powwwiii
Crew
Pre/post Screening Comments Welcome Powwwiii
Thu Nov 08, 2012 1:17 am
opening a new thread for my uploads, the old one has been locked.
Please comment on these two new uploads, which one to keep? probably can not have both because of the double rule.
These are the first 787 flight arriving at ORD, I like the second one better because the angle probably will be a bit different with others and the 320 adds some interest too. but the light was not as good, so I hope it can make it, what do you think? Thanks!
http://www.airliners.net/addphotos/b...ady/q1352305179.4263dsc_3294-2.jpg
http://www.airliners.net/addphotos/b...ady/u1352305303.0841dsc_3303-2.jpg
dlowwa
RE: Pre/post Screening Comments Welcome Powwwiii
Thu Nov 08, 2012 3:24 am
Quoting powwwiii (Thread starter):
Indeed, you should submit only one.
Light looks fine for both, though the first has a moderately strong yellow tint.
powwwiii
Crew
Wed Nov 14, 2012 12:38 am
thanks Dana. just got the second one accepted, hope ppl like it.
Please comment on these rejections, both for cyan tint, I thought they are already a bit yellow, what do you think? Thanks!
http://www.airliners.net/addphotos/r...1113_a1352339879.782dsc_3167-2.jpg
http://www.airliners.net/addphotos/r...113_p1352305044.3595dsc_3288-2.jpg
http://www.airliners.net/addphotos/r...1113_h1352343539.221dsc_3626-3.jpg
[Edited 2012-11-13 16:39:17]
Wed Nov 14, 2012 2:17 am
UA 738 - more of a cast here than on the others, that's for sure; if that helps, I'm not too sure.. It only really exists towards the nose.
I see no cyan on the BR MD11.
I hardly see a cyan cast on the A320.. If there was one, it's extremely faint. I'd probably add a wee bit more contrast to this one if you were going to edit it further..
dlowwa
Wed Nov 14, 2012 3:15 am
Quoting powwwiii (Reply 2):
Yes, they all have color casts to varying degrees. Cyan/green on the two UA, and I'd say the BR is also a bit oversaturated. Check out the right side of the two below which I've adjusted:
http://imageshack.us/a/img585/6883/20121113a1352339879782d.jpg
http://imageshack.us/a/img231/3673/20121113p13523050443595.jpg
powwwiii
Crew
Wed Nov 14, 2012 11:57 pm
Thanks NZ107, and thank Dana for the edition, now I can see the color tint.
Now, these two new rejections are for grainy and soft, I have taken many pictures with similar light condition, ISO was still 200 I believe, same work flow as many accepted pictures, never had a grainy rejection, soft is different question. so I want to ask for a second opinion to see if you see grainy and soft. thanks!
http://www.airliners.net/addphotos/r...114_w1352419223.5354dsc_1468-2.jpg
http://www.airliners.net/addphotos/r...114_v1352419729.8835dsc_1480-2.jpg
JKPhotos
Thu Nov 15, 2012 2:15 pm
Hi,
I can see the grain in the first one, but it is minimal.
The rejection is probably a bit hard.
But you can easily remove it with a noise reduction-tool.
And at least with my camera I do sometimes have a slightly grainy sky even with ISO200, too.
Personally I don't see the first one as soft but the second one is indeed a little bit soft. It should be better with some extra-sharpening.
But there are probably better judges on soft rejections than me.
dlowwa
Thu Nov 15, 2012 10:37 pm
Quoting powwwiii (Reply 5):
I see a tiny bit of noise, but not enough to warrant a rejection. Same for the softness.
powwwiii
Crew
Wed Nov 21, 2012 1:11 pm
Thanks Dana, here are some more grainy rejections, which I feel also not guaranteed, please take a look and comment, thanks!
http://www.airliners.net/addphotos/r...121120_p1352834490.008dsc_3323.jpg
http://www.airliners.net/addphotos/r...21120_b1352834423.1519dsc_3321.jpg
http://www.airliners.net/addphotos/r...21120_h1352834125.8222dsc_3316.jpg this one also oversharpened?
and this last one was for soft, really soft?
http://www.airliners.net/addphotos/r...21120_w1352834213.5255dsc_3317.jpg
dlowwa
Wed Nov 21, 2012 4:44 pm
Quoting powwwiii (Reply 8):
Not sure what you mean about them being 'guaranteed' (did you mean warranted?), but I don't see noise being an issue with any of them.
I see some jaggies on the leading edges, but otherwise not too bad.
Doesn't seem really soft to me.
powwwiii
Crew
Mon Nov 26, 2012 5:14 am
thanks Dana, yes I meant "warranted". those are all fine now.
Here are a few new uploads, please comment on the quality, I am not sure about the color of them mostly. Thanks!
http://www.airliners.net/addphotos/b...ady/z1353905161.3802dsc_3532-3.jpg
http://www.airliners.net/addphotos/b...ready/u1353906282.5582dsc_3471.jpg
http://www.airliners.net/addphotos/b...ady/f1353906430.5145dsc_3507-4.jpg
Mon Nov 26, 2012 9:41 am
Quoting powwwiii (Reply 10):
Colour seems ok.. But I'd probably tone down the images - the 2 E170s seem a bit overexposed for my liking.. Another sharpening pass could also be beneficial.
powwwiii
Crew
Tue Dec 04, 2012 12:51 am
Thanks NZ107.
I just recently got a new monitor, seems the color and brightness are different with the old one, probably my eyes are already used to the old one. Please help me to calibrate my eyes to the new monitor. Here are three new uploads, please comment on the quaility, especially color, brightness, etc. Thanks!
http://www.airliners.net/addphotos/b.../ready/b1354574460.773dsc_3787.jpg
http://www.airliners.net/addphotos/b...ready/n1354574590.8434dsc_3923.jpg
http://www.airliners.net/addphotos/b...ady/v1354581949.1399dsc_3572-4.jpg
Tue Dec 04, 2012 2:29 am
AA and B6 seem ok.. I'd be inclined to add a bit more contrast to the UA 753. It just feels a little flat, especially under the wings and around the undercarriage.
powwwiii
Crew
Sat Dec 15, 2012 8:07 pm
Thanks NZ107, that was very helpful.
Some reupload, this one was rejected for color and soft. now it is better? thanks!
http://www.airliners.net/addphotos/b...ady/q1355601873.5629dsc_4412-3.jpg
and the next one was for low contrast, now looks ok?
http://www.airliners.net/addphotos/b...ady/n1355601179.8156dsc_4456-6.jpg
dlowwa
Sat Dec 15, 2012 8:52 pm
Both look yellow and a touch bright, but otherwise ok.
powwwiii
Crew
Fri Dec 21, 2012 2:02 am
Thanks Dana, they have been corrected and re-uploaded.
Here are two new uploads, please comment on them, thanks!
http://www.airliners.net/addphotos/b...ady/n1356054345.4724dsc_6300-2.jpg
http://www.airliners.net/addphotos/b...ady/f1356055087.7291dsc_6321-3.jpg
dlowwa
Fri Dec 21, 2012 9:07 am
Quoting powwwiii (Reply 16):
Color is off, cyan cast or worse. Look at the top of the fuselage of the 67, the color is different than the rest. I see my fair share of AC aircraft, and can't say I've ever seen a similar effect.
powwwiii
Crew
Sat Dec 22, 2012 1:14 am
Thanks Dana, I give up on that 767, but re-work a bit on the 319, hope it is passable now?
http://www.airliners.net/addphotos/b...ady/n1356135855.3252dsc_6321-4.jpg
And uploaded a new one, the lighting was quite difficult, please see if it gets a chance, thanks!
http://www.airliners.net/addphotos/b...ready/d1356138286.8474dsc_3991.jpg
dlowwa
Sat Dec 22, 2012 11:03 am
Quoting powwwiii (Reply 18):
No, still green/cyan.
A touch bright.
powwwiii
Crew
Mon Jan 07, 2013 5:39 am
thanks Dana!
Here are a few new uploads, would like to ask for any comments.
Like this parallet approach, especially all 3 are United 319s, so any problem with this one?
http://www.airliners.net/addphotos/b...ready/z1357535714.2432dsc_4495.jpg
the second one would be a new addition to the database, I like to have the tower in the picture, so the crop/center is a problem?
http://www.airliners.net/addphotos/b...ready/n1357535954.8529dsc_4285.jpg
those fence and lights are problems for the third one?
http://www.airliners.net/addphotos/b...ready/t1357536821.4195dsc_4524.jpg
Thanks in advance!
Mon Jan 07, 2013 8:40 am
1. A bit soft, possibly due to the noise reduction and still a little flat.
2. Might be ok but to me, it doesn't really add too much to the picture. Seems a little on the cool side too.
3. It's low in the frame to begin with and the other bits are distracting, especially the overhead light.
dlowwa
Mon Jan 07, 2013 9:46 am
Quoting powwwiii (Reply 20):
Needs cw rotation.
the second one
Borderline, but might be passable.
Quoting NZ107 (Reply 21):
Color is fine.
Yes, very distracting, especially whatever's in the foreground. Also a bit dark.
No, centering is fine.
powwwiii
Crew
Wed Jan 09, 2013 2:26 am
thanks Dana, I made corrections accordingly.
Just got a rejection for soft, now resized the picture to 1100, so it looks sharp enough? Thanks!
http://www.airliners.net/addphotos/b...ady/m1357698182.0201dsc_3489-3.jpg
aussie18
Crew
Wed Jan 09, 2013 3:57 am
Quoting powwwiii (Reply 23):
Still looks soft around the nose,left wing and along the fuselage-All the windows look quite soft.
Cheers Mark
powwwiii
Crew
Wed Jan 09, 2013 4:49 am
Thanks Mark, so try one more time with more sharpening, how it looks now?
http://www.airliners.net/addphotos/b...ady/u1357706823.8745dsc_3489-4.jpg
aussie18
Crew
Wed Jan 09, 2013 5:05 am
Still quite soft around the center part of fuselage,made tad blurry the center windows above wing.
Cheers Mark
powwwiii
Crew
Thu Jan 17, 2013 1:44 pm
thanks Mark!
got this one rejected for the crop too tight, I used to like to crop a bit tight, maybe too tight, but seems not a problem for upload, so really a problem?
http://www.airliners.net/addphotos/r...30116_g1357538348.2336dsc_4184.jpg
DL747
Thu Jan 17, 2013 3:06 pm
Crop is a bit too tight for my eyes. It makes the plane look to be at a very strange angle. I think a bit looser crop would benefit.
Just like the shirt says, Boeing Builds It Better!
powwwiii
Crew
Sat Jan 19, 2013 12:18 am
thanks DL747.
got two rejections, first one was for soft, and second one is for color. Please help me to see what I can do to re-edit. Dana, pleae help, thanks!
http://www.airliners.net/addphotos/r...118_y1357738875.5395dsc_4270-2.jpg
http://www.airliners.net/addphotos/r...30118_f1357710622.7109dsc_5864.jpg
dlowwa
Sat Jan 19, 2013 12:27 am
Quoting powwwiii (Reply 29):
Both look a little yellow, and the first is a touch soft. Should be easy fixes.
powwwiii
Crew
Sat Jan 19, 2013 4:55 am
thanks Dana for the quick response, corrected and reuploaded!
powwwiii
Crew
Fri Jan 25, 2013 1:34 pm
Hi there, this is a new upload, please comment on it, color, brightness or anything else? Thanks!
http://www.airliners.net/addphotos/b...ready/v1359120636.1513dsc_4574.jpg
DL747
Fri Jan 25, 2013 2:13 pm
Looks a bit low in the frame for me. Also, might be a bit harsh. Looks good to me other than that.
powwwiii
Crew
Sat Jan 26, 2013 1:21 am
thanks DL747. Got two rejections for grainy, these were taken at sunset, so lighting was not really good, any chance to fix them? although I could not really see too much noise in the sky.
http://www.airliners.net/addphotos/r...125_o1358387232.3038dsc_4535-3.jpg
http://www.airliners.net/addphotos/r...30125_r1358388184.0664dsc_4500.jpg
DL747
Sat Jan 26, 2013 4:49 am
Yeah, I don't see that much grain either. You'll have to wait for further input on that one.
powwwiii
Crew
Sun Jan 27, 2013 5:03 pm
thanks DL747.
got this rejection for cyan cast and overexposure. but I only adjust the white balance very little to get rid of the yellow cast, now cyan? also I feel the exposure is fine, what you think? Thanks!
http://www.airliners.net/addphotos/r...127_z1358563498.1955dsc_4270-4.jpg
DL747
Sun Jan 27, 2013 5:13 pm
Quoting powwwiii (Reply 36):
now cyan?
Looks a bit cyan, yes.
It appears the whites are a bit too strong, not sure if it is fixable. The SA symbol especially looks a bit blown out.
dlowwa
Mon Jan 28, 2013 12:37 am
what you think?
Overexposed, soft, and more yellow than cyan. It seems you have more problems with color than most. Perhaps there is an issue somewhere, either with your monitor, camera, or other?
powwwiii
Crew
Mon Jan 28, 2013 2:18 am
Thanks Dana, this one was shot around 4pm here, so sun was low and light was warm. I corrected the exposure. But soft? I thought it was OK.
I did get a new monitor a couple months ago, still trying to get used to it.
powwwiii
Crew
Sat Feb 02, 2013 11:38 pm
Re-uploading some pictures, Dana please help to see if they are fine now, they were rejected for color and soft. Thanks!
http://www.airliners.net/addphotos/b...ady/o1359847764.4213dsc_5859-3.jpg
http://www.airliners.net/addphotos/b...eady/d1359848117.533dsc_4270-7.jpg
dlowwa
Sun Feb 03, 2013 6:05 am
319 is a touch dark & cyan; 57 is a bit bright/contrasty.
powwwiii
Crew
Mon Feb 04, 2013 2:35 am
Thanks Dana, those have been corrected, hopefully they are fine now.
Got a few rejections, and this one was for oversharpened to compensate a blurry/soft or out of focus picture. I looked at the raw picture, it is not blurry or out of focus. This is the second time it was rejected, first time for low contrast, and I added a bit more contrast, but now oversharpened... What you think? Thanks!
http://www.airliners.net/addphotos/r...203_q1359248022.0278dsc_4990-2.jpg
dlowwa
Mon Feb 04, 2013 7:14 am
Yeah, hard to judge the sharpening on that one. All that wording/advertising on the aircraft is either going to look too soft, or oversharpened. Not sure what to tell you in this case. That KL 47 you also had rejected for dark, however, shouldn't have been.
powwwiii
Crew
Thu Feb 14, 2013 3:29 pm
Thanks Dana!
I have a few rejections on a few 57s. one I just can not get the color right, I might need maybe Dana to help me with the processing, can I send the RAW to you? Thanks!
Then the following first 57 was for dark, but I think it is not dark at all. the second 57 was for soft, I really don't see it. And finally the 77W, for cyan tint and oversharpen, it may has the color problem, but again I can not see the sharpness problem, what is your opionion? Thanks!
http://www.airliners.net/addphotos/r...214_h1360080609.0956dsc_4714-4.jpg
http://www.airliners.net/addphotos/r...213_d1360042299.0848dsc_4754-3.jpg
http://www.airliners.net/addphotos/r...211_b1359936541.6109dsc_4906-4.jpg
dlowwa
Thu Feb 14, 2013 11:01 pm
Color's a bit off again on the first two, but otherwise they should be fine. Third one indeed has a cyan cast.
powwwiii
Crew
Sat Feb 23, 2013 9:06 pm
Thanks Dana! got 12 rejections today, mostly for dark, kind of surprise for me, will you please take a look?
also I am uploading some new ones, please comment on these two, window shots and night shots are new to me, so please comment, thanks!
http://www.airliners.net/addphotos/b...ready/z1361652882.4937dsc_5088.jpg
http://www.airliners.net/addphotos/big/ready/p1361653339.7dsc_5034.jpg
dlowwa
Sat Feb 23, 2013 11:34 pm
Quoting powwwiii (Reply 46):
Not much aircraft visible on the first, so motive would be a concern. Second has a very strong yellow cast.
Sorry, I'm not going to go looking through your rejections to find possible issues. If you have questions about specific images, please post them here.
powwwiii
Crew
Fri Mar 15, 2013 11:49 pm
Thanks Dana!
Here is a new upload, please comment on it, dark? soft? Thanks!
http://www.airliners.net/addphotos/b...ready/i1363391186.6783dsc_6526.jpg
dlowwa
Sat Mar 16, 2013 12:17 am
Maybe a slight cyan cast, but I don't see it being too dark or soft.
