Stitch
Return Of The 767-400ER - Usaf Bird Assigned Line#
Sat Jan 19, 2008 8:09 pm
I was perusing RobK's "Seattle Deliveries" page and noticed that the USAF 767-400ER, originally tasked to the now canceled E-10A program, has been assigned the line number 965, so it looks like she's official.
You can view her entry here - http://www.seattle-deliveries.com/767deliveries800-999.htm
Background on the E-10 program can be found here - http://www.globalsecurity.org/intell/systems/e-10.htm
Boeing's page on the plane - http://www.boeing.com/defense-space/ic/e-10a/index.html
I also recommend a read of the article here - http://www.spyflight.co.uk/767%20mc2a.htm
While the original E-10A plan was eventually scrapped due to the inability to combine many fundamentaly incompatible functions (like passive ELINT on a plane engaged in active scanning) , a number of the subsystems designed for her have continued to be funded.
So it is quite possible the USAF wants to complete their 767-400ER and use her as either a static or active test-bed for these systems, which would then eventually be installed on separate fleets of aircraft performing their respective roles.
cancidas
RE: Return Of The 767-400ER - Usaf Bird Assigned Line#
Sun Jan 20, 2008 6:26 am
maybe this is boeing's secret to winning the KC-45 contract...
[Edited 2008-01-19 22:26:50]
"...cannot the kingdom of salvation take me home."
FlagshipAZ
Sun Jan 20, 2008 8:33 am
Good to see that this 767 has a service life now. In any role, she'll be useful, whether military
or civilian. I hate to see any brand-new airframe sit around & do nothing.
Regards.
"Beer is living proof that God loves us and wants us to be happy." --Ben Franklin
Stitch
Sun Jan 20, 2008 7:46 pm
It should also be noted that LN965 has yet to begin construction, and should not be confused with LN953 - N766TT - which is a KC-767 (767-200) for the Japanese Air Self Defense Force.
RobK
Sun Jan 20, 2008 9:02 pm
Quoting Stitch (Reply 3):
Not quite true Chris. 965 is the next one to roll out as the JAL pax machine (ln 964) is out on the ramp in primer so I think 965 will be well on its way to completion.
R
mattcawby
Sun Jan 20, 2008 11:51 pm
Final body join was January 18, it will be outside in three weeks. I will have some pictures but can't put the link here, RobK will try to get my post deleted again.
paineairport.com
Stitch
Mon Jan 21, 2008 12:48 am
I stand corrected. As I wrote it, I was wondering since LN963 is already "out and about", it stood to reason LN965 was somewhat along. Should have gone with my gut.  Smile Since leaving my job in Everett I don't drive by PAE on a daily basis anymore, so I am out of the loop on what's going on.
Devilfish
Mon Jan 21, 2008 4:45 am
Quoting Stitch (Thread starter):
As you noted in the previous thread, the $256M final funding must have gone towards the acquisition of the 767-400ER, and for testing and evaluation of the resulting technology demonstrator and risk-reduction airframe.....
http://www.defenseindustrydaily.com/images/AIR_E-10_MC2A_Concept_lg.jpg
http://www.flightglobal.com/articles...throp-to-end-e-10-development.html
"Awarded to Northrop in its role as E-10A weapon system integrator, the latest $256 million contract covers design and analysis work under a scaled-back technology demonstration programme. But zeroing of the budget for 2008 means work on a new platform - previously expected to use the Boeing 767 - is unlikely to continue beyond the initial design review.
Instead, Northrop and the USAF are looking at transitioning technology to the existing E-8C JSTARS airborne ground surveillance system. This includes the wide-area sensor to be developed under the Multi-Platform Radar Technology Insertion Programme (MP-RTIP) and the battle management, command and control (BMC2) system being developed separately by Northrop for the E-10.
The MP-RTIP active-array radar remains in development for Northrop's RQ-4B Global Hawk unmanned air vehicle, and a larger version could replace the synthetic-aperture radar/ground moving-target indication sensor in the E-8. The still-funded BMC2 suite, meanwhile, could be the basis for a future 'back end' upgrade to the JSTARS."
Here's an older report describing the scope to be scaled back.....
http://www.flightglobal.com/articles...-could-fund-767-400er-testbed.html
"The testbed aircraft configuration would be substantially curtailed from the original plan for a production-representative design, says Jerry Madigan, Northrop's E-10A programme manager. Boeing would still provide the 767-400ER, but Northrop would not be tasked with several planned modifications, including adding in-flight refuelling, anti-icing and military-standard cockpit controls.
The 767-400ER would not be considered the baseline E-10A platform under the new proposal, allowing USAF officials to decide on a common widebody platform for tankers and command and control aircraft after 2008.
In addition, the BMC2 system, which has already been cut back by 40%, would see further capability reductions, says Madigan. Only systems that are focused on providing a capability against cruise missiles and moving ground targets would be retained."
cancidas
Mon Jan 21, 2008 6:21 pm
Quoting DEVILFISH (Reply 7):
is the 762 MRTT and 764 ELINT not common enough? i think so.
Stitch
Mon Jan 21, 2008 7:30 pm
Quoting Cancidas (Reply 8):
Boeing is depending on the 767-200's smaller size to win the KC-45A RFP against the larger KC-30B. Boeing could certainly offer the 767-400ER for the KC-45A, but at that point, the KC-30B really comes into her own in a comparison test.
And as easily as the USAF could use the 767-400ER for both a tanker and an RC/EC/E-series replacement, they could use the KC-30B, as well. So Boeing making the KC-767 Advanced having the same cockpit as the 767-400ER would be a way for Boeing to try and tie the tanker and the RC/EC/E-series replacement together across two platforms from within the same family.
I admit I am kind of surprised the E-10A was based on the 767-400ER. The 767 AWACS uses the 767-200ER so I would think Boeing would have pushed it for the RC/EC/E-series replacement to reinforce the original KC-767 bid, but then again they didn't really have to since they had a sole-source contract for the tanker at the time...
Flighty
Mon Jan 21, 2008 10:41 pm
could it be as simple as, a tanker only needs wing capacity (which the 762 LRF has) and the AWACS application needs more floor space for staff and computers? Tanked fuel is a small and dense material.
The 762 LRF is going to be almost as heavy as a 764. Considering the 764 has more metal on it, the 762 may have superior tanker performance overall.
texl1649
Tue Jan 22, 2008 12:56 am
It's not quite that simple, flighty, as APU requirements and fuel tank configurations etc. have all been thoroughly reviewed for each program, but yes, lift vs. floor space for the two programs are the two fundamental drivers behind the particularized model selection within the 767 airframe program.
TropicBird
Tue Jan 22, 2008 2:37 am
Would the clipped fan GEnx engine for the 747-8 fit under the 767-400ER wing?
texl1649
Tue Jan 22, 2008 12:33 pm
GEnx engines have a 111 inch fan (Trent 1000 is about the same). The CF6 (engine used on the 767) has a fan that's about 105-106 inches (depending on the model).
I'm pretty sure that at one point an improved 767 was considered with a GEnx derivative, but I don't have a link to that and at this point it is possible that is a contrivance of my mind on two sips of coffee. Off-hand though, there's more than 5 inches worth of room for growth under the 767 wing (but Boeing/GE have no intention of doing this, well, maybe GE in a mid-life re-engine program circa 2045 for the USAF).
kc135topboom
Thu Jan 24, 2008 11:23 am
Do we know what MDS (designation) is going to be given to this airplane? C-45B maybe? Or perhaps a C-46A? IIRC, the B-767-400ER is only offered with the CF-6-80 engines, no P&W, like the KC-767ADV has.
RobK
Fri Jan 25, 2008 7:44 am
Quoting KC135TopBoom (Reply 14):
 confused
Hey, how about the E-10A ?!  irked
R
kc135topboom
Fri Jan 25, 2008 9:31 am
Quoting RobK (Reply 15):
I don't know, since there isn't an E-10A program anymore.
ebj1248650
Sat Jan 26, 2008 9:43 pm
Quoting KC135TopBoom (Reply 16):
Excellent answer, TopBoom. I suspect the designation will be C-45 something or other; perhaps RC-45B or EC-45B, reflecting a commonality of sorts with the KC-45? Not sure on this. E-11, perhaps?
Dare to dream; dream big!
aeroweanie
Sun Jan 27, 2008 1:39 pm
ln965 now might be intended to replace N404PA "Paul Revere". N404PA was the testbed for systems intended for the E-10A.
Photo © Dave O'Brien Top Gun Photography
Revelation
Sun Jan 27, 2008 11:23 pm
Quoting Cancidas (Reply 1):
Nope, you can see from http://www.seattle-deliveries.com/767deliveries800-999.htm that LN923 is the frame that was going to be the original KC767, whereas we are discussing which was going to be the original USAF E-10A.
LN923 is more or less a 767-200ER.
LN965 is more or less a 767-400ER.
The current KC767 proposal is a 767-200ER fuse mated with 767-300ER wings and undercarraige and 767-400ER cockpit. No such frame has been built yet.
kc135topboom
Tue Jan 29, 2008 9:54 am
Quoting Revelation (Reply 19):
Maybe I got this wrong, but will the B-767ADV (B-767-200LRF) also have the raked wingtips of the B-767-400ER?
Tue Jan 29, 2008 1:03 pm
Quoting KC135TopBoom (Reply 20):
No, does that surprise you ?
kc135topboom
Sat Feb 02, 2008 11:59 am
Quoting Zeke (Reply 21):
Actually, it does. The KC-30 has winglets, and many airlines are going to put winglets on their B-767s, all to save fuel. Raked wingtips essentially do the same thing as wingtips, reducing wingtip vorticies and drag, like winglets do. The plus side for this during refueling is less wake turbalance from the heavy tanker (but not elimiunation of the wake turbalance).
I know the wings proposed for the KC-767ADV are from the B-767-300ERF, but changing out the wingtips could be (more) easily engineered during the design process.
I don't know how long the -300ERF wingtips are from the main wing fuel tank, and surge tanks to the end of the wing, as compared to the raked wingtip design on the -400ER. Although the B-767-400ER has a 14' longer wingspan than the B-767-300ERF does. Looking at pictures and drawings it appears the raked wingtips of the -400ER are simply added to the standard wingtips of the -300ER. But, I'm guessing there is more engineering work done than that.
Sat Feb 02, 2008 12:38 pm
Quoting KC135TopBoom (Reply 22):
If Boeing get the tanker contract, I think they will put them on. In my view the only reason why they are not there is the extension of 14 ft makes it closer and closer to the A330 wingspan of 197 ft, and blows the footprint issue out of the water.
kc135topboom
Sat Feb 02, 2008 1:58 pm
Quoting Zeke (Reply 23):
It does take some away from their argument, no doubt about that. But, it is still not as much as the A-330s wingspan is still much longer. The B-767-300ERF has a span of 159' 1", and the B-767-400ER has a span of 170' 4", still some 27' shorter than the A-330.
Sat Feb 02, 2008 2:34 pm
Quoting KC135TopBoom (Reply 24):
30' longer than the 135.
kc135topboom
Sat Feb 02, 2008 3:00 pm
Quoting Zeke (Reply 25):
The wingspan of the KC-135 is 130' 10", the same lenght as the B-707-120 series (but it is a different wing design).
Stitch
Sat Feb 02, 2008 5:08 pm
Perhaps the wingtip extensions affect the vortex propagation behind the wings and this could impact either the stability of the two drogue refueling hoses or the stability of the planes tanking off those respective hoses?
Spacepope
Sun Feb 03, 2008 2:48 pm
Quoting Stitch (Reply 27):
This could be. To extend that train of thought, the drogue tests (which were problematic for the Japanese and Italian fleet) were done on non-wingtipped 762s. Perhaps by not putting them on, Boeing can avoid new testing criteria.
kc135topboom
Tue Feb 05, 2008 10:44 am
The drogue test for the JASDF was only based on the centerline hose reel drum. The KC-767J does not use wingtip refueling pods.
But, I think raked wingtips, or blended winglets would be helpful on a KC-767, the KC-30 already has winglets..
dalb777
Mon Jun 23, 2008 4:35 am
Has there been any word on the fate of this aircraft? It is still sitting on the ramp at PAE (next th the EK 777):
http://www.microvoltradio.com/images/kpae3537.jpg
Who technically owns it, the USAF or Boeing???
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
XT6Wagon
Mon Jun 23, 2008 6:49 am
Quoting Stitch (Reply 9):
I think it was due to the size of the equipment at the time of the bid. Since then like all electronics the stuff they were going to put in has gotten alot smaller.
TropicBird
Mon Jun 23, 2008 5:11 pm
Quoting Dalb777 (Reply 30):
I was told it belongs to Boeing and later read it is for sale.
