Joyrides Down Under Part 2: EK A380 Revisited
Fri Jan 08, 2010 10:03 am
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W8S9jdpUI/AAAAAAAADX4/0Nuc7xf-yXA/s800/IMG_5237edittitle.jpg
Joyride
Noun: A ride in a vehicle taken solely for pleasure
Verb: A ride in a vehicle with no particular goal and just for the pleasure of it
Ok, there seems to have been a small goal to my joyrides: that of trying out new aircraft and (hopefully) new airlines.
2 International flights.
8 Australian domestic flights, 3 airlines, 4 states, 5 types.
6 New Zealand domestic flights, 3 airlines, 2 islands, 3 types.
Welcome to my next series of Trip Reports. These flights over 3 weeks, summarised above, includes flights on Air New Zealand, Emirates, Qantas, Virgin Blue, Pacific Blue and Jetstar; takes me through New South Wales, Victoria, ACT, Queensland and New Zealand while travelling on 6 different types of planes. I hope you enjoy my journey around eastern Australia and also New Zealand. At the end of the final TR, I’ll write up a comparison between the domestic carriers in both New Zealand and Australia according to my personal experience with them.
If you missed the first TR of the series, here’s the link: Joyrides Down Under Part 1: Air NZ AKL-CHC-AKL (by NZ107 Dec 23 2009 in Trip Reports)
This TR will cover my AKL-SYD leg of the journey: my second flight on the EK A380, in Economy.
I couldn’t get enough of Emirates once I disembarked the first commercial A380 flight into New Zealand last February. It didn’t take long for the specials to start rolling in either. The Emirates website is very easy to use but the interesting thing is that they need you to provide valid passport details before they allow you to book. Luckily, my passport was still valid for a while so I booked this flight (for a bargain NZ$350 return) well in advance; in fact it wasn’t that long after my previous flight that I booked it! Apart from that, it is an easy website to navigate around. The other plus is the option to reserve your seat well in advance. If it’s not booked with Emirates, you’ll need to be a Skywards member to reserve a seat. On advice from other A.Net members, I decided to sit down the back for both flights and try it out. More details about this decision will be made clearer later.
I didn’t have much time to pack after arriving back from Christchurch the day before but managed to fit everything into the suitcase. Emirates have a very generous 30kg baggage limit for Economy – every gram was used wisely! Eventually the afternoon came around and it was time to head to the airport.
After driving myself to the airport, I found myself at the Emirates check in area. I was super early for the flight and there barely a queue. If you do happen to arrive at Auckland Airport flying Emirates about 2 hours before the flight, make sure you expect to stand in the queue for quite some time! That is, of course, if you don’t have Skywards Gold or Silver status (EK’s FF program); or aren’t flying First or Business. It was a breeze and it was interesting to note that I didn’t need to show anything other than my passport. Ten minutes later I was on my way, less one bag.
The Relatively Empty Check In Desks
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4UNB6eQI/AAAAAAAADOs/waH6n5dtr9E/s800/IMG_4997edit.jpg
Boarding Pass
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4VTxIDwI/AAAAAAAADOw/GA1Psownd58/s800/IMG_4998edit.jpg
FIDS
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4ZhfyT6I/AAAAAAAADO8/jWnZ3IdaQRc/s800/IMG_5003edit.jpg
Qantas/OneWorld Premium Check In Area
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4Wx7eYaI/AAAAAAAADO0/BpkAard5WKg/s800/IMG_4999edit.jpg
Check In Counters
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4YPjic9I/AAAAAAAADO4/06K_0UjtaB4/s800/IMG_5001edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4bLV5hOI/AAAAAAAADPA/ZdVWuTAMjhk/s800/IMG_5004edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4cOA1okI/AAAAAAAADPE/UobafyGYal8/s800/IMG_5006edit.jpg
Auckland Airport’s landside departure area in the international terminal has changed significantly over the last 7 months. There used to be many shops lining the walls leading to the security checkpoint. Now, a lot of those shops (including both main Duty Free stores) have disappeared in favour of a larger customs area and a larger airside duty free area (I’m assuming this will also grow in size) as you walk through towards the gate. I guess I won’t be going to the airport to have a nosy at what’s in the duty free stores anymore!
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W4dudBoEI/AAAAAAAADPI/KKNfbZZIeE0/s800/IMG_5007edit.jpg
Comparison Shot From January 2009(first image) With November 2009 (second image):
http://lh5.ggpht.com/_cYYIjMZbEQA/SYwfERjzuhI/AAAAAAAABYI/u-Ka5WkX0wU/s800/IMG_9562reformat2.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4fGeeO2I/AAAAAAAADPM/napV10UFj1c/s800/IMG_5008edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4iJKVSWI/AAAAAAAADPU/MM8qoN_DCgg/s800/IMG_5010edit.jpg
Spotting From The International Observation Deck:
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4jQWVYaI/AAAAAAAADPY/t6A-hmffoNw/s800/IMG_5012edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4ke7Y4tI/AAAAAAAADPc/GUKseYuii-s/s800/IMG_5014edit.jpg
Three Big Trans Tasman Rivals
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W4l6LwXAI/AAAAAAAADPg/QRsD2hnO1Cg/s800/IMG_5015edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4pZOTD4I/AAAAAAAADPs/KqOTxyGE3Xw/s800/IMG_5024edit.jpg
TG993 To BKK
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4nITy2JI/AAAAAAAADPk/UBhi5gX1J5Q/s800/IMG_5017edit.jpg
Air Calin Back To Noumea
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4oOBterI/AAAAAAAADPo/u1TYAHQW528/s800/IMG_5021edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W4qtFplqI/AAAAAAAADPw/traKABc_qeU/s800/IMG_5026edit.jpg
NZ105 To Sydney
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4r-o6sDI/AAAAAAAADP0/OeY1IZvPGqE/s800/IMG_5028edit.jpg
Any Idea What That Hatch Is Under The Door?
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W4s1yrIFI/AAAAAAAADP8/BPStZ-fZkl8/s800/IMG_5040edit.jpg
QF25 To LAX
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4uBhIJyI/AAAAAAAADQA/VV7CzbRkYX8/s800/IMG_5047edit.jpg
Being rated in the top ten best airports in the world by Skytrax (yes, whoever believes in their surveys), I was out to try and find what made AKL so great. Here it goes. Public transport – they have only just implemented a 24 hour public bus service to some place in South Auckland in which you can change to a bus which goes to the city (this is excluding the well established Airbus service direct to the city which is much nicer than the real public transport of Auckland). Extra effort would be required to get anywhere else, such as the North Shore or out west. No trains get anywhere close to the airport. Taxis are extremely expensive (Upward of NZ$60 to get into the city). Amenities – no free Wi-Fi - it’s only free to check the Auckland Airport website which I use when spotting sometimes. Ok, facilities are clean, I give them that. But you’d expect that from any good airport. Signs are quite clear. Maybe the lack of hoards of people makes it popular. Duty free shopping – the same worldwide where they push you right through/past the shops on the way to the gate. It beats me to guess why Auckland Airport is rated so highly. And apparently only ICN, HKG, SIN, ZRH, MUC, KIX, KUL, AMS and NGO are better than Auckland. I think I should check out more of these airports before making a valid conclusion but it is by no means near the class of Hong Kong.
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4gqJijzI/AAAAAAAADPQ/FM8KVgvzYY0/s800/IMG_5009edit.jpg
Lines were rather long for passing through immigration and also for the security screening but once through that, it was easy going. Last time I didn’t give myself long enough to explore the new pier but this time was slightly different. I probably had too long there this time! It’s quite bare actually, there is only a little bookstore and some toilets down the pier. But I guess it doesn’t see the bulk of the traffic anyway. The original pier itself after the duty free shops hasn’t changed a bit.
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4-zPaj5I/AAAAAAAADQw/Qp0ff4gVbSY/s800/IMG_5079edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4yEbQmPI/AAAAAAAADQI/iD4wRjAo1g0/s800/IMG_5062edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W4zD9hRUI/AAAAAAAADQM/5oTy0oCPRwU/s800/IMG_5063edit.jpg
On The Main Pier
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W4xGGEsyI/AAAAAAAADQE/YXdwY3ASjS4/s800/IMG_5060edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W40usANiI/AAAAAAAADQU/dMi5vGd-u6Q/s800/IMG_5064edit.jpg
EK435 To BNE DXB
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W43d_ksfI/AAAAAAAADQY/Z-OV7ZIBEag/s800/IMG_5067edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W44Z9w_aI/AAAAAAAADQc/8yTEbcw3mS0/s800/IMG_5070edit.jpg
EK 407 To MEL DXB
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5ByKHmPI/AAAAAAAADQ0/P7gCrN3sXtg/s800/IMG_5083edit.jpg
Smartgate is a new passport clearance system for those with NZ or Australian chipped passports. It allows you to clear customs by a machine scanning your face and seeing if it matches with that of your passport photo. There is a kiosk set up in Auckland which allows you to walk straight up to the machine without having to get your passport out at the other end.
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W47znzSkI/AAAAAAAADQo/lALQc1sdQEQ/s800/IMG_5076edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W49VRHDRI/AAAAAAAADQs/TDIjSI74KxY/s800/IMG_5078edit.jpg
I made it to the end of the pier – Gate 16 – the gate where today’s A380 was sitting and waiting to head back to Sydney and Dubai. Boarding time on the boarding pass was 1800 and there weren’t any signs that boarding would take place soon. No gate agents were present. No announcements about what was going on. There were far too few seats for the number of passengers due to fly out that evening.
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5Cvm6FTI/AAAAAAAADQ4/5nOIsGRv8tg/s800/IMG_5084edit.jpg
Again, So Many Air NZ Planes
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5Dp9PJYI/AAAAAAAADQ8/eC0hfmlkIvQ/s800/IMG_5085edit.jpg
A6-EDC, Operating EK413 To SYD DXB
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5Ero6IKI/AAAAAAAADRA/2e0zw4g5TE4/s800/IMG_5089edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5FYHq6TI/AAAAAAAADRE/4x6moQbVlhQ/s800/IMG_5092edit.jpg
The new pier is one of the most environmentally friendly buildings in New Zealand. It has solar panels and collects rainwater for use in toilets.
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5GgWTWhI/AAAAAAAADRI/Lhhhjl0IeTc/s800/IMG_5094edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5HyeoBNI/AAAAAAAADRM/YaPdX5Xx1oI/s800/IMG_5095edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5IppmH0I/AAAAAAAADRU/2W9Y_KKP384/s800/IMG_5096edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5J3yTTXI/AAAAAAAADRY/ryeS8kLmubY/s800/IMG_5097edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5K0x-7qI/AAAAAAAADRc/STvW4TA0QRU/s800/IMG_5098edit.jpg
Tonnes Of Room, Lack Of Seats
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5MLQbXqI/AAAAAAAADRg/36UedH35lt8/s800/IMG_5099edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5NAS_NnI/AAAAAAAADRk/S8nixp-zWJI/s800/IMG_5100edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5ObNW4yI/AAAAAAAADRo/AfyHr7vevRg/s800/IMG_5107edit.jpg
Nice Pictures On The Wall
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5PcgJq9I/AAAAAAAADRs/T7AQS5s7Nt0/s800/IMG_5109edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5Qqf0c9I/AAAAAAAADRw/2nUMz7OfR2Q/s800/IMG_5110edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5RvaFklI/AAAAAAAADR0/iC7OEgPiD4M/s800/IMG_5111edit.jpg
Flight Information
19 Nov 2009
Routing: Auckland – Sydney (AKL-SYD)
Airline: Emirates
Flight: EK413
Scheduled Time of Departure: 1845hrs
Actual Departure: 1909hrs (pushback), 1931hrs (rotate)
Scheduled Time of Arrival: 2005hrs
Touchdown: 2032hrs
Flight time: 3hr 23 min
Aircraft: Airbus A380-861
Registration: A6-EDC
Seat: 74K
A6-EDC is Emirates’ 3rd A380-800. It was delivered on the 15th November 2008, making it just over a year old when I flew on it. All EK A380s use Engine Alliance GP-7200 engines.
Photo © Sam Chui
Photo © Sam Chui
Photo © Mark H
Photo © Kavin Kowsari
Photo © Sarmad Al-Khozaie
Photo © Dmytro Myrnyy
Plenty of people were waiting around the gate and it seemed like forever before the first boarding call was made. It was made about 20 minutes after scheduled boarding time which surprised me considering the A380 lays over in AKL for a good 4 and a half hours. Maybe there was a delay in the crew getting to the airport or something but it didn’t seem right to have such a delay. I eventually joined the long Economy line to board but because there were no F or J passengers around, a lot of people were ushered over to the F and J boarding machines. Down the long corridor we went. There’s one side for Economy which leads to an air bridge direct to the front door on the main deck and the other side is for First and Business passengers leading to the first door on the upper deck. A whole stash of newspapers, The New Zealand Herald (Auckland’s daily paper) to be exact, were on a stand just outside the door. No wonder why so few people had taken them – it was the end of the day already.
Queuing Up To Board
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5SqYz5_I/AAAAAAAADR4/WjiZ0P4dmE4/s800/IMG_5112edit.jpg
Down The Economy Side Of The Air Bridge
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5T0S_xVI/AAAAAAAADR8/jX4N_Dpw2Ec/s800/IMG_5113edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5VJ0g8PI/AAAAAAAADSA/3kp_OX53a-g/s800/IMG_5115edit.jpg
And so I stepped into the A380 for the second time. I must admit it didn’t feel as special as the first time. I was welcomed on board by one of the stewards upon presentation of my boarding pass: “Welcome aboard, Mr. Young, your seat is the window seat on the far side”. It’s always nice to get personal welcomes as you board the plane. I don’t think I get quite enough of that  Wink It does make you feel a bit more special than “just one of those 300 odd Economy passengers”. I made my way down towards the back of the plane, taking pictures as I went until I finally came to my row – 74 – situated in the middle of the 3rd Economy section on the lower deck. I took my window seat with someone already sitting in the aisle seat. I was surprised that EK hadn’t got rid of their in flight magazines yet – it was something that they said they were going to do to save weight. The IFE book is very thick as well. The windows – yes, I had kind of forgotten how hard it was to take pictures or see out of them. But I got a firm reminder of it when I sat down. It’s positioned rather high as well in comparison to other windows – much like the 737 vs A320 where the 737 window is lower than the A320. Maybe that’s just my experience from the airlines that I’ve been on. There is plenty of reflection from inside the cabin and it is definitely not photographer friendly by any means of the imagination. Below is a guide to how big it is, in comparison to my Nokia E63. I came up with that idea to show window sizes using a scale but I just never remembered on my other flights. One other thing that people don’t like about the A380 is the fact that the wall curves and is so far away from the seat. It’s very uncomfortable to lean against the wall and another few photos below show this.
Stairway To Heaven
First Section Of Economy
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5X1_BvEI/AAAAAAAADSI/Me5kJmraagc/s800/IMG_5117edit.jpg
My Row
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5aF4qqwI/AAAAAAAADSQ/CiN9qJM3JdM/s800/IMG_5120edit.jpg
View
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5cA3mKRI/AAAAAAAADSY/qrFLf8suscA/s800/IMG_5122edit.jpg
Distance Between Wall And Seat
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5dHoemTI/AAAAAAAADSc/sGemKceYgdA/s800/IMG_5123edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5fLf5UII/AAAAAAAADSk/hV93M0xgzbg/s800/IMG_5125edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5h8ZeBXI/AAAAAAAADSw/9lGjNhiRCYg/s800/IMG_5129edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5i1YR1UI/AAAAAAAADS0/ri7PXHHnzbw/s800/IMG_5130edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5mBAl1ZI/AAAAAAAADTA/03R6e4BxT3g/s800/IMG_5132edit.jpg
Emirates, like all other A380 carriers, have their Economy Class configuration on the lower deck in 10 abreast, 3-4-3 layout. The seat wasn’t too bad but I retract my comment in the other TR about the seats being soft. But they weren’t too hard either however it’ll take a long haul flight for me to figure out if it’s entirely comfortable. Though, in saying that, it is a very nice seat for a 3 hour journey. The table is nice and folded to allow more room for the PTV and remote. The cabin is very spacious, although it must be that much better in the premium classes. They still do quite a good job in taking away most of the claustrophobic atmosphere. The ceilings are high and it doesn’t seem like there’s another level on top of you. There’s plenty of space to stand up in the seat.
Recline
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5368SqEI/AAAAAAAADUU/eksuX8RtYlQ/s800/IMG_5170edit.jpg
There is a power socket in every arm rest apart from the ones on the aisles and those on the walls. So it means 2 for the 3 people sitting on the side of the plane.
Power Socket
Thankfully, nobody came down to sit in between us so there was plenty of space to stretch out. I had a chat to him about various things including planes and he seemed quite interested in the mood lighting! It took just over 40 minutes from when I boarded the plane to when we pushed back. Hot towels were passed around the cabin and recollected just before pushback. The pilot came on over the PA and announced the various details about our flight, expecting the flight time to be 2 hrs 50 min, cruising at an altitude of 40,000ft. He also announced the languages which the flight attendants spoke – all sixteen of them! I couldn’t believe it when he said sixteen. Included of course were: English, Spanish, French, German, Italian, Portuguese, Arabic and Mandarin. That is one very extensive list and I’d say it would be hard to surpass. And this is only for the AKL-SYD flight with quite a few people like me only travelling as far as Australia! It wasn’t long until we were moving under our own power. The taxi took us past all the buildings (on the other side of the plane to where I was) right to the base of Runway 23L. There were a few movements in the moments prior to us holding short of Alpha 1.
Safety Demo
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5nTn-2NI/AAAAAAAADTE/MPXE8g9vyvo/s800/IMG_5134edit.jpg
Pushback
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5oP4MAEI/AAAAAAAADTI/8Ayqhzp5Qnc/s800/IMG_5135edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5ol8Wl5I/AAAAAAAADTM/NmYpQKOlBn8/s800/IMG_5136edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5ph46kvI/AAAAAAAADTQ/Fqa6_AbZkK8/s800/IMG_5139edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5qcJKkNI/AAAAAAAADTU/ABzNywXn4b0/s800/IMG_5140edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W5rAZ6dLI/AAAAAAAADTY/9lFnVuqjlSA/s800/IMG_5141edit.jpg
Alpha Taxiway And Unused 23R/05L Runway
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5r_85G_I/AAAAAAAADTc/Ttle1auiGzo/s800/IMG_5142edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5suRn-VI/AAAAAAAADTg/ZYRj8s9HK64/s800/IMG_5143edit.jpg
Two TV Screens Setup For Departure
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5tyd2KUI/AAAAAAAADTo/bZSuEvD5UdY/s800/IMG_5144edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5wtlOZpI/AAAAAAAADT0/FmI6MjvUskk/s800/IMG_5150edit.jpg
Holding Short
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5xjGqrsI/AAAAAAAADT4/JIsXlK3QRdk/s800/IMG_5153edit.jpg
We held short at Alpha 1 and waited for the last NZ 733 in the queue to depart. The soft whine of the EK A380’s EA engines signalled the spooling up and our imminent departure from Auckland. Late in doing so, however, at least we were on our way. Rotation occurred around the International terminal meaning we used up about 2/3 of the 3635m long runway. The wing flex is pretty cool as well although no way near as noticeable as the 787 – isn’t that going to be a thrill to fly in! I was surprised at how quickly the flaps were retracted. We were barely 2 minutes into the flight. We turned slightly towards the north and en route for Sydney. And about the same, the Emirates “information” programme started playing. Too bad it can’t be disabled because it takes out quite a lot of time out of such a short flight! I just want to get onto doing what I want on the system like looking at the cameras and watching the airshow. 15 minutes into the flight, the menu and arrival cards were distributed. It’s nice of EK to still provide menus in Economy.
Lining Up Runway 23L
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W5ySY6RiI/AAAAAAAADT8/ZMvCe-xZ70Y/s800/IMG_5154edit.jpg
Power Away!
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W5zK-0mYI/AAAAAAAADUA/L8fcXH-Mov8/s800/IMG_5156edit.jpg
NZ 6 To LAX
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W50DIsjkI/AAAAAAAADUE/y_ulryHHIuc/s800/IMG_5157edit.jpg
Rotate! With International Pier In The Background: AR A342, NZ Planes
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W502O7RhI/AAAAAAAADUI/k-XhSOh9Y1Y/s800/IMG_5160edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W51gCzs9I/AAAAAAAADUM/4pIirhXGfFA/s800/IMG_5161edit.jpg
The Auckland Isthmus
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W52hzF-GI/AAAAAAAADUQ/l2WtBOawyhE/s800/IMG_5165edit.jpg
Levelling Off
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W55ami3LI/AAAAAAAADUc/d6KeWjV-qYE/s800/IMG_5173edit.jpg
The entertainment system, ICE, has been covered in detail by many and also by me in my other report on the A380 so I have decided not to do a complete overview again so if you have missed my other TR on the A380, the link is provided at the end of the TR. One thing I had missed out on however was the ability to view your own photos using the USB port next to the screen in front of you. I was shooting in RAW so I had to create a JPEG file to be able to view it. PDFs and music can also be played on the system. But the main function I like about the IFE is definitely the Airshow and the cameras situated in the tail, nose; and the camera looking straight down (the last one is very boring to watch when crossing the ocean!)
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W56fSAmQI/AAAAAAAADUg/urSD80ey8nA/s800/IMG_5177edit.jpg
USB Use
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5-mzTGmI/AAAAAAAADU0/v4m8Stm6H2E/s800/IMG_5187edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W5_o6fr7I/AAAAAAAADU4/deZ-qMjJEM4/s800/IMG_5189edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6Aox3pqI/AAAAAAAADU8/G218L6CbtnA/s800/IMG_5190edit.jpg
I Can See Through To The Next Seat!  Wink
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6BvCy_uI/AAAAAAAADVA/2JcFHXtkGJA/s800/IMG_5191edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6DHvWZ8I/AAAAAAAADVE/DpgEi_2IBbc/s800/IMG_5192edit.jpg
Airshow
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W6EEpL6HI/AAAAAAAADVM/LjfVgVBEpog/s800/IMG_5193edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W6FFGD5iI/AAAAAAAADVQ/sF-4ww4su8c/s800/IMG_5194edit.jpg
Fifty minutes into the flight, the meal service came to me in the third section. The choices (also shown in the following pictures) were honey baked ginger chicken with rice and stir fried vegetables or grilled lamb medallions with thyme jus, oven- roasted parsnip, carrot, broccoli and sautéed potato cubes. Because we were in the third cabin (quite a long way down), the most popular choice had already run out – that of the lamb. We were told it would be a 20 minute wait if we did want to take lamb. I was really hungry by then so I gave up on the lamb and took a chicken. People around me were asking for the lamb and in the end I believe they ran out of that too and so some people had to settle for the chicken anyway. It was quite a nice meal although there wasn’t enough rice to go with the main and the chicken was a bit on the salty side. The dessert – sticky date pudding – was delicious and I wish they gave bigger portions. Strangely enough, the drinks weren’t following the dinner service closely enough. I was too hungry to wait around to have a drink with my meal so I ate it all. I think most people around me were long finished as well by the time the drinks cart came around. Twenty nine minutes later, yes I repeat, nearly half an hour later, the drinks cart finally arrived beside my row. I had finished my meal a good 10 minutes prior and definitely needed something more than the 200ml package of water to wash down both the salty chicken and the sweet pudding. This type of wait shouldn’t be necessary. I ordered a coke and a red wine. The red wine wasn’t too bad, a bit on the dry side but I do think that taste buds are affected by the high altitude. And the coke, like usual, came in the cute little cans.
Menu
Today’s Selection
SYD-DXB Part
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W583N3-II/AAAAAAAADUs/igz-tMwMyNQ/s800/IMG_5182edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W59dvN1eI/AAAAAAAADUw/BGajo3rYZnw/s800/IMG_5183edit.jpg
Dinner
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6G4Py-0I/AAAAAAAADVU/-5hYMsb9M4Y/s800/IMG_5196edit.jpg
The Waiting For The Drinks Continues
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6H1nTnyI/AAAAAAAADVY/mpHEIwkey80/s800/IMG_5197edit.jpg
Nice Sunset While Eating
Is That Drink I See?
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W6J33ooNI/AAAAAAAADVg/1Mz-Z2h75PU/s800/IMG_5203edit.jpg
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6LPCawII/AAAAAAAADVk/MTBFKf3xRmU/s800/IMG_5205edit.jpg
Cleaning Up
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6MSDL0EI/AAAAAAAADVo/Oe5XC31UIvk/s800/IMG_5208edit.jpg
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6M1vhYoI/AAAAAAAADVs/SFSr11LQ_pM/s800/IMG_5209edit.jpg
There was one more thing that annoyed me during the flight. The call button was faulty on my seat and it kept on going off randomly. The good thing was that they were quick to answer it whenever it went off until most of the ones serving my area came to my side for me to tell them that there was something wrong. I’m glad that I could have got a drink at nearly any stage of the flight however! I seriously wouldn’t have liked to carry on to Dubai with that problem. It also seems that a fellow A.Netter, Foxecho, travelled on EDC but a row behind where I was sitting a few months before I took my flight and the FA call button was malfunctioning then as well. I wouldn’t have a clue about how long something like that would take to fix but with tight schedules for the A380, I don’t think it’ll be fixed anytime soon. Someone else about 3 rows in front of me had the same problem too.
After the meal trays were cleared up, I decided to have a wander around the cabin. First of all, I checked to see if I could pay a visit to my favourite Economy Class toilet. I got down to the front of the plane and to my anguish, the stairs to that particular toilet and the cockpit were roped off! It now has a sticker saying “Cabin Crew Only” on it. It’s such a disappointment that they took away the right for passengers to use this toilet but the crew must feel happy that they get such a big toilet to use. I had a wide angle lens too on this trip, ready to show everyone the size in one picture but it wasn’t to be. I had to settle for another toilet which was much, much smaller than the roped off one.
Over Wing View
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6NV0BxGI/AAAAAAAADVw/ysp1ZWLuL9s/s800/IMG_5211edit.jpg
Second Section
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6QN6ky0I/AAAAAAAADV0/7M2UIdiFFxQ/s800/IMG_5213edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6XD-JNPI/AAAAAAAADWI/vJkgJ2Kjj1E/s800/IMG_5223edit.jpg
One Day, First Class!
No! The Biggest Toilet Now Out Of Bounds!
Another Toilet
First Section
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6Vo3asnI/AAAAAAAADWE/AOhtNNEa4BY/s800/IMG_5222edit.jpg
Back Section
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6YG1EljI/AAAAAAAADWM/hFA9c4in5dk/s800/IMG_5224edit.jpg
I returned to my seat after a rather brief stroll up and down the aircraft.
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6ZB-K6vI/AAAAAAAADWQ/nqFCFB3V-z8/s800/IMG_5225edit.jpg
Mood lighting is one great invention. I enjoyed watching the colour changes occur and I was lucky to see ‘stars’ appearing in the form of LEDs in the ceiling just before the cabin lights were brightened for disembarking. Here’s a run through of “sunset” according to the mood lighting:
Orange Stage
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6ZyJeKDI/AAAAAAAADWU/aeG-O4qmqVI/s800/IMG_5227edit.jpg
Part Pink Stage
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6bNgp9qI/AAAAAAAADWY/qh3fNzBWogw/s800/IMG_5233edit.jpg
THAT Call Button
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6cGpFyTI/AAAAAAAADWc/Va2gX0hhS04/s800/IMG_5234edit.jpg
Purple And Fading Orange
http:</div>
									<div id=It's all about the destination AND the journey.
RE: Joyrides Down Under Part 2: EK A380 Revisited
Continued here:
Blue Stage
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6iAgBN4I/AAAAAAAADW4/aYxUP0E8aE8/s800/IMG_5247edit.jpg
Eventually it was time for descent. It was nigh on complete darkness in Sydney. It was a very smooth landing, one expected by the A380 in calm conditions. We stopped quite quickly and soon taxied for Gate 57, ending a pleasant, but slightly flawed journey across the Tasman. We docked half an hour behind schedule due to the late departure but we made up about 15 minutes in flight.
Closing In On Sydney
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6dOpE-3I/AAAAAAAADWg/0YP9AbKVmfE/s800/IMG_5235edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6gG8xk0I/AAAAAAAADWs/qcezx7hv-JM/s800/IMG_5245edit.jpg
Funny Kink In The Flight Path, Any Idea Why?
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6hCkWvuI/AAAAAAAADW0/LUEjwwV6z_E/s800/IMG_5246edit.jpg
The Line Didn’t Follow Us! Lining Up Runway 34L
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6iyeS0cI/AAAAAAAADW8/7X9trELEa1o/s800/IMG_5256edit.jpg
Short Final
http://lh4.ggpht.com/_cYYIjMZbEQA/S0W6j_SHi0I/AAAAAAAADXA/LR3-YfP6Jqc/s800/IMG_5259edit.jpg
Touchdown
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6k2WRKxI/AAAAAAAADXE/NcSstgpy0hQ/s800/IMG_5263edit.jpg
Disembarking this massive plane from the back takes a while. It does surprise me how many people decide to stand up, especially so far back because surely they’d know that they’d have to wait about 10 more minutes before they would move. I just took in the limited view of a QF A332 and an Air NZ A320 while I waited for the front sections to clear out. And eventually I made it off the plane and onto Australian soil. There was a seemingly long walk through the duty free area to Customs where I entered that card I was issued with at Auckland into the face scanner machine. The gates opened, I took the card back and away I was to collect my luggage. Because I was so quick to get through, the bags had barely started trickling out onto the carousel. It might have been just as quick standing in the line to see a person and also to get another stamp in the passport! It’s going to be boring for kids who only travel to Australia from New Zealand as there won’t be any stamps for them to collect in their passport! The card I took back from the face scanner machine was handed to the quarantine official who sent me straight out the door although I had declared some food that wouldn’t be confiscated. What a great end to the trip!
Familiar Sights
http://lh6.ggpht.com/_cYYIjMZbEQA/S0W6mFkQqbI/AAAAAAAADXI/_t33UsIX9y8/s800/IMG_5269edit.jpg
http://lh5.ggpht.com/_cYYIjMZbEQA/S0W6pXfiZYI/AAAAAAAADXU/wTtN-uRlk4c/s800/IMG_5273edit.jpg
http://lh3.ggpht.com/_cYYIjMZbEQA/S0W6qRUMnyI/AAAAAAAADXY/SU8svm5DAv4/s800/IMG_5274edit.jpg
That sums up my second experience on the A380. I thank you for getting this far and I do appreciate those who have spent time reading this very long thing. The flight was full of mixed feelings about the service but what they provided was nothing less than decent. I should be trying out new aircraft on my next trans Tasman flight though!
Soon I’ll be onto writing my next report: SYD-OOL-MEL-SYD on DJ, JQ and QF so keep an eye out for that one!
The link to this TR’s album can be found here: http://picasaweb.google.com/bogey.nz/TRAKLSYDEK412EmiratesRevisited
Search a little deeper and you’ll find other pictures of other TRs.
Previous Trip Reports: Grabbing A Seat With Air NZ Part 1/2: AKL-ZQN-AKL (by NZ107 Dec 1 2008 in Trip Reports) Grabbing A Seat With Air NZ Part 2/2: AKL-NPE-AKL (by NZ107 Dec 22 2008 in Trip Reports) Air New Zealand: NZ105 AKL-SYD Economy (by NZ107 Feb 6 2009 in Trip Reports) A Whale Of A Time: Emirates A380 Inaugural SYD-AKL (by NZ107 Feb 15 2009 in Trip Reports) NZ Domestic Competition: Part 1 Air NZ AKL-WLG-AKL (by NZ107 Jun 24 2009 in Trip Reports) NZ Domestic Competition: Part 2 JQ/DJ AKL (by NZ107 Jul 23 2009 in Trip Reports) Joyrides Down Under Part 1: Air NZ AKL-CHC-AKL (by NZ107 Dec 23 2009 in Trip Reports)
Fri Jan 08, 2010 10:40 am
Hi Nicholas,
Thank you for this very well detailed trip report from NZ to Australia. It really cheers me up to enjoy the summer sceneries you have beautifully captured over there while facing myself a severe cold in the the icing cold Holland.
What a difference! I do however prefer the airy feeling out of the second image.
Too bad, that is limited to NZ or Australian passport holders. It would be less hassle to expand it to let say European chipped passports.
Are you sure there were no Dutchies around?  wink
Another Toilet
Still look great with the wooden interior.
Thanks again for sharing.
gardermoen
Fri Jan 08, 2010 10:42 am
Hi.
Fab report and great detailed pictures. A + !!
AKL seems to have spruced itself up big tine since I was there last in 2007, good for them.
A shame the new pier at AKL lacks sufficient seating, I really hope they address the issue.
Fri Jan 08, 2010 12:43 pm
Hi Nicholas,
Another superb trip, excellent pictures too!
AKL looks like a pretty nice airport, I'd sure like to visit and do some spotting from the deck one day - have to agree there are too few seats in that waiting area though!
- Yes, they made a big thing about this before teh 1st service, suprised they are still there.
- It is, kind of gives you a little something, though I though these might have been done via the IFE system by now.
- This is a pet hate of mine. I too like to have a drink with my meal, sometimes I wait for the drinks to arrive but the meal is getting quite cold by then and I feel like a pratt for sitting with meal and doing nothing with it.
Quoting NZ107 (Reply 1):
- Great, look forward to the repots when they are on-line.
Best Wishes
TR1
Fri Jan 08, 2010 1:18 pm
NIcholas,
Fabulous report. I can't wait for the opportunity to experience this aircraft.
Interesting comment about the drinks service. The inability of the drinks cart to closely follow the meal cart was one (but not the only) reason why we now have a selection of drinks on top of the meal carts in our international economy service on the NW side of Delta. Granted its not a complete selection but it beats having to wait another 10-20 minutes for the cart. Whether or not this continues remains to be seen, however.
Looking forward to the next report.
DLATL777
Fri Jan 08, 2010 8:36 pm
Thanks for the report; may I ask what camera you use?
Fri Jan 08, 2010 9:35 pm
Hey, Nicholas,
once again a very detailed and good-to-read story.
Never been on the A380 myself, so something more interesting to follow you´re
point of view.
EK doing well also here, so it seems.
Looking for the next part now.
Greetings from snow covered southern Germany,
airpearl
Sat Jan 09, 2010 12:19 am
Hi Nicholas
Thanks for this report, a very nice part 2 to your latest series. Great details, excellent pictures! I especially enjoy the spotting pictures from New Zealand, perhaps it's the light that make even relatively mundane liveries stand out at AKL airport  Smile
Is this a new facility? I somehow only remember the premium NZ check-ins with private 'fast track' immigration clearance. Does QF have the same?
You're pretty harsh on your home airport  Wink Granted it may not have the design and architectural excesses of many of the others listed by Skytrax (yes, I agree that's questionable for a start), but it's quite a nice facility and, perhaps most importantly for me, has great close-up views of the tarmac and traffic. So it's aces in my book.
That's interesting. Quite a contrast to my experience at BKK. I was surprised at how early EK was boarding its A380: Y class more than 1 hour before departure, on a 2h30 min turnaround.
Often times, I don't hope for much in Y class. If I get an empty seat next to me, I'm as happy as a lark.
That's not great at all. I would have expected better of EK.
First Section
Back Section
Having toured the plane and been on EK's A380 twice now, is there a section you would recommend/prefer in Y?
Thanks again for this wonderful report.
airpearl
Sat Jan 09, 2010 3:17 am
Great report. Always nice to see the A380 TRs
Nothing unusual about that with 24 cabin crew on the A380! Emirates as you know hires from all over the world, so there is bound to be at least one from a specific country. And here is the statement of 30 crew (total in all) by an Emirates crew member himself
http://clauderic.blogspot.com/2009/12/time-goes-by-so.html
They wouldn't just have English only or Aussie crews for the Australia-New Zealand-Australia run, It's the same crew that originate from Dubai, have a 2-3 day layover in Australia and then a 24 hour in New Zealand, before staying again in Australia and finally back to Dubai.
Sat Jan 09, 2010 8:34 am
Hi Nicholas,
excellent report with many stunning pictures, enjoyed reading a lot. A380 reports are still something special.
Nice, I like that, too.
Indeed, one of the major negative aspects when travelling on the Whale.
Good shot, shows well another negative aspect.
Another nice shot!
Oh no, EK and the lamb, the neverending story...
Too bad that this still hasn't been improved yet, quite annoying actually.
Interesting issue. They should really fix that problem.
Bedo
Sat Jan 09, 2010 11:42 am
Hi Nicholas!!
What a great breakfast that i had reading you!!!
I flew the A6-EDE last November, DXB to LHR, it was a great flight with a great product from EK.
It might have been just as quick standing in the line to see a person and also to get another stamp in the passport! It's going to be boring for kids who only travel to Australia from New Zealand as there won't be any stamps for them to collect in their passport!
This is what we have in Europe, you have to get out the continent to get an stamp on your passport.
Quoting Flightsimboy (Reply 9):
http://lh5.ggpht.com/_cYYIjMZbEQA/S0.../1Mz-Z2h75PU/s800/IMG_5203edit.jpg
What about the wine?? It's an Spanish wine.
The four times that i flew EK never had the coincidence with spanish talking stewardess.
Thank you Nicholas, I'll be waiting the next joyride!!
bedo
Sun Jan 10, 2010 12:45 pm
Hi everyone,
Thanks for all of your comments!
Quoting Akhmad (Reply 2):
Hi Suryo,
Thanks for your feedback! I'm glad to have cheered you up - I can't even imagine being in Europe right now.. I have a few friends over in Europe at the moment too! Maybe the other pictures from SYD will thaw you out.. It got to 43 on one of the days I was over there.
What a difference indeed! I never thought that the area could be changed so dramatically but it feels like a completely new airport from where I took the photos from.
I'm sure New Zealand might start doing similar things but with Australia, you'll need a visa to get in and that may complicate things if some people are allowed to use the chip to enter and others aren't. Because once NZ and Australia introduce a single aviation market (SAM), there won't be a need for passports when travelling across the Tasman and all that technology brought in to speed up trans Tasman processing won't be needed. There must be some use for it afterwards!
Haha. I can't recall all of them but I wish I could have recorded the PA because it was so interesting hearing so many languages!
Quoting Gardermoen (Reply 3):
Hi Gardermoen,
Thanks for your comments! Yes, as I mentioned above, AKL has done a bit of renovations. 2007 was a while ago now that I think about it and the new pier which houses the A380 wouldn't have been close to existence.
Quoting BA319-131 (Reply 4):
Hi Mark,
Thanks for your comments, glad you enjoyed it! I hope you're surviving the winter!
It'd be great if you could make it down here some day! It is a nice airport though. And another pro about it is probably the size - you aren't walking/travelling for miles on end to reach your gate.
I really wonder if it's still on the agenda to be canned..
Indeed, with a system like ICE, such a thing shouldn't be too hard to do!
I'd be surprised if you could hold out for 30 minutes if you were as hungry as I was on that particular evening!
Quoting TR1 (Reply 5):
Hi TR1,
Thanks for your comments. It seems strange how on the other two flights on EK (one more TR coming near the end of the series) and on other airlines the drinks cart is quite close behind the meal one.
Quoting DLATL777 (Reply 6):
Not a problem, DLATL777.
I use a Canon EOS400D (or in US terms, the Rebel XTi) with an 18-55mm IS, 70-300mm IS USM and I borrowed a 10-22mm lens from my friend.
Quoting FLIEGER67 (Reply 7):
Never been on the A380 myself, so something more interesting to follow you´re point of view.
Hi Markus, greetings from the balmy subtropical warmth of Auckland! If I were where you are right now, I'd be so envious of the warm weather on the other side of the world!
Glad you enjoyed it, thanks for commenting! With all that flying you did in those small planes, it's time you upgraded to something like a whale
It is a peak season to travel in down here so I don't think there are too many surprises. EK also manage to keep prices down and are usually cheaper than NZ and QF on average. No business people who travel trans Tasman would use EK as the timing is really bad. I'd also assume quite a few people go all the way onto Europe too. Sometimes they get less than 100 onboard - this occurred quite frequently in 2009 I think but it's still cheaper than keeping it parked up in Sydney for that period of time.
Quoting Airpearl (Reply 8):
Hi Airpearl,
Thanks for your comments! You'll be glad to know that there are 2 more New Zealand domestic TRs coming up at the end of this series and I hope some of the pictures I took in Queenstown will further entice you to come down here!
Been there for a while, at least 10 years by memory. It's just sitting at the other end of the original check in counters - the EK area is an extension to the international terminal completed some time around 2004. When I went to HKG in CX Business in 2005, I used the 'fast track' immigration clearance. So that answers your question - QF does have the same but there is no direct link to the lounge as I believe NZ has this. There's a small booth inside that check in area which is operated sometimes (could be occupied more frequently now) which gives you pre clearance to basically go straight through to the security checkpoint. Emirates has also got a pre clearance desk now - available for F, J, Skywards Gold and Skywards Silver passengers.
You're pretty harsh on your home airport Granted it may not have the design and architectural excesses of many of the others listed by Skytrax (yes, I agree that's questionable for a start), but it's quite a nice facility and, perhaps most importantly for me, has great close-up views of the tarmac and traffic. So it's aces in my book.
Haha, yeah, possibly a bit harsh. I think I'll come to respect it fully once I experience a few more airports! I wish it had a better view of the tarmac though. They brought in pier separation only a few years ago and that allowed a view over both sides of the main pier. That was built and blocked any view of the other side of the pier. Not only that but all flights to the US depart from the far end and can't be seen very well from landside. And the new pier.. Well, that's just too far away!
That's what I would have expected on my flight! Too bad there were a few things that went wrong on my flight.
So was I. But I'm glad that there was no repeat the second time around.
I'd definitely recommend the front two sections. If you were wanting to take photos out of the window, getting in front of the wing would be good for starters and you can do that by being in either the first section or the first 3 rows of the second. I liked the seat I originally chose for my flight last February because you don't have the queues for the toilet like you might in the first section (although there is a big area where you can wait around in) and your meal service would be relatively quick along with getting the meal that you actually want to eat. I haven't even talked about boarding/disembarking either! But you can imagine sitting right at the back which I was doing on the return trip and having to wait for 390 odd people to get through that air bridge before you do!
Hi Flightsimboy,
I'm aware of that.. But it's so interesting!
Hi PH,
Thanks for commenting! Glad you enjoyed it! I must say I think I'm getting a bit tired of writing EK A380 TRs in Economy.. Time for a change of scenery I think.
Yes, the lamb. But this would have been New Zealand lamb which would make it that much better! That's the good thing about sitting in the front - something that I'll strive to do whenever I'm on an A380 in Economy (apart from SQ where I'd hope to get onto the upper deck)!
Yes, it is annoying. But I'm glad it was back to an acceptable time for my return trip.
Quoting Bedo (Reply 11):
Hi Bedo,
I'm glad I enlightened your breakfast!
Yeah, not quite the same because there is an option for me to get my passport stamped but I don't think the time standing in a queue is worth it when the technology to walk virtually straight through immigration is available to you.
Oh, nothing about the wine. The caption was more about: "finally, I see myself with some drink at my seat" more than anything else. Half an hour is far too long to wait for drink, especially if you wished to have it accompany your meal.
Well I guess there was one FA on board who was multi lingual!
Thanks again for all your replies, I hope they keep on coming in!
[Edited 2010-01-10 04:54:08]
Sun Jan 10, 2010 2:47 pm
Quoting NZ107 (Reply 12):
That sounds heaven. I wish I were there. It would have been much better than sub zero!  cold
Sun Jan 10, 2010 3:53 pm
Hi Nicholas!
What an amazing Trip Report on the EK A380, and a great part two of your new TR series!
The pictures are simply amazing. Do tell more about that wide angle?
I think the tone of your pictures will really go well with HDR, something i am looking into off-late.
It is like comparing any IFE to ICE, where ICE is guaranteed to top it off. Same goes with HKG, where nothing compares to it. It will only be too harsh to compare any airport to HKG  Smile
Very interesting! I really like that idea.
Definitely agree here! Wouldn't want to be there when that A380 is overbooked!
I always thought that on evening/night flights, the newspapers should be replaced with magazines. Newspaper readers would have already read the newspaper by then!
And so I stepped into the A380 for the second time. I must admit it didn’t feel as special as the first time. I was welcomed on board by one of the stewards upon presentation of my boarding pass: “Welcome aboard, Mr. Young, your seat is the window seat on the far side”. It’s always nice to get personal welcomes as you board the plane. I don’t think I get quite enough of that It does make you feel a bit more special than “just one of those 300 odd Economy passengers”.
It is now customary that each and every passenger is addressed by name once boarding an EK flight; for the very least, an EK A380! Quite nice actually!
Totally agree!
The Y class seat on the EK A380 is actually very comfortable. I managed to get a decent 6 hours of deep sleep on this seat!
That was incredibly well-written and so detailed! I think that was the best take-off description i have ever read! haha  Smile
I am also just starting to experiment with RAW. Much better than shooting with JPEG!
Seems to happen quite a lot on EK. I really wonder how airlines calculate the ratio of meal choices that should be loaded on board. I would think it would be quite a challenging task to get it as accurate as possible,
They could have taken care of that by putting EDC on BKK and delaying the flight (or even switching it to a 77W if need be) .. BKK used to act as the buffer point that would absorb all A380 operational glitches. But now that the two higher-density birds entered service, things could be different now.
All lavatories on the higher density aircraft have now moved to the back i think. And that big crew bunk is no longer there, and has been replaced with more seating.
Now i am in the mood to write up my EK TR!!! ..
Thanks a lot for sharing this very detailed report filled with excellent pics!!!  Smile Looking forward to the next installment!
SQ772
Sun Jan 10, 2010 4:13 pm
Thanks for the detailed report. Excellent pictures and commentary as well... I'm still waiting for a chance to get on my first A380 flight  Sad
Sun Jan 10, 2010 4:19 pm
Quoting SQ772 (Reply 15):
You love SQ, you are from SQ's territory, and SQ has the A380  Smile ... Hop on one and tell us what you think  Smile
SQ772
Sun Jan 10, 2010 4:34 pm
Quoting Ronerone (Reply 16):
Unfortunately they don't fly to places that I need/want/wish to go to...  Wink
Sun Jan 10, 2010 5:57 pm
Hi again, Nicholas. A very nice and interesting report, with some great pics. Love those wide-angle shots  Wink
The pics from the gate area really gives an impression on how big the A380 really is, I haven't really thought much about the rather great amount of people it can carry. Those massive lines at boarding, and the huge crowd during de-boarding, seems like quite a hazzle to fly on the A380. But I suppose that price is worth paying  Smile
The IFE system in EK looked great, and it seemed pretty cool that it was possible to use your own media!
The food on EK looked nice as always, and the portions seemed pretty big to me.
Sun Jan 10, 2010 7:23 pm
- New Zealand is on the list, don't worry, I'll get there!
Keep the excellet reports rolling my friend.
BTW - Have you thought of getting on the AR A340-200 to SYD? - Quite a rare beast!
Best Wishes
Mon Jan 11, 2010 5:35 am
Quoting Akhmad (Reply 13):
It isn't very comfortable but I'd be sure to take it over -20C!
Quoting Ronerone (Reply 14):
Thanks for your comments Roni! Good to know it gave you some motivation to write your EK TR  Wink
Thanks! The Canon EF-S 10-22mm obviously only fits the crop Canon cameras. It isn't a fisheye variety but obviously has a bit of distortion at 10mm. Too bad it doesn't have IS because that would make it such a good lens. Great quality down to f/3.5 too although I was shooting around f/8 for a lot of them, just to keep depth of field and sharpness up. One lens I truly recommend! I might buy one for myself sometime soon to stop bothering my friend..
Yes it would be.. But if nothing can be compared to it and if AKL is 10th, then it makes you question what other airports worldwide are like. I wouldn't have thought AKL was comparable to the others further down that top ten either like ZRH and AMS.
Nope, nor would I. I hope it doesn't take too long before they commence with the next phase of the pier and complete the other side.. They really need something else down that long corridor.
Oh well, they're rich enough.. Could be leftovers from other flights earlier in the day..
Very nice. One thing I'll always be looking forward to when flying EK, that's for sure!
Haha, I think this makes up for my lack of the Ryanair sense of humour Big grin
Just one warning with RAWs - don't try taking an entire TR series in RAW or you'll end up like me in this one. It's a real pain and it took me an age to edit the 120 odd photos I posted up here. Yes, the quality is great but there was a lot of extra and possibly unrequired effort which went in.. And it also means that it'll take a while for the series to be completed! Especially as you wouldn't have as much free time as I do, stick to JPEG unless you're wanting A.Net photos (I guess that was part of the reason why I shot in RAW). RAW images are the best to make HDRs out of as there is no movement like you would if you were shooting handheld with brackets.
I always thought they had equal portions of each choice onboard.. But yes that lamb is something special and ellusive for those who sit at the back!
Oh right.. Is there a seat map for the high density configuration out yet?
Interesting. It'll make the front section a very nice area to be seated in that case. The back would also feel better and less claustrophobic.
Hi SQ772,
Thanks for your comments! Glad you enjoyed.
Quoting SQ772 (Reply 17):
A short trip to HKG doesn't sound too hard to me  Wink
Quoting LH4116 (Reply 18):
Hi Jonas,
Thanks for your comments! Yeah, those wide angle shots are something special. I was amazed at how much could fit into the screen!
I'd like to see the high density A380 gate area.. Now that would be one freakish sight! Luckily the airfare was so cheap I didn't exactly mind but if you are sitting at the front of the plane, it's a much smaller problem and you probably wouldn't realise that there were so many people.
If I hadn't starved myself, the meal would have been very good. I do like their portion size though, much more generous than Air NZ.
Quoting BA319-131 (Reply 19):
And a TR on NZ!  Wink
I'll try but I need a break from all this photo editing.. I'm wishing I hadn't shot the entire trip in RAW!
I have thought about the A342 but I tend to overlook it.. But after that trip to Aussie to try out the A332 and A321, I think I'm keen to try more! Maybe one way A342 then back on an EK A345 from MEL. I acutally think I'd prefer a long haul journey though! Trying at the moment to get a seat on a CV-580 which would be a nice and unique TR if I can secure it.
Thanks guys!
Mon Jan 11, 2010 7:54 am
Quoting NZ107 (Reply 20):
- That sounds like a good idea, wish I was there to do it myself!
- This would be a major coup, good luck!
Econojetter
Mon Jan 11, 2010 2:34 pm
This is your second EK A380 trip but you still make it sound interesting!
I really like that view.
Haha... clever trompe-l'oeil. For an instant you had me thinking EK had introduced a new "Your forward seat neighbor's hairy neck" camera view.
I've had out-of-sequence service before, but not quite this bad!
Nice lavatory. One feature I like (that I've only noticed on SQ so far) is the foot pedal for opening the lid of the trash bin; sometimes the lid can look a little nasty and you don't really want to touch it. Doesn't look like this lav has it.
Thank you for sharing, Nicholas. Looking forward to your next trips!
airpearl
Mon Jan 11, 2010 3:47 pm
Hehe... it doesn't take too much to entice me to visit New Zealand Nicholas... only thing it can't be done over a long weekend, which is the most I can be away for, at least for the next few months. I hope I can manage a trip this year though  Wink
Oh wow, didn't realize. I must have seen it and instantly forgotten it.
Used it once on NZ Business. Pretty cosy little arrangement actually - literally not more than 5 paces from check-in to a single immigration counter and then thru to security. Real easy. There's no direct access to the lounge though if I recall correctly.
The NZ domestic gates have a better view - do you agree? You get closer to the planes and all the heavies have to taxi past as well.
9MMAR
Mon Jan 11, 2010 4:13 pm
Hello NZ107,
I think this is the first time I read a report of yours. Pretty good. Do you have a FlightMemory account to show us all?
This is mine if you never heard of it. http://my.flightmemory.com/9MMAR
a1ring23
Mon Jan 11, 2010 4:30 pm
Nice, that would've set you back quite a bit...
No WA though.....maybe next time?
Whilst convenient, it does offer less of a national identity to EK. No disrespect to them or anything, but it's just not the same as stepping onto a QF or SQ bird, where you know you're going down under or to Changi..
The food and cabin looks decent as usual, looking forward to trying EK in the not-too-distant future hopefully.
Nice cabin and shots of AKL, looks like a nice terminal, well laid out.
What do you think of EK's 'wood' panelling on their toilets etc
Looking forward to the next part.
Pete
Tue Jan 12, 2010 5:25 am
Quoting BA319-131 (Reply 21):
I really wish I had more money, Mark!
Quoting Econojetter (Reply 22):
Hi Econojetter,
Thanks for your comments. I try my hardest to make them interesting but I've got a feeling that the return trip won't be as exciting apart from the photos taken in SYD before flying out..
Haha, wouldn't that be interesting! ICE could probably do just about everything if it could take a video of the head of the person in front of you! I can imagine: "Hey, instead of watching the tail view, why don't we check out what the person in front of us is doing?"  Smile
I haven't had it that bad either..
It seems rather cramped. I really wish I could have shown everyone the massive one at the front though because I swear it is about 2x bigger than the one in this photo! That idea of a foot pedal is one that I wish became compulsory on every new plane because it is just so much nicer only having to press down on something rather than try to avoid touching that self closing lid!
Quoting Airpearl (Reply 23):
What a shame.. Lack of holidays must be something annoying. I guess I won't enjoy finishing up at Uni and getting about 3-4 weeks of annual leave.. I'll be flying during the whole time I reckon!
If you don't get dropped off at the left end of the check in counters, you'll never notice it as the escalators up to the departures area isn't near there. But being an A.Nutter like the rest of us, I'm sure you'd try to explore every nook and cranny of an airport!
Shows how often I've used the NZ Premium check in AKL! Yeah I just checked with my uncle and he said that there is no direct lounge access.
In a way I guess.. Just that the windows are usually a bit dirty.. Ok for spotting though.
Quoting 9MMAR (Reply 24):
Hi 9MMAR,
Thanks for your comments. Yes I do have a FlightMemory account which I just updated a few days ago. http://my.flightmemory.com/NZ107 which was a predictable username  Wink
I've flown MUCH less than you!
Quoting A1ring23 (Reply 25):
Hi Pete,
Yeah, probably just over a grand NZ overall.
One day.. NT, TAS and SA to go too. I just couldn't find a flight that I really liked and it was a bit too far to go in the short amount of time I was in Aussie for. Didn't really have the money to get that far either. I had planned to go as far as ADL (for the E90 or A321) but I ended up not being able to find good time slots to get there and then back to SYD by night.
I'm sure you'll enjoy it when you get on them!
I don't really care - I personally don't think it makes it tacky and all that but it's nicer to come across that than a dull plastic one.
nethkt
Wed Mar 10, 2010 3:17 pm
Such a perfect, complete, wonderful, fabulous trip report!
I am sure I will re-visit the report once I make my mind flying EK A380 in the near future.
Thanks for all the photos!! Very well presented!   esp the trompe-l'oeil! Clever!!
nethkt.
Fri Mar 12, 2010 4:47 am
Quoting nethkt (Reply 27):
Hi nethkt,
Wow, thanks for your comments!
Bear in mind that if you are flying the EK A380 out of BKK, it'll be the higher density A380- hence it'll be slightly different such as the removal of the crew rest from the back section of the main floor economy cabin.
nethkt
Fri Mar 12, 2010 7:51 am
Quoting NZ107 (Reply 28):
Even higher density on an already high density aircraft?   hehe
However, I know what you mean. And actually I'd rather not have the box in my sight!!
EK is good at mixing all configurations they could think of for one aircraft type.
I don't want to imagine when there is an Adhoc Schedule Change!! Ground staff must hear a lot of complaints!!
Thanks again.
nethkt
Thu May 27, 2010 3:20 pm
Ok, it's time for a F Class report!
Really? Remind me that I try NZ lamb when I visit the country one day.
midcon385
Fri May 28, 2010 9:28 am
Outflow valve for cabin pressurization.
Great TR! Beautiful A380!
Tim
MidContinent Airlines: We Know How To Fly!
Sat May 29, 2010 5:14 am
Hi PH,
Quoting PlaneHunter (Reply 30):
I nearly have enough Skywards points to upgrade myself to J on EK to Sydney! That could become an option one day. But F is definitely out of my league at this present time!
Haven't you heard all the good things about New Zealand lamb before? The tenderness and simply the taste of this animal which you know has eaten grass its entire life, running freely around wide open paddocks.. I'm sure to remind you when you come down here! You mightn't be able to tell the difference onboard Y but a nice chunk of meat at some restaurant should do the trick.
Quoting Midcon385 (Reply 31):
Hi Tim, thanks for your comments!
Glad to finally know what it is, thank you.
Thu Jun 03, 2010 6:50 pm
Quoting NZ107 (Reply 32):
Ok, sounds really good.
Users browsing this forum: Google Feedfetcher, Highflyer1973, triple7man, vrbarreto and 26 guests
