Quoting AWACSooner (Reply 3): as my job MIGHT possibly depend on the outcome of this mishap investigation. |
Quoting Cross757 (Reply 4): How is that, exactly? Seems like it was a mechanical malfunction. There might possibly be some pilot error involved if a checklist was not followed properly (i.e. they knew of a possible malfunction prior to landing). Let's not over-sensationalize this, please. |
Quoting Venus6971 (Reply 6): Being a mx troop I would call that a hard landing. |
Quoting Venus6971 (Reply 6): According to the grapevine it was the pilot flaring late or not at all and landing on the nose gear first blowing the nose tires and sending the main gear through the wing. Being a mx troop I would call that a hard landing. But never believe the first reports they are usally wrong. |
Quoting KC135TopBoom (Reply 8): Did the MLG break into the wing? If so, that would be a write-off in most cases. But, looking at the pictures, it does not seem like that happened, at least not in a major damage way as the AWACS is sitting on in a "normal" atitidude for no NLG. I guess the E-3s have enough nose ballest to keep the tail up if the NLG fails, as that frisby weighs a lot. |
Quoting AWACSooner (Reply 3): Looks like 0556, but I can't tell from the pic (God I hope it's 0009, that jet is the bane of my existence). My roommate from OTS was on that jet (I'm in another squadron), I'll see what all he can tell me without compromising the investigation. Obviously, there's gonna be a LOT of inquiries going on here...I would ask that the hearsay and speculation be kept to a minimum...as my job MIGHT possibly depend on the outcome of this mishap investigation. |
Quoting Venus6971 (Reply 9): Everytime we had a acft with gear problems at LSV we always had to safety wire the landing gear pins in for a geardown flight back to Tinker. If the Keal beams and the wing spars are undamaged I say repair it. |
Quoting KC135TopBoom (Reply 11): Normally correct. You are also right about the B-1B and two C-17As, but all of them were all gear up landings, and usually produce less damage than one with no NLG, or one where the NLG collapses during the landing. Recently an AA B-767-300ER in maintenance at the AA maintenance hub in TUL had the NLG collapse during maintenance work, no jet taxiing,or anything, but she broke her keel beam. Yes, I know the drop is a lot higher on a B-767 than a B-707. My concern is the fire, even though it was extinguished quicly, all that sheet metal and the stringers, and possibly that portion of the keel beam will need to be replaced just from the heat stress, let alone the damage from falling and sliding on the runway. Do we know how far the AWACS slid on the runway before coming to a stop? The accident investigators will measure that based on the scars on the runway. |
Quoting KC135TopBoom (Reply 11): Recently an AA B-767-300ER in maintenance at the AA maintenance hub in TUL had the NLG collapse during maintenance work, |
Quoting Venus6971 (Reply 12): I believe there is a magic number of cost if it excedes that number it will be scraped even if repair is possible. |
Quoting RFields5421 (Reply 13): Quoting KC135TopBoom (Reply 11): Recently an AA B-767-300ER in maintenance at the AA maintenance hub in TUL had the NLG collapse during maintenance work, I thought this occured at Alliance - AFW |
Quoting Venus6971 (Reply 9): If the Keal beams and the wing spars are undamaged I say repair it. |
Quoting KC135TopBoom (Reply 11): NLG collapse during maintenance work, no jet taxiing,or anything, but she broke her keel beam. |
Quoting KC135TopBoom (Reply 11): Recently an AA B-767-300ER in maintenance at the AA maintenance hub in TUL had the NLG collapse during maintenance work, no jet taxiing,or anything, but she broke her keel beam. |
Quoting BladeLWS (Reply 21): Keel beam runs the length of the aircraft and provides its structural support, just like the keel of a ship, it runs the bottom of the aircraft. |
Quoting BoeingFixer (Reply 23): I would find it very hard to believe that a nose gear collapse could compromise the Keel Beam unless parts of the nose gear impacted the area of the Keel Beam. |
Quoting Fridgmus (Reply 25): Could one of you tell me why "The Frisbee" could not located in a more forward position on the aircraft? Wouldn't that help with the CG? |
Quoting Venus6971 (Reply 27): I do not know of a piece of concrete that is legal to jack anything bigger than a F-111 at Nellis and zero hanger space for a E-3. |
Quoting KC135TopBoom (Reply 28): Could this be a job for the Boeing AOG repair team? I know the TIK MX troops and Depot guys are experts on the B-707 airframe now, maybe some of the best B-707 people in the world, but, the Boeing team has a great reputation of getting things done at a bear base situation. The thin ramp at Nellis is not a real problem as they can shore it up with steel and wooden mats to place the jacks on. Hanger space might, or might not be a problem. A tempoary shed can be built over the aircraft. |
Quoting Venus6971 (Reply 29): Quoting KC135TopBoom (Reply 28): Could this be a job for the Boeing AOG repair team? I know the TIK MX troops and Depot guys are experts on the B-707 airframe now, maybe some of the best B-707 people in the world, but, the Boeing team has a great reputation of getting things done at a bear base situation. The thin ramp at Nellis is not a real problem as they can shore it up with steel and wooden mats to place the jacks on. Hanger space might, or might not be a problem. A tempoary shed can be built over the aircraft. Boeing AOG team would be the right answer, I know the 552 mx guys they sent but they have zero experiance with this type of job. I have no doubt they will figure it out. The E-3 is too valuable just to write off if it was like a C-130 or T-38. I just wondering when they start digging into it how many worms they will find into that bucket. Plus getting Boeing involved is way above my pay grade, those guys don't work cheap. |
Quoting KC135TopBoom (Reply 32): Good reminder, I had almost forgotten about this accident. I have not heard anything. The AWACS folks are a pretty quite group normally. Hopefully someone will post something soon. |
Quote: Pilot mistakes led to the $100 million crash landing of an E-3 AWACS on Aug. 29, an investigation conducted by 12th Air Force found. The report, released Tuesday to Air Force Times, concluded that the E-3’s pilot and co-pilot allowed the jet’s nose wheel to hit the runway at Nellis Air Force Base, Nev., so hard that it broke the nose landing gear. The jet skidded down the runway for 4,500 feet before coming to a stop. Investigators believe that about 100 feet above the runway, in calm weather, the pilots lost track of the plane’s altitude. The co-pilot, who was handling the landing, put the aircraft into a steeper than normal approach. With the jet 50 feet high, the pilot called for the co-pilot to bring up the nose, but it was too late to prevent the hard landing. |
Quoting venus6971 (Reply 37): Can go only on rumors that Boeing is doing the work and they are going to graft a 707-300 forward fuslage on it from AMARC doner acft. |
Quoting KC135TopBoom (Reply 41): RAF E-3D. |
Quoting FlyingSicilian (Reply 10): That must have been some hard landing since the E-3 was designed to land with almost no flair to begin with. |
Quoting bucky707 (Reply 43): I'm curious how being a SD qualifies you to comment on how to land a E-3? |
Quoting AWACSooner (Reply 45): For us flight deck peeps, we have to undergo lots of extra training due to it...not fun! |
Quoting ZANL188 (Reply 42): Quoting KC135TopBoom (Reply 41):RAF E-3D. Was the RAF frame actually scrapped or is it some sort of super can bird? |
