TriStar500
EXTreme Flyin':CDG-EXT-CDG W/ BE (+35 Pix)
Fri Aug 19, 2005 3:38 pm
About the trip
Whenever I am going somewhere on vacation for a few days, I usually try to schedule a quick daytrip to some other destination in between in order to try out new airlines, which are not serving my home region. flybe, formerly known as British European and once operating as Jersey European, has turned itself into a low fares airline after long years of franchise operation for Air France, so I was curious about how the airline would fare in comparison with "original" low cost carriers like EasyJet, Germanwings and others.
flybe offered a very good deal for a daytrip to Exeter, a mid-sized town in the southwest of England, for just 82 Euro including all taxes and fees, so I did not hesitate one moment when I found this offer, and booked a trip.
Tuesday, August 2, 2005
Paris Charles de Gaulle Airport (CDG)
My flight was scheduled to depart from Aerogare 1, the original terminal, which was erected in the early Seventies. You would be hard pressed to find any positive comments by frequent travellers about this place, in fact, possibly the most fitting description would summarize this architectural “masterpiece” as a “dump”.
I arrived by shuttle bus from the nearby regional train station about two hours before departure. One of the many unusual features of the terminal is evident right upon arrival – unlike possibly every other airport in the world, the levels are sorted the other way around, i.e. the departure level is below the arrivals level. Talk about being unneccessarily difficult.
I went inside the dark and sinister looking raw concrete structure, located an information monitor and retrieved the check-in desk for my flight – it would be at row 18B this morning. After paving my way through masses of weary and anxious travellers, who were queueing up for some of the trans Atlantic flights, which would be leaving at roughly the same time as our short hop, I finally managed to find the two check-in desks dedicated to our flybe service. With only four passengers waiting at both desks, the registration process was over in a matter of minutes. I was assigned seat 14F.
Still having quite a lot of time to spare, I walked around the circular terminal hall (another unusual feature, which you will also see in the very last picture of this report) and pursued one of my many aviation related hobbies, i.e. hunting for timetables. Although my bounty was somewhat limited, at least it was rather exotic, because I scored a Pulkovo Aviation and Saudi Arabian Airlines timetable!  Smile
The landside part of Aérogare 1 is not the most pleasant place in the world with its dark, run down and crowded corridors, so I walked towards the central patio, checked the departure information once again and then passed the boarding pass control.
All flights at Aérogare 1 are departing and arriving at satellites, which can only be reached by way of long tunnels. And again, one an irregular oddity of this terminal is that once you have passed boarding pass control, an escalator takes up upstairs over a rather large and fairly sunny patio,…
…before you reach the outer ring of the central terminal building, where your ID is checked and customs controls are conducted. Afterwards, you select the corridor leading towards your assigned satellite terminal, and take a longish escalator ride through rather sinister looking corridors – places one would be more used to find in decrepit train stations than in a contemporary international airport terminal!
After a lengthy voyage through the “caverns”, I finally arrived in satellite 4, which was dedicated to our flight and an array of United Airlines services to Washington and Chicago. From an architectural standpoint, the furniting and layout of these satellite is rather fascinating – as you can see from the following picture, the décor looks like it has been teleported right out of the Seventies. One could almost expect to see an Air France B747-100 in old colors waiting at one of the gates!
Unfortunately, one of the less attractive aspects of this “time warp” is that one can see the age of the building at every corner, i.e. the seat covers are usually worn or damaged and the corners look like they only get “round cleaned”, if you know what I am trying to say.
After passing through security control, I walked around, trying to find our gate. Unusually (I think, you see what would be another good adjective describing this terminal!), there are no monitor at the various gates indicating your point of departure – would it have been too much too ask for Aeroports de Paris to install at least one TV set per departure lounge for the orientation of their customers?
The gate areas for the United flights filled up pretty fast, and some ground handling employees arrived to put of large wooden (!) billboards (yes, we are living in the digital ages, you know!) in front of the various gates, indicating the flight number and destination.
About thirty minutes before our scheduled off-block time, I finally spotted a flybe Bae-146 slowly taxying toward sour terminal through the morning mist (despite being summer, it had been unusually wet during the night) and finally positioning next to our building. Within a few minutes, the arriving passenegers had disembarked, and while the aircraft was being fed and watered by the ground crew for the return hop across the Channel, the gate agent commenced with the boarding process. First to go were two unaccompanied minors with their typical small transparent plastic bags around their necks containing all travel documents, then the rest of us were allowed to vacate the terminal, take the short stroll across the tarmac and board the waiting BAe.
The flight (CDG-EXT)
Paris Charles de Gaulle (CDG) - Exeter International Airport (EXT)
Flight number: BE 1502
Scheduled block time: 0945h - 1015h
Off-block: 0955h
Take-Off: 1009h (RWY 27L)
Touch-down: 1006h (RWY 26)
On-block: 1008h
British Aerospace BAe 146-200
G-JEAK
c/n E2103
delivered: April 21, 1988
Seat 14F (Economy Class)
Photo © Jid Webb
After entering the cabin through the 1L door, I said "Good morning!" to the two friendly female flight attendants in bright red uniforms, who were welcoming passengers, and proceeded to my seat in the rear of the cabin. Since the Bae-146 features shoulder-mounted wings, it is advisable to either reserve seats at the very front or very rear of the cabin in order to have a view outside, otherwise the only scenery you will be able to "enjoy" would be a view of the inboard engine pod, which might become a bit tiresome after the first minute or two. I arrived at my seat in row 14, put my backpack into the smallish overhead bin and took my seat.
You could really tell that this was an Eighties' aircraft by small details in the cabin design - ranging from the rather dated looking layout of the overhead service unit (lights, air vents, flight attendant call) to the really tiny overhead bins, which are a far cry from the "widebody cabin design" experienced on contemporary aircraft designs. I would not complain though - after a lot of flying on the more and more generically looking Airbus and Boeing standard bodies, this was a welcome change to something more "exotic". And despite being "six abreast", the greyish leather seats were actually quite comfortable as long as no seat neighbor was sitting next to you, and the pitch was also satisfactory for a person of moderate size and height like me.
Cabin doors were closed five minutes later and an announcement from the flight deck informed the passengers about the slight delay this morning, which had been caused by ATC disruptions during the approach to CDG. In fact, the weather had been a little misty this morning, but nothing grave actually, so I wondered wether flybe's Bae's were not certified for landings under reduced minimum visibility like Cat 2 or CAT 3. A ten minute delay until off-block time would not have grave impact on our scheduled flight and arrival times however, since flybe has scheduled plenty of ground time into their CDG schedule. The net flying time would be about one hour, so there were another thirty minutes of ground time available in order to buffer out smaller delays like this one.
We were pushed back a few minutes afterwards, and slowly taxied towards the threshold of RWY27L through the murky morning mist. A steady flow of longhaul aircraft, chiefly Air France birds, was rushing past our left hand side on RWY27L while we were taxiing to the active runway, touching down after long flights from North and South America. Outbound, only a few other flights were preparing for the departure. A Bae-146 Air France's Irish affiliate CityJet prepared for takeoff in front of us, possibly going to some other British destination - quite ironical to see it next to us, because flybe used to be another franchise carrier of the French national carrier until only a few years ago.
The CityJet quad jet rumbled down the runway in front of us, and soon it was our turn to enter the active runway, and without any further delays, the engines were throttled up and we commenced our short and bumpy ride down the four kilometre stretch of concrete, which a few years ago was the last runway the fateful Concorde F-BTSC graced before her crash only a few seconds after lift-off.
Fortunately - and, to be honest, quite as expected - our takeoff ride was much less spectacular, and after lifting off into the morning haze, we cleared a few Parisian suburbs before continuing our steady ascent towards the west. The annunciator bell chimed when we passed 10.000 feet, also signalling the start of the onboard service program.
As already mentioned, flybe has transformed into a pure-bred low cost carrier, so while none of the cabin service was free, there was an extensive selection of small snacks and drinks available for sale. An information brochure in the seatback pocket showed a list of the available offerings.
On this lightly loaded flight - as it turned out, only 39 passengers had selected to book a seat on this segment - only very few sandwiches, sweets and beverages were sold despite the charming and continuous efforts of the all-female cabin crew in their bright red, and not "low-costish" looking uniform.
Meanwhile we had levelled off at our cruising altitude of 24.000 feet and were bumbling along at a mere 380 knots. The haze in the Paris area had given way to a lightly clouded sky, so many interesting landscapes were visible below us while we cruised along towards Devon. First we passed the Seine estuary near Le Havre, before continuing parallel to the "invasion beaches" of 1944, with the remnants of the artificial "Mulberry" port of Arromanches clearly visible below (unfortunately my picture didn't turn out that well, otherwise I would have loved to include it for you!). Our last view of the continent came at the very northern tip of Normany, where the city and harbor of Cherbourg greeted from below.
While flying over the English Channel, the second service run started, comprising the sale of duty free items. A catalogue was available in the seatback pockets, but again, the motivated sales effort was greeted by only very limited interest.
Our descent started while we were still a few miles away from the English coastline. Soon, the dark green meadows, small woods and hedges of southwest England became visible, and while were continuously loosing height during our line-up for Exeter's RWY 26, more and more of the trademark English countryside presented itself to the pleased eye of the passenger above - small villages, cottages and even a few mansions were nestled between the lush meadows and gently rolling hills of Devon. From this first impression, this country certainly seemed to be quite well adapted for even a longer stay than just a daytrip - a quite surprising new impression, which will surely influence future vacation decisions of mine.
Soon enough we gently soared across the runway threshold and touched down firmly on the rather short runway, using some heavy braking, full spoilers and reversers in order to vacate the runway closer to the terminal instead of travelling all the way down the runway to its other end.
Having the braking mission accomplished successfully, the wing was "cleaned up", and we slowly travelled past the diminutive terminal building and a pair of company Dash 8Q-400's, which were prepared for their flights to the Channel Islands and to Belfast. Our BAe came to a halt next to one of the Canadian propliners,…
…and after only a few more minutes of waiting time, the front 1L door was opened and we left the airplane into a bright and almost crystal clear sky, walking one last time past our mount, which had taken us across the Channel so faithfully.
After a short wait at immigration control (it was a weird feeling to sue the ID card after a long time of travels just within the Schengen countries), I was cleared to proceed to the landside, where I made my way straight towards the bus stop in order to spend a few hours in the scenic downtown of Exeter,
After spending some hours in the surprisingly scenic cathedral city of Exeter, I returned to the airport about two and a half hour before departure.
For an airport of its size – AFAIK, last year’s figure was about 800.000 passengers per year – EXT proved to be surprisingly busy upon my return to the terminal about two hours before departure.
Besides several flybe services to domestic destinations, there was also an Air Malta A320 waiting for passengers to Heraklion, Crete and a flybe B737-300, which was prepared for the flight to Faro.
Earlier in the morning, while I was waiting for the bus to Exeter City, I had also watched the arrival of an Air Transat A310 from Toronto – not bad for such a provincial airport!
I spend most of the remaining time on the small visitor’s deck, which, despite its glass walls, offers a surprisingly good view over the apron acitivities and the adjacent runways. On the far end of the airport, several parked RJ-100 were visible in a variety of markings of their former owners. From what I remember, these were originally destined to go to flybe as a replacement for the BAe’s, but due to their bad technical condition, the management had revised this decision and instead became the launch customer for the EMB-195.
Spotting seems to be quite a popular past-time in this part of England, because even on this Tuesday afternoon, the terrace was jam-packed with meeters and greeters waving off their loved ones before their journey for the skies. Others were undoubtedly waiting for friends or family to arrive from business or leisure trips abroad.
Before passing though customs and security, I took one last picture of the fairly unimpressive looking terminal building… or dare I say: terminal hovel, and the landside access. Visible on the right hand side of the picture is the “arrivals zone”, which is actually just another small building plastered to the side of the terminal.
On my way to the airside, I had to stop at the customs checkpoint, where I expected to be waved through after a glimpse on my personal ID. Not so in the Great Britain of the post-7/7 era! A friendly, but nevertheless sincere gentleman in civilian clothes handed me a green form, asking me to fill it out.
Me (slightly irritated): “Err, excuse me sir, but I am a citizen of the European Union and we do not have to fill out visa-releated forms.”
Guy in civilian clothes: “This is a new regulation, which is compulsory to every person leaving British soil. We would kindly ask you to take this short effort and fill out the card.”
Sigh… what kind of choice did I have? Actually, while I can partly understand the motivation behind this, I was not very amused (to put it friendly) to be asked about my profession and the name and address of my employer! But since I didn’t want to risk to run in trouble during my next visit to the United Kingdom, I resignated and filled out this part of the information request, swallowing down my protest.
Passing customs control was just a formality after filling out the card and showing my ID. With no more than maybe thirty minutes to go, I wanted to explore the terminal a bit, but was slightly astonished to see that it basically just comprised two halls – a large one with a few bars and bistros plus a duty free store, where most of the passenegrs where waiting for the announcement of their boarding gates, and the actual gate area.
While usually the strategy of the British Airport Authority is to herd the cattle, err, passengers within the commercial areas by not announcing the gate information until the very last moment, this was a feeble attempt at an airport of the size of EXT, where all gates were easily recognizable once inside the small hall dedicated to the embarkation process.
Therefore, I settled down on a bank next to a large apron window, and spend the last few minutes until our BAe arrived.
Turnaround was completed in a very short period of time, and with only a slight delay, boarding our light load of passengers (ca. 35-45) started. We leisurely walked out of the terminal, strolled across the sun-drenched apron and entered the cabin of our “146” via the 1L door.
The flight (EXT-CDG)
Exeter International Airport (EXT) - Paris Charles de Gaulle (CDG)
Flight number: BE 1505
Scheduled block time: 1730h - 2000h
Off-block: 1742h
Take-off: 1750h (RWY 26)
Touch-down: 1947h (RWY 09R)
On-block: 1951h
G-JEAK
c/n E2103
Seat 2F (Economy Class)
Photo © Justin Wood - Woof Photography
After greeting the two friendly female members of the cabin crew, who were waiting for us in the forward galley, I proceeded towards my seat, which would be on this segment right in front of the wings (2F). The cabin filled up very quickly – except for a few businesspeople, the majority of our pax load would be comprised of families and couples going to visit the city of lights.
Cabin was cleared in a matter of minutes, because we had already incurred a small delay from the previous leg, and we were off-block soon. Taxying towards the threshold of RWY 26 past the flybe hangars, I noticed a rather derelict looking BAe ATP in former Air Europa colors standing next to it – judging from the sorry state of this bird, it was only used as a cabin or maybe maintenance trainer. What a tragic end for another true British airliner before her time!
With little other traffic on this sunny afternoon going on, we proceeded right onto the runway, our four Lycoming engines spooled up and sluggishly, our “Jumbolino” started her run down the runway, passing a few of the stored RJ-100’s and also a Globespan B737, which seemed to be being prepared for delivery to her customer. Lifting up around two thirds down the runway, we steeply climbed out into the steel blue sky,…
… gear and most of the flaps was retracted, and then we were already right above the City of Exeter.
A few left hand turns later, the Devon coastline greeted us below, while we continued our ascent towards the Channel Islands.
After reaching our cruising altitude a few minutes later, it was only a matter of minutes until the aforementioned group of islands became visible below us – the Channel Islands are another important destination for flybe, and I had noticed at least two other flights going to Jersey and Guernsey during my stay on the EXT visitors deck.
The rest of the flight went by quickly and mirrored the service program already described on the outbound leg. Soon enough, over the continent near the City of Rouen, our descent was initiated and we commenced our long arrival back to Paris’ intercontinental gateway. The first suburbs became visible below, then we glided along the northern outskirts.
Visible right next us was Le Bourget Airport, site of the Aerosalon and one of the most interesting aviation museums in the world, the Musee de’l Air (in fact, if you look very closely, you can see a couple of the static exhibits on the following picture, including a static “Ariane” rocket).
Right as we crossed the threshold, the FedEx hub became visible, where activity was already commencing for another busy night of operations.
Then followed the Air France maintenance base with a static Concorde and an all-white Boeing 747-200B (see photo below).
With a noticeable thumb, we touched terra firm again, and with very little reverser action, our BAe slowed down to taxying speed and vacated the runway right next to Aérogare 1, which even from the outside just gives an impression of darkness – if there would be a terrestrial equivalent of George Lucas’ “Death Star”, this building would come very close to it in outward appearance.
A couple more minutes of maneuvering ensued, and then we were finally back where my journey had started about ten hours before – one of the aircraft stands next to Satellite 4.
Grabbing my backpack and walking out of the aircraft only took another minute or two, and then I was back in French soil, ready for the trip back to downtown Paris, where a picknick on the Champs de Mars next to the Eiffel Tower was already awaiting me.
flybe offers a very streamlined, but nevertheless classy product, which sets the airline positively apart from the "urban transport"-style cattle carriers like EasyJet or Ryanair. Although cabin service is no longer free, virtually every other service element along the travel chain still mirrors the former identity of the carrier as a "full frills" regional airline – a network of large hubs and small, conveniently located regional airports, comfortable cabin seating (despite being 6 abreast on a Bae), friendly and courteous staff both on the ground and in the air, and the availability of seat assignments upon check-in or if you book a full-fare ticket are welcome and much needed stress relievers from the hustle and bustle of the cattle call practised at many other low cost competitors.
Therefore I can fully recommend choosing flybe, even if it should cost a little more than flying Ryanair or EasyJet - you will certainly appreciate the relaxed travelling on board smaller regional airliners like the Dash-8 or Bae-146 and not having to worry about your seat assignment compared to the rather generic mass transit experience on "purebred low cost carriers".
Thanks for reading my report - questions, comments, or criticism is always appreciated.  Smile
flyingchoirboy
RE: EXTreme Flyin':CDG-EXT-CDG W/ BE (+35 Pix)
Fri Aug 19, 2005 6:00 pm
Amazing trip report, well done! I read every word, and the pictures were great. I can't believe CDG is still in the stone-age...sort of. Can't wait to read another trip report that you write!
-Scott
cambrian
Fri Aug 19, 2005 6:52 pm
Nice trip report!
Am I the only person on these boards who actually likes CDG1?
Next time you are looking for an "exotic" trip, why not try an Air Wales ATR to Cardiff? Much nicer than Exeter..... Smile
SQno1
Fri Aug 19, 2005 9:26 pm
Great Report Tristar500!
The pictures were much better than in my report, damn Sony Cybershot, hopefully I will get some experience from this. I was just wondering, was the headrest in 8F still missing?
I also totally agree with you with the seats in the CDG terminal. I sat in between two seats and felt the sharp pain of the metal go through my arse and into my back.
If you haven't read my report on the same route from three weeks ago, feel free to read and comment here.
Why? EXT-CDG Day Trip On BE (Long, Lots Of Pix!) (by SQNo1 Jul 21 2005 in Trip Reports)
I Don't understand why my photos shrunk like that, if anybody can help, send me a e-mail.
Once again, fabulous TR, Tristar!
With Regards,
Alex.B
[Edited 2005-08-19 14:41:54]
[Edited 2005-08-19 14:42:58]
Sabena 690
Fri Aug 19, 2005 9:47 pm
Hi Jens,
Thank you for posting this excellent trip report!
Quoting TriStar500 (Thread starter):
CDG T1 is indeed awful. At least you were able to leave, without a fuel strike  Wink
G-JEAK
This aircraft seems to fly the CDG-EXT flights very often. I've seen this flight already several times at CDG, and it's always G-JEAK, both in the morning and in the evening.
Never heard about this procedure. And it looks ridiculours to me for passengers with the EU as destination.
Quoting Flyingchoirboy (Reply 1):
You are right... when talking about T1 and T3. T2 is totally different.
Quoting Cambrian (Reply 2):
I think so  Wink Big grin
Frederic
cambrian
Fri Aug 19, 2005 11:00 pm
Quoting Sabena 690 (Reply 4):
I think so
Ouch!  Wink
TGV
Sat Aug 20, 2005 12:29 am
While I agree that CDG T1 is not the ultimate terminal (let's see the result of the on-going refnovation), I nevertheless like being in the satellite, where you have good views of the planes.
But I have a question: why do you think having the departure level below the arriving level is unnecessarily difficult ?
This is precisely what they are doing in CCS, with a new arrival hall opened above the departure hall.
And if my memory is correct, some years ago you took a climbing escalator when disembarking in MIA (Terminal for AF flights).
Avoid 777 with 3-4-3 config in Y ! They are real sardine cans
semsem
Sat Aug 20, 2005 1:09 am
Very interesting to see all these British regional airports now having international flights. However how were the loads? The plane looks pretty empty.
follonica
Sat Aug 20, 2005 2:29 am
Cambrian,
You are NOT the only one who likes CDG1. I remember my first flight into CDG in 1974. It was brand new and very StarWars-esque, for lack of a better term. Over the years, I've flown in there on TWA, and then USairways, all CDG1 tenants. Coming into the satellite and onto the moving walkway through the tunnel feels like coming home.
Of course, I've never used CDG2, so I can't compare them. CDG1 can be daunting during the morning rush, but it's familiar and I know my way around fairly well, so I just get on with it. The waiting areas at the gates can be scruffy but I'm usually so hacked about leaving, I rarely notice.
sulman
Sat Aug 20, 2005 3:44 am
Jens,
Another great report from you, this time featuring an airline a little closer to home!
I see these aircraft so much, but I've only used BE once (to Malaga) and, like your own experience, I found it a pleasant way to travel - the 146 is a great aircraft.
Seeing the same registration 'sticking' to some routes isn't that unusual; they only have five 146-200's!
I made a little photo album for them, with all their different liveries over the last couple of years.
James
Contact Air
Sat Aug 20, 2005 4:25 am
Hi Jens,
thanks for this highly interesting report - as always illustrated by high-quality pics! Having visited Britan many times and having experienced a lot of British airlines as well, FlyBE is still missing in my "collection", so your report gave me a good impression of what to expect if I should get the chance to try out this airline in the future.
As you know, I'm a big Britain-fan, so I'm glad to hear that...  Smile But the Exeter area is also new to me - I have only visited Plymouth in the West and Bournemouth in the East.
Well, I can't imagine any other European country where spotting is as popular as in Britain. I guess Exeter only gave you a small impression of it. You will see much more spotters on your trip to MAN, as the airport is much bigger and offers a great variety of movements.
Christoph
TriStar500
Sat Aug 20, 2005 6:05 pm
Thanks to all of you for your kind words and interesting replies!  Smile
@Scott
Thank you very much for thosekind words. After compiling a report for several hours, trip report authors like us highly appreaciate a small feedback from our readers, as it indicates that we are actually putting out an effort, which is relevant to some other people, too.
@avid
Thank you for the good idea concerning Air Wales. After flying around Spain and France a lot during the last couple of years, and effectively nailing most airlines in these countries, I have decided to put more focus on the UK during the coming year. So if you have any other good ideas concerning interesting airlines and routes from gateways like STN, LGW, LHR or MAN, please feel free to post them here.  Smile
@Alex
I have read and psted a comment to your report when I first saw it a few weeks ago - what a funny coincidence that were wereboth travellign this route ins uch a short intervall. I actually enjoyed your report very much, because it was highly detailed and the photos added alot to the atmosphere - even to the point that I almost decided not to write a report myself, because I could hardly add anything new to your report.
@Frederic
Yeah, I guess I was a little more lucky than you - I don't quite remember it, but wasn't your ground staff also part of Globeground? Aren't you going to LHR by BD in a few weeks? I'll be interested to hear if you have to go through the same ridiculous "visa" routine.
@TGV
IMO the "reverse" solution concerning the arrival and departure level at CDG1A is just not very practical, because it deviates from the principle which is used virtually everywhere else in the world. Therefore both frequent travellers, who are used to the common worldwide principle and seldom travellers, who don't know their way aroudn airports very much, will probably be a bit irritated.
Or maybe it is just me..  Wink
@Semsem
Loads on both flybe flights were pretty bad - i.e. less than 40% SLF. I suppose, flybe is just using the wrong equipment on this route -for a double daily rotation on such a niche route, a Dash 8-300 with 50 seats would be much better suited to the light loads. Why they have chosen to in fact use their largest equipment on this route is beyond my comprehension.
@James
I really like BE's concept of serving both regional airports and large hubs - and also, by using somewhat smaller equipment than traditional LCC's, their service also feels a bit more personal than riding on "urban transit", i.e. U2, FR etc. From what I have read somewhere else, BE at one point was also considering adding routes to Germany - have you heard anything else concerning that matter? I would be thrilled to see them here in my home state of Northrhine-Westphalia at DUS, CGN or so, because this short excursion to Exeter has really triggered my appetite to visit Southwest England for a few days.
@Christoph
Unfortunately, Iwon't be going to MAN in October, because AB has decided to cancel the DUS-MAN-DUS route due to poor loads from August 15. Instead, Iam now rebooked on a daytripto STN, where I haven't been to before, but AFAIK, spotting facilities are really not that great over there, to use an understatement. I bet, you have been there before: can you give me any ideas or advice, where to go to at STN for some "plane action"?
sulman
Sat Aug 20, 2005 11:27 pm
Jens,
I'm not sure whether BE are looking at Germany, but I do know that Air Berlin are withdrawing SOU-PAD in October.
Maybe BE or another carrier could step in and introduce some services. Would be great to see KLM or LH regionals here!
James
Contact Air
Sun Aug 21, 2005 1:23 am
Quoting TriStar500 (Reply 11):
Indeed, spotting facilities at STN can be described as poor. There is no designated spotting area and BAA staff has a strict attitude towards spotters; you are usually not allowed to stay at one of the parking areas close to the apron for a longer time (you will be "politely" asked to move away...). There is a small area on the right side next to the terminal building (so if you walk out of the terminal you have to turn left) where spotting is usually allowed; it offers a mediocre view to parts of the apron and runway. There is also a small grass hill on the other side of the terminal which offers a mediocre view to an other small part on the apron and runway... The only advice I can give you is to check in as early as possible for your return flight as airside views are much better than landside.
I don't know how much time you are going to spend at STN and if you are also planning to move away from the terminal area by bus / taxi. If you are concerning this, maybe some locals here on A.net can give you more detailled information about the surrounding.
Christoph
teva
Sun Aug 21, 2005 2:41 am
Cambrian,
You are not alone.
I think CDG1 has a lot of charm.
And the pictures in trhis report are really great!
Of course, renovation is more than needed. And it is very unfortunate it has been delayed by Sep 11.
I hope this renovation will improve the luggage delivery (my only nightmare in this terminal). But I hope it will not kill its unique atmosphere
Teva
Ecoute les orgues, Elles jouent pour toi...C'est le requiem pour un con
Sun Aug 21, 2005 4:03 am
Hi Jens,
finally I found the time to read your report, a pleasure as always.
Amazing, or not, we had the same targets this month, you know from my Paris trip last weekend and the UK is expected for next Saturday.
I love it to fly this classic airliners as long as its possible.
TriStar500
Sun Aug 21, 2005 7:51 pm
@James
I heard about AB stopping their PAD-SOU-PAD service durig winter, however AFAIK this is usually a seasonal route anyway, so it might be back next summer. I have read an interview with Mr. Hunold, the CEO of AB a while ago, and he said that the routes from PAD to the UK would be working surprisingly well due to the large number of Royal Army soldiers and their families in the region.
Otherwise, an exotic route like PAD-SOU-PAD would be hard to explain anyway.
@Christoph
The time between my inbound and outbound flight at STN will be about 8 hours, so I won't go to London. I was thinking about cancelling this trip altogether when my MAN booking was withdrawn, however I need the mileage for my Gold Status and also AB will most likely use an F-100 on this route, which is still missing from my collection of AB planes.  Smile
Are there any interesting towns in the closer vicinity which might be interesting for a short visit of three to four hours?
@Markus
Funny coincidence - this goes to prove that there might be some truth to the phrase "it's a small world" after all.  Smile
Where are you going to in the UK on your next trip?
sulman
Sun Aug 21, 2005 8:03 pm
Jens,
If you hire a car, you could squeeze in a trip to Duxford - it's not far, about a 25 minute drive down the motorway.
James
[Edited 2005-08-21 13:07:52]
TriStar500
Mon Aug 22, 2005 7:08 pm
James,
Duxford sounds like an interesting idea, thank you very much. I'll check, how much a day's car hire is and then probably hit the road (maybe even litteraly, since I have never driven on a left-lane-system before).  Wink
Tue Aug 23, 2005 1:58 am
Hi Jens,
I will go next Saturday:
STR-LHR/BA
LHR-GLA/BD
GLA-STN/EZY
STN-STR/4U
And about driving left-lane for the first time:
Enjoy it, it will be real fun as long as no other cars behind yours especially at the first roundabout!.
For real, no problem, think always and don´t forget: left hand driving.
TriStar500
Tue Aug 23, 2005 6:38 pm
Markus,
Sounds like a great plan! I'll keep my fingers crossed that you don't have any delays or cancellations along the way.  Smile Since you are surely going to write a trip report about this adventure anyway, I'll wait with further questions until I read your story here.
mrniji
Tue Aug 23, 2005 7:04 pm
Jens, your report was on my top list (especially after my Thread in SR)! Finally I found (better: I just took) the time this "hard" and consistent work deserves and read it in all detail. Wonderful! TRs are great if they really begin at the airport (or even before) and have a nice "vogue" ending!  Smile
This picture is amazing.. the 70s style with all these "LSD-Colors" is in my eyes more attrative than the so-called modern grey dull style. A matter of taste. Maybe its coz I come from a colorful country Big grin
And the 80s are even more fascinating.. my childhood, my first flights, all these memories. for that very reason I enjoy the time warp on the AI A310 Big grin
That is a surprise! I went to the UK on Bloedhansa last End of July.. since when is this regulation in force? And would they verify if you gave some 'fake' employee? I agree, I don't want too much data of me collected!
Nice report, hope to see more such detailed reports!  Smile
"The earth provides enough resources for everyone's need, but not for some people's greed." (Gandhi)
TriStar500
Wed Aug 24, 2005 6:55 pm
Subin,
Thank you for the interest in my report! Reading your comments about the Eighties mirrors my personal feeling about that decade - I am pretty much and Eighties' guy myself. Probably not a big surprise if your adolescence years were during that period and you have a weak spot for tacky things.  Smile
Interesting to hear about the lack of "departure visa" control during your last trip to the United Kingdom... maybe I just ran into a random check or some guy just "pulled a Monthy Python" on me. Considering British humor, even the second option is not entirely unlikely.  Wink
mrniji
Wed Aug 24, 2005 8:37 pm
Quoting TriStar500 (Reply 22):
I was actually considering, while buying new spectacles a week ago, whether I should buy an 80s modell, with a huge thick Pentagon shape, and the frame low at the glasses, and then taking a huge slide up towards the ears.. Big grin - they are just great..
Sabena 690
Thu Aug 25, 2005 4:05 am
Your itinerary looks very interesting, Markus! Good luck!
Indeed, correct!
I had 6 BMI flights (2 returns BRU-LHR and 1 return LHR-MAN) about 4 weeks ago, and didn't have to fill in that visa-form at any point during my journey.
Frederic
ZKSUJ
Thu Aug 25, 2005 12:06 pm
Very nice report. I love the photos.  Smile
TriStar500
Thu Aug 25, 2005 10:12 pm
@Frederic,
Hmmm... my impression of the Globeground staff was that they were rather friendly and motivated. They even adressed me in English right away as soon as they saw my ID - not really common in France as you will know. However, it is good to know that there is also a not very positive side to their operation once they decide to go on a "strike" for whatever questionable reason.
By the way, where is the second part of you AZ trip report?  Smile
@Nigel,
Thanks! I really appreaciate that. Big grin
Sabena 690
Thu Aug 25, 2005 11:15 pm
Quoting TriStar500 (Reply 26):
The strike wasn't Globeground's fault, and the people from Globeground where the only friendly people I saw on that evening. Varig (and its staff) caused the frustrations.
No time at the moment, hopefully somewhere next week.
Frederic
Ndebele
Fri Aug 26, 2005 12:36 am
Hi Jens,
I have to apologize for my late reply to this interesting and detailed report, which I enjoyed reading a lot! Sounds like you had a fun trip, and FlyBE seems to be a good airline - though I have to say the BAe146 6-abreast-cabin can be hell if you're sitting in the middle seat, as it happened to me on a Buzz flight years ago. - Though a bit old-fashioned, the cabin looks still great on your pics, and who needs large overhead bins anyway if there are only few passengers on the plane  Wink
FlyBE seems to be a good airline, and EXT would be a nice destination as well, however they're simply not flying anywhere close to any of my possible departure airport. Hope they'll open some a route somewhere around here, I'd like to visit Exeter.
Quoting TriStar500 (Reply 16):
The time between my inbound and outbound flight at STN will be about 8 hours...
Eight hours at STN? You're going to die! No honestly, eight hours at STN can become really boring. If I were you, I'd either consider viditing any town (==>Duxford?) or doing a nonsense trip somewhere else - like my recent STN-NCL-STN or STN-CRL-STN flights, just because a whole day at STN would be too boring. Think about it, STN is a low-cost Mekka, there are certainly interesting (and cheap) just-for-fun flights available.
Quoting FLIEGER67,reply=15 and 19:
STR-LHR/BA
It's a small world indeed, a friend of mine will also be on BA's morning flight STR-LHR next saturday. Unfortunately(?) I'll be flying to Helgoland on Saturday, so I can't wave goodbye neither to her nor to you. Enjoy your trip!
Regards, Alex.
TriStar500
Fri Aug 26, 2005 8:48 pm
Alex,
Unfortunately my eight hour layover at STN will be too short for a quick roundtrip by plane, so I will look out for anything within reach on the landside. Duxford looks like a very good proposition, although I am also considering, weather permitting, to visit some of the smaller towns nearby to catch some English countryside atmosphere for a day. Isn't Cambridge nearby?
sulman
Fri Aug 26, 2005 9:19 pm
Cambridge is a little further up the motorway. With regard to Duxford, you can easily kill the time there - it's absolutely huge. Plenty of interesting stuff to see if civil aviation is your primary interest - BAC 1-11, VC10, Concorde (you can go inside), Comet, etc. The American section of the museum is excellent, with a good selection of Aircraft (B52, SR71, Vietnam F-4, UH-1 etc).
James
TriStar500
Sun Aug 28, 2005 5:30 pm
James,
Hmmm... this is really going to be a tough decision. Fortunately I still have until the end of October to make up my mind. I am currently pretty open about whether to go to an old university town or visit what is arguably one of the greatest aviation collections of the world.
christao17
Mon Aug 29, 2005 11:20 am
Fantastic, detailed trip report and thanks for all the pictures. Felt like I was right there on the trip.
CDG's Terminal 1 reminds me a lot of Tommorrowland at Disneyland. It's the way the future was envisioned to be, from the perspective of several decades ago. And, man, did they get it wrong!
I look forward to the next report.
TriStar500
Tue Aug 30, 2005 2:55 pm
@Chris,
Thanks a lot! From my perspective of an airport planner, who had to take urban planning history at university, it is highly interesting to visit such awkward terminal designs, because they mirror the philosophy of their decade very well.
However, from my perspective as an airport plannner, who tries to streamline processses and optimize functional areas and traffic flows in such buildings, it is sometimes hard not to walk through a structure like this without constantly shaking my head in disbelief.  Wink
godbless
Sun Sep 04, 2005 8:23 pm
Jens, you once again presented us a great and very detailed trip report. It was a pleasure to read.
Your short journey did remind me of my flight on Buzz from DUS to STN back in 2002. An airline that sadly ended up as breakfast for the Irish devil's airline.
I guess that FlyBe still wants to catch business pax or elsewise they would have probably left the coffin of Terminal 1 at CDG and moved to the more LCC-like Terminal 3.
Maybe that Terminal was intended to be another way of protectionism towards Air France, with future expansion in form of Terminal 2 in mind.
Max
TriStar500
Mon Sep 05, 2005 2:56 pm
Hi Max!
Thank you for finding the time to read and reply to this report.  Smile I have to agree with your notion regarding the "lowest common denominator" of low cost flying - it often seems like there is little interest in a midfield position between low-fare cattle-carrying and high-fare, full-frills options.
However, as the success of Air Berlin in Germany or hopefully flybe. in the UK might be showing, not all hope is lost, and customers will start to realize that one can actually have a decent flight experience at sensible prices without having to choose the unnamed Irish carrier and its siblings.
Ndebele
Wed Sep 07, 2005 3:34 am
Quoting TriStar500 (Reply 35):
You can add DBA to that list as well, I think. Damn this report really makes me want to give FlyBE a try, maybe during one of my next UK trips...
ManxATP
Wed Sep 07, 2005 5:48 am
Great Report! - Enjoyed seeing the pics from what is my local airport when I'm at uni. Was a little surprised to hear Exeter described as 'scenic' (I suppose if you're into 60's concrete) but I suppose it's quite nice round by the cathedral.
Users browsing this forum: 777-500er, 777dfw, aeromoe, EK006 and 5 guests
