riflex
Post-Screening(Riflex)
Thu Oct 25, 2012 8:17 pm
Hello,
So I have sent this image which got rejected due to being grainy:
http://www.airliners.net/procphotos/...ename=p1350399687.9106img_6031.jpg
The first 2 rejections were mainly because it was soft, which I corrected by giving it some sharping(to the whole picture).
In my opinion I think it's exagerated because I don't see almost any grain. I would like to ask for some opinion(s) to see what can I do to improve the image
Nuno Faria
dlowwa
RE: Post-Screening(Riflex)
Thu Oct 25, 2012 8:28 pm
Quoting riflex (Thread starter):
There's a slight amount of noise in the shadows. Should be easy to fix. Noise often get introduced to an image when you sharpen it, so you shouldn't be totally surprised.
riflex
Fri Oct 26, 2012 1:29 am
Hello,
Thanks for your help! I'm aware that images can get noisy but in this particular case I didn't think it would get rejected because of grain.
So all I have to do is to select the shadows and remove some noise?
Nuno Faria
dlowwa
Fri Oct 26, 2012 1:32 am
Quoting riflex (Reply 2):
Yes, that should take care of the noise, but it does also still look a little soft to me.
riflex
Fri Oct 26, 2012 1:34 am
Hm...I'll give it a little more sharp then and fix the noise in the shadows. Thank you once again for your help!
Nuno Faria
riflex
Fri Oct 26, 2012 2:25 pm
Dana, a quick question again about the noise removal:
I've used: Strenght 6, preserved 80% of the details, reduced 5% of color noise and sharpen details are at 25%. I'm note sure if I should be a bit more "harsh" in treating the photo...
http://www.airliners.net/addphotos/b...eady/v1351261411.6077img_60312.jpg
Nuno Faria
dlowwa
Fri Oct 26, 2012 3:29 pm
To be honest, I don't see much difference between this one and the rejected; on the other hand, the rejected doesn't need much adjustment, so just be sure you don't overdo it.
riflex
Fri Oct 26, 2012 3:52 pm
Right...I've corrected again, this time: http://www.airliners.net/addphotos/b...eady/t1351266654.7713img_60312.jpg
This time I diminished the details a bit more to 55%.
Nuno Faria
dlowwa
Fri Oct 26, 2012 9:16 pm
Quoting riflex (Reply 7):
You've removed the previous version, so I can't really compare. The difference between this and the rejected seems also slight.
riflex
Sat Oct 27, 2012 1:14 am
Well...it's getting more challenging than I expected   how about this: http://www.airliners.net/addphotos/b...ready/e1351300300.565img_60312.jpg
The link doesn't appear since I'm uploading the pictures again deleting the previous one but I guess the best picture to compare is the first one that got rejected.
Nuno Faria
dlowwa
Sat Oct 27, 2012 5:56 am
Quoting riflex (Reply 9):
how about this:
I don't see noise being an issue for that one.
riflex
Sat Oct 27, 2012 9:08 am
Allright then, I'll give it a go   let's see the results...thank you again for your help!
Nuno Faria
riflex
Wed Oct 31, 2012 5:39 pm
Hello again.
Got this one rejected because it was high in frame and high contrast:
http://www.airliners.net/procphotos/...ename=p1350920165.4716img_4808.jpg
The contrast I agree, the centered reason...it's sort of confusing. The aircraft body is in the middle, I even lowered a bit because of the tail but still wasn't enough.
I also wanted to ask for some opinion about these 3:
http://www.airliners.net/addphotos/b...ready/k1351700696.5975img_4875.jpg
http://www.airliners.net/addphotos/b...ready/q1351702050.0869img_5867.jpg
http://www.airliners.net/addphotos/b...ready/s1351705080.9171img_5948.jpg
Nuno Faria
dlowwa
Wed Oct 31, 2012 6:05 pm
Quoting riflex (Reply 12):
Looks a bit high to me.
http://imageshack.us/a/img841/2779/20121031p13509201654716.jpg
All soft/blurry to varying degrees, especially the second. The first might also not be fixable, as it looks like heat haze.
riflex
Wed Oct 31, 2012 6:23 pm
Ah, now I understand better the centering   thank you for showing me that. I'll fix it in no-time.
About the other 3 pictures, I'll eliminate the first 2. The 3rd one...it seems that the nose needs a bit of sharpening. Is there any other area I should fix?
Nuno Faria
riflex
Wed Oct 31, 2012 6:38 pm
Fixed version of the Air Italy, I had to give a bigger crop or the aircraft would be again high in frame:
http://www.airliners.net/addphotos/b...ready/s1351708638.7947img_4808.jpg
Nuno Faria
dlowwa
Wed Oct 31, 2012 9:33 pm
Quoting riflex (Reply 15):
Centering looks fine, though the contrast is still harsh, and looking again it might need a bit of cw rotation.
riflex
Thu Nov 01, 2012 11:54 pm
Hello,
http://www.airliners.net/addphotos/b...ready/e1351813789.9148img_4808.jpg
Gave some CW rotation and took care of the harsh contrast.
I'd like to ask an opinion also about this one:
http://www.airliners.net/addphotos/b...ready/a1351706511.4969img_7637.jpg
The first rejection was also because of too much contrast.
Nuno Faria
riflex
Sun Nov 04, 2012 1:57 pm
Hi,
Got this one rejected this time because the sky was noisy and not only the aircraft shadows:
http://www.airliners.net/procphotos/...ename=e1351300300.565img_60312.jpg
Is it worth appealing?
Nuno Faria
dlowwa
Sun Nov 04, 2012 5:09 pm
Quoting riflex (Reply 18):
I do see a bit in the sky, but it's not that bad.
Quoting riflex (Reply 17):
Definitely still needs cw rotation, and contrast still a bit harsh.
Also still a bit dark/contrasty.
riflex
Sun Nov 04, 2012 5:42 pm
Hello,
http://www.airliners.net/addphotos/b...ready/g1352050399.0421img_4808.jpg
Used one of the buildings to try and line-up the horizont, still I'm not sure if it will work. I had to give a negative contrast.
http://www.airliners.net/addphotos/b...ready/a1352050830.4247img_7637.jpg
Less contrast, more light!
Thanks for your help so far Dana!
[Edited 2012-11-04 09:43:07]
Nuno Faria
dazbo5
Sun Nov 04, 2012 5:52 pm
Quoting riflex (Reply 20):
It still looks to need some CW rotation to me.
but unlevel and needing some CW rotation.
Darren
riflex
Mon Nov 05, 2012 12:56 am
Hi,
Thanks for your reply Darren!
Corrected the B737 again:
http://www.airliners.net/addphotos/b...ready/o1352076785.8645img_4808.jpg
About the A340, I'm not sure because I lined the horizon according to the airport lamps, it was the best reference in the picture.
Fixed noisy sky, I think this time it's ok.
http://www.airliners.net/addphotos/b...ready/a1352080410.9584img_6031.jpg
[Edited 2012-11-04 17:55:14]
Nuno Faria
dlowwa
Mon Nov 05, 2012 8:11 am
Quoting riflex (Reply 22):
Level still off, and looking flat & soft now.
Should be ok.
riflex
Mon Nov 05, 2012 3:13 pm
Hello,
Gave more CW rotation but now I'm not sure if it's the right level...
http://www.airliners.net/addphotos/b...ready/c1352128320.6431img_4808.jpg
There's an antenna close to the nose of the aircraft, should I use it to line-up the horizon?
Nuno Faria
dazbo5
Mon Nov 05, 2012 3:43 pm
Quoting riflex (Reply 24):
Are you sure you gave it CW rotation? It looks like you gave it CCW rotation to me. It needs to be rotated more to the right, not left.
That, and the buildings in the background.
Darren
riflex
Mon Nov 05, 2012 4:00 pm
Hello,
Using the antenna to line the horizon, the photo turns out like this:
http://www.airliners.net/addphotos/b...ready/d1352131019.7769img_4808.jpg
I was rotating to the right(CW) in the previous fixes. With this fix the photo got a slight CCW.
Nuno Faria
dazbo5
Mon Nov 05, 2012 7:54 pm
Quoting riflex (Reply 26):
That looks much more like it level wise.
Darren
riflex
Mon Nov 05, 2012 9:28 pm
Allright!   thanks for your help! I just hope it's not too soft.
Nuno Faria
riflex
Tue Nov 06, 2012 4:14 pm
Hello,
Would like to ask about this photo:
http://www.airliners.net/addphotos/b...ready/p1352218106.7073img_8179.jpg
Not sure about: sharp, nose soft, heat haze.
Nuno Faria
dazbo5
Tue Nov 06, 2012 4:19 pm
Quoting riflex (Reply 29):
This doesn't have the quality for here. There's heat haze and it's quite soft towards the front.
Darren
riflex
Tue Nov 06, 2012 5:45 pm
I was afraid of that. Well...instead of that one, I'll try this:
http://www.airliners.net/addphotos/b...ready/h1352223830.8523img_8132.jpg
Thanks for your help again Darren
Nuno Faria
dlowwa
Wed Nov 07, 2012 10:33 pm
Quoting riflex (Reply 31):
I'll try this:
Quality is ok, but verging on being backlit.
riflex
Wed Nov 07, 2012 11:11 pm
Hello Dana,
I had that in attention, I chose the photo with most light possible(the reflection of the piano keys of the runway in this case). Let's see if it makes it
Nuno Faria
riflex
Fri Nov 09, 2012 10:59 pm
Hello,
Would like to ask an opinion on this picture again:
http://www.airliners.net/procphotos/...ename=l1351709125.1321img_5948.jpg
Got rejected due to being oversharped and dark.
I only did one modification on this photo since the previous rejection(rejected for being soft only) which was a bit more sharpness in the nose zone.
Nuno Faria
dlowwa
Sat Nov 10, 2012 12:47 am
Quoting riflex (Reply 34):
Oversharpened? Can't see that. It's not dark so much as the contrast is a little harsh (which makes certain areas look darker). Try reducing the contrast a little, and also brightening just slightly, and see how it looks.
riflex
Sat Nov 10, 2012 3:11 pm
Hi Dana,
http://www.airliners.net/addphotos/b...ready/j1352560173.5157img_5948.jpg
Done the corrections on the contrast and gave a bit of bright to the picture.
Would like to ask about this one I forgot:
http://www.airliners.net/procphotos/...ename=m1351707125.7118img_7474.jpg
Also rejected because it was oversharped and dark(I may agree with this last one).
To finish, do you think this one has a chance?
http://www.airliners.net/addphotos/b...ready/j1352563421.3308img_6101.jpg
First time I uploaded it was rejected only because it was soft(I only sharped the aircraft), at the second time I sharped the whole picture and the rejection reasons increased: blurry, dark, soft, etc...
Regards and thanks for your help again
[Edited 2012-11-10 08:07:03]
Nuno Faria
dlowwa
Sun Nov 11, 2012 2:08 am
Quoting riflex (Reply 36):
Still seems a bit dark.
Again, the 'dark' rejection comes from the poor light/contrast, not necessarily underexposure.
No, sorry, quality looks quite poor.
riflex
Sun Nov 11, 2012 3:21 am
Hello,
Fixed the 757 with more bright, I just hope I didn't exagerated this time:
http://www.airliners.net/addphotos/b...ready/m1352603763.2387img_5948.jpg
Also for the Turkish same thing, more bright and a bit less of contrast:
http://www.airliners.net/addphotos/b...ready/s1352604013.2358img_7474.jpg
Nuno Faria
dlowwa
Sun Nov 11, 2012 6:32 pm
Like I said above for both: it's not really the exposure that is the problem, it's the poor contrast. I think the first is more fixable, but you will be able to do that by adjusting the levels/contrast more than by just increasing the exposure.
riflex
Mon Nov 12, 2012 1:04 am
Hello Dana,
Well, instead of increasing the bright, I used the levels as you said:
http://www.airliners.net/addphotos/b...ready/q1352682215.0774img_5948.jpg
Tried not to exagerade since it was only needed a small correction
Regards!
Nuno Faria
dlowwa
Mon Nov 12, 2012 10:04 am
Quoting riflex (Reply 40):
Contrast/exposure is better, though I can't really compare to the older versions as you seem to have removed them. This one is also starting to look a little soft & noisy.
riflex
Tue Nov 13, 2012 5:18 pm
Hi Dana,
Made a few corrections to the 757, this time we can compare
Old version: http://www.flickr.com/photos/9001755...182570943/in/photostream/lightbox/
Fixed version: http://www.airliners.net/addphotos/b...84.2414img_5948comsharpnomotor.jpg
I fixed the noise below the wings and in the sky and added an extra sharp to the engine with the titles but not sure if there's anything missing.
Nuno Faria
dlowwa
Tue Nov 13, 2012 9:08 pm
Quoting riflex (Reply 42):
Should be ok now.
riflex
Wed Nov 14, 2012 4:30 pm
Thanks for your help on the 757 Dana
Would like to ask about this one, I'm still a rookie in night pictures: http://www.airliners.net/addphotos/b...29420.307519dejaneirode2011031.jpg
Nuno Faria
dlowwa
Thu Nov 15, 2012 10:42 pm
Quoting riflex (Reply 44):
It's soft and noisy.
riflex
Fri Nov 16, 2012 10:27 pm
Nuno Faria
dlowwa
Sat Nov 17, 2012 6:25 am
Quoting riflex (Reply 46):
Fixed version:
Don't see much difference. On second look, it could also be brightened a bit.
riflex
Mon Nov 19, 2012 3:24 am
Hello Dana,
Old version: http://www.flickr.com/photos/90017555@N02/8192069994/lightbox/ (I forgot to save the picture that I fixed after this one)
Fixed version: http://www.airliners.net/addphotos/b...95224.632419dejaneirode2011031.jpg
Also would like to ask if you think this one has any chance or if it's possible to fix: http://www.airliners.net/addphotos/b...ready/a1353293626.1412img_5174.jpg
Nuno Faria
dlowwa
Mon Nov 19, 2012 3:32 am
Quoting riflex (Reply 48):
Fixed version:
This one looks noisy and blurry/oversharpened.
Don't think so, the quality looks quite poor.
