teopilot
Pre-screening: General
Mon Nov 19, 2012 9:24 pm
Hello everybody!
I have a shot from last summer which I am quite doubtful about...
http://img526.imageshack.us/img526/3703/img3872n.jpg
What do you think about that?
thanks in advance!
Matteo
mjgbtv
RE: Pre-screening: General
Tue Nov 20, 2012 3:52 am
Hi Matteo,
What is it that you are doubtful about?
Here are some possible issues that I see:
1. A bit grainy in the distance.
2. Not a lot of aircraft showing.
3. Some areas look like too much noise reduction was applied.
However, #1 could probably be fixed, #2 might be okay (I have seen window shots with less aircraft) and I could be completely wrong about #3. Overall it is a nice photo with great detail so I would not give up on it. It would probably not hurt to resize to 1200 or smaller, though.
kl692
Tue Nov 20, 2012 5:55 am
It's a beautiful shot and like the previos person said, there is a lot pics in the DB with less a/c compare to yours
A310, A330,A346,B73H, B747,B772,B77W,CRJ
teopilot
Tue Nov 20, 2012 8:09 am
First of all, thanks guys for posting a feedback!
Then...
Quoting mjgbtv (Reply 1):
Pretty much an eventual blue dominance (almost all pictures from that sequence seems to suffer from this problem...) + the "transition" between the foreground and the "far away plain". But I think this may be due to the atmosphere on a quite humid summer day.
Anyway, thanks also for pointing out some issues you have noticed: I will work on them more carefully and let's see what I got!
Thanks again!
