airfoilsguy
Are There Brakes On The Nose Gear?
Tue Jan 24, 2006 10:16 am
I don't seem to recall seeing break rotors on the nose gear of most aircraft. If they don't have breaks on the nose gear, why not? Wouldn't that help reduce stopping distance. I know cars use the front wheels for a majority of their stopping power.
It's not a near miss it's a near hit!!
Jetlagged
Tue Jan 24, 2006 10:24 am
The nose gear only takes about 10% of the aircraft's weight, so can't provide much braking force. There have been a few airliners with nosewheel brakes (some 727s had them). Generally they aren't seen as being worth the weight penalty.
I'd guess the front wheels of a car might be taking 60% or more of the weight of the car under heavy braking, which is why they provide most of the braking force.
airfoilsguy
Tue Jan 24, 2006 10:35 am
Quoting Jetlagged (Reply 1):
My though was that once breaking action started the center of gravity shifts toward the front of the plane, thus putting a greater percentage of the aircrafts weight forward.
2H4
Tue Jan 24, 2006 10:56 am
Convairs had them, too:
Photo © Christian Waser
2H4
Intentionally Left Blank
OPNLguy
Tue Jan 24, 2006 11:05 am
Quoting Airfoilsguy (Thread starter):
Are There Breaks On The Nose Gear?
Only if the pushback tug hits the nose gear really hard...
Brakes on the other hand...  Wink
Tue Jan 24, 2006 6:44 pm
Since the Main Gear brakes take most of the Aircraft Weight.It makes sense to have them Installed there.On the B727 there were NLG brakes.
Cannot locate a pic though.
If the purpose can be served by The Main Gear brakes alone,the Weight savings along with the Mechanical complications can be avoided.
Also the NLG Brakes were effective only after approx 60% of the Main Brake application as I was told.
regds
MEL
LH4U
Wed Jan 25, 2006 1:41 am
Quoting Airfoilsguy (Reply 2):
Center of gravity doesn´t move when braking.... it´s only dependent on weight ditribution. The main wheels are almost always behind CoG, so when main gear braking starts, there will be a momentum on the nose gear. That´s probably what you mean. But still, with this momentum nose gear braking would have relatively little effect...
Greets
2H4
Wed Jan 25, 2006 1:44 am
I just found this quote from http://www.b737.org.uk, referring to the 737-200ADV:
Autobrake, improved anti-skid, automatic speedbrake for RTO, automatic performance reserve and even nose-brakes became available.
This is the first I've heard of nosewheel brakes being offered on the 737. Were any actually installed?
2H4
Jetlagged
Still its a very small percentage on a small contact area. The vast majority of the aircraft's weight stays on the main wheels, even under braking. Also, the nosewheel tyres have enough work to do with nosewheel steering.
Car tyres start with roughly 50/50 fore/aft weight split (maybe 55/45 allowing for the engine). Braking g loads further increase this imbalance. In an aircraft, to transfer significant weight forward onto the nosewheel would required dramatic deceleration rates, which might not go down too well with the self loading cargo.
CosmicCruiser
Wed Jan 25, 2006 2:37 am
Fedex had all the nose gear brakes removed on our 727s years ago.
Elvisisalive
Wed Jan 25, 2006 5:40 am
Am pretty sure all the wheels on the 747-400 nose or main are the 3-1479-2
so if the -400 does not have nose brakes is there just a cavity in the wheel were the brake would be ?
FredT
Wed Jan 25, 2006 5:56 am
Not to mention maintenance!
The center of gravity stays put, but the weight distribution among the wheels is changed by the torque generated by the braking force.
The Saab Gripen has nose wheel braking. Makes for a lot of stopping power, combined with lift dumping, canards doubling as giant airbrakes and anti-lock brakes that can be applied prior to touchdown. Hardly an airliner though...  Smile
So, who will be first to estimate the force on the nose wheels of an airliner during braking?
Fred
Matt72033
Wed Jan 25, 2006 6:01 am
Quoting Elvisisalive (Reply 10):
no brakes on the nosewheel of a 744
RE: Are There Brakes On The Nose Gear?
Wed Jan 25, 2006 2:54 pm
Quoting 2H4 (Reply 7):
I heard on this forum someplace that it was an option.Although have never personally noticed a B737 equipped with NLG brakes.
regds
MEL
saintsman
Wed Jan 25, 2006 4:49 pm
There are brakes fitted to some aircraft to stop the wheels spinning after they have been retracted. They are applied directly to the tyres.
Matt72033
Wed Jan 25, 2006 7:44 pm
Quoting Matt72033 (Reply 12):
but your right, i checked, and the part numbers are interchangeable!
Thu Jan 26, 2006 12:20 am
Quoting Saintsman (Reply 14):
http://www.b737.org.uk/wheelwellnose_ng_labelled.jpg
They are referred to as Snubber pads.The above pic does not depict the total pads though,the Aft section is visable.Will post a better one when available later.
regds
MEL
Gunships
Thu Jan 26, 2006 11:07 am
We used to call them "spin brakes" on the C-141. Just static brake pads installed near the top of the NLG wheel well that the NLG tires would contact as they retracted.
Eliminated the "gyro" effect of the tires spinning, which would add an unecessary force to an already heavily-stressed structure.
Users browsing this forum: crownvic, David L, mcdu, Menzenski, OldAeroGuy, planecane and 15 guests
