AviationAddict
Could 747F Be A Possible C-5 Replacement?
Tue Apr 11, 2006 2:21 pm
Would the USAF ever consider replacing it's C-5s with 747s? I can't imagine there being a huge size difference (but I don't know much about the C-5, so I could be very wrong) and I'd imagine using a 747 would cost a lot less than building an all new military cargo aircraft. I know the C-5s are getting pretty old and I also know they've never been all that reliable, so the military must be at least eyeing potential replacements. Any thoughts?
N1641
RE: Could 747F Be A Possible C-5 Replacement?
Tue Apr 11, 2006 2:48 pm
the military cant fit its crap into a 747, theres no holes big enough, for example the flipping nose or rear end that splits open so you can drive vehicles into it.
AviationAddict
Tue Apr 11, 2006 2:57 pm
Quoting N1641 (Reply 1):
What do you think would cost more; build a new 747 based variant that would have doors and cargo bays wide enough to fit the military equipment, OR constructing an all new freighter? In this case I suppose it might be easier (but maybe not cheaper), to just build an all new model.
wingnut135
Tue Apr 11, 2006 7:33 pm
Fred was designed to carry out sized cargo and won the contract against the 747. The only way you'd get it to work is if you could redesign the landing gear to get the cargo deck at least 6 feet closer to the ground and then make it so they can kneel to get even closer when needed; the biggest selling point if I'm not mistaken. See the Antonov 124 and 225 for that as well. Also you'd need to redesign the body shape. Floor to ceiling on Fred is about 13ft all the way down; the flight deck on a 747 cuts front end load height but I don't know by how much.
Just my  twocents
Wingnut
A good friend will get you out of jail. A real friend will be there with you saying, "Damn that was fun!"
ptrjong
Wed Apr 12, 2006 12:05 am
Galaxy is nicknamed Fred? Why?
Peter
dw747400
Wed Apr 12, 2006 1:52 am
Quoting Wingnut135 (Reply 3):
As many have said here, the C-5 NEVER competed against the 747 for a military contract. The Boeing entry for the CX-HLS competition was significantly different than the 747--the only significant contribution from Boeing's CX-HLS competition was the development of high bypass engines. It is possible that the experience in designing very large aircraft helped Boeing engineers build the 747, but there is no relation between the 747 and the Boeing CX-HLS (which looked like a slightly bigger version of the C-5).
By the way, Lockheed won on price, not technical ability. The Boeing entry was judged superior, but the price they wanted was DRAMATICALLY more than the Lockheed. Of course, with all the C-5 issues that occured, many feel the Boeing would have been the better buy. Of course, not having ever seen it move of paper, no one can say for sure. Boeing may have hit the same problems Lockheed did.
EDIT: Also, I have seen plans to make the 747 kneel. I'm not sure if they ever did a full scale test. It was still higher than the C-5's deck, but low enough for dirve-on ramp loading.
[Edited 2006-04-11 18:55:44]
CFI--Certfied Freakin Idiot
Boeing Nut
Wed Apr 12, 2006 2:03 am
The 747 was never in the running for this contract. Lockheeds proposal beat out Boeing's which looked a lot like an An-124 from what I remember.
Now here is a true military version of a 747 freighter. Interesting stuff on how a KC-747 would come together. Pan down to page 64 for the freighter stuff.
AirRyan
Wed Apr 12, 2006 4:36 am
Quoting Ptrjong (Reply 4):
It's like a platinum blonde hollywood actress - kinda bitchy and high maintenance and not quite worth the price (as in other alternatives may have been wiser.)
When your C-5 flies halfway around the world to deliver cargo 1/10th of it's limit - and then breaks down itself so that another has to deliver the parts to get it in the air again, well....
FRED - F*cking Ridiculous Economic Disaster
prebennorholm
Wed Apr 12, 2006 5:00 am
Quoting AviationAddict (Thread starter):
I don't think that the 747 will be around to replace the C-5. When will the C-5s retire? 2040? 2050?
Right now they are getting a new life with lots of improvements. When that is over in 5-10 years time, then they will have another 25 years without much modification.
In addition the 747 is not the obvious choice. The floor is too high due to the wing center box.
The upper deck floor is rather low, and it is an integrated structure to keep the pressurized hull in shape. Therefore it cannot be easily modified.
It all means that all but the smallest helicopters cannot be loaded. That alone disqualifies the 747 as C-5 replacement.
It is more likely that the C-5 will never be replaced. Simply because peace breaks out on planet Earth before the present C-5s are beer-canned.
747400sp
Wed Apr 12, 2006 6:53 am
In the early 80's the USAF was looking at the 747-200F to supplement there C-5 fleet. Because of this, Flying Tiger did kneeling test using one of there 747-200F. I fore got what device they used but I believe they successful.
ptrjong
Wed Apr 12, 2006 7:18 am
Quoting Dw747400 (Reply 5):
I realized that the Boeing competitor to the C-5 was different from the 747, but I did buy the story that the 747's elevated cockpit was inherited staight from that design. Not so?
Why then did the 747 get that? To enable civil cargo loading throug the nose? Aerodynamically the raised cockpit, not repeated in other widebody airliners, is a penalty I suppose.
dw747400
Wed Apr 12, 2006 8:04 am
Quoting Ptrjong (Reply 10):
It's a logical conclusion for sure (I thought the same thing at one time), but it is not the case.
The history of the 747 is amazing--one big battle was the idea of a single or double deck airplane. Put very simply, Juan Trippe and Pan-Am wanted a double deck plane, while Joe Sutter at Boeing wanted a single, large deck. In addition to his concerns that evacuation, servicing, etc. could be a problem (just building a 350 passenger plane was radical enough!), many believed any subsonic transport would soon be relegated to cargo duty as SSTs took over passenger routes.
To make the 747 a competitive freighter, Sutter's team basically drew a circle around two 8x8 shipping containers sitting on the main deck and decided on that as a cross section. The idea of nose loading these containers was very apealing, so Boeing looked at ways to add a nose door. Moving the cockpit was looked at but proved too complex as all the control linkages would have had to been reconnected every time the door was opened (I wonder what they would have done if they had FBW!).
Initially, boeing built a blister on the top of the fuselage for the cockpit, but this proved to be aerodynamically inefficient. Therefore they fared the cockpit into the fuselage. Orriginally the space behind the cockpit was going to be a crew rest area, but when Trippe saw the deisgn his dreams of a double decker came back, and an exclusive upper deck lounge was born. Sadly, business class seating followed shortly thereafter.
Aerodynamically, the 747's hump has some bennefits, in the form of area ruling. I'm sure it has penalties too, but one of our aerodynamics folks could explain that better than I.
Of course, lots more was going on, but I hope that gives you a good overview!
ptrjong
Wed Apr 12, 2006 8:33 am
Very interesting. Thanks David.  Smile
RC135U
Wed Apr 12, 2006 10:59 am
After Lockheed completed the C-5B run, did they save the tooling? I see that Sikorsky is planning to produce brand new CH-53K models for the USMC with production running through 2022. How about a fresh run of C-5s in maybe 25 years (and addressing all the MX headaches)?  Wink
Thorny
Wed Apr 12, 2006 11:06 am
Quoting Dw747400 (Reply 11):
How did they solve this problem for the Pregnant Guppy and Super Guppy, derived from Boeing 377 and C-97s?
dw747400
Wed Apr 12, 2006 11:27 am
Good question Thorny!
It took a LONG time to reconnect the flight controls on the Guppy variants, but compared to a typical cargo aircraft they were used for specialized, low frequency flights. Thus, the fact that it took a long time to close the door wasn't a huge issue. Plus, I'm sure the control lines were a lot less complex than whats on the 747.
I can't recall the exact time it took to reconnect the flight controls, but I do know it was more than an hour (after the tail was swung into place).
This is one of the reasons Airbus built the Beluga. In addition to being newer, larger, more efficient, and most importantly NOT A BOEING, they could do much faster turnarounds.
The one I'm curious about is the new 747 super freighter for the 787. It is going to have a swing tail. And speaking of C-5 replacements... that sucker sure has capacity!  Wink
seefivein
Wed Apr 12, 2006 11:34 am
New 747 design
http://seattlepi.nwsource.com/busine...html?searchpagefrom=3&searchdiff=6
The nose lifts up to enter
http://www.aviapartner.aero/images/press_saudi-747-pallet-high.jpg
I remember seeing some plans and booklets on the C5 from the early 60's and they had drawn one with 6 engines and a high lift wing(I hope I have it right)-yeah the one that looks like the Antov.
They had also drawn one with a nose that swung out to the sidewhich included the cockpit.
If..When they build another Heavy Lifter..I hope they make several versions so that One size is not their only hope.
wingnut135
Wed Apr 12, 2006 3:01 pm
I stand corrected. I knew Lockheed and Boeing were in the running for a large freighter at the same time and that the final design 747 was the result of Boeing's bid. I thought I had read that the C-5 and the 747 were in competition against each other. I'll have to look further into the CX-HLS though.
Wingnut
kc135topboom
Wed Apr 12, 2006 7:08 pm
Quoting Dw747400 (Reply 15):
The B-747-400LCF swing tail will have all the tail and rudder control connections, and the APU electrical connections transit through the hinges, somehow. They will not have to be disconnect or reconnected every time the tail is opened/closed. Additionally, the upper deck portion will be extended almost to the tail as the fuselarge sections of the B-787s must fit inside. But, the B-747-400LCF (first one in modification right now by EVA) will not be equipped with a NCD. Boeing is also going to increase the fleet size now from 3 airplanes to 4 or 5.
Triple Seven
Thu Apr 13, 2006 2:10 am
They actually dug a ditch or some sort and drove the 742F nose wheel into it to simulate the kneeling height of the proposed AF 747F infront of some AF brass.
mikehobley
Thu Apr 13, 2006 2:40 am
just want to add my  twocents  to this....
If you look at Boeings proposal for the CX-HLS, you can clearly see where the 747 inherited its looks from. Boeings design was basically a 747 nose section, with a hi wing/turbofan and an upper deck that stretched all the way back to the tail - giving it the look of what we now know to be the C-5..its easy to see how Boeing and the airlines developed this into the 747 we know and love today....this Boeing package was technically superior to the C-5 but to expensive at just over $2billiion....
dw747400
Thu Apr 13, 2006 3:14 am
Quoting Mikehobley (Reply 20):
As I mentioned above, this is not the case. Any resemblance is due to the fact both aircraft have a nose cargo door, nothing more. Joe Sutter spoke about this a while back.
galaxy5
Thu Apr 13, 2006 6:56 am
How far are you gonna kneel a 747 before the engines hit the ground?
"damn, I didnt know prince could Ball like that" - Charlie Murphy
seefivein
Thu Apr 13, 2006 8:46 am
If you get a chance to watch the new commercials for the new SUV from GMC,, it has a 747 with the nose opening up and showing the inside of the 747 too
sonic67
Thu Apr 13, 2006 10:00 am
Quoting Galaxy5 (Reply 22):
This answer your question?
http://www.strangedangers.com/content/item/114927.html
Triple Seven
Thu Apr 13, 2006 10:52 pm
just want to add my to this....
There is alot of misconception to the origin of the 747 design.
To make it short, Boeing benefited widebody design experiance and not inspiration from the CX-HLS competition.
Boeing 747 designers came up with two essential design; Widebody single deck concept and a narrower wide body twin deck design.
As we know the widebody single deck layout was the chosen one. It was belatedly decided that the flight deck be move above the passanger cabin to allow the possible fitting of a nose door. In the 60s no one was sure if the 747 would make it as a passenger carrier, it was a gamble. The nose door allows the 747 a second life as a freighter in the event the 747 failed as a passanger carrier.
Oroka
Fri Apr 14, 2006 12:12 pm
It would take alot of structural strengthening to the floors too. I remember something about the old Air Canada 744s (maybe ex Canadian) having abnormally strong floors because of some contract they had with the Canadian military... dont ask for a source, I forget where I read it.
IMO the USAF should eventually replace the C-5s with a fleet of 744s and C-17s. The C-17 can deal with the heavylift stuff, then the 744 can do the palletized and smaller hardware. Maybe they could even sell off the C-5s to cargo haulers, let them do the AN-124 thing, and contract out if they have a C-5 class heavylift capactiy, kinda like when they contract out to airlines to move troops when needed.
Devilfish
Tue Apr 18, 2006 2:43 pm
Quoting KC135TopBoom (Reply 18):
Quoting Oroka (Reply 26):
From CivAv: I wonder if the 787 fuselage sections would also require the "JUMBOHAULER" to kneel, as the military requirements.
http://seattletimes.nwsource.com/htm...aerospace/2002931297_boeing15.html
[Edited 2006-04-18 07:53:11]
dw747400
Tue Apr 18, 2006 11:16 pm
Quoting DEVILFISH (Reply 27):
I can't see why. They will have specialized loading/unloading equipment for the aircraft--and it is a lot less complicated to build a tall loader than a kneeling 747, especially when the cargo is loaded through the tail! You would need to lift the nose gear up or retract the mains.
Devilfish
Wed Apr 19, 2006 2:17 am
Quoting Dw747400 (Reply 28):
I can't see why.
My error. I didn't immediately see the impracticality of loading a long, large fuse section up into an incline, and the swing-out tail hitting the pavement. I was thinking about a special heavy loader for military applications, but I think that too would be an unacceptable, time-consuming complication, especially in the field.
airbusA346
Sat Apr 22, 2006 6:05 am
Can you please show me, because I can't find anything.  Sad
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
Users browsing this forum: Areopagus and 8 guests
