wilco737
MD11F FRA-EMA Pilots View, Ferry Flight
Thu Sep 06, 2007 3:24 am
Hello guys,
I did several trip reports when I was a 737 driver. Now I changed to a little bigger aircraft, the MD11F of Lufthansa Cargo.
This is a trip report for just 2 short hops. One is a ferry flight (no load) and the 2nd a normal short flight.
It was a normal day, I knew I had to show up at the airport at 10:10pm. 1.5 hours prior the STD at 11:40pm. I drove up to the operations 'Center' of Lufthansa Cargo in Frankfurt. Parked my car in the car park and walked up to the meeting point with the captain.
He was there already and we introduced ourself and were both happy that we could spend the night together  Wink I connected my computer to the LH server and brought my laptop up to date with the necessary information (we have to do that prior each trip). No big news, so where are the charts? Looking for the charts, for a short flight from FRA to EMA you dont need many of them.
Then the dispatcher came with the papers and showed us the flight plan, weather, NOTAMS and all the other information we need. He told us its a ferry flight, so load is 0kgs. That means the MD11F is out of trim if no load on board. So you need at least 16tons of ballast fuel in the upper AUX tank to keep her in trim. Rules say: take at least 16tons of block fuel plus 16tons of ballast fuel: gave us a total fuel of 32tons. Well, 13 tons would've been sufficient, but with the ballast fuel, we had to take 32tons total.
Weather was fine in Frankfurt and EMA as well, westerly winds at both airports, so we planned for 25R in FRA (18 and 25L closed at nights for maintenance).
The bus came and took us to security check and passport control. No problems here, so the bus took us to our parking position F231.
I prepared the cockpit while the captain did his walk around. All systems in the cockpit were working properly and the aircraft was in perfect shape! Everything was working very good!
Aircraft is being refuelled and then the MD11F reschedules the fuel. If you fuel 32tons it will all in the 3 main tanks. but we need 16tons in the upper AUX tank, so the MD11F transferred the 16tons to the upper AUX tank. That took some time, but we could offload the ballast we had in the cargo hold. So here we had a cargo bay of those who cared Big grin EMPTY!  Wink
Ok, doors closed, FMS ready, cockpit all set for pushback, APU is running, APU AIR is ON, ready for push and start. Calling ATC for start up. Well, the gave us runway 18... It was still open, although the NOTAMS said it was closed already. So, we had to recalculate everything. Weather was the same, but flap setting was different, speeds slightly different. Well, took another 4 minutes. Then we were ready for pushback. "Pushback approved, face to the east".
We pushed back and started all engines in the sequence: #3, #1 and finally #2. All engines stabilized at idle without problems. So, disconnect the towing truck and the steering pin. Hand signal of the ramp agent and then we set the flaps, armed the spoilers, set the trim and did the flight control check. Flaps tonight was only 10°, lowest possible flap setting for take off. Take off weight was only 148tons. (MTOW is 286tons) We were really light, and the engines were at max thrust reduction.
We taxied to runway 18 and got a take off clearance behind a Turkish Airlines 737-800.
I was pilot flying and the captain taxied the aircraft onto the runway and aligned it with the runway. Once aligned, he said: "you have control", I replied: "I have control"! Put my hands on the yoke and kept the aircraft on the runway with the rudder pedals. Engines spooled up to a take off N1 of 99.5%. The acceleration was enormous! This light aircraft and still so much power. After only few seconds "80" "checked" and a few seconds later "go" and "rotate". I only needed a very light pull on the yoke and the MD11F lifted off pretty much immediately! "GEAR UP". and we climbed with 4500ft/min into the dark sky. Calling Frankfurt departure real quick, because on the departure route you have to level off at 4000'! We got a climb to FL110 and we retracted flaps and slats and accelerated to 250kias. We climbed with 5000ft/min! Reaching FL110 we got a climb to FL240! We accelerated to 354knots, our standard climb speed above FL100. After reaching that speed we climbed with more than 6000ft/min, shortly we reached 7700ft/min... Big grin reaching FL240 we asked for further climb and the controller said: wow, you are at FL240 already?! We were laughing and we got a new frequency and they cleared us to FL380 (cruising level). After only 10minutes after lift off we were at FL380. With the level off at FL240. Big grin That was fun.
The flight itself was uneventful, no clouds, so we had a nice view over the channel and passed London a little north of it. Via LAM (how many hours have I spend in this holding when approaching LHR  Wink) and then right turn vie WELIN and VELAG and radar vectors to the approach to runway 27 in EMA.
Weather was okish, a little cloudy up here but on the ground it was ok. We started the descent already abeam London, we were instructed to do so by the controller. Descent speed was only 280 knots because we were 10 minutes ahead of schedule, so no need to flight too fast. Below FL100 we reduced 250 knots. Then we got the descent to 2000' and heading 300 to intercept the ILS 27. I commanded "slats extent" and the captain did so. We reduced the speed then I commanded "Flaps 15" what the captain did. I disconnected the autopilot and the autothrust and did the rest manually. Level off at 2000' and shortly after that we intercepted the glideslope and descended with the ILS. "Flaps 28" and speed at about 150knots now. "Gear Down" and "flaps 35", final flap setting. Landing checklist read and cleared to land. Vapproach this evening was 138knots, pretty slow for an MD11F, but no load... The wind was straight on the nose, so no big deal to stay stabilized all the way down.
Mrs Douglas started to count: 100, 50, power reduce to idle, 40, 30', 20' pull on the yoke slightly and wait for touchdown, 10' release backpressure slightly, touchdown! Reverser deploy, but only idle reverse, light weight and runway dry and light weight... We vacated the runway at taxiway 'H'. Contact ground. Taxi to stand 121. Not hard to find in EMA; small airport, only a few meters to taxi.
Into the stand, parking brake set; engine #1 and #3 off, engine #2 stays on until the ground electric is connected. then engine #2 off and the mechanic on the ground told us: chocks in position: parking brake released and parking checklist.
Thats it. Captain opened the door and I did all the paperwork and completed the flight...
not much to offload in EMA for the loading crew, but they put ballast into the cargo hold to prevent tailtipping when the fuel is transferred back to the main tanks.
That was my nice ferry flight from FRA - EMA.
Sorry that there are no pics, but it was dark and hard to take pictures then  Wink
I hope you enjoyed reading it
WILCO737 (MD11F)
 airplane
RE: MD11F FRA-EMA Pilots View, Ferry Flight
Thu Sep 06, 2007 3:57 am
Hallo WILCO737!
Enjoyable trip report. I think it is really interesting to read bout cargo flights, very different perspective from passengers point of views.
I have to admit as well that I got quite lost in some of the vocabulary used.
Danke sehr!
wilco737
Thu Sep 06, 2007 4:06 am
Quoting Rogerbcn (Reply 1):
Sorry, didnt mean to do that... I tried to keep it simple...  ashamed
WILCO737 (MD11F)
 airplane
gjunnar
Thu Sep 06, 2007 4:14 am
Interesting read. What did you guys do after you had landed in EMA? Travel back to FRA?
wilco737
Thu Sep 06, 2007 4:17 am
Quoting Gjunnar (Reply 3):
After 1.5 hours and 19tons of load we flew to CGN where the aircraft left a few hours later to BAH...
We got picked up by a mini van and were brought back to FRA... 1.5 hours drive...
WILCO737 (MD11F)
 airplane
Door5Right
Thu Sep 06, 2007 4:47 am
Shocking to think you get paid for such fun  Wink
My soul is in the sky...
wilco737
Thu Sep 06, 2007 4:52 am
Quoting Door5Right (Reply 5):
 angel
WILCO737 (MD11F)
 airplane
Thu Sep 06, 2007 4:53 am
Quoting WILCO737 (Reply 2):
Please.... it is always great to learn new things!!
Grüsse,
Thu Sep 06, 2007 5:23 am
Nice Report.Any pics during the flt or is it not advisable to post it on a public forum due regulations.
regds
MEL
wilco737
Thu Sep 06, 2007 5:25 am
Quoting HAWK21M (Reply 8):
As I said: it was dark... so hard to take pics... and taking pictures on the apron you usually get asked by security if you have a permission. Well I dont, so I am not allowed to publish them. So only for private use...
WILCO737 (MD11F)
 airplane
Ryanair737
Thu Sep 06, 2007 5:44 am
Great insight, thanks for sharing!
FL380 in 10 mins is very impressive indeed.
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
Comeflywithme
Thu Sep 06, 2007 6:48 am
WILCO737 - Great report,always nice to get an insight into a pilots day at work.  thumbsup
More please.
musapapaya
Thu Sep 06, 2007 6:57 am
Wow, nice to see you are doing 6000 or 7000 feet per minute. I am no pilot but just a MS Flight Simulator. I often dont know how to set the vertical speed and quite a few times I set it too high and the plane stalled in the middle of the climb. It is a very bad design for the flight simulator that they dont tell you climb speed or decent speed etc... I hope I can learn mroe on here so that I can polish my skills with Microsoft! Any comments for me Wilco?
Its fun to read your report. But 19 tons of cargo back to CGN, is it a little bit little? I mean for a big plane like yours, 19 tons seems little. And the plane is ferried empty to EMA, at an employee's point of view, is it not that efficient?
Lufthansa Group of Airlines
noelg
Thu Sep 06, 2007 7:36 am
Hey great trip report! Very interesting to see the pilot's perspective of this nightly flight into my local, EMA.
And don't worry about the vocabulary - made perfect sense and makes it a much more interesting report!
Noel
PS - congrats on the upgrade to the MD!
LAXspotter
Thu Sep 06, 2007 7:46 am
Wilco, thanks for this great report, enjoyed it thoroughly, hey Phil just wondering at FRA, how often do you use Runway 18 along with 25R and 25L? Is 18, usually for takeoffs? Man, its a long taxi to 18 from T-1, and I heard you tell us that once you taxied from T-1 to Runway 36, sheesh that seems like 4 miles of taxiing.
"Patriotism is the last refuge of the scoundrel" Samuel Johnson
22886
Thu Sep 06, 2007 10:17 am
Hi, great report!! working at EMA I see Lufthansa Cargo's MD-11Fs fly in every night, and always wish I could be flying onboard it. Reading about being onboard is one step closer!  Smile
I actually have a few photos of the LH MD-11Fs at EMAs DHL ramp.
WILCO737 you are right, the security at EMA are a right pain, I almost had my airside pass confiscated for these photos, even though I had full permission from the crew.
Here are the pics:
http://i9.photobucket.com/albums/a82/vman228/PICT5975.jpg
http://i9.photobucket.com/albums/a82/vman228/PICT3018.jpg
http://i9.photobucket.com/albums/a82/vman228/PICT2993.jpg
http://i9.photobucket.com/albums/a82/vman228/RIMG0094.jpg
http://i9.photobucket.com/albums/a82/vman228/RIMG0100.jpg
http://i9.photobucket.com/albums/a82/vman228/RIMG0098.jpg
Please post more trip reports of your flights, I think we'd all love to read them.
thanks for the report!
Vin
Boeing744
Thu Sep 06, 2007 2:19 pm
Great report Phil! It sounds like you're really having fun with your new plane. Thanks for taking the time to write this report.
Servus.  Wink
wilco737
Thu Sep 06, 2007 2:37 pm
Quoting Musapapaya (Reply 12):
Yes, its just very light load. Our maximum load we can carry is: 94,5 tons!!!! So 19tons is piece of cake  Wink
Quoting LAXspotter (Reply 14):
Runway 18 is ONLY used for take off and runway 36 pretty much doesnt exist! Not used in this direction! ONLY 18...
And runway 25L/R is used parallel with runway 18. No problem because rwy 18 is only used for take offs...
Quoting 22886 (Reply 15):
Well, its not only in EMA... Its everywhere.... Nice pics btw!! What do you do at EMA airport? Why havent you told me earlier?!  Wink Been at EMA 5 t times in the last 4 weeks Big grin
WILCO737 (MD11F)
 airplane
DFW13L
Thu Sep 06, 2007 3:54 pm
Quoting WILCO737 (Thread starter):
Wow, how many G's did you pull? It had to be close to the space shuttle.
Actually, thanks for the tip. I don't speed up enough in FS after 10,000, so I'll fly it your way!
That was funny about how you surprised the controller!
Thanks for the report!
See, I knew American Eagle was first class all along!
wilco737
Thu Sep 06, 2007 4:01 pm
Quoting DFW13L (Reply 18):
We pulled smoothly, so I'd say 1.3G's maximum...
Normal climb out speed for most aircrafts it between 280 and 330, depends on the aircraft type, but MD11 is a little faster during climb  Wink
WILCO737 (MD11F)
 airplane
Thu Sep 06, 2007 11:05 pm
A really really good TR. I love this kind of TR.
Really hopes that you can write more about your cargo flights. It is so cool.
Thank you for taking time to write it.
Looking forward for more TR from you.
That is really cool. 7700ft/min. WOW
Aleksandar
Fri Sep 07, 2007 7:47 am
Hi there!
I must admit, I missed your trip reports and hopefully you'll treat us with more now that you'reflying the big bird.
Lufthansa Cargo seems to be flying to interesting destinations. Where did you fly so far?
Alex
R-E-S-P-E-C-T
Sat Sep 08, 2007 3:04 pm
Watching those Pics.I noticed that the MD11F MDCD [Main deck cargo door] is opened to Full position.Isn't there a canopy position on these Freighters.
regds
MEL
Aaron747
Sun Sep 09, 2007 1:14 am
Ummm not quite buddy. The Space Shuttle reaches 50,000 feet in 70 seconds  Wink
warszawa
Sun Sep 09, 2007 12:53 pm
Excellent report - all pilot reports are always the best  Wink
I am amazed you climbed at 7700ft per minute, I thought that's something only Flight Simulator computer pilots do! And that max climb in airliners is usually 4500fpm, but nothing more. 7700, wow!  Wow!
Hey that MD-11 Lufthansa Cargo at EMA is from KILN Wilmington Ohio here in the USA (at least if it's on the DHL ramp).
Wilco 737 have you flown EGNX-KILN yet transatlantic to the DHL hub in USA?
In a few weeks I may be shipping a laptop to a friend in Poland via DHL, so in the USA, it'll fly KILN-EGNX on a Lufthansa MD-11 (because DHL contracts the Lufthansa flight to EGNX for hauling the majority of USA-Europe packages & return).
What is the maximum load you have flown so far on the MD-11? Did the MD-11 fly well with this heavy load?
Flying a plane is no diff. from riding a bicycle. Its just a lot harder to put baseball cards in the spokes. -'Airplane'
jafa39
Sun Sep 09, 2007 1:27 pm
So here we had a cargo bay of those who cared EMPTY!
LOL!
I think I'd like a job just doing ferry flights, no pax to worry about, seemed all very simple  Smile
We, the undersigned, do hereby consent.....
Mon Sep 10, 2007 7:34 pm
Quoting Jafa39 (Reply 25):
You'll be happy working for a freighter Airline.Trust me its more peacefull  Smile
regds
MEL
Captain.MD-11
Tue Sep 11, 2007 3:46 am
Nice to hear from a MD-11 flight crew perspective, would love to get my hands on one, but I´m happy learning my trade on the 737.
In comparison, on our 737´s, normal ecom climb would be around 280-300Kts and with a light load 37,000 can be done in around 14mins with 4000 or so FT/MIN max.
Used to load the MD´s at EMA a couple of years back, much nicer condition when compared to the Gemini birds.
Any chance of a jumpseat  Wink
Safe flying
Twins,twins, everywhere.... but where are the three holers?
wilco737
Tue Sep 11, 2007 2:33 pm
Quoting Aleksandar (Reply 21):
On my profile you can see all the places I have visited so far. Not up to date though, just got back from HKG and I am in SHJ now... needing some rest  Wink
Quoting HAWK21M (Reply 22):
Yes, there is a "half open" position, but for some reason they always open it fully...
Quoting Warszawa (Reply 24):
Yes, did that trip twice already! Very nice airport in EGNX and the city as well. KILN is pretty boring, our hotel is in Cincy, which is a lot better!  Wink I enjoyed it both times!
The max load I had once was 89tons of freight, max we are allowed it 95tons... so pretty full  Wink The MD11F can handle that weight pretty good, but wont make 7700ft/min  Wink Just got back from HKG with 82tons of freight, we had 75tons of fuel and we needed 18minutes to FL315 (9600m in China  Wink)
Glad you all enjoyed the trip report...
WILCO737 (MD11F)
 airplane
kaitak
Wed Sep 12, 2007 4:06 am
Fascinating report, WILCO737. I have always been curious about the MD11 and converting to it, because it used to have a reputation for being quite a difficult for being quite a difficult aircraft to handle. Can you tell us something about the conversion process you underwent. For example, how did you come to choose the MD11? What kind of syllabus is involved - in terms of time and process?
I did an Airways article on the MD11 with VARIG a few years back and they used to do their training with AY in Helsinki (must have been quite a culture shock for Brazilians - particularly the weather) and I remember them saying it was quite a lengthy conversion process.
How long will you stay on the MD11 ... and what's your next target? A380? 747-8?
wilco737
Wed Sep 12, 2007 4:58 am
Hey there,
Quoting Kaitak (Reply 29):
Well, yeah, I used to fly 737s and they are pretty easy to handle. But the MD11F is a lot heavier and bigger and the approach speeds are a lot higher! We had a Vappr of 163knots today. The MD11F is very sensitive in changes in pitch (nose up or down) just a slight change in the pitch the rate of descent changes and you get below or above the glideslope and due to the high approach speeds you have to be careful. If you get too high, you cannot dive with 2000ft/min towards the glideslope... I would say its just a little more difficult due to the high speeds you are flying. The descent planning is challenging as well... If the MD11F is heavy you need a LONG descent. Apparently Mrs Douglas loves to fly Big grin
The training took place in ZRH at Swiss Training Center, but done by our own training and check captains. So I spend about 8 weeks in ZRH for the Sim training which involves normal flying, approaches etc etc and of course all the ermergenies. Then a checkride and the flight training in the sim and real aircraft. The German law says that you dont need the flight training because its a Level D simulator, but LH Cargo says: Its safer because the MD11F is bitchy to land  Wink Then you get some courses about weight and balance, security issues, long range and NAT instruction and then you do the last training in the real aircraft on the network of LH Cargo with a check captain. I took only 3 trips and then I had a checkride and thats it... Quite a lot to study during the ground course with all the systems and different procedures... but it was ok... I really like the MD11F, cockpit is huge and comfortable and really powerful  Wink
I have 30 more months on the MD11F (thats the contract with LH Cargo) and then I hope for B744/ 748. I already applied for it but my seniority is not high enough yet. So I enjoy my flying here on the MD11F so long.
A380 is NOT an option because I am not very much into Airbus  Wink
WILCO 737 (MD11F)
 airplane
Wed Sep 12, 2007 11:31 pm
Quoting WILCO737 (Reply 28):
Does that mean the Hydraulic Arm sw to the MDCD is on throughout.Else by disarming it should drop to the Canopy Mechanically locked position.Find that strange.
regds
MEL
wilco737
Wed Sep 12, 2007 11:47 pm
Quoting HAWK21M (Reply 31):
I have no clue Big grin  Wink never opened the cargo door on my own and I guess I will never  stirthepot
I only fly this thing Big grin
WILCO737 (MD11F)
 airplane
BAW076
Thu Sep 13, 2007 10:01 am
Fantastic report Phil, I enjoyed it from start to finish!
I am astonished by the 7700ft/min climb rate! I imagine that is a sight for sore eyes!!
Excellent stuff mate!
Chris  wave
N754AN (x2), G-CPEL, G-MIDE, G-BPEC, G-BZHC, EI-DCH, LN-KKN, G-VIIW, G-BNLT, G-DBCA, G-MEDE, G-DBCE, G-MIDP.
MD11Engineer
Thu Sep 13, 2007 6:09 pm
regds
MEL
It is not being used often because the larger containers will snag with the door actuator arm unless the door is fiully opened..
regds
MEL
The actuator arm has two hooks, one for the half open position and one for fully open. You just open the door just above the respective hook and let it drop into it. Especially since LH uses the original simple Douglas cargo door design with a hand operated mechanical valve in the cabin floor just inboard of the L1 door. Locking and unlocking is accomplished either from outside (from the k-loader) or from inside.
UPS had a different door valve and actuator design, probably because their pilots refused to get on their knees to operate the valve. There they used push buttons on a panel just aft of the L1 door, which actuated valves in the nose wheel well (where the door hydraulic motor and reservoir are located). The UPS system (designed by Boeing) was very sensitive and we often had problems with it.
Jan
Qantas744er
Fri Sep 14, 2007 4:08 am
Quoting WILCO737 (Reply 30):
What is Airbus?
BTW
Do all of LHC's MD-11 feature the MD IPP for the MD-11? Including larger inlet on engine N°2 etc. etc.
If not how do the ones with it and without it compare?
Leo  devil
[Edited 2007-09-13 21:10:39]
You live and you die, by the FMA
Fri Sep 14, 2007 4:56 am
Hi Wilco737!
great to read a report of "my" company! Was it a scheduled flight to ferry an MD11F to EMA, or did one of our partners fall down on us ( again ). It's the first time I've read a report about LCAG, and what a great read it was!
Why did you do your simtraining in ZRH, as we have a MD11 sim in FRA aswell  Smile
Thanks for sharing the other side of our jobs! I'll sell the space, you fly it around the globe!
Btw. How is TSE? Just interested how our new destination is situated.
Gruss aus AMS,
Joost ( DALCE )
flown: F50,F70,CR1,CR2,CR9,E75,143,AR8,AR1,733,735,736,73G,738,753,744,77W,788,319,320,321,333,AB6.
wilco737
Sat Sep 15, 2007 1:59 am
Hi DALCE, the MD11 in the special WOW livery  Wink
Quoting DALCE (Reply 36):
Well, since we bought swiss, we bought the Sims as well. And it seems to be cheaper to let us do the training in ZRH and sell the Sim hours in FRA to other airlines...
Yeah, good old TSE, the gateway to far east  Wink Its not too bad. Its pretty expensive. But there are nice places where you can have good food or a nice drink and the hotel is very nice as well with free WiFi Big grin Thats all we need  Wink Usually we dont have much time in TSE. And sightseeing? well, not a lot to see there...
WILCO737 (MD11F)
 airplane
mighluss
Mon Sep 17, 2007 7:01 pm
Thanks for your report, I had probably my last chance to fly in a MD-11 this summer, althought mine was probably heavier! Big grin
As discussed in other topics... With a so light weight, is possible that in CLB mode, thurst setting could be higher than in the max derated take-off (anyway a take-off with 99,5% N1, seems not so derated to me!)
Miquel.
wilco737
Sat Sep 22, 2007 5:54 pm
Quoting Mighluss (Reply 38):
Depends on the engine. It was max derated. When using full thrust the N1 was at roughly 110%... weird, but thats it  Wink
WILCO737 (MD11F)
 airplane
boeing764
Sun Sep 23, 2007 1:16 pm
Thanks Wilco. Pilot reports are always my favourite trip reports. I'm already looking forward to your next one.
From Dr. King's America to Nelson Mandela's Africa, the journey of equality moves on.
Users browsing this forum: Baidu [Spider], Google [Bot], Google Feedfetcher, Pengaea, snowingairlines and 27 guests
