nikog
Pre Screening - General (nikog)
Fri Nov 02, 2012 9:00 am
Hi Guys,
I am not sure about this one.
http://www.airliners.net/addphotos/b...y/i1351846556.5609img_6243_2af.jpg
The things that bother me are centering, exposure and sharpening.
What do you think?
Gregory Verba
dazbo5
RE: Pre Screening - General (nikog)
Fri Nov 02, 2012 9:18 am
Quoting nikog (Thread starter):
What do you think?
Centring looks about right to me. With the large tail, it needs to be slightly lower than usual but it looks balanced enough to me. The contrast is quite strong so it may get a contrast or dark rejection here. Sharpening and colour balance look fine on my screen.
Darren
dlowwa
Fri Nov 02, 2012 3:36 pm
It's a touch high, and the contrast and sharpening are both also a little strong. Only minor adjustments should be needed for all three.
nikog
Fri Nov 02, 2012 4:25 pm
Thanks guys for helping.
I will try to correct it.
Gregory Verba
nikog
Mon Nov 12, 2012 6:35 pm
Gregory Verba
dlowwa
Mon Nov 12, 2012 7:29 pm
Quoting nikog (Reply 4):
I have these photos rejected today:
First one is a bit bright, but I don't see the second as being oversharpened.
nikog
Mon Nov 12, 2012 8:07 pm
Quoting dlowwa (Reply 5):
Thanks Dana.
How is this now?
http://www.airliners.net/addphotos/b...y/x1352750743.3412img_2972_3af.jpg
Gregory
Gregory Verba
nikog
Mon Nov 12, 2012 8:10 pm
Was appealed and accepted. Thanks Dana!
Gregory Verba
nikog
Thu Nov 15, 2012 7:12 pm
Hi guys,
These photos were rejected today:
http://www.airliners.net/addphotos/r...5_d1352478130.0427img_2849_4af.jpg
oversharpened?
http://www.airliners.net/addphotos/r...5_m1352475206.6075img_3043_2af.jpg
oversharpened?
http://www.airliners.net/addphotos/r...5_p1352479130.2126img_6496_1af.jpg
was rejected for being dark and common. Can something be done with common or no chance?
http://www.airliners.net/addphotos/r...5_o1352478947.8302img_3001_2af.jpg
was rejected for centering, oversharpen and overexposed. Should it be lower in frame? Is it oversharpened and overexposed?
Gregory Verba
dlowwa
Thu Nov 15, 2012 10:40 pm
Quoting nikog (Reply 8):
The first LH and the OS look ok, but the other two were rightly rejected.
Common won't be given as a rejection reason on its own, so if you can fix the other problems, it won't be an issue.
nikog
Fri Nov 16, 2012 2:51 pm
Quoting dlowwa (Reply 9):
Thanks Dana,
LH appealed but rejected.
I have other 3 rejected now:
http://www.airliners.net/procphotos/...me=f1352562763.986img_2725_3bf.jpg
Red Cast?
http://www.airliners.net/procphotos/...e=a1352561624.4136img_2926_4af.jpg
This one oversharpened?
http://www.airliners.net/procphotos/...e=u1352559497.4021img_2816_4af.jpg
Yellow cast?
I am very sad...Everything I try to upload is rejected.
Gregory Verba
dlowwa
Sat Nov 17, 2012 6:23 am
Quoting nikog (Reply 10):
Red Cast?
Yes, a little.
Can't see the image.
Yellow cast?
Just a touch, yes.
nikog
Sat Nov 17, 2012 6:42 am
Thanks Dana!
Quoting dlowwa (Reply 11):
The mid photo was appealed and accepted.
Gregory Verba
nikog
Sat Nov 17, 2012 6:02 pm
Yes, a little.
Hi Dana,
Is this ok now?
http://www.airliners.net/addphotos/b...y/f1353175270.1152img_2725_4af.jpg
Gregory
Gregory Verba
nikog
Sat Nov 17, 2012 6:12 pm
Gregory Verba
dlowwa
Mon Nov 19, 2012 3:29 am
First looks a little bright & yellow; the second should be ok.
GZIP: Off
