maodeh
"vignetting Visible"
Thu Nov 01, 2012 7:28 am
Hello
I uploaded my first picture to Airliners.net but unfortunately it was rejected and i got this comment regarding my picture :
A comment from the screener regarding this upload:
"vignetting visible"
Could anyone tell me what does this exactly mean ?
this is my picture i need your opinion about it :
http://www.airliners.net/procphotos/...in?filename=d1350829492.076499.jpg
and,, if it will be accepted after some editing ? or i have to capture completely different one ?
Thnx.
dlowwa
RE: "vignetting Visible"
Thu Nov 01, 2012 7:35 am
Hello, and welcome.
Quoting maodeh (Thread starter):
I'll asume vignetting wasn't the only rejection reason? I see issues with softness, color, size, and centering as well. That having been said, it's not too bad for your first attempt, though I don't know if you will be able to edit it to standards for here. Assuming you can fix the issues I have just mentioned, the image will still be backlit, which in general, doesn't work too well for here. In any case, you can try giving this one a re-edit addressing the problems mentioned above, and we'll how that turns out.
Dana
JKPhotos
Thu Nov 01, 2012 8:50 am
Hi,
Take a look at the sky, it is darker on the sides and especially in the corners. This is called "Vignetting".
Wiki: "In photography and optics, vignetting ( /vɪnˈjɛtɪŋ/; French: "vignette") is a reduction of an image's brightness or saturation at the periphery compared to the image center. "
You could try to solve this problem by using a Lens Correction filter for example in Photoshop.
But you should trust Dana's words, there seem to be other obstacles to get it accepted.
Anyway good luck and don't give up.
Perhaps take a look at airliners editing guide, it might help:
http://www.airliners.net/faq/editing_guide.php?
jay
maodeh
Thu Nov 01, 2012 9:30 pm
Thanks Dana and Jay for your help and advice
here is the picture after editing :
http://i1231.photobucket.com/albums/ee504/maodeh/Untitled6.jpg
i'm not good at editing picture let me be honest   so how is it now ?
Thnx .
Mahmoud .
dlowwa
Thu Nov 01, 2012 9:37 pm
Quoting maodeh (Reply 3):
so how is it now ?
Framing & size are ok now, but still quite soft. How sharp is the original?
maodeh
Thu Nov 01, 2012 9:44 pm
here is the original picture :
http://i1231.photobucket.com/albums/ee504/maodeh/049.jpg
when i try to sharp it , it affects the color . i don't know
maybe i should ask an expert
dlowwa
Thu Nov 01, 2012 9:58 pm
Quoting maodeh (Reply 5):
If the original image is only 1023 pixels across, there is probably not much that you will be able to do. You should keep in mind that while very versatile cameras, super-zooms like your SX40 make great compromises in terms of quality to fit such a massive focal range into a single camera/lens combination. You shouldn't expect results to be too good in anything but the best light, and at relatively close range. Anything outside of those conditions, and you'll start to see quality issues, like with the image above.
maodeh
Thu Nov 01, 2012 10:10 pm
it's actually 4000 pixels across , i think the uploading website is minimizing the image size
i captured this pic by the SX40   and i can see that you are completely right about what you said MR.Dana
so anything to do more or i have to captre another picture
Thanks a lot .
dlowwa
Thu Nov 01, 2012 11:44 pm
Quoting maodeh (Reply 7):
Like I said, I would need to see the original before making any final conclusions, but I wouldn't get your hopes up for this one.
maodeh
Fri Nov 02, 2012 10:52 am
i re-uploaded the picture , it's 4000*2248 Pixels
http://www.m5zn.com/img/?img=d3a1f777e6d696d.jpg
Quoting dlowwa (Reply 8):
  no problem , i really appreciate your help and advice and this is enough for me .
dlowwa
Fri Nov 02, 2012 3:34 pm
Quoting maodeh (Reply 9):
That's quite soft, almost to the point of being blurry, so I don't think there is much you can do with this one. Sorry.
maodeh
Fri Nov 02, 2012 6:46 pm
aha , no problem
what about this one :
http://www.m5zn.com/img/?img=7c79414394d8d1b.jpg
many thanks .
dlowwa
Sat Nov 03, 2012 5:56 am
Quoting maodeh (Reply 11):
Also quite soft and noisy, and the fact that you would need to crop a significant part of the frame means the quality issues would be quite obvious.
maodeh
Sat Nov 03, 2012 7:28 pm
Thank you MR.Dana i will try to catch better pictures   Thanks a lot
maodeh
Mon Nov 05, 2012 9:51 pm
I didn't find any airplanes to catch
After trying to sharp the photo here is the result :
http://www.m5zn.com/img/?img=8c71cf04e0f1395.jpg
this is the best thing i've got , bad eh ?
dlowwa
Mon Nov 05, 2012 10:35 pm
Quoting maodeh (Reply 14):
Unfortunately would still be rejected for multiple reasons.
maodeh
Sat Nov 10, 2012 6:30 pm
the multiple reasons is what i want to know
Thanks dana
here is the 3rd atempt
http://www.airplane-pictures.net/ima...es/forum/attached/2012/11/376m.jpg
dlowwa
Sun Nov 11, 2012 2:15 am
Quoting maodeh (Reply 16):
Not much better. I don't think this one is going to be possible, so better to start anew with a different image.
