DL747
Pre-Screening (DL747 Newbie)
Thu Nov 29, 2012 11:17 pm
Hello everyone, have had a couple photos rejected, but I have learned an immense deal already since joining. Thank you to all. I am wondering if these are any good for the queue. Any feedback/tips are appreciated. Thank you.
http://www.flickr.com/photos/9063121...8231280486/sizes/l/in/photostream/
http://www.flickr.com/photos/9063121...8230217521/sizes/l/in/photostream/
If they have quality issues, that is probably because I am resizing wrong. I would appreciate tips on that (I have a thread in the regular photog forum.) Thanks again!
Just like the shirt says, Boeing Builds It Better!
dlowwa
RE: Pre-Screening (DL747 Newbie)
Thu Nov 29, 2012 11:48 pm
Both are dark and soft, and show jpeg compression. The softness and compression are perhaps fixable, but they are obviously backlit, which is not fixable. You will find it very difficult to get backlit shots accepted unless there is a motive for having the sun on the wrong side, and there is no such motive here.
DL747
Fri Nov 30, 2012 12:12 am
Well, thanks for the feedback. They aren't actually backlit, the sun was at my 4 oclock. Pehaps it was how I brightened them? Also, is the compression just from flickr?
[Edited 2012-11-29 16:22:10]
DL747
Fri Nov 30, 2012 12:25 am
Accept for a lot of compression, which I am still trying to figure out, is this one better?
http://www.flickr.com/photos/9063121...8230344647/sizes/l/in/photostream/
dlowwa
Fri Nov 30, 2012 12:54 am
Quoting dlowwa (Reply 1):
Yes they are. Look at the tail fin. If the sun were on the same side of the aircraft as you, it would be sunlit. It is not.
Quoting DL747 (Reply 3):
is this one better?
No, also backlit.
DL747
Fri Nov 30, 2012 1:04 am
Okay, thanks. Now that i think of it, the sun was more head on with the plane. I will be at LAX again in three weeks shooting from the same spot, from around 1230pm to 3pm. Do you think I can get some non-backlit images?
dlowwa
Fri Nov 30, 2012 1:11 am
Quoting DL747 (Reply 5):
Given I don't know where exactly you where, nor when you took the images above, how could I even speculate?
Use this tool to help plan your spotting a little better:
http://suncalc.net/
chriswade
Depends where the sun is. You want the sun lighting the side of the plane you are shooting.
DL747
Fri Nov 30, 2012 2:44 am
Thanks Dana, very handy tool! Your assistance is very helpful. FYI, I am at the In and Out, which I am sure you have heard of, very famous place. Sorry if am I am trying too much too fast, but I'd like your opinion on one more. Thank you!
http://www.flickr.com/photos/9063121...8231727914/sizes/l/in/photostream/
[Edited 2012-11-29 19:28:31]
I am aware of the compression, it is from Flickr.
[Edited 2012-11-29 19:29:14]
dlowwa
Fri Nov 30, 2012 4:24 am
Quoting DL747 (Reply 8):
It has a blue tint, and seems somewhat soft, but it's hard to tell with the compression. Imageshack is also free and won't compress your images as much.
http://imageshack.us/
DL747
Fri Nov 30, 2012 4:52 am
Alright thank you sir. I will try imageshack at a later time. I will fix up that DL and get back ovet the weekend.
DL747
Sat Dec 01, 2012 12:08 am
Dana, could you have a look again, it is the same image, only on imageshack. I just want to make sure flickr isn't messing up the pic before I make the changes you suggested. Thanks so much.
http://img35.imageshack.us/img35/5264/dsc2578copy.jpg
dlowwa
Sat Dec 01, 2012 2:32 am
Quoting DL747 (Reply 11):
Very soft, and blue tint.
DL747
Sat Dec 01, 2012 3:19 am
Okay, thanks, any better?
http://imageshack.us/f/850/dsc2578copy.jpg/
Well I'm at it, how's this SK?
http://img827.imageshack.us/img827/3441/dsc2804copy.jpg
[Edited 2012-11-30 19:24:36]
dlowwa
Sat Dec 01, 2012 3:33 am
Quoting DL747 (Reply 13):
Looks sharper. Still blue.
Low contrast, and dark/backlit. Also has blue cast.
DL747
Sat Dec 01, 2012 3:59 am
Okay, I'll give the DL a go once more and forget the SK since it is backlit.
http://img832.imageshack.us/img832/5264/dsc2578copy.jpg
Less blue now I hope? I have given it three rounds of - blue at -6, -2, -9.
dlowwa
Sat Dec 01, 2012 7:23 am
Quoting DL747 (Reply 15):
A bit. Quality's still not that great unfortunately.
DL747
Sat Dec 01, 2012 7:30 am
Well I have the original, so I will start fresh with that tomorrow with all the changes you suggested. That will probably improve quality, as the original is pretty good, although through glass.
DL747
Sat Dec 01, 2012 4:49 pm
Okay, Dana, here is a complete rework of the original with all changes incorporated, for some reason, it looks to have worse quality and be more compressed on the website, on my screen, it looks fine in my editor.
http://img10.imageshack.us/img10/5264/dsc2578copy.jpg
Is this any good?
Also, how is this nose shot at SEA? It will be resized down to 1100 px high, I just wanted to see how it looks now.
http://img10.imageshack.us/img10/6424/dsc5009copy.jpg
dlowwa
Sat Dec 01, 2012 9:23 pm
Quoting DL747 (Reply 18):
Is this any good?
A bit better, but still soft and blue.
Soft, flat, grainy, and yellow.
DL747
Sat Dec 01, 2012 10:10 pm
Okay, here are re-edits of both
763: http://imageshack.us/f/12/dsc5009copy.jpg/
319: http://imageshack.us/f/37/dsc2578copy0.jpg/
I know the 319 looks soft around the nose, but it isn't really soft at all in my editor, perhaps that is the upload process at imageshack? Thanks for looking, hopefuly these are better.
dlowwa
Sat Dec 01, 2012 10:22 pm
Quoting DL747 (Reply 20):
First is flat, a bit overexposed, and blue; second is soft, flat, and yellow.
No, that will have no effect on sharpness.
DL747
Sat Dec 01, 2012 10:40 pm
dlowwa
Sat Dec 01, 2012 11:49 pm
Quoting DL747 (Reply 22):
Crossing fingers and toes.
Same issues with both. Can't tell you if they are better or worse as you have removed the previous versions.
DL747
Sun Dec 02, 2012 3:58 am
Quoting dlowwa (Reply 23):
Hmm.. that surprises me. i made significant adjustments to both, especially the second. I'll table them for now. I'll rework them later. How are these?
http://imageshack.us/f/211/dsc5932copy.jpg/
http://imageshack.us/f/12/dsc5506b.jpg/
http://imageshack.us/f/708/dsc5462i.jpg/
http://imageshack.us/f/594/dsc5243copy.jpg/
http://imageshack.us/f/41/dsc8681v.jpg/
Think the last one might be a no-go, but I might as well have the pro's look at it. Thanks for all your help. These probably have some issues too.
dlowwa
Sun Dec 02, 2012 4:45 am
Quoting DL747 (Reply 24):
How are these?
All are soft. I don't think you're getting my point about backlighting. If you were, you'd realize images like the second and third have no chance. Besides softness, the other three have issues with the white balance (too yellow), and centering (last one).
DL747
Sun Dec 02, 2012 4:56 am
I do understand backlighting, I just wasn't aware there was a rule forbidding backlit images. I guess I'll try again for #1 and #4. So, 1 is soft and yellow? And 4 is soft and yellow also? I am feeling a bit dumb not being able to get a non-crap image.
dlowwa
Sun Dec 02, 2012 5:06 am
Quoting DL747 (Reply 26):
It's isn't forbidden, but you need a good reason to make it work. Your images have no reason for being backlit.
Yes.
Check your white balance settings, that is often the cause of images being too yellow (or too blue).
DL747
Sun Dec 02, 2012 5:10 am
So, backlighting obviously has the sky behind the aircraft brighter, but why is that bad if the aircraft is still properly exposed.
By the way, here is the 320 reedited with quite a bit of sharpening.
http://img338.imageshack.us/img338/207/dsc5243copy.jpg
Hopefully it's good?
If it is still soft, it has to be something in my resizing process, it looks much more sharp in the original non-resized.
dlowwa
Sun Dec 02, 2012 7:27 am
Quoting DL747 (Reply 28):
Still a bit soft, flat, and overexposed. Starting to show some noise as well. Aim for something like the left side here:
http://imageshack.us/a/img825/207/dsc5243copy.jpg
DL747
Sun Dec 02, 2012 5:21 pm
Okay here is the L-39.
http://img809.imageshack.us/img809/7686/dsc5932copy.jpg
And the 320 fresh image. The nose looked a lot sharper on this one upon further exam, so I went with it instead.
http://imageshack.us/f/547/dsc5239.jpg/
Both look a bit compressed to me, but they are 1 edit originals so I think that's imageshack doing that. Aside from that, how are they? Thanks.
dlowwa
Sun Dec 02, 2012 7:56 pm
Quoting DL747 (Reply 30):
Soft, yellow, and flat.
Also soft, yellow, and flat.
No, compression is not an issue. Why do you seem to keep thinking it is?
DL747
Sun Dec 02, 2012 8:22 pm
Well, they just looked a bit grainy to me. Here are re-edits.
L39: http://imageshack.us/f/23/dsc5932copy.jpg/
320: http://imageshack.us/f/39/dsc5240copy.jpg/
Maybe a bit soft around the titles, I can't tell very well.
[Edited 2012-12-02 12:22:55]
dlowwa
Mon Dec 03, 2012 9:25 am
Sharpness better, but both still flat and yellow.
DL747
Mon Dec 03, 2012 11:40 pm
dlowwa
Tue Dec 04, 2012 3:32 am
Quoting DL747 (Reply 34):
Okay, here they are, fixed.
Bit better. Are you starting from scratch each time, or just tweaking the same files? If the latter, that would explain why each progressive edit is showing more and more compression.
DL747
Tue Dec 04, 2012 3:35 am
Funny you ask, with every other one, it has been from scratch, these two are tweaks, though. Are they passable?
dlowwa
Tue Dec 04, 2012 8:11 am
Quoting DL747 (Reply 36):
Are they passable?
No, contrast & color are still issues.
DL747
Wed Dec 05, 2012 3:40 am
Ok, thanks Dana, here are re-edits from the original, with all changes incorporated.
L39: http://img853.imageshack.us/img853/3923/dsc5932copy0.jpg
320: http://imageshack.us/f/5/dsc5240copy0.jpg/
And one more.
http://imageshack.us/f/22/dsc5335copy.jpg/
dlowwa
Wed Dec 05, 2012 4:07 am
Quoting DL747 (Reply 38):
here are re-edits
Still yellow and a bit flat.
And one more
Also yellow.
DL747
Wed Dec 05, 2012 4:28 am
Okay, will fix those up. I fogot to add blue to both the 320's, my bad! I did on the L39, but will add a bit more. Also boosted contrast on the two older ones.
Vigin 320: http://imageshack.us/f/138/dsc5240copy1.jpg/
L39: http://imageshack.us/f/41/dsc5932copy1.jpg/
US 320: http://imageshack.us/f/191/dsc5335copy.jpg/
dlowwa
Wed Dec 05, 2012 7:03 am
Quoting DL747 (Reply 40):
I fogot to add blue
Why not just adjust the white balance? A lot simpler and you won't have to go through so many iterations to find the right color. If you don't have the raw files, you might not be able to fix the images at all. Adjusting improper white balance settings with jpegs only is quite difficult.
DL747
Wed Dec 05, 2012 2:25 pm
Yes, I could do that, but these are jpegs. I only leraned to shoot RAW a few months ago, after these were taken. Are they acceptable now, or do they still have cast issues?
dlowwa
Wed Dec 05, 2012 4:35 pm
Quoting DL747 (Reply 42):
They still need work.
DL747
Thu Dec 06, 2012 12:45 am
Sorry, guys I just don't have any eye at all for color cast. Is that the only thing needing work?
dlowwa
Thu Dec 06, 2012 1:16 am
Quoting DL747 (Reply 44):
Contrast/lighting is not great either. Probably best to give up on these and concentrate on getting it right next time.
DL747
Thu Dec 06, 2012 1:49 am
Well, given the fact it's Seattle, and the weather is probably going to suck until next April, do you think I could drop the Vrigin, as I think it has the worst light, and try to fix the US and the L-39? Or, are the too far off to fix. Most of my pics have coulds and not fantastic light, so I would like to at least try. Thanks.
dlowwa
Thu Dec 06, 2012 2:50 am
You've heard my opinion, but they're your images so you can do whatever you wish with them.
DL747
Thu Dec 06, 2012 3:43 am
Well, whatever, then I guess I will dump those and try again from LAX, hopefully with better light. I thought I might try a few ones from different days.
http://img16.imageshack.us/img16/3202/dsc4970copy0.jpg
I don't know if the poor quality of the background is an issue with this one.
http://img338.imageshack.us/img338/7367/dsc5072copy.jpg
Will be at 1100 pxels high, just wanted to see if it is close before going further. Mainly concerned about quality, noise, and motive.
http://img854.imageshack.us/img854/5998/dsc5249e.jpg
This last one looks way compressed to me, don't know why. Hopefully these are at least worth editing further?
dlowwa
Thu Dec 06, 2012 4:48 am
Quoting DL747 (Reply 48):
The background will not be a factor. The level and softness, almost blurriness of the aircraft will, however.
Won't comment unless it's upload size.
Low in frame and slighly soft/dark/yellow.
