B737-112
F-27 BUR-IFP (Laughlin)-BUR
Thu Aug 16, 2001 5:22 pm
The Aircraft: Eagle Jet Charter Fokker F-27 Series 200 (N279MA). Built 1966. Powered by two 2320hp Rolls-Royce Dart Mk 536-7R turboprops.
The Leadup: I showed up to the Hilton Hotel in Burbank at around 9:00am and at around 10:10 I, and around 30 other people got onto a "Paddy Wagon" bus and drove around the airport to Mercury Air Center where the plane had not yet landed. We then sat on the bus right outside the airport perimeter for about 10 minutes and the plane landed right in front of us on Runway 8. The bus then drove up to about 10 feet away from the left wing and we lined up in a single file line (me first). After all passengers were now off the plane we made our way to the back temporary steps.
On Board: I selected the first row to sit because the blades were right at that window and I figured it would be the most noisy there. It was actually row 2 because row 1 was taken out and replaced with a storage area. There's a door in the cabin, when you walk through that door you're in the baggage area and beyond that is the flight deck, just to give you a mental image. I selected seat 2D and within 10 minutes the number 2 engine was spinning. The high pitch scream filled the cabin as did the smell of Jet A. Engine 1 is now being started and the aircraft is jumping and lurching around like an off-balance washing machine. With both engines started we taxi for about 3 minutes to Runway 15 and wait off to the side to let a WN735 by. At around 10:40 we then taxi around the corner onto 15 and the takeoff power is applied in the turn.
The Flight: I was pushed back more than I expected and we were off the ground in around 3,500ft and then climbed slowly over the fence is a slight right turn to 210. We then turned right to 330 and flew directly over Van Nuys airport and then it was hot desert all the way through. The sound from the propellers was nothing like I had ever heard, various beat frequencies and noises that sounded like chains rattling, whistles and jackhammers combined. The flight attendant served Nutri-Grain Apple Cinammon bars and Cool Glacier water 16oz bottles. We were jolted with some updrafts over the desert and thrown around pretty good, there were people yelling "ooh" and "what was that?" and various other phrases. We made our approach into Laughlin by paralleling the hotels and circling in a sweeping right turn to final. We touched down around at around 11:50am and the sound of the reverse was deafening. We taxied to the tiny terminal and I was off the plane at about noon.
Flight Two: Now at dusk, 7:40pm we load onto the same F-27 for the return from IFP (International Fun Place) as they call it and I selected seat 7D so I can look at the main landing gear during takeoff and landing, this time with about 20 on board. The sounds during start up and taxi were much more tolerable from this seat. At about 8:00pm we lifted off into the still 100 degree dry heat and left the desert mecca behind. During cruise (13,000ft) we were now offered Goldfish snacks, but the same water. We were again in turbulence on two seperate occasions, this time with no yells and such. Now almost to BUR, after descending to around 4000AGL we passed almost directly over Magic Mountain. We made a straight in Runway 8 approach now completely dark outside and the gear came down 5 miles out and a very nose down attitude to correct began. We touched down about 500ft past the numbers and we pulled off the runway after using only 3,000ft. We began a taxi back to Mercury Air Center and all passengers were off about 9:10pm.
I know this was too long of a post but it's past 1:00am and my brain is fried from the 110+ temperatures at Laughlin. So if this doesn't make sense, I'm sorry. Any questions or if you want me to clear something up just let me know
Ryan
Click for large version
Photo © Eddy Gual - Aviation Photography of Miami
RE: F-27 BUR-IFP (Laughlin)-BUR
Thu Aug 16, 2001 10:01 pm
I am jealous. Ever since I was a kid, I have always wanted to fly on an F27. Ever since I used to see the Hughes Airwest F27's flying over my house on final to SFO.
Richard Silagi
jabpilot
Fri Aug 17, 2001 1:10 am
This is a great trip report and because I've flown this route many times in various Piper aircraft and once on a States West B-1900, I can enjoy reading about the flight and route you traveled. Out of all the times I've flown in there though, I've always landed Rwy.34 and only departed Rwy.16 once during a gusty South wind. It sounds like you may have landed on Rwy.16 after flying downwind along the river and then making right traffic for landing over the dam. When I started flying out there I believe Bullhead City airport was known as "P06" (I'd have to check my logbook) and re-identified as "IFP" only within the last few years.
I've flown aboard the F-50 and even though they're related they have different engines and do not sound like they give the same kind of ride. The way you describe your story about the engine startup, it sounds like the F-50 is much more superior in terms of passenger comfort but for a aviation enthusiast always looking for something different, it sounds like the F-27 is a plane that's quite different from ordinary.
Jeff
B737-112
Fri Aug 17, 2001 3:09 am
Flygga, you should come down to BUR and catch this flight before it goes away (they all do out of here). I forgot to mention the charter was done through Air Laughlin. It's worth the effort for a dream plane.
Jabpilot, We did land Runway 16 right over the dam just like you mentioned and departed the same runway. The identifier did just change recently to attract attention. Where did you fly on an F-50, those are so rare and I've never seen one in the US.
Thanks, Ryan
Fri Aug 17, 2001 12:59 pm
Yes I know Ryan. We got the F27 up here at SJC a couple of times on the Air Laughlin flights. Lately we have been getting Allegiant DC9's on the flights. Now that would be a ride, SJC-IFP on an F27!
jabpilot
RE: 737-112
Sat Aug 25, 2001 4:36 am
My F-50 flight was from Reykjavik City Airport to Vestmannaeyjar (Westman Islands), with the return on a Dornier 228.
Jeff
Thu Aug 30, 2001 11:08 am
I flew on F-27's (the Fairchild version) many times in the 1970's; FH-227's, too. I remember the noise much as you do, this constant throbbing sound and lots of metallic clanking from who knows where. I still loved it, though, and I'd love to fly on one again. The last F-27 flight I took was Business Express between New Haven, CT and DCA. The flight was packed. Emerald Airlines used to fly them around Texas. I flew on one that still had Wien Consolidated logos in the cabin (N4901). Thanks for your account.
P.S. Ever fly on a Nord 262?
B737-112
Thu Aug 30, 2001 4:59 pm
Scott s, I've never flown on a Nord unfortunetly.
It was nice reading your account of the Fairchild. It's certainly a different kind of flight experience, it almost seems to me like flying on a early Russian passenger helicopter.
Fri Aug 31, 2001 12:15 am
Just a quick question did you have to go through any airport security? Did they check your bags or what not?
Iain
access-air
Sat Sep 01, 2001 1:25 am
WOW!!!!
My fave plane is the F27 series of planes!!!
I have flown on the Fokker F.27-200/500, Fairchild F-27, F-27F and FH-227C. It is the most wonderful and sleek looking aircraft ever built in my opinion!!! I think that on my trip to Southern california this coming October i will look into that trip if they are still runing them!!!Im dying to get on an F27 again..dont care what type either.....altho Eagle has one plane ive already flown on and that is N278MA..only I flew on it As Mesaba for Mesabas final F2.7 flight on 15 Sept 1995.
I shall call Air Laughlin to check it out!!!! Thanks for the Info!!!!
Access-Air
Remember, Wherever you go, there you are!!!!
B737-112
Sat Sep 01, 2001 2:06 am
Iain, there was no security (metal detectors) out of BUR. They check your bags in at the bus but do no security check on them.
Out of IFP they had us line up in the terminal and go through the detector though.
Users browsing this forum: Ex_SQer, lukasgv1 and 3 guests
