotos/b...ady/q1349443893.7171img_0926-2.jpg
Looks better?
Maybe this v2 firmware for the 7D is getting my photos sharper. I don´t know.
vikkyvik
Fri Oct 05, 2012 5:15 pm
UA looks a bit soft.
Angola looks soft and a bit noisy.
Patich
Fri Oct 05, 2012 7:45 pm
Thanks for your comments Vik
UA-
It seems I reduced too much. Just reverted to the previous version
Angola
Increased the NR and sharp. There is some distortion around the reg that I´m having some trouble to fix
Do you see the noise all around?
http://www.airliners.net/addphotos/b...ady/o1349465458.4385img_0926-5.jpg
Bruno
vikkyvik
Fri Oct 05, 2012 9:40 pm
Quoting Patich (Reply 8):
Mostly in the darker areas, like the grey on the bottom of the fuse.
It still looks soft to me - I'm thinking that you're putting in too much NR now. Also looks quite dark overall.
dlowwa
Sat Oct 06, 2012 8:52 am
I see a slight amount of noise, but as Vik said, softness would be the bigger problem.
Patich
Tue Oct 09, 2012 10:23 am
Thx Dana
The Angola was at ISO 800 and I´m failing to reduce Noise and Softness at the same time. Maybe it has no solution. I don´t know
Another one.
I would like your comments on this rejection:
http://www.airliners.net/procphotos/...ame=g1348936576.0305img_9502-2.jpg
Quality
Blurry
Over-sharpened
Overexposed
dlowwa
Tue Oct 09, 2012 1:30 pm
Quoting Patich (Reply 11):
I would have added color as well, a little too much yellow.
Patich
Sat Oct 13, 2012 7:53 pm
Quoting dlowwa (Reply 12):
ok... thats embarrassing. but yes I see your point. I´ll leave that to later.
Pre-screening
Please comment on this one. I like these greys skys but they are tricky.
http://www.airliners.net/addphotos/b...ady/u1349823066.2465img_2358-1.jpg
Bruno
Newark727
Sat Oct 13, 2012 8:22 pm
I would say that the tail and reg area is a little overexposed and possibly a little oversharpened, and I think it could stand to be a tick higher in the frame.
vikkyvik
Sat Oct 13, 2012 11:07 pm
Quoting Newark727 (Reply 14):
I actually see it the opposite - I'd probably give the whole thing a slight kick of sharpening.
dlowwa
Sun Oct 14, 2012 2:42 am
Sharpening & centering look passable, it should be ok.
Patich
Sun Oct 14, 2012 1:28 pm
Thanks guys.
Pre-screening
Keeping in the greys skies theme and pushing it up a level.
I´ve just realize I have one photo of this "K" baby. I thought I had missed it.
http://www.airliners.net/addphotos/b...ady/z1350220824.8365img_2362-3.jpg
Bruno
dlowwa
Sun Oct 14, 2012 6:53 pm
Quoting Patich (Reply 17):
Should be ok.
Patich
Wed Oct 24, 2012 6:16 pm
dlowwa
Wed Oct 24, 2012 6:57 pm
Not the best light on the second, but both will probably be passable.
dlowwa
Wed Oct 31, 2012 9:28 pm
Quoting Patich (Reply 21):
Please comment on these ones:
Just a dust spot on the second; no major issues otherwise.
Patich
Thu Nov 01, 2012 8:33 pm
Hello Dana, spot removed and uploaded.
Now, my first experience indoors in a museum and also with a ultrawide that a fellow visitor lended me there.
Pre-screening
http://www.airliners.net/addphotos/b...ady/p1351800830.6821img_1723-1.jpg
http://www.airliners.net/addphotos/b...ady/a1351801384.4878img_1699-2.jpg
http://www.airliners.net/addphotos/b...ady/l1351801889.5079img_1676-1.jpg
Thx in advance
Bruno
dlowwa
Thu Nov 01, 2012 9:36 pm
Cockpit shot is a bit bright, but otherwise they look ok for quality. For level, try to use the verticals in the center of the frame, and keep in mind for the barrel distortion typical with uwa shots the edges should tilt in equally as much.
Patich
Thu Nov 01, 2012 11:17 pm
ok
Pulled back a little on the 2nd. Is it better?
http://www.airliners.net/addphotos/b...y/k1351810335.7894img_1699-2-3.jpg
For the level,
ajusted on the 1st by the two bars on the top.
http://www.airliners.net/addphotos/b...ady/u1351811148.7638img_1723-2.jpg
the 3rd is leveled by the bar over the captain window. does seem leveled. is it correct?
Bruno
dlowwa
Thu Nov 01, 2012 11:48 pm
Quoting Patich (Reply 25):
Yes.
I think it needs cw rotation.
Patich
Fri Nov 02, 2012 7:47 pm
dlowwa
Sat Nov 03, 2012 6:00 am
First should be ok, but second still feels cw.
Patich
Sat Nov 03, 2012 9:25 am
Ok
Leveling this is revealing more complicated than I thought.
Now I leveled by the vertical bars between the blue column and the aircraft.
http://www.airliners.net/addphotos/b...eady/q1351934310.333img_1723-4.jpg
And this one got rejected:
Post-Screening
http://www.airliners.net/procphotos/...ame=f1351102023.3853img_1477-1.jpg
Over-sharpened
Overexposed
Bruno
dazbo5
Sat Nov 03, 2012 9:35 am
Quoting Patich (Reply 29):
Museum photography and wide angle lenses are inherently difficult when it comes to levelling. As a rule of thumb, always level using a vertical in the centre of the frame. This averages any barrel distortion. There are plenty of verticals in the background on the window frames so I'd have used those as reference. Having said that, it's what looks right in the end that matters. I get the feel it needs a little more CW rotation. I'd probably give is a little extra sharpening as well.
Over-sharpened
Overexposed
It is a little sharp on my screen, the cheat lines are very jagged. You may need to selectively sharpen the aircraft and not sharpen the cheat lines. For me, it's not overexposed, that rejection reason is a little misleading. It's just a little too bright for this site. Reduce the exposure a little and you should be fine.
Darren
Patich
Sat Nov 17, 2012 10:32 pm
Hello guys
Today I´ve tried something different. Comments please
Pre-screening
http://www.airliners.net/addphotos/b...ady/m1353191191.1619img_2265-2.jpg
Bruno
gonzalu
Crew
Mon Nov 19, 2012 2:29 am
What happened to the wheels? How are they hidden by the background grass? Or is the runway not actually the one in front?
Manny Gonzalez, Thrust Images.
dlowwa
Mon Nov 19, 2012 3:23 am
Quoting Patich (Reply 31):
Not sure what is different about it, but the missing wheels will be an issue, as it was avoidable, and it is oversharpened.
Patich
Mon Nov 19, 2012 9:39 am
I should have been more specific in my previous post. You are both right. Sorry for that.
The difference in the photo was the lower speed, but with the wheels issue I´ll scrap this one.
Patich
Sat Nov 24, 2012 8:02 pm
Hello
I would like your opinion on this photo in general and, for future reference, if the aircraft is allowed to be offcenter to the left because of the follow-me
Pre-screening
http://www.airliners.net/addphotos/b...ady/z1353786949.2103img_2532-1.jpg
Bruno
dlowwa
Sun Nov 25, 2012 10:00 am
Quoting Patich (Reply 35):
Centering should be ok, but there are exposure (high) and contrast (low) issues.
Patich
Sun Nov 25, 2012 7:48 pm
Ok Dana
Made some corrections on exposure and contrast.
Did I get it right??
Pre-scennning
http://www.airliners.net/addphotos/b...ady/o1353872665.6504img_2532-2.jpg
Thx again
Bruno
dlowwa
Sun Nov 25, 2012 10:09 pm
Quoting Patich (Reply 37):
Better, but the light is still pretty poor.
Patich
Sun Nov 25, 2012 10:44 pm
One last try.
http://www.airliners.net/addphotos/b...ady/g1353882933.6681img_2532-3.jpg
Maybe I´m aiming too high with this one.
Thx
Bruno
dlowwa
Mon Nov 26, 2012 9:42 am
Quoting Patich (Reply 39):
One last try.
As above. Better than the first, but the light is quite poor.
Patich
Sat Dec 08, 2012 9:38 pm
Hello
I would like your comments on this one.
I like it because of the condesation in the engine, but the sun was high and in front.
Does it stand a chance? (and do you see it oversharped?)
Pre-screening
http://www.airliners.net/addphotos/b...dy/t1355002296.8976img_2914-02.jpg
Bruno
dlowwa
Sun Dec 09, 2012 10:35 am
Quoting Patich (Reply 41):
Sharpening seems ok, but look a little flat & noisy.
Patich
Thu Dec 13, 2012 8:57 pm
Hello,
Made another edit to the Angola to correct contrast anf NR.
Is it ok?
Pre-screening
http://www.airliners.net/addphotos/b...ady/x1355432046.9565img_2914-2.jpg
Thx again
Bruno
dlowwa
Fri Dec 14, 2012 1:07 am
Quoting Patich (Reply 43):
Is it ok?
Should be passable.
Patich
Sun Dec 23, 2012 1:55 pm
Hello
Happy hollidays to all.
I need your opinion on this one.
It´s another try on low shutter speed photo
Pre-screening
http://www.airliners.net/addphotos/b...ady/c1356270810.3088img_3829-1.jpg
Thx
Bruno
dlowwa
Mon Dec 24, 2012 9:32 am
Quoting Patich (Reply 45):
Sorry, more than a few severe problems with this one.
Patich
Mon Dec 31, 2012 6:14 pm
Hello
Wish you all a happy new year with everything you desire.
Quoting dlowwa (Reply 46):
Lets just forget I showed you that one, ok...?
Now I need help with this one:
Post-screening
- Level (no cw or ccw mention)
http://www.airliners.net/procphotos/...ame=j1356293798.3381img_0732-1.jpg
I zoomed the photo and the edges of the houses seem ok.
Thx
And again a happy 2013
dlowwa
Mon Dec 31, 2012 11:34 pm
Quoting Patich (Reply 47):
Post-screening
- Level
Looks like it needs a little cw.
Sorry about that. I'll try and remind the screener he should be leaving personal messages with level rejections.
Patich
Thu Jan 03, 2013 9:27 pm
Hello again
I would like your opinion on this one.
I can´t say i´m happy with this edit but i´m failing to see where to improve.
This was yesterday and was a huge, really huge, surprise as Condor don´t fly here to Lisbon. It was a medical emergency almost at lunch time with a very high sun.
Pre-screening:
http://www.airliners.net/addphotos/b...ady/a1357247573.2096img_4225-1.jpg
Thx
Bruno
