Flying Belgian
Another 737NG PFD Question.
Sun Feb 13, 2005 12:13 am
I've been browsing 737NG cockpit's pictures for a while now, and a question has always intrigued me:
What's the difference between the two ways to display the PFD on a 737NG ??
Photo © Dario Crusafon - Iberian Spotters
Photo © Javier F. Bobadilla - Iberian Spotters
Why did Boeing design it so ? Does an Airline decide to set definitly only in one way ?
I see AirEuropa pilots fly with both type of PFDs.
FB.
Life is great at 41.000 feet...
RightWayUp
RE: Another 737NG PFD Question.
Sun Feb 13, 2005 2:42 am
The one above is a new designed PFD and ND which originated from the 747-400. It is an easier and simpler display from a flying point of view. The lower one represents the older EFIS found on 737 3/4/500s and is used (in general) by airlines such as Southwest for commonality with the older variants thus reducing or nullifying initial training to fly the EG and NG.
Flying Belgian
Sun Feb 13, 2005 2:45 am
Can you switch from one to the other on all 737NGs ?
Thx,
FB.
AvionicMech
Sun Feb 13, 2005 5:17 am
FB
I cant be 100% certain because I have never converted one type of display to the other on a 737 but I am pretty sure that it would all be done by what is known as pin-programming. I know for sure this is how various items can be changed on the 757 EADI, which is the same as the PFD on the 737, such as changing the rad alt from a digital readout to a dial type reading for example. Another one that can be changed is the fast-slow indicator to a speed tape as shown in these pics just to the left of the artificial horizon on the top screen.
Photo © Bruno David
Photo © Jerry Search
Avionic Mech
LMP737
Sun Feb 13, 2005 8:18 am
Flying Belgian:
You can switch from one to the other by loading different software.
dl757md
Sun Feb 13, 2005 2:57 pm
As LMP737 has said it is a simple 5 minute OPC software load into each DEU(Dispaly Electronics Unit). There is pin programming on the DEUs but AFAIK it doesn't have anything to do with customer configuration options.
Dl757Md
AvionicMech
Mon Feb 14, 2005 8:39 am
I wish it had been as simple as a software change on our 757 as we ended up having to take equipment racks out just to put in two or three wires which I am sure you guys would agree is very annoying. Its not the removal and doing of the job but all the functions that have to be done just because we needed to put a couple of wires in.  Angry
DeltaGuy
Mon Feb 14, 2005 10:31 am
You can also reprogram to change Flight Director configuations...for instance, AA uses an 'inverted V' or double cue FD, whereas DL uses a 'double needles' or single cue FD....they could be re-programmed relatively easily if you were switching the aircraft over.
DeltaGuy
Mon Feb 14, 2005 12:24 pm
Look at it this way.....It wont be needed to be undone.A one time job  Smile
regds
MEL
AvionicMech
Tue Feb 15, 2005 12:17 am
Mel,
That's funny, I have heard that said before though. It wont be needed to be undone, we have had a system called CONTRAN installed on our 757's for years, I don't know if you have seen it but it is a black box which basically stops any problems in case you get a stuck PTT switch. Well this system was so bad that we just ended up removing the box on every aircraft because it was causing VHF transmission snags. Well we have now started taking this CONTRAN system out and wiring the aircraft to use the in-built stuck microphone system in the VHF transceivers. So this proves there is no such thing as a 'one time job'. There is always something that needs changing, which is good because otherwise I might be out of a job. hahaha.  Big grin
Avionic Mech
Tue Feb 15, 2005 5:02 pm
Very true.
But If theres no other routine work,I dont mind doing the "One time job" again  Smile
regds
MEL
Users browsing this forum: PaddyOMaddy, zknzf and 1 guest
