wilco737
Pilots View, MD11F Oerk To Omsj
Tue Dec 18, 2007 11:06 am
Hey guys,
I thought I can write another trip report about another pretty short flight.
It all started in OERK/ RUH. The weather was fine, 15 degrees C no clouds, just 3knots of wind. So a perfect day for flying. The captain and I were sitting in the cockpit and waited for the loading to be finished. Pretty impressive, the guys in RUH were indeed fast with offloading and loading our MD11F! They were done way ahead of schedule!
Pretty much all preparations in the cockpit were done. I did all my tests and switching which are necesarry, the FMS is programmed for the short flight with a calculated distance of 594NM to SHJ. Our planned deparure runway was 15L, which is 4200m long.
We recieved the loadsheet and everything was as planned. Only 10tons of load (max possible is 94.5tons) so VERY light. Only 12 tons of fuel for such a short flight. So our take off weight was 180tons (MTOW is 286tons)! I was looking forward to a GREAT powerful take off  Wink
I finished the take off calculation. Flaps 15, FLEX 60degrees (max thrust reduction) V1: 131, VR 131, V2 147. So pretty slow  Wink
Doors were closed, everybody is from board (except us of course). I contacted RUH Ground for the start up and push back clearance. The controller was slightly confused and had to check for the flight plan, because we were WELL AHEAD of schedule... It took just 3 minutes and he cleared us for start up and push back. Parking brake released and here we go! Slowly we were pushed back and we were cleared to start the engines, #3, #1 and #2 ...
All engines running in idle and push back is completed, parking brake set, Ground staff is leaving the aircraft and showing us the clear signal(thumb up). I called in for taxi! Its just short way to runway 15L. Only 4minutes. The controller passed us the enroute clearance. And then we had to switch over to tower.
I put in the flaps, set the trim, armed the spoiler and hit NAV and PROF button (for the autopilot). Last checklist read and contacted tower: WE ARE READY!
CLEARED FOR TAKE OFF and after departure contact departure, bye bye.
The captain was pilot flying. He advanced the throttles. Even at 60% N1 you felt the acceleration, were pressed back into your seat! 96% N1 was the take off powersetting and the bitch accelerated like hell! All engines were at take of power and we already hit the 80knots, shorty later: GO, ROTATE! About a third of the runway only used and we lifted off with an initial pitch of 21degrees into the air! Our climb rate was about 5000ft/min! GEAR UP and we climbed away!
I contacted departure and they cleared us to FL270! YAY, perfect for a nonstop climb! Flaps 0 and slats retract and up we go! Climb rate somewhere near 7000ft/min!! Speed at 310knots and still climbing! Shortyl after it: level off at FL270 and been there for 10 minutes until we received further climb to FL410! Our cruising level today...
We left Saudi Arabia behind us and saw Bahrain to our right and shortly after it we saw Qatar, but couldnt see Doha, too far away and too hazy...
We got handed over to UAE control where we got an intil descent to 13000feet... We had to reduce speed pretty early tp 250 knots due to a lot of inbound traffic to DXB. But we want to go to SHJ...
We saw everything during the approach. The Palm, Bursh Al Arab, The World, Dubai Tower etc... Just lovely! A few minutes later we got cleared to 6000 feet. We passed the coast and had SHJ in sight, but runway 30 was in use, so we had to fly pass SHJ airport and then got vectored around. We passed the airport at 6000 feet with a speed of 200knots. About 12NM out from the airport we got cleared to turn right heading 270 and cdescent to 2000 feet and cleared for approach 30.
The Captain switched off the Autopilot and flew manually. Slats extend, slowly reducing speed and descending to 2000 feet. We interecepted the localizer and the glideslope. Flaps 15, contact tower and already cleared to land... There wasnt too much traffic around I guess  Wink flaps 28, Gear Down, Spoiler arm, Autobrake minimum, Flaps 50... Final approach speed 134knots... (pretty slow eh?)
Captain flown a nice approach all the way to the runway, with a positive touchdown! This bitch is even more difficult to land with that light weight... Full reverse and vacated via taxiway C!
Parking stand will be 21A, but hold short of cargo apron, push back in progress! Captain and I were looking at each other and were thinking: which aircraft?! The 2 ones with covered engine inlets or the one with all cargo doors open?! I asked for what traffic we had to wait and the controller cleared an A300F for pushback, but ALL cargo doors were open. I told him that and he asked the A300F if they were ready with loading. They said NO, so were were allowed to pass behind them into our stand 21A.
Everybody was waiting for us to offload 10 tons  Wink Parking brake set, engines off, beacon off and thats it.... OFF for today!
Made all the paperwork and packed all my stuff. Bus was waiting for us already and we were taken to the terminal and then to the hotel! Weather was lovely: 28 degrees C and just light winds and no clouds! Lovely!
I must say, it was another nice flight with nice sightseeing, nice climb performance Big grin I just enjoyed it as usual...
Thats it guys! Hope you enjoyed reading it  Wink
WILCO737 (MD11F)
 airplane
RE: Pilots View, MD11F Oerk To Omsj
Tue Dec 18, 2007 11:15 am
Hi Wilco737,
Great to read another report from upfront!
10 tons is really light indeed! Do you now the load on the FRA-RUH stretch?
I thinkI must work a bit harder to give you some better loads  Smile But that will spoil your fun a bit  Smile
Gruss,
Joost ( D-ALCE )
wilco737
Tue Dec 18, 2007 11:22 am
Quoting DALCE (Reply 1):
It was a little over 40 tons, I think 43 or so! not too much as well, but usually on the westbound flights we have HUGE load! So when coming from PVG, ICN, NRT, CAN, HKG etc etc back to Europe then we are usually at 80+ tons load... But its still fun! not 7000ft/min climb then, but still nice!! Big grin
WILCO737 (MD11F)
{airplane]
airivoireA321
Tue Dec 18, 2007 1:37 pm
Quoting WILCO737 (Thread starter):
wow nice climb , when you have full load is it possible to have climb rate closed to the others above?
musapapaya
Hey WILCOMD11F,
Thanks for your great report! Thoroughly enjoyed what you wrote. FL410 for such a short flight seemed great, was it the optimum altitude? I so much want a MD11 to myself (on FS9) and try the 7000ft/min climb. The best I have on the 737-400 at FS9 was just 3000ft/min. LOL! You are great and thank you again for the report!
Best wishes and enjoy your next flights,
William
Lufthansa Group of Airlines
wilco737
Tue Dec 18, 2007 1:39 pm
Quoting AirivoireA321 (Reply 3):
No, not even close... I'd say you get average of 1500ft/min... sometimes maybe 3000ft/min for a short time but not more...
WILCO737 (MD11F)
 airplane
wilco737
Tue Dec 18, 2007 1:41 pm
Quoting Musapapaya (Reply 4):
Actually FL430 would've been the optimum altitude, but at that altitude one has to put on the oxygen mask! And we try to avoid it, its not very comfortable  Wink And FL410 is high enough  Wink
Glad that you enjoyed the TR...
There are add ons for FS9! An MD11F of LH Cargo and another KLM MD11 passenger version! Check at www.avsim.com or so! I cant remember where I got them from...
WILCO737 (MD11F)
 airplane
Great TR.
I really love your TRs.
To climb 7000ft/min seems to be really funny.
Keep your TRs coming, they are really interesting
B747forevver.
OHLHD
Tue Dec 18, 2007 1:47 pm
 banghead   bigthumbsup   rotfl  Fantastic Big grin Great memories come to mind while reading this. Big grin
This is what my friend at LH Cargo told me too. Not easy to handle if not fully loaded.  Smile
Interesting report, indeed!
wilco737
Quoting B747forever (Reply 7):
Yes, it is! thats my face always when I see 7000ft/min:  eyepopping   Big grin
WILCO737 (MD11F)
 airplane
OHLHD
Tue Dec 18, 2007 1:58 pm
Are you basically allowed to take a camera into the cockpit ( on the flight)?
Tue Dec 18, 2007 2:00 pm
Quoting WILCO737 (Reply 9):
LOL!!!
Quoting OHLHD (Reply 10):
Interesting question!!!
wilco737
Tue Dec 18, 2007 2:05 pm
Yes, I am! But it should make sense WHEN I take pics! of course NOT during take off or approach or landing... but during cruise flight and not much to do: why not?
WILCO737 (MD11F)
 airplane
OHLHD
Tue Dec 18, 2007 2:09 pm
Quoting WILCO737 (Reply 12):
why not?
I was thinking that there was some sort of rule about it. Why don't you get a little stativ and film your take-offs and landings? And a decent go-around Big grin
Tue Dec 18, 2007 2:16 pm
Yes, I am!
Could you take some pics and post them here , if you are allowed to have a camera??
wilco737
Tue Dec 18, 2007 2:17 pm
Quoting OHLHD (Reply 13):
I have such a small tripod... Filming my take offs and landings?! Maybe on one of my next flights I will try to take a pic of the vertical speed indicator to prove you guys the 7000ft/min Big grin A decent go around?! usually the go arounds come pretty surprising and arent planned  Wink So hard to film them!
WILCO737 (MD11F)
 airplane
OHLHD
Tue Dec 18, 2007 2:20 pm
Quoting WILCO737 (Reply 15):
A decent go around?! usually the go arounds come pretty surprising and arent planned So hard to film them!
So why don't you just... you know.... f%&k one up for us. Big grin  Big grin
No just kidding, I meant have the camera always in running mode during approach.  Smile
A friend of mine who is a captain used to do that on each and every landing until he filmed some 800 landings without a single go around so he decided it was about to stop and bingo..... the next flight... go around Big grin
wilco737
Tue Dec 18, 2007 2:24 pm
Quoting OHLHD (Reply 16):
 faint  that sucks hehe...
I will see what I can do on my next trips! same with the pics! Just taking a few and making another trip report then...
WILCO737 (MD11F)
 airplane
OHLHD
Tue Dec 18, 2007 2:26 pm
Quoting WILCO737 (Reply 17):
Great, OK have a nice evening. I need to catch my flight here at ARN. Hopefully no delays since I am up since 04:00 am.  Smile
Tue Dec 18, 2007 2:27 pm
LOL
OMG, that is so typical!!!
Great, looking forward fore that TRs.
wilco737
Tue Dec 18, 2007 2:30 pm
Quoting OHLHD (Reply 18):
Have a safe flight! I will head out to diner now Big grin YUMMY! Lets see what they offer here in SHJ!
WILCO737 (MD11F)
 airplane
sandrozrh
Tue Dec 18, 2007 3:07 pm
Hey Phil!
Nice read indeed, felt a bit as if I was there. Looking forward to more, and cant wait to write similiar reports myself Big grin
ag92
Tue Dec 18, 2007 4:14 pm
Great trip report. I can only dream of your position currently
Which airline do you fly for?
Ag92
LO231
Tue Dec 18, 2007 4:42 pm
Quoting Ag92 (Reply 22):
It's Lufthansa Cargo.
LO231
Got both LO 788 frames already, next LO E95 and 734 BRU-WAW-BRU
wilco737
Tue Dec 18, 2007 5:54 pm
Quoting LO231 (Reply 23):
See, I have an assistant who is replying for me now Big grin
But he is right  Wink
Quoting SandroZRH (Reply 21):
You will, just in a weird aircraft Big grin hehe
WILCO737 (MD11F)
 airplane
Vio
Tue Dec 18, 2007 7:04 pm
Very nice read! Are you allowed to take photos during flight, or is it company policy not to?
It'd be awesome if you could (obviously, when you can spare a few seconds)...
Vio
wilco737
Tue Dec 18, 2007 7:06 pm
Quoting Vio (Reply 25):
As I posted further up: I can take pictures during flight! but of course not during take off or landing or so...
And I see what I can do on my next flights to share some photos...
WILCO737 (MD11F)
 airplane
Vio
Tue Dec 18, 2007 7:28 pm
Quoting WILCO737 (Reply 26):
WILCO737 (MD11F)
Opps! I must've missed that post! Thanks so much. That would be awesome!!! I have a few trip reports on a.net myself (with lots of photos), but during landing / take-off I always have my passengers take photos. You're in a different possition though!
Vio
EireRock
Tue Dec 18, 2007 11:37 pm
Hi Wilco737, really enjoyed your TR and the fact that LH is one of my favourite airlines maks it all the more interesting.
Looking forward to the next one!
LO231
Tue Dec 18, 2007 11:48 pm
Quoting WILCO737 (Reply 24):
Invoice is on it's way, sir!
But he is right
I always am. Perfect assistant. Coffee?
LO231
wilco737
Wed Dec 19, 2007 6:04 am
Quoting LO231 (Reply 29):
But you need to be female to be the perfect assistant Big grin Coffee? No thanks, I dont drink coffee at all... Maybe the only pilot on this planet not drinking coffee Big grin
WILCO737 (MD11F)
 airplane
CO7e7
Wed Dec 19, 2007 8:35 am
Very well written report. I really enjoy reading pilot reports!
Thank you very much for posting and keep em coming......
musapapaya
Wed Dec 19, 2007 11:57 am
Quoting WILCO737 (Reply 30):
Out of curiosity what do you drink? Apparently you cant drink alcohol on the plane, might be tomato juice? Lemoade? Or might be I can be your assistant too?
Papaya
wilco737
Fri Dec 21, 2007 5:56 pm
Quoting Musapapaya (Reply 32):
Usually I only drink water and from time to time a small can of coke, and if we have: fresh orange juice Big grin and thats it  Wink
I am glad that you all enjoyed this TR... next will follow, WITH PICS Big grin And a go around  Wink
WILCO737 (MD11F)
 airplane
karan69
Fri Dec 21, 2007 6:26 pm
Hey Wilco great report mate, 7000F/min is incredible climb rate,
I have one question what is the route of the LH MD-11F to BOM--where does it come in from and where does it go and is the cargo as light as it was on this routing.
have you done the BOM route.
karan
OHLHD
Fri Dec 21, 2007 7:53 pm
Quoting WILCO737 (Reply 33):
And a go around
I have noted that Big grin
wilco737
Sat Dec 22, 2007 2:20 am
Quoting Karan69 (Reply 34):
Hey there,
I dont know  Wink Dont know where it is coming from and where it is going... Sorry, have never been to BOM yet... But I guess it is coming from FRA and is going further to the east, maybe BKK or something like that, but I dont know for sure... sorry
WILCO737 (MD11F)
 airplane
OHLHD
Sat Dec 22, 2007 2:41 am
Quoting WILCO737 (Reply 36):
I guess you are getting ready to fly?  Smile SHJ-FRA?
wilco737
Sat Dec 22, 2007 9:31 am
Quoting OHLHD (Reply 37):
I guess you are getting ready to fly? SHJ-FRA?
Oh no, I flew: SHJ-CCU-HKG-ALA and I am still in ALA flying back home tomorrow around noon, will be back in FRA around 6pm...
And the go around was in ALA because of too much tailwind on final... but you will hear more about on the next TR Big grin
WILCO737 (MD11F)
 airplane
Mon Dec 24, 2007 11:28 am
Nice TR Wilco737.
Get the SNY crew to hold the Camera on the next round.
You've ever operated to BOM & Back.
Cheers.
regds
MEL
LO231
Mon Dec 24, 2007 1:38 pm
Quoting HAWK21M (Reply 39):
Ahem, assistant here.
Good I've noticed, hey boss?  Wink
LO231
Tue Dec 25, 2007 10:05 am
Very nice written TR .
pitops
Sun Dec 30, 2007 3:30 pm
I would've loved to see some pics of Dubai. I've always wanted to go and visit there. So much interesting architecture and the tropical/ desert weather. Gotta love it.
Ground Ops, Southwest Airlines, CMH
Lp0815
Mon Dec 31, 2007 2:32 pm
Joost (D-ALCE),
am based out of SIN (F/G4) and yes, we could use some better loads on the east-bound flights into our area....
Was a duty-traveller on LH 8411 SIN-DEL-LEJ recently.
Big fun, including sitting in the cockpit for landing in LEJ.
Thanks for the crew to take me along and all the great explanations.
It's an interesting world up there!
Guten Rutsch, all together!
Lp0815
Time waits for nobody
Users browsing this forum: Google Feedfetcher, itismarkc, rockyracoon, stefanJ and 33 guests
