( Quoting Ba97 )
Quite simply, in my view, the "jump" was brought about by the availability of more raw power thanks to bigger, larger and more fuel-thirsty engines, such as the J75 ( on the F-105 ) and the J79 ( on the F-4 and the F-104 amongst others ).
The quest at the time was for ever more speed ( in a straight line at high altitude ), as well as more range and more fire-power. Obviously, this meant more fuel, and hence more weight and larger size, with very little attention to aerodynamics.
This was a common trend adopted by fighter designers all over the world, but especially in the USA, as exemplified by the whole so-called " century series " of large , heavy and fairly complex multi-role fighters, such as the F-100 Super Sabre, F-101 Voodoo, F-102 Delta Dagger, F-105 Thunderchief , F-4 Phantom and F-8 Crusader. It reached its zenith with the aborted
YF-12 ( which was eventually adapted as the
SR-71 Blackbird strategic recce aircraft), before advances in aerodynamic research led to the next generation of much more capable multi-role fighters powered with far more efficient turbofans with far lower fuel consumption rates and allowing for greater maneovrability, high speeds at all altitudes, longer ranges and heavier weapon loads, without the need for big sizes and ultra-heavy weights.
This was infact the generation examplified by the F-16 Fighting Falcon and the F-18 Hornet
as well as the relatively heavier F-15 Eagle and F-14 Tomcat. Also, around the world, it led to such types as the MiG-29 and Saab-39 Gripen.
Even the Soviets caught up with the trend and moved on from such enormous types as the
TU-128 Fiddler and Su-15/21 Flagon to more realistic and operationally flexible types like the MiG-29 and the formidable Su-27/30 family.
