Quoting N328KF (Reply 1): Ares I is a joke. What fool decided that solid rockets were a good idea for manned boosters? That thing's a damn firecracker... |
Quoting DfwRevolution (Reply 4): There is no more fundamental risk between launching a manned vehicle on a solid rocket versus a liquid rocket. |
Quoting Moo (Reply 6): ckets can't be shut off, liquid rockets can be - the degree of control is much greater. |
Quoting Moo (Reply 6): Solid rockets can't be shut off, liquid rockets can be - the degree of control is much greater. |
Quoting N328KF (Reply 7): This is exactly my point. SRBs are great for ICBMs or satellites, |
Quoting N328KF (Reply 7): but Ares I is a recipe for death. |
Quoting TheSonntag (Reply 8): And while the same was true for shuttle, its SRBs at least could have been jettisoned, |
Quoting TheSonntag (Reply 8): I mean, if we look at the current situation, the Orion capsule and its safety system can also be put on another rocket system. So this is no wasted use of money. Scrapping Ares I now would still be relatively cheap. |
Quoting N328KF (Reply 7): This is exactly my point. SRBs are great for ICBMs or satellites, but Ares I is a recipe for death. |
Quoting Thorny (Reply 5): That may be true, but Ares I's performance problems are essentially tied to the decision to abandon the Space Shuttle Main Engine as the upper stage powerplant. That cost the vehicle 200,000+ lbs. of thrust and a few dozen seconds of ISp where it needed it the most. Since the decision to go with J-2S (and then J-2X) the SRB grew from four segments to five, and now might inherit Ares V's 5 1/2 segment design. It will be so long, they might as well name it the Javelin. NASA needs to pull the plug on Ares I as soon as possible. Sure, all launch vehicles have gone through teething problems (Saturn V's second stage was a real bear) but there are alternatives essentially available off the shelf now, or at most requiring 1/2 the development time and costs to field. Why is NASA wasting so much effort on this dog of a rocket? To save Ares V, which itself is turning into an unaffordable behemoth? Pull the plug, NASA. Change the architecture from 1 1/2 launches to a full-fledged 2 (which it really is anyway) and use Delta or Atlas as the basis of Ares I (call it Ares II to save face) at least for the first stage, perhaps a smaller version of the Ares I Upper Stage on top, using the earlier/easier J-2S engine instead of the costly and unproven J-2X. Or go the DIRECT/Jupiter direction, NASA. Call them Ares III and Ares IV if you want to... they started out as NASA NLS proposals anyway, and it won't be the first time rockets skipped numbers in their designation series (no Saturns II, III, and IV, or Atlas IV was ever built, remember.) The public won't really notice, and all Congress is worried about is jobs, and all the alternatives still employ a lot of Shuttle people. |
Quoting Thorny (Reply 9): Not while they were firing... they'll race ahead and incinerate the Orbiter/ET if the stack somehow survives the seperation (which will be violent). Shutting down the SRBs in flight is theoretically possible (blowing off the nose cap to reduce chamber pressure to zero) but the stack wouldn't survive that, either, so the option was dropped early in development (you can still find some pictures of Titan IIIs with thrust-termination covers on the tops of the solids) |
Quoting Connies4ever (Reply 11): The decision to back away from the SSME to me is unfathomable. |
Quoting Connies4ever (Reply 11): Seem to recall reading (sorry, I have no link) that if the crew tried to bail on the SRBs while they were firing, the orbiter would pivot back on the aft attach points, wings would come off, and then what's left (if not incinerated as indicated by Thorny) would do essentially what the crew cabin did on -51L. Same conclusion. |
Quoting Nomadd22 (Reply 13): I'm pretty sure that the one booster failure everybody refers to wouldn't have been that serious on the Ares I, although it caused the destruction of Challenger. |
Quoting TheSonntag (Reply 14): How much weaker is a J-2x compared to a SSME? |
Quote: New engine configuration under evaluation for Ares V By Chris Bergin/David Harris, 8/1/2008 12:21:54 PM The Ares V core stage team is currently evaluating a configuration change to the location of the six RS-68 main engines on the ever-growing Ares V. External engine fairings - similar to the Saturn V first stage - are being considered, in order to configure the six RS-68 engines away from the Solid Rocket Booster exhaust. (snip) |
Quoting Cloudy (Reply 19): What would come after is anybody's guess |
Quoting Thorny (Reply 20): Ares I seems to be a lost cause, and I think McCain's advisors will make that clear to him. Griffin might be reappointed by McCain, |
Quoting Thorny (Reply 20): Starting up deep space operations once the Shuttle's heavy-lift infrastructure is gone will be even more expensive than Ares I and Ares V are today, and they are approaching "impossibly expensive". |
Quoting Cloudy (Reply 22): Who would tell McCain what he needs to hear? |
Quoting Cloudy (Reply 22): After the election he won't have much time for this issue. There are far more pressing matters he has to deal with |
Quoting Cloudy (Reply 22): He may start a MASSIVE investigation, which would probably result in the end of all US ambitions beyond Earth orbit. |
Quote: "September 2014 is when we are saying we will launch the first crew on the Orion," program manager Jeff Hanley told reporters in a conference call Monday. |
Quoting TheSonntag (Reply 25): Are they dreaming? They are low on budget, facing lots of delays, suffering from technical problems, how on earth do they want to be faster? |
Quoting Thorny (Reply 26): Shocked. Shocked I am. |
Quoting TheSonntag (Reply 28): But wasn't 2014 always the targeted date for the first Orion mission anyway? So far, even that date seems very doubtful for me. |
Quoting TheSonntag (Reply 28): So they better try to get Orion going. |
Quoting Thorny (Reply 29): I really think Congress is going to start pushing NASA on this now. 2015 is the same year ISS is to be decommissioned. (Everyone thinks that date will be pushed back, but Congress has not bought into that idea yet, so they might be irked by NASA's endless delays in Orion.) |
Quoting Sv7887 (Reply 30): One question. Is there any way Congress would say, "heck with it, just fly the shuttle to bridge the gap" |
Quoting DfwRevolution (Reply 31): Keeping the Shuttle active past 2010 means delaying Orion even further unless Congress steps forward and gives NASA the funding to continue operating STS while Orion is in development. |
Quoting Sv7887 (Reply 30): Thorny thank you so much for your posts on Anet. I truly enjoy the vast wealth of knowledge you bring here. |
Quoting Sv7887 (Reply 30): What was the basis for this recommendation? |
Quoting Sv7887 (Reply 30): Was it a genuine safety concern or was it more of a economic incentive to push NASA onto Constellation? |
Quoting Thorny (Reply 29): Now 2014 is first manned flight and 2015 is first operational mission. |
Quoting Moo (Reply 34): Interestingly enough, this means that a minimum 3 year absence of US personnel from the ISS is likely - the Shuttle retires in 2010, but currently NASA only has an exemption from the 'Iran Non Proliferation Act' until 2011. |
Quoting Cloudy (Reply 35): This would require a large increase in Soyuz production, |
Quoting Cloudy (Reply 35): NASA plans to keep a presence on ISS during the gap by buying Soyuz rides from the Russians. That plan may be questionable, however. |
Quoting Thorny (Reply 38): Technically, the Georgia affair has nothing to do with Russia selling nuclear technology to Iran, so maybe not. |
Quoting BOACVC10 (Reply 40): Does anyone have a list of the companies that are working in the two areas (Moon, Mars) so far? I am familiar with the NASA publications, but am looking for background information about the players only. |
