rakoon
Post Screening - Dark
Sat Nov 10, 2012 4:19 pm
The following picture was rejcted by over-sharpening and dark. I have a lot of problems with sharpening, so I'll try to fix in some way, but I would like to know until wich point I should compensate the exposition to consider this picture ok instead of dark, obviously I put the picture in dark category.
I've included a screen capture with the histogram in order to know more easily in wich point it should be right.
Thank you and sorry for the inconveniences.
dlowwa
RE: Post Screening - Dark
Sun Nov 11, 2012 2:13 am
You could brighten it just a bit, but otherwise I think it should be fine for a night shot. Can't say much else about the quality from a screen capture.
rakoon
Sun Nov 11, 2012 6:03 pm
Thank you Dana.
Before to upload again I've put a little brightness, and eliminate the sharpening mask (the other reason to rejected it was over-sharpened).
This is the new edition
and the link to the rejected: http://www.airliners.net/addphotos/r...0121109_d1351780924.0096ei-eki.jpg
Thank you in advance.
dlowwa
Sun Nov 11, 2012 6:25 pm
Quoting rakoon (Reply 2):
Looks generally ok, though I might sharpen the fuselage (titles, window line) a bit more.
rakoon
Sun Nov 11, 2012 7:19 pm
Something like this?
dlowwa
Mon Nov 12, 2012 9:52 am
Quoting rakoon (Reply 4):
I think the exposure looks about right, but you may still have a few issues with softness/blur as it looks like that's what the oversharpening was compensating for. In any case, you can keep working on the sharpening or just give it a shot as is and see what happens.
rakoon
Mon Nov 12, 2012 1:27 pm
Ok. Thank you Dana.
I'll try to fix the sharpening a little, although it's a little frustating to have the same problem again and again
