QF88
Pre-Screening QF88
Tue Oct 23, 2012 11:13 am
Here my picturehttp://farm9.staticflickr.com/8469/8115760973_0084b90065_b.jpg
Go ahead critique
arndt262
RE: Pre-Screening QF88
Tue Oct 23, 2012 11:30 am
It has a light yellow cast. Easy to fix...
Arndt
dazbo5
Tue Oct 23, 2012 11:51 am
Quoting arndt262 (Reply 1):
I would also add there's noticable noise, it's a little blurry and oversharp to compensate.
Darren
QF88
Tue Oct 23, 2012 12:16 pm
http://farm9.staticflickr.com/8047/8115877085_65ac580846_b.jpg Well I tried reducing the yellow cast by reducing saturation and vibrance. If I was to re-edit instead of 85%, 0.2, 0 I should use 70%, 0.2, 0
dlowwa
Tue Oct 23, 2012 2:04 pm
Quoting QF88 (Reply 3):
Still a bit noisy & oversharpened.
QF88
Tue Oct 23, 2012 7:51 pm
http://farm9.staticflickr.com/8047/8116909553_f2abedc8f6_b.jpg
I tried to reduce the noise and eliminate oversharpness by reducing to 70% 0.2 0
dazbo5
Tue Oct 23, 2012 8:07 pm
QF88,
It looks better on my screen now.
Darren
QF88
Thu Oct 25, 2012 11:03 am
http://farm9.staticflickr.com/8472/8121716221_98f5034b8a_b.jpg
So what do you guys think of this picture?
Thanks for your opinions
henkita217
Thu Oct 25, 2012 11:13 am
Hi QF88,
Nice photo indeed but due to the interference/obstruction of the fence at the bottom of aircraft, I think it would be rejected for motive.
Also, not sure how to put it, but the colors looks off. Did you use shadow/highlight tool? Over saturated, probably?
HB
[Edited 2012-10-25 04:13:55]
dazbo5
Thu Oct 25, 2012 11:14 am
Quoting QF88 (Reply 7):
It'll get motive due to the fence blocking part of the rear fuselage. Do you have a shot taken a second later to avoid the fence?
Darren
QF88
Thu Oct 25, 2012 11:44 am
http://farm9.staticflickr.com/8185/8121795740_75135f3dc8_b.jpg
Here is one I took around one second latter.
dlowwa
Thu Oct 25, 2012 1:56 pm
Quoting QF88 (Reply 10):
A little yellow, but otherwise should be ok.
QF88
Fri Oct 26, 2012 12:08 pm
http://farm9.staticflickr.com/8187/8124669512_2f3e11d8f4_b.jpg
I tried to compensate for the yellow by adding a bit of blue colour balance
dlowwa
Fri Oct 26, 2012 3:24 pm
Quoting QF88 (Reply 12):
A bit flat, but color looks ok.
QF88
Sat Nov 17, 2012 11:57 am
http://farm9.staticflickr.com/8064/8192138069_8879fdc6c0_b.jpg
Your opinions is welcomed. And my SIA 777 got rejected for being soft. Is that right because first it was too sharp now its too soft?
QF88
Sat Nov 17, 2012 12:05 pm
http://farm9.staticflickr.com/8203/8192198317_19b630e4af_b.jpg
Here the 777-300ER SIA. I fixed the green cast issue but i'm not sure if I should do Additional sharpening.
dlowwa
Sat Nov 17, 2012 2:54 pm
Quoting QF88 (Reply 14):
Flat, dark, and noisy.
Quoting QF88 (Reply 15):
Looks oversharpened, and there is an obvious dust spot that was missed top of frame.
Looking at it in the rejection log, it seems like you never posted that one for feedback. Yes it is too soft.
QF88
Tue Nov 20, 2012 11:45 am
http://farm9.staticflickr.com/8062/8201868505_ed8c3d3ec0_b.jpg I've played around with the colour to make look less dull and compressed so if this one gets the tick it will be submitted
dlowwa
Tue Nov 20, 2012 7:07 pm
Quoting QF88 (Reply 17):
Contrast better, but looks a bit noisier.
QF88
Tue Nov 20, 2012 8:36 pm
I didn't do any additional sharpening so I don't see how it can be noisier. Maybe when photoshop compressed it it made it more noisy. I really can't figure out why it more noisier
dlowwa
Tue Nov 20, 2012 9:47 pm
Quoting QF88 (Reply 19):
Adding contrast can easily introduce more noise.
QF88
Sat Nov 24, 2012 11:02 am
http://farm9.staticflickr.com/8343/8213742250_625f55d065_b.jpg
