747400sp
Why The Usaf Cancel The YC-14 & YC-15
Tue Feb 21, 2006 8:19 am
In the mid 70's the USAF was looking for a jet replacement for the C-130. Both Boeing and Mcdonnell Douglas flew their prototype, Boeing had the YC-14 and Mcdonnell Douglas YC-15. The YC-14 and YC-15 out performed the USAF expectation. So why the USAF drop the project.
PS I thought the YC-15 was the best choice
474218
RE: Why The Usaf Cancel The YC-14 & YC-15
Tue Feb 21, 2006 9:52 am
Because the C-130 could do everything the YC-14 and YC-15 clould do, and do it for a lot less money.
Dougloid
Tue Feb 21, 2006 9:58 am
Good point. The money wasn't totally wasted though, a lot of the YC15 development work went into the C17
N328KF
Tue Feb 21, 2006 10:36 am
Quoting Dougloid (Reply 2):
A lot? The C-17 looks like a super-sized, swept-wing YC-15.  Wink
“In the age of information, ignorance is a choice.”
-Donny Miller
scbriml
Thu Feb 23, 2006 4:01 am
The YC-15 looked cool, but those engines didn't look like they could get it off the ground.
Photo © Steve Brimley
Dougloid
Thu Feb 23, 2006 10:39 am
Quoting N328KF (Reply 3):
And even before the C17 got built we were all proud that the YC15 whupped the Boeing offering.  bigthumbsup   bigthumbsup
whitehatter
Fri Feb 24, 2006 9:14 am
Quoting Scbriml (Reply 4):
Deceptive photos.
The YC-15 used the JT8D, so it had the power of two 732 or DC-9 aircraft after all.
Boeing's offering used a pair of CF6 engines.
Lead me not into temptation, I can find my own way there...
kc135topboom
Tue Feb 28, 2006 12:57 pm
The Boeing YC-14 was technologily musch more advanced. The 2 CF-6 engines were mounted on the wing leading edge, thrust was blown over both the upper and lower wing surface, producing an enormaos amount of lift. The YC-14 clearly out performed the 4 engine MD YC-15. It could lift a lot more weight than either the C-130 or YC-15.
But, later in life, the YC-15 test airplane was used to flight test the (then newly designed) CFM-56-B2 engine.
N328KF
Tue Feb 28, 2006 11:52 pm
Quoting KC135TopBoom (Reply 7):
Yes, and then the Soviets wound up using the Coanda effect for the An-72 design.
-Donny Miller
RayChuang
Thu Mar 02, 2006 6:41 am
Quoting 474218 (Reply 1):
That and the fact the USAF realized they truly needed a bigger plane than the YC-14/YC-15, so as not to repeat the experience with the C-141 Starlifter. The result is the C-17A Globemaster III.
zwaving
Sat Jul 21, 2007 9:15 pm
What was the experience factor with the starlifter?
There is no free lunch!
Stealthz
Sat Jul 21, 2007 9:31 pm
Quoting Zwaving (Reply 10):
IIRC, it was too small for it's weight carrying capacity.
If that doesn't seem to make sense, it often filled the available volume before reaching max weight. This led to the C-141B which were C-141A with plugs inserted in the fuselage fore and aft of the wings adding a total of 23ft 4in to the length.
If your camera sends text messages, that could explain why your photos are rubbish!....well that might have changed!!!
dl021
Sat Jul 21, 2007 9:37 pm
Quoting StealthZ (Reply 11):
I think that it's a very rare thing to max out a freighter weight wise prior to filling the volume. What they really wanted was a wider airplane to make more stuff fit inside.
Is my Pan Am ticket to the moon still good?
kc135topboom
Sat Jul 21, 2007 9:50 pm
The C-141B mod also added air refueling capability that the C-141A did not have.
Stealthz
Sat Jul 21, 2007 9:57 pm
Quoting DL021 (Reply 12):
Not rare at all, much cargo is not that dense.
Much military cargo comprises things like helicopters, wheeled vehicles etc these will max out volume long before weight is an issue.
Absolutely agree, but what you want you can't always have.. had to wait for the C-17 to get the width.
Adding width to the C-141 was not an option so a stretch was the compromise they had to live with.
Quoting KC135TopBoom (Reply 13):
Sorry KC135... should have mentioned that!
[Edited 2007-07-21 15:00:19]
EMBQA
Sun Jul 22, 2007 3:41 am
......and 30 years later it is still doing it.
CTR
Sun Jul 22, 2007 4:07 am
Neither the YC-14 or YC-15 programs were canceled. To be canceled you first need to be awarded a contract to develop a production aircraft.
Both the YC-14 and YC-15 were technology development prototype aircraft built to test advanced heavy lift concepts. The size of these aircrafts was based on the minimum size (least $$$) required to be scaleable to larger aircraft, not as a C-130 replacement.
Each aircraft had their own merits. Although the lift performance of the YC-14 was impressive, the associated complexity in the engine, wing and moving surfaces was judged by the USAF as unacceptable.
Have fun,
CTR
Aircraft design is just one big compromise,,,
AirSpare
Sun Jul 22, 2007 4:25 am
To chime in a 4th time, it also had major wing root mods, IIRC, didn't it have problems with cracks?
Get someone else for your hero worship fetish
L-188
Sun Jul 22, 2007 4:52 am
A little history here, the C-141 was built to replace the C-133. Both of which had one mission in life when they where developed. To carry a minuteman missle in it's shipping container. That is why they where able to keep the C-130 sized floor dimensions.
But as noted it was quickly realized that a lot of their capacity was wasted when they wheren't carrying a heavy ICBM and it's shippng cradle so that is why they decided to stretch the aircraft and take advantage of the whole lift capability of the aircraft.
Quoting CTR (Reply 16):
That was my understanding, it was a test program not a program leading to a production run.
Thorny
Sun Jul 22, 2007 6:08 am
Quoting AirSpare (Reply 17):
No, that was the C-5A.
AirSpare
Sun Jul 22, 2007 7:29 am
Quoting Thorny (Reply 19):
C-5A.
I thought there was a cracking problem. Here is a good synopsis. I had remembered it as part of the upgrade to the B models but it wasn't.
TropicBird
Sun Jul 22, 2007 11:02 am
As I recall the YC-15 was the precursor to the C-17... MDC won the competition over Boeing.
MCIGuy
Mon Jul 23, 2007 2:37 pm
Quoting TropicBird (Reply 21):
I was gonna say, put some HBT engines on that YC-15 and you have the look of the C-17, even if the 17 is larger.
PS> I had the pleasure of seeing the YC-14 at Pima. There's just something about touching one of only two aircraft.
[Edited 2007-07-23 07:44:56]
Airliners.net Moderator Team
DeltaGuy
Mon Jul 23, 2007 9:46 pm
That was the problem, being just a stretched C-130 really. It was that...then the C-5. No middle ground like the C-17 is now.
I did like the old 141 though....miss those old Lockheeds.
DeltaGuy
aeroweanie
Wed Jul 25, 2007 1:19 am
The first aircraft modified got the wing root mods, but they weren't incorporated on subsequent aircraft, to save money.
Thorny
Wed Jul 25, 2007 8:57 am
Sort of. Changing requirements favored an outgrowth of the YC-15 over the YC-14, but the YC-14 was the better aircraft in meeting the original requirements.
The Air Force belatedly decided it wanted a much larger airlifter than the C-130-sized STOL prototypes it got in the YC-14 and YC-15. Boeing's YC-14 ran rings around the YC-15 in most areas: STOL in particular (and the YC-14 needed only half the runway of a C-130 for the same payload, so it isn't true C-130 could do everything YC-14 could.) Remember YC-14 and YC-15 were developed in a STOL tactical airlift competition to succeed C-130, not a competition to succeed C-141 (which C-17 eventually won.)
But when the Air Force decided it wanted a new strategic airlifter and not a tactical airlifter (probably as headaches with the hangar queen C-5 grew), the STOL capability wasn't as important, and the YC-15 was more easily scaled up to what the Air Force now wanted. So YC-14 ended up as an impressive curiosity and YC-15 led to C-17.
Users browsing this forum: No registered users and 28 guests
