Quoting Zeke (Reply 99): March Air Reserve Base, Calif |
Thats really good, March will have MQ- 9 Reapers, C-17s and KC-X!
Quoting Zeke (Reply 99): They had the same choice between the upgraded F-15 and the F-22, history shows which was they went there, and now you are suggesting they should buy more F-22s, the aircraft with more capability. |
Quoting Zeke (Reply 99): Yes the KC-767 might, but the 767 line will not employ more people than the A330 line in the US. The KC-30 also brings the A330F. |
Quoting Zeke (Reply 99): The 767 line has a small backlog, plus whatever tankers, the A330 line would be for 400 odd freighters and the tankers (and possibly for A330 passenger aircraft when the A350 goes into production). |
Quoting Zeke (Reply 99): No, NG is doing the US military conversion of the aircraft. |
Quoting Zeke (Reply 99): 5 KC-30s provide the capability of about 9-10 KC-135R aircraft, |
Quoting Zeke (Reply 99): he bases that are earmarked for the KC-X are : |
Quoting Zeke (Reply 99): They did not use a different assessment standard or specification for NG and Boeing. |
Quoting Zeke (Reply 99): Same could be said about Boeing in Seattle, lots of talk has been made of them moving the future 737 assembly where it cheaper, and the majority of the 787 is made elsewhere. |
Quoting Zeke (Reply 99): Large wing span yes, highest weight, no. Depending on the surface, the KC-30 actually has a lower ACN than the KC-135 |
Quoting Alien (Reply 101): Really bad analogy Zeke. The F-22 is a game changer. It is a quantum leap in capabilities over the F-15. The Kc-30 is merely bigger and can carry some more fuel and cargo. It does not do o for less money and it does not change anything in any way. |
Quoting Alien (Reply 101): This is just laughable. The assembly line in Alabama, according to EADS will employ 1500 - 2000 people. Compare that to the entire supply chain of the 767 being kept intact for the next 10 years. It's not even close. Keep the 1500 metal slapping jobs in Europe. I would rather keep the 10s of thousands of engineering jobs here. |
Quoting Alien (Reply 101): Big deal. NG is bolting in radios and doing PR. Thats like saying the IFE vendor is the prime contractor for the A380. |
Quoting Alien (Reply 101): Thats not so good Zeke. It's all about having greater numbers of booms in the air. You get less booms with the KC-30. |
Quoting Alien (Reply 101): Don't you think you are being a bit premature? |
Quoting Alien (Reply 101): The most certainly did use a different standard. They told boeing that they had the right sized tanker. |
Quoting Alien (Reply 101): Unlike Mobile where the planes are slapped together from major assemblies, Boeing has a large engineering presence in Washington. |
Quoting Alien (Reply 101): It is a fact that extensive upgrades of runways, taxiways and hangers will have to be performed. |
Quoting Ken777 (Reply 90): The key for the WTO issue is that Airbus cannot pass on any charges, or increases in related costs, that they may get hit with if the WTO rules against them. |
Quoting Alien (Reply 101): You get less booms with the KC-30. |
Quoting Alien (Reply 101): They told boeing that they had the right sized tanker. |
Quoting NorCal (Reply 70): Do you buy an SUV if a sedan will do the job? |
Quoting NorCal (Reply 70): There was never any doubt that the KC-30 could haul more stuff than the KC-767. The debate has always been rather that extra capability was really needed and how much it would cost to get it. |
Quoting Ken777 (Reply 98): Of course the AF generals wants bigger planes, regardless of the costs. As far as I'm concerned they have their head in the clouds when it comes to costs. Why settle for a plane that can do the job when you can buy a bigger plane for more money? One should not dare to ask them if the KC-10 can handle those rare and unique jobs the 330 can do, but the 767 can't. |
Quoting Stitch (Reply 107): Boeing is not going to pitch the 777F unless the DoD tells them it would win because it would get even more "extra credit" then the KC-30A. |
Quoting Rheinwaldner (Reply 105): Depends on the job. In this case the job would be to deliver fuel to gas stations with a fleet of 180 cars. If 180 SUV's would cost only a little more than 180 sedans what car would you take to do that job? |
Quoting Rheinwaldner (Reply 105): IMO the cargo capability alone will allow huge savings. Having a bunch of freighters with leading efficiency in the fleet will allow to cut costs a lot. |
Quoting Rheinwaldner (Reply 105): I dare to say that the existing cargo fleet causes multitude of costs per transported ton compared to the KC-30 in the airlifter role. |
Quoting Rheinwaldner (Reply 105): Even against outsourced cargo operations the KC-30 will shine on the cost side. Save many, many tax $! |
Quoting Rheinwaldner (Reply 105): It is my understanding that with tanker-operations the airplanes have long idle times. That suits well to the idea of a multi-role-aircraft. Highly improved usability |
Quoting Zeke (Reply 99): hat is very true, but that plant is already involved with the A330/A340/A350/A380. |
Quoting Keesje (Reply 108):
It's much heavier and does not meet the 7000 ft runway requirement met by the 767 and A330, would be far more expensive, has to be developed from the start taking years etc.. I think it would score low. You can score "extra credit" within given requirements, not outside. |
Quoting Stitch (Reply 107): What is the point of even re-bidding? If the DoD is going to give the KC-30A all the "extra credit" that won it the RFP in the first place, then it is going to win the re-bid, as well, on the same grounds. Boeing is not going to pitch the 777F unless the DoD tells them it would win because it would get even more "extra credit" then the KC-30A. So at this point, Boeing should probably do what NG/EADS did and threaten to pull out of the RFP because it cannot possibly win based on the RFP criteria being tailored to the "other team's" product. |
Quoting Zeke (Reply 99): The other aspect of the post which you are obviously inferring is the KC-767 would fit 8 aircraft, that is also false |
Quoting Zeke (Reply 99): they should have kept Boeing informed and the discussion open |
Quoting DeltaL1011man (Reply 55): The A330 cost more burns more fuel and puts 8,000 people out of a job. |
Quoting MOBflyer (Reply 67): If it burns more fuel but can offload enough to compensate, then it is a better value. |
Quoting Zeke (Reply 69): Aerial Refueling Efficiency = (fuel offloaded) / (fuel burned + fuel offloaded) |
Quoting Rheinwaldner (Reply 105): Depends on the job. In this case the job would be to deliver fuel to gas stations with a fleet of 180 cars. |
Quoting Revelation (Reply 111): Heck, if they can vote for FISA with a clear conscience, they'll vote for anything. |
Quoting MOBflyer (Reply 82):
I just wrote a letter to Senator Murray of Washington State: |
Quoting Rheinwaldner (Reply 105): Makes no sense if we consider that the capacity gain is bigger than the cost gain. To show the principle take this example: The KC-30 allows missions to fly with say 2 aircrafts that would require 3 KC767 or 5 KC 135 -> Huge savings over the time! |
Quoting NorCal (Reply 109): There are still plenty of other states in the union like Alabama that will do the work for cheaper than Seattle. Maybe that'll teach the unions to stop being so greedy. |
Quoting Revelation (Reply 111): I think the USAF/DoD can rewrite the RFP to get whatever plane they want, and I think they now want the A330. |
There's still a few more rounds to play out, but at some point Boeing will have to decide how to deal with the loss. |
Quoting TropicBird (Reply 118): The small category aircraft were dismissed as not cost effective as was the very large category A380 |
Quoting BlackKnight (Reply 121): The point is the USAF needs changed. Boeing was focused upon the 1 round proposal which they won first. The USAF changed their minds in the process of the 2 round. EADS listened and Boeing held tight to the paper RFP which already they had won previously. The score is now 1 to 1. This seems to be the best 2 out of 3. The sad story is that Boeing's cheese has moved and it is unknown what they will do now. |
Quoting ANZUS340 (Reply 122): Does anybody really believe the US is going to give a contract like this to an outside party? If anybody believes another company aside from Boeing will ultimately win this contract then you are wonderfully gullible. |
Quoting NorCal (Reply 109): Really, that is it? That is more of a raw deal then I thought. I thought all the major parts (wings, fuselage, tail, etc.) were coming to NG and then being assembled into the plane. I thought that was the plan all along? If all they are doing now is just adding the boom and the other equipment then that is a raw deal and hardly a final assembly line, the Chinese got a better deal then NG and the state of Alabama did. I thought they were doing both? |
Quoting M27 (Reply 119): After going back and reading the article above, I have some problems with this being a fair and impartial redo, and even that the DOD doesn't care who wins. Hope congress is watching really closely! Young said that Boeing has no basis for protesting. "Everything I have seen is, this was a very well-run source selection, by the books and in accordance with the law," he said. Sure thing Mr Young!! |
Quoting AirRyan (Reply 127): Your smoking dope if you think this is less to do about specifics than it is politics |
Quoting AirRyan (Reply 127): I can't imagine the JSF or F-22 getting the nod right now in this climate, we still can't even resolve CSAR-X. |
Quoting AirRyan (Reply 127): Boeing doesn't deserve either one of the bids until they can offer the USAF cutting edge and modern technology and not what's lying around in their parts closet |
Quoting M27 (Reply 119): Young said that Boeing has no basis for protesting. |
Quoting TropicBird (Reply 126): But I would disagree that Boeing won round 1 |
Quoting Ken777 (Reply 129):
If he believes that then is didn't read the GAO report. All we need running this additional review is someone who is still living in the pre-Boeing protest era |
Quoting MOBflyer (Reply 125): The planes (A330F) will be fully assembled by Airbus in Mobile. They will then roll about a football field's length to the adjacent NG facility, where they will be militarized and converted to tankers. |
Quoting Curt22 (Reply 131): Then sometime in the near future, the aircraft in pieces and production facilities will be utterly destroyed when the next major hurricane slams into Mobile Bay! Why on God's green earth did NG/EADS select such a vulnerable location to build aircraft? Before you defend how safe the Mobile location is, many remember what happened only a mile away at Battleship Park to the USS Alabama and the aircraft display hangar, and even greater destruction of Biloxi/Kessler AFB MS just 50 miles to the west. |
Quoting Stitch (Reply 132): I believe Mobile was one of the sites Boeing was looking to assemble the 787 at. |
Quoting MOBflyer (Reply 133): Kind of funny they called us stupid and incapable of building aircraft. |
Quoting NorCal (Reply 70): Alternatively there is another theory available to why NG got the bid. Boeing and a lot of other experts thought Boeing had the bid in the bag, but NG lobbied enough to get the extra credit clause added. They said they were going to walk away from the competition if the bid wasn't adjusted to give them a chance of winning. NG has just as powerful of a lobby as Boeing does. |
Quoting NorCal (Reply 70): NG is just going to be a contractor assembling planes. This will not give them the know how or financial resources to build a commercial jet. As soon as the contract is filled and the A330 goes out of production, the assembly line and the aerospace center disappears. NG will just go back to what they are really good at, building aircraft carriers. |
Quoting RedFlyer (Reply 71): Being able to "operate" from an airfield is a little different than being able to operate out of it efficiently or maintaining the same operational tempo. For example, the 161st ARW is located here in PHX. The ANG ramp on the south side of PHX can currently accommodate, I believe, 8 tankers. Of course, the KC-30 can operate from PHX, but without structural enhancements those 8 tanker pads will be able to accommodate not more than 5 KC-30s. |
Quoting MOBflyer (Reply 72): Quoting NorCal (Reply 70): If you are using it to that end most of the time. I would argue that if there is EVER a need for it, then it should be in the AF inventory. |
Quoting NorCal (Reply 74): 767s won't be built forever either but once that project concludes those workers can move to the 737RS ot Y3 down the road. What aircraft project after the A330 is Airbus planning on assembling in Mobile? |
Quoting NorCal (Reply 75): You are assuming the dollar will stay weak forever. As soon as the dollar regains its strength Airbus will cut ties and run. |
Quoting MOBflyer (Reply 79): Just like the autos, refineries, and other manufacturing positions? They've all come to the south for this cheap labor, and the mast majority are still enjoying it. |
Quoting Tugger (Reply 135): Quoting RedFlyer (Reply 71): Being able to "operate" from an airfield is a little different than being able to operate out of it efficiently or maintaining the same operational tempo. For example, the 161st ARW is located here in PHX. The ANG ramp on the south side of PHX can currently accommodate, I believe, 8 tankers. Of course, the KC-30 can operate from PHX, but without structural enhancements those 8 tanker pads will be able to accommodate not more than 5 KC-30s. So won't 5 KC-30's be able to do the job of 8 KC-135's? |
Quoting Stitch (Reply 132): I believe Mobile was one of the sites Boeing was looking to assemble the 787 at. Boeing also has a large IDS presence at Huntsville. |
Quoting MOBflyer (Reply 133): Katrina was an exception to the rule. But I concur: if a tropical storm hits within 50 miles of MOB, you can go swimming in downtown. That hasn't stopped MAE (Singapore Technologies - Mobile Aerospace Engineering) from doing conversions and heavy maintenance for most major US carriers as well as many international ones. |
Quoting Tugger (Reply 135): Hurricanes are rare and seldom hit the same spot twice. Also the military and defense industry sites in the area recovered very quickly. I mean what happens when the Cascades fault line let go and wipes out all of coastal Washington? |
Quoting Baroque (Reply 138): A bit of a wild guess, but I think they might rebuild them. Perhaps a bit faster than the restoration in NO?? |
Quoting MOBflyer (Reply 142): Katrina had the storm surge and geographic span of a Category 6 hurricane. |
Quoting Redflyer (Reply 144): The Saffir-Simpson Hurricane Scale only goes as high as Category 5. |
Quoting Curt22 (Reply 140): Lost bridges, railways, power distribution, communication systems etc take time to repair. Doesn't mean much to repair the EADS hangar if the railways, ports, bridges and power of the coastal town of Mobile is still in shambles. |
Quoting Baroque (Reply 146): I have to say, news of hurricanes in the GoM has been very limited so perhaps they were not aware of any problem. angel |
Quoting MOBflyer (Reply 145): My point exactly. As I said earlier, Katrina was the exception, not the rule. Also, I am aware that the SS scale disregards storm surge and storm size. Someone just said that MOB was so jolted b/c of a Cat 3 hurricane hit 120 miles west, and they implied that that would happen with any hurricane. The Battleship and hangar had never been damaged so... ever. |
Quoting Curt22 (Reply 148): Katrina was the exception? No, it was not...Katrina was just the latest in a long line of storms who have done significant damage to Mobile and this one didn't even make landfall near Mobile. |
Quoting Curt22 (Reply 148): I mean to imply nothing...I mean to state as fact that MOB has sustained significant damage from a storm that landed 100 miles away, we can expect even greater damage to the town and future EADS facilities should the town take a direct hit from a major hurricane in the future. |
Quoting Curt22 (Reply 148): To claim that since the battleship and hangar had "never" seen such damage in the past means this are will never see such damage in the future is as foolish as it is wrong. |
Quoting Curt22 (Reply 148): You can pretend that Mobile has NEVER sustained significant damage from hurricanes in the past but the fact is I have named but a few of the storms and the years they struck the AL gulf coast and all can "google" these storms and see the very real, very deadly, and very costly these storms have been to the Mobile area time and again. Aug 69 - Camille Sep 79 - Fredrick Jul 97 - Danny Sept 98 - Georges |
