747438
Post Screening (level) 747438
Mon Nov 19, 2012 4:07 pm
Had this one rejected, stating it needs CW rotation. I really cant see that.
http://www.airliners.net/addphotos/r...1352735620.9438zkokmlhr1211pjb.jpg
Any feedback greatly appreciated.
Phil
dazbo5
RE: Post Screening (level) 747438
Mon Nov 19, 2012 4:12 pm
Hi Phil,
I think this is one that might technically be level, but it doesn't look like it. I can see why the screener has commented CW needed. Visually, it does look like it leans to the left. A little CW will help to balance it I feel. Did you use the roofline of the building in the background as reference? That is perfectly level, but the verticals on the building still suggest it needs a little CW and the aircraft does look a little unlevel. Maybe 0.15 or 0.25 degrees CW and you should be sorted.
Darren
vposbic
Mon Nov 19, 2012 5:14 pm
Hi Phil,
I quickly did a check in PS by running straight lines from mirrored aircraft elements (e.g. the engine spinners & tips of the horizontal stabilizer) and the left side is indeed low, requiring CW rotation. Check it out yourself, or I can upload the image with the lines if you'd like. Hope this helps! Great photo nonetheless, hope it gets accepted.
-Vincent
747438
Tue Nov 20, 2012 11:16 am
Thank you both, I will have another try at editing this one.
747438
Tue Nov 20, 2012 12:27 pm
Is this any better ?
http://www.airliners.net/addphotos/b...414350.0703lastzkokmlhr1211pjb.jpg
Thank you for your input.
Phil
dazbo5
Tue Nov 20, 2012 2:08 pm
Quoting 747438 (Reply 4):
Certainly looks better level wise on my screen.
Darren
