epten
Pre-screening: Oversharpened?
Tue Oct 23, 2012 7:47 pm
http://www.airliners.net/addphotos/big/ready/r1351021402.0143ur-gax1.jpg
dazbo5
RE: Pre-screening: Oversharpened?
Tue Oct 23, 2012 8:05 pm
Epten,
It looks soft in places, oversharp in others, but mainly soft on my screen. How sharp was the original? There's some chromatic aberration as well. Be careful with the noise. I wouldn't say there's too much, but it's borderline for here.
Darren
vikkyvik
Wed Oct 24, 2012 3:31 am
Quoting dazbo5 (Reply 1):
Same here, which usually leads me to believe it may have been a bit blurry.
dlowwa
Wed Oct 24, 2012 7:05 pm
The aberration Darren points out is a pretty good indication that your lens wasn't quite up to the task, either you were shooting at the extreme end of its range, or it was relatively wide open, which would account for the noticeable softness/blur. If that's not the case, the overall quality of the lens might just not be up to par.
epten
Thu Oct 25, 2012 12:29 pm
Yes, it was shot at maximum zoom and maximum aperture.
How about this one:
dlowwa
Thu Oct 25, 2012 1:55 pm
Quoting Epten (Reply 4):
How about this one:
This image is below the minimum size, so can't say anything about quality.
epten
Thu Oct 25, 2012 4:52 pm
Low in frame and oversharpened?
http://www.airliners.net/addphotos/big/ready/i1351183831.4074hbijb.jpg
[Edited 2012-10-25 09:55:30]
dazbo5
Thu Oct 25, 2012 6:25 pm
Quoting Epten (Reply 6):
Are you asking if they are correct rejection reasons or for pre-screening? The aircraft isn't low in the frame for me, it's correctly centred and doesn't look oversharp on my screen.
Darren
epten
Thu Oct 25, 2012 6:32 pm
I am asking for pre-screening, about things I am not sure about, like center and sharpen in the last example.
Thank you for your feedback!
epten
Fri Oct 26, 2012 2:11 pm
Yet another: is it oversharpened and low in frame. Any other issues?
http://www.airliners.net/addphotos/big/ready/f1351260523.2669tc-fbr.jpg
dlowwa
Fri Oct 26, 2012 3:27 pm
Quoting epten (Reply 9):
Maybe a touch low, but the bigger problem is the tail is blurry.
epten
Fri Oct 26, 2012 4:26 pm
Quoting dlowwa (Reply 10):
Thank you for your response! Do you mean the leading edge of the vertical stabilizer?
dlowwa
Fri Oct 26, 2012 9:15 pm
Quoting epten (Reply 11):
No, the whole tail is either blurry, or very, very soft.
epten
Mon Nov 05, 2012 12:45 pm
Any hope for this one?
http://www.airliners.net/addphotos/big/ready/t1351969593.7703ef2000.jpg
dlowwa
Mon Nov 05, 2012 2:56 pm
Quoting epten (Reply 13):
Not too bad, just slightly oversharpened/noisy. I don't see why you wouldn't be able to fix it up.
frado
Thu Nov 08, 2012 7:25 pm
dazbo5
Thu Nov 08, 2012 7:44 pm
Quoting frado (Reply 15):
Could one please help me here?
Great shot, I love the angle but it's oversharpened. How sharp was the original? Motion blur can be difficult to avoid at that angle if your shutter speed isn't pretty fast so I suspect there's a little blurriness in the original and you've have to apply a lot of sharpening?
Darren
dlowwa
Thu Nov 08, 2012 7:52 pm
You should probably start your own thread.
