jpmagero
Pre/post Screening (jpmagero)
Tue Oct 09, 2012 2:44 pm
Had the following rejection for: "Bad crop motiv soft personal", and I don't understand the "bad crop/motiv", how should I adjust it? The balance seems right to me with roughly equal space above/below the ac. I see the "soft" and another color issue to fix anyways, but need some help on the crop. Thanks.
http://www.airliners.net/procphotos/...9351__n805mr_rsw_20120928_1200.jpg
John M - Aussie expat in the US
jpmagero
RE: Pre/post Screening (jpmagero)
Tue Oct 09, 2012 3:07 pm
Another for comment:
reject reason: "Oversaturated, magenta cast, dirty top right".
Oversaturated - maybe, with the sun at that direct angle, I think it looks about right?
Magenta cast - it was taken late afternoon near sunset and the clouds are going pink, but is the body of the aircraft really magenta?
Dirty - looked at my larger crop, and that's just the sky, not any dirt, though I can easily "clean" that if needed
http://www.airliners.net/procphotos/..._airforcetwo_rsw_20120928_1200.jpg
dazbo5
Tue Oct 09, 2012 3:16 pm
Quoting jpmagero (Thread starter):
The composition looks fine to me too, cropping just aft of the wing. It is a little soft though.
Quoting jpmagero (Reply 1):
I have to agree with the screening decision, the colours look too strong to me.
Magenta cast
I must say I can't see a magenta cast. The fuselage looks white to me so there's nothing you can do about the natural colour in the sky, it's just the time of day.
In the far upper corner, it does look like it's a large dust spot rather than a cloud. It's easily removed though.
I'm surprised you didn't get a comment about noise as well. There's a little noticeable noise in the sky although it's probably marginal as to whether it's acceptable or not. I never know what the standard is here with regards to noise these days, it seems inconsistant.
Darren
jpmagero
Tue Oct 09, 2012 6:10 pm
Thanks Darren - I am ok with putting these through the queue again, but I don't want to fix something that isn't broken, and if I can't see something after it's pointed out to me (magenta cast, crop, motive) then I will just leave as is - not much else I can do.
Will look at the saturation and noise too...txs.
jpmagero
Tue Oct 09, 2012 11:05 pm
Quoting dazbo5 (Reply 2):
I see that, but I just checked my sequence of photos before and after and it's definitely not dust, it's just a darker portion of cloud. I could remove it to satisfy the screeners - not a big deal.
vikkyvik
Wed Oct 10, 2012 6:48 am
Just to add another opinion...
On the first one, my guess on the motive/crop is that you cut off the engine. Although, I'm not sure it would look any better with the whole engine there. Might be one of those aircraft that really only look good with either a tight crop on the nose, or to just forward of the wing, or the whole airplane in the frame.
On the second one, I can definitely see magenta in the sky and on the paved areas. I think it could stand to have some of that removed - I doubt you'd notice much difference in the white of the airplane, since it's so bright anyway. As for oversaturation, the green/yellow grass pops quite a bit, but doesn't quite look oversaturated to me. Though again, I'd say no harm in a slight reduction.
Wed Oct 10, 2012 9:40 am
Quoting vikkyvik (Reply 5):
I wonder if overcontrasted would have been a better rejection 'reason' - it seems like part of it may have been caused from the contrast slider too.
My thought too - it's only a little more to include the rest of the exhaust.
And with the magenta - I think it's pretty faint.. I mean I can see it but it by no means detracts from the image significantly enough for me to think of it as a rejection reason..
jpmagero
Wed Oct 10, 2012 9:50 am
could be...I figured that if I cropped just off the wing would be ok - I guess it's a question of preference in these cases. Will look for another shot there, since that is essentially out of the camera, though I do have others in the sequence to use instead, even though this is my preferred shot.
jpmagero
Wed Oct 10, 2012 10:30 am
I've worked on the rejects above and have the below in the queue - do you feel they correct what was wrong with the originals?
Air Force Two: http://www.airliners.net/addphotos/b...4img79656_980002_krsw_20120928.jpg
Customs and Border Control (the original crop was out of the camera so had to use another shot): http://www.airliners.net/addphotos/b...2img79361_n805mr_krsw_20120928.jpg
vikkyvik
Wed Oct 10, 2012 2:57 pm
They both look a bit washed out to me - low on contrast, and maybe a bit bright for my taste, though possibly fine for A.net.
jpmagero
Fri Oct 12, 2012 5:35 pm
Here's another for some feedback, rejected for soft, dark:
soft - I'm having a hard time getting the balance right...getting some photos as both soft then over-sharpened with only the slightest tweak in between. My eyes tell me that this is not really that soft, but not sure I trust my eyes on this anymore.
dark - it was taken before sunrise, and I put that in the comment, so it's not going to be "bright" - the lighting is naturally soft. Should I just brighten it up, or just drop it as it will never be "bright" due to the natural lighting.
http://www.airliners.net/addphotos/r...98img72588_ok-geb_prg_20120902.jpg
dlowwa
Fri Oct 12, 2012 9:34 pm
Quoting jpmagero (Reply 10):
Only a bit soft, but contrast probably should have been included with the rejection, as it's quite low. You should be able to adjust the brightness/contrast, see the left side:
http://imageshack.us/a/img211/3228/20121012n13491804763398.jpg
jpmagero
Fri Oct 12, 2012 10:29 pm
Quoting dlowwa (Reply 11):
Cheers...I'll give that a go - it would make it brighter than the actual scene, but I suppose that's ok - hard to tell based on the image.
jpmagero
Sun Oct 14, 2012 10:29 pm
quick pre-screening question: does this have a chance here? Was a quick shot without a lot of prep for the settings, though I quite like the view of the plane coming in for landing just ahead of the rain. Cheers.
http://www.flickr.com/photos/vandari...087677303/in/photostream/lightbox/
dlowwa
Mon Oct 15, 2012 6:28 pm
Quoting jpmagero (Reply 13):
Probably not, a little too distant/dark. Sorry.
jpmagero
Sat Oct 20, 2012 11:57 am
Help...I still don't see it...it's the same shot I had here before, the plane is white, any cast in the ground has to be the real color. Worth an appeal or just give it up?
Reject reason: ground still has a purple cast oversharpened contrast colour personal
http://www.airliners.net/addphotos/r...4img79656_980002_krsw_20120928.jpg
dlowwa
Sun Oct 21, 2012 1:07 am
Don't think those rejection reasons were quite correct; for me it would have been a color & overexposed rejection. There is a magenta (similar to purple I guess) cast. See the adjusted left side:
http://imageshack.us/a/img823/2323/20121019d13498645787424.jpg
jpmagero
Fri Oct 26, 2012 12:15 pm
I've brightened up this shot (rejected for dark) - any better?
http://www.airliners.net/addphotos/b...mg72588_ok-geb_prg_20120902_v3.jpg
dlowwa
Fri Oct 26, 2012 3:25 pm
Quoting jpmagero (Reply 17):
any better?
Should be passable.
jpmagero
Sun Oct 28, 2012 3:04 am
I'm pretty happy with this shot of a sunstrike, but do you think it's something that could work here?
http://flic.kr/p/dokUyk
dlowwa
Sun Oct 28, 2012 10:33 am
Quoting jpmagero (Reply 19):
Hard to tell, as Flickr isn't the best for judging quality, but it might have a chance.
jpmagero
Mon Oct 29, 2012 3:25 pm
How does this edit look (bit of NR on the sun, and sharpening on the outline of the aircraft)? Are the edges of the sun too soft?
http://www.airliners.net/addphotos/b....1028n949fr_krsw_20121027_1024.jpg
dlowwa
Mon Oct 29, 2012 7:34 pm
Quoting jpmagero (Reply 21):
  I don't think we'll be judging solar sharpness. The aircraft does look a little soft/blurry though.
jpmagero
Mon Oct 29, 2012 8:05 pm
Quoting dlowwa (Reply 22):
Don't know what I was thinking
Did some selective sharpening...better? http://www.airliners.net/uf/165178/phpHJX4w1.jpeg
dlowwa
Tue Oct 30, 2012 6:32 pm
Still borderline, but not sure how much better you'll be able to do. If you're happy with it, just give it a go as it is.
jpmagero
Sun Nov 04, 2012 3:41 pm
I'm thinking of appealing this, as I don't agree that the contrast is too high, nor that the image is grainy. It first got rejected for dark, and I brightened it up for that, now it's "High Contrast grainy contrast". Thoughts or hints as to where the contrast is too high?
http://www.airliners.net/addphotos/r...mg72588_ok-geb_prg_20120902_v3.jpg
dazbo5
Sun Nov 04, 2012 4:36 pm
Quoting jpmagero (Reply 25):
I don't agree the contrast is too high, it looks about right to me but there is noticable grain. Given it's a shot taken after sunset and you may have had to increase the ISO, it's not surprising to have some grain. This site doesn't like any noticable grain though so you'll need to reduce with noise reduction.
Darren
jpmagero
Sun Nov 04, 2012 4:49 pm
Quoting dazbo5 (Reply 26):
exactly...it's taken before sunrise, using a low ISO and long exposure using a remote. After the first "dark" rejection I brightened it up (a lot brighter than the actual environment was at the time) and that may have introduced the grain/noise, which IMO, is not that noticeable, but I guess it is what it is. Frustrating, but oh well.
dlowwa
Sun Nov 04, 2012 5:05 pm
Yes, an appeal might be worthwhile.
jpmagero
Sun Nov 04, 2012 8:42 pm
"Screener rejection correct" oh well, moving on.
jpmagero
Sun Nov 04, 2012 9:51 pm
Have given it one more go...am worried that the NR may have softened up the underbelly too much, do you think it's ok? or too much?
http://www.airliners.net/addphotos/b...mg72588_ok-geb_prg_20120902_v4.jpg
dlowwa
Sun Nov 04, 2012 10:40 pm
I would give it a little more sharpening, but otherwise I think it should be ok (as I indicated above).
jpmagero
Tue Nov 06, 2012 3:23 am
Quoting dlowwa (Reply 31):
Done...thanks for the feedback.
Here's one I uploaded...I like the shot - considering it's from inside the aircraft, but not sure if this would be backlit and soft? Sun is hitting the wings, but I'm on the wrong side of the body - does it have a chance?
http://www.airliners.net/addphotos/b...71542_g-civv_lhr_20120829_1200.jpg
jpmagero
Sat Nov 10, 2012 10:47 am
Rejected for "quality soft".
http://www.airliners.net/addphotos/r...48n949fr_krsw_20121027_1024_v2.jpg
The silhouette of the aircraft is not soft, so I have to assume it is the sun that is being called soft?
As to quality, there is nothing I can do about that, but when looking at the silhouette, it's not perfect, but not too bad either. Seems to me the uniqueness of this kind of shot might be taken into account? Or best to just leave it?
dlowwa
Sat Nov 10, 2012 2:58 pm
Quoting jpmagero (Reply 33):
No, as I mentioned above, that would be irrelevant - the problem is with the quality of the aircraft.
jpmagero
Sat Dec 01, 2012 12:25 pm
HI - been a while. Got a bunch of rejections that I would like some feedback on. Thanks!
1: [backlit; needs more contrast dark contrast personal] The aircraft is not backlit as far as I can tell, the shadow is the horizontal bit of the tail, and light is clearly hitting the side (front, as far as the photo is concerned) of the plane directly. The front of the plane is pure black, so doesn't show up as bright as the back end, which is clearly lit.
http://www.airliners.net/addphotos/r...75273_n891at_rsw_20121020_1200.jpg
2: [flat/low contrast contrast personal ] - tried increasing the contrast but it just doesn't look as good. Seems ok to me on my screen.
http://www.airliners.net/addphotos/r...93img74214_n936at_rsw_20121015.jpg
3: [soft] - Can't really see any soft spots, most areas seem sharp to my eye.
http://www.airliners.net/addphotos/r...73447_n44fg_krsw_20121012_1200.jpg
4: [Soft tail. soft personal] - the reg number has a drop-shadow which may give it a soft appearance, but the tail as a whole seems sharp to me.
http://www.airliners.net/addphotos/r...0517_n243ms_kfmy_20121004_1200.jpg
Appreciate the feedback.
dlowwa
Sat Dec 01, 2012 9:18 pm
Quoting jpmagero (Reply 35):
Might be salvageable with a better edit, but backlit or not the light is borderline.
Yes, looks a little flat.
3: [soft]
A bit soft towards the nose, with maybe a bit of heat haze.
This one should be fine.
