Quoting Keesje (Reply 1): Just buying a standard aircraft & customizing it would have been so much cheaper, faster & better. |
Quoting RC135U (Thread starter): I didn't know the Nimrod fleet was in such peril after that loss a year or two ago over Afghanistan. |
Quoting GDB (Reply 4): The Nimrod MRA.4 is a great idea, that was for years, very badly executed. They'd be in service now had all new airframes been brought - possible since only the original fuselage pressure shell is left from MR.2 Nimrods, everything else is new, the conversions even get new serials. But try getting that past the Treasury back in 1996, 'conversions' imply quicker and cheaper. The MoD can say 'look, we are not asking for new aircraft here'. |
Quoting RC135U (Reply 2): I don't think the P8 is the answer, but for fun a 757 pops into my head, maybe because it stands tall off the ground with lots of clearance for antennae and radomes and such, and it's not short on power. Too bad 757s are in demand these days. |
Quoting KC135TopBoom (Reply 5): Hmmm, I wonder if this has anything to do with the USAF now wanting their B-767-400ER built? |
Quoting RC135X (Reply 7): Quoting KC135TopBoom (Reply 5): Hmmm, I wonder if this has anything to do with the USAF now wanting their B-767-400ER built? Yes. I can't imagine the USAF lending any RJs given their current tasking (not to mention training RAF crews, etc.). I realize this might open a real can of worms, but I think there is a stronger and more compelling reason to buy RC-135/E-3/E-6/E-8 replacements than additional F-22s. |
Quoting MD90fan (Reply 8): Wow, RAF seems to be short on just everything,from the bewitched C-130s, to picking up Saffie Pumas and Danish EH-101s, now this? |
Quoting KC135TopBoom (Reply 9): The RN is in even worse condition. |
Quoting Venus6971 (Reply 10): The Brits have always been trying to stuff a elint/signit/AEW suite into a Nimrod with mixed results, |
Quoting Venus6971 (Reply 10): There are alot of low time KC-135A's in AMARC that are slotted for FMS, since the engineering has been already done to convert -135's to the RC configuration and the formerly known" E systems"(Greenville Texas) is now owned by BAE I can see the blocks fall into place . |
Quoting RC135U (Reply 13): Maybe the RAF would really like an RC-135U Combat Sent platform, and I'm intrigued by the suggestion of going to AMARC for a 135 frame or two. Too bad there's no Rolls counterpart to the CFM56. |
Quoting GDB (Reply 12): Yep the RAF are strained, no doubt. Maybe some of our European NATO allies do not have these strains, since they are not operating at the same tempo-or sending troops/assetts to fight in Southern Afghanistan. |
Quoting KC135TopBoom (Reply 14): The Brits don't need an RR equivelent to the CFM-56, since half of it is built in France. Also, the RAF already flys the CFM-56 in their inventory, aboard their E-3K AWACS |
Quoting Spacepope (Reply 15): Quoting KC135TopBoom (Reply 14): The Brits don't need an RR equivelent to the CFM-56, since half of it is built in France. Also, the RAF already flys the CFM-56 in their inventory, aboard their E-3K AWACS E3-D. The -K is the Saudi version, with boom. |
Quoting KC135TopBoom (Reply 14): For years, it has been rumored the different RC-135 configuerations were the world's most expensive airplanes. |
Quoting RC135U (Reply 2): What airframe were the RAF planning to use to replace the R1 before budget woes caused then to abandon that approach? What off-the-shelf airframe would be suited for this mission? You'd need something able to lift a recon suite that is generally on the heavy side, plus the mission operators ("back enders" in the RC-135s) and their gear, then some decent range is a good idea so you don't necessarily have to depend on too many refuelings. I don't think the P8 is the answer, but for fun a 757 pops into my head, maybe because it stands tall off the ground with lots of clearance for antennae and radomes and such, and it's not short on power. Too bad 757s are in demand these days. |
Quoting RC135X (Reply 17): Based on open sources, I have a hard time believing that the MR1 is that much more capable than the current Bloc of the RIVET JOINT in terms of ELINT collection. The AEELS is the "industry standard" and has been for years, serving as the basis for the Israeli and South African suites, as well as some alleged installations on other airframes for other nations. The RIVET JOINT Raven crews were well qualified to deal with radar and ELINT. |
Quoting Bennett123 (Reply 21): Do you mean MR1 or R1. The former is the initial standard of what is now MR2 and will soon be MR4. The R1 is the ELINT bird. |
Quoting GDB (Reply 24): But a NATO force, like the AWACS arrangement, as proposed for ground surveillance, on A321 or any suitable airframe, would be a very useful asset for European AF's. |
Quoting Columba (Reply 19): Well Nato will get Ground Surveillance aircraft based on the A321 maybe the RAF could buy some for their own: http://www.globalsecurity.org/milita...s.htm |
Quoting KC135TopBoom (Reply 27): The only programs I know of to replace any RC-135 model, is the E-10A (possibly) or the USN EP-X program. |
