zanl188
Bezos Finds Apollo 11 F-1 Engines
Thu Mar 29, 2012 12:20 am
Amazon founder Jeff Bezos claims to have found the F-1 engines from Apollo 11.
If true this would be a major, major find with huge historical significance.
Let's hope he can raise one, hopefully all, from 14000 ft down on the ocean floor.
http://www.bezosexpeditions.com/engine-recovery.html
kc135topboom
RE: Bezos Finds Apollo 11 F-1 Engines
Thu Mar 29, 2012 12:31 pm
This would be a major undertaking for anyone. A burnt out F-1 engine weighs more than 20,000 lbs, not counting the the weight of the wreckage of the S-1C-6 they are attached to, or at least near the wreckage of it.
http://en.wikipedia.org/wiki/File:F-1_rocket_engine.jpg
The general location has been known since the July 1969 launch, but I think this is the first time anyone has looked for the wreckage.
http://toolserver.org/~geohack/geoha...gename=S-IC&params=30_13_N_74_2_W_
flipdewaf
Thu Mar 29, 2012 1:45 pm
Does this count as treasure if he gets it from the surface? Can he legitimately claim it as his?
Fred
boeingfixer
Thu Mar 29, 2012 2:11 pm
Quoting flipdewaf (Reply 2):
Fred
It's all in the link the OP posted.
John
Cheers, John YYC
zanl188
Thu Mar 29, 2012 8:57 pm
Quoting KC135TopBoom (Reply 1):
Don't forget you also have to consider the weight of several miles of lift cable. IIRC when Liberty Bell 7 was raised several years ago the lift cable far outweighed the capsule itself.
Besides, Bezos has enough money - he could charter the Glomar Explorer and bring up the whole S-IC.
My understanding is that a number of the S-ICs, including Apollo 11s, came down in the same 16X5 mile area. So I'm wondering how it is that Bezos knows that he got Apollo 11? This will be interesting to watch regardless.
KFLLCFII
Fri Mar 30, 2012 1:13 am
Assuming the S-IC survived the splashdown fairly intact with the F-1s still attached, and the necessary raising equipment is in place...Would it be harder to try to separate an individual engine from the stage in a way not contrary to respecting the stage's historical significance, or just raise the entire stage in one piece?
[Edited 2012-03-29 18:21:37]
[Edited 2012-03-29 18:21:59]
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
kc135topboom
Sat Mar 31, 2012 10:51 pm
Quoting zanl188 (Reply 4):
Quoting KC135TopBoom (Reply 1):This would be a major undertaking for anyone. A burnt out F-1 engine weighs more than 20,000 lbs, not counting the the weight of the wreckage of the S-1C-6 they are attached to, or at least near the wreckage of it.
Very good point, I hadn't thought of that.
They know the positions of each crash site for S-1C-3 to S-1C-12. Yes, all of these are in the same 65 mile by 10 mile box. S-1C-6 should be the furthest one to the east in the NE courner of the box. The closest S-1C wreckage to the -6 wreckage should be S-1C-8 (Apollo-13), which should be about 2 miles west of S-1C-6.
http://en.wikipedia.org/wiki/S-IC#Stages_built
zanl188
Sun Mar 03, 2013 4:40 pm
Since it's been almost a year since Bezos made his initial announcement I expect we'll hear from him again soon.
I thought it might be interesting to discuss what he might have found as well as what condition it might be in. See if we can guess what he's got before the announcement.
I speculate that last year he had found all of the S-1C crash sites, or at least the ones likely to be Apollo 11. He may even have been able to do some sonar imaging to confirm that the site was an S-1C. How will he know which is Apollo 11?
First problem is base heating. As you can see in these pix the S-1C got pretty well charred up during it's short flight:
Courtesy: NASA
Courtesy: NASA
Base heating is caused by the low pressure area at the back of the vehicle recirculating the exhaust gases. Effect is enhanced as the vehicle accelerates and as atmospheric pressure drops in relation to altitude. As you can see the charring effect takes place over a good bit of the S-1Cs surface area. Yes, the exhaust gases recirculate up the side of the stage!
This youtube is also a good visual of the process:
http://www.youtube.com/watch?v=XKtH0uzg8wU
If the charring isn't too bad and if the stage isn't completely broken up one thing he might look for is this marking on the lower half of the stage:
Courtesy: Scott Jacobson
S-1C-6 is the Apollo 11 first stage. Pix was taken at the KSC visitor center on the restored stage there, which is definitly not the Apollo 11 stage.
Here's another shot of the stage at KSC for perspective. The marking is just beneath the center of the shot:
Courtesy: KSC Visitor Center
If that doesn't work he might try to ID the stage by serial numbers from an engine. This pix of an engine serial number plate was taken at the I-10 rest stop just outside of the Stennis Space Center:
Trouble with that though is that engines were covered with insulation before launch to protect from the aforementioned base heating. Not a great shot of the engines covered with insulation at launch. If I find some better ones I'll post them:
Courtesy: NASA
And of course the stage could be, and probably is, completely smashed & covered with mud and marine growth.
With any luck though he may pull up all five engines and the thrust structure. We can only hope:
zanl188
Sun Mar 03, 2013 5:37 pm
Someone asked what the white spots are on the S-1C engine fairings in the shot taken after stage seperation. My thought is that this is caused by the firing of the solid retro rockets located in the fairing. I'm not sure by any means but that seems plausible.
Von Braun & his engineers added the retros to ensure the stages did not recontact after staging. Later stages had fewer retros to save weight but the capability was not entirely removed. S-II had them as well, however with the S-II they were located on the interstage structure between the S-II and S-IVB.
prebennorholm
Mon Mar 04, 2013 1:15 am
When the AF447 recorders could be retrieved, then this is certainly also possible.
The question is how interesting it is. 100,000 lbs of F-1 engines connected to an empty fuel tank will have come down tail first at considerable speed. Those engines may be broken in a thousand pieces, and what may remain will certainly be bent beyond recognition.
kc135topboom
Mon Mar 11, 2013 12:00 am
Quoting zanl188 (Reply 7):
There would be little, if any marine growth on it. Deep sea wrecks like Titanic, Thresher, and Scorpion are all deep, but not as deep as 14,000' and they have almost no marine growth on the wrecks.
My guess is that what survived the slash down at the ocean surface would have been crushed as the wreckage sank deeper into the ocean.
Titanic is at about 12,000' down, Thresher is at about 8,400' and Scorpion is in 9,800' of water. All of these wrecks showed crush damage when they were found.
zanl188
Mon Mar 11, 2013 1:54 am
Quoting KC135TopBoom (Reply 10):
Thresher & Scorpion certainly imploded when they exceeded their crush depth. Titanic, on other hand, was open to the sea and could not have been crushed, aisde from isolated compartments collapsing or overpressurizing as she sank.
As far as the S-1C is concerned it seems unlikely that any of the major structures were intact enough to be crushed as the stage sank.
seachaz
Thu Mar 14, 2013 5:41 pm
Does anyone know in what orientation the S-IC stage impacted the water? Did it continue on a ballistic trajectory or did use of the retrorockets cause it to tumble back to the ocean?
ssteve
Thu Mar 14, 2013 6:47 pm
Quoting zanl188 (Reply 8):
I had never seen that photo, and it's amazing. I didn't notice the bright white spots-- I was too busy wondering how the lower stage was separating from the upper stage when it appeared there was still quite a large plume below the lower. And so you answered that. Retrorockets. Neat.
boeingfixer
Thu Mar 14, 2013 8:56 pm
Those bright spots are only light reflections off the F-1 engine fairings. The reason they're not the S-1C retro rockets firing is that they fire for only 0.541 seconds at stage separation. Look at the 3:04 minute mark on the following video and you'll see the short duration bright orange flame. these are the S-1C retros firing.
John
Cheers, John YYC
zanl188
Thu Mar 14, 2013 9:58 pm
Quoting boeingfixer (Reply 14):
I always thought the bright orange flame at staging was S-II Ignition. The third bright spot, on the left, is in shadow.
On the other hand there's little point in having retros fire when already well clear of the S-II. Maybe the bright spots are some after effect of the retro firing? Post firing burning or maybe some effect caused by the retro cover being blown off...
zanl188
Thu Mar 14, 2013 10:44 pm
Quoting seachaz (Reply 12):
My guess would be that the stage tumbled due to the fairly light overall structure and dense engines at the back. Then broke up due to aerodynamic forces while tumbling.
boeingfixer
Fri Mar 15, 2013 3:29 pm
Quoting zanl188 (Reply 15):
The video is really interesting to look at and understand the staging process. The large orange fireball is from the S-IC retros and as soon as the fireball dissipates you can see the residual plumes from the retros in the fairings.The S-II ignition is rather benign looking as it used LOX and LH2 for oxidizer and fuel. The J-2 engine starts up without any red/orange flame. When you look closely at the video you can also see the S-II ullage rockets firing(very faint) while the J-2 engines are starting up. The S-IC retro rockets were very powerful at 75,800 lb thrust each x8 in comparison to the ullage rockets on the S-II at 23,000 Lbs thrust each x4 so they look dramatically different in operation.
If the visual effect was caused by post retro burn out you would think that the third fairing in shadow would be emitting light as well.
Anyway this all really has no bearing on the subject of the post.
Quoting zanl188 (Reply 16):
I have the same idea in that the tank structure would have not have survived the fall, or if it did, it was totally destroyed on impact with the ocean. I feel the only real chance at anything surviving the impact would have been the thrust structure and the upper elements of the F-1 engines themselves.
John
Cheers, John YYC
zanl188
Sat Mar 16, 2013 1:09 am
Quoting boeingfixer (Reply 17):
I was reading up on the retros last night in the Apollo 8 S-V manual - they were rated at 88,000 lb thrust each there  Wow!
boeingfixer
Sat Mar 16, 2013 1:32 pm
Quoting zanl188 (Reply 18):
Yes indeed. I got the 75,800 number out of the SA 507 Saturn V manual. The S-IC retros on SA 503 were definitely 87,913 lbs thr. and also fired for a fraction of a second longer. No wonder the retro fireball was impressive.
John
Cheers, John YYC
zanl188
Sat Mar 16, 2013 2:56 pm
Quoting boeingfixer (Reply 19):
Downsized for weight reduction I suspect...
canoecarrier
Wed Mar 20, 2013 8:06 pm
They're out of the water now. Cnet has some photos of the recovered equipment.
http://news.cnet.com/2300-10797_3-10016189.html
The beatings will continue until morale improves
ssteve
Wed Mar 20, 2013 8:20 pm
canoecarrier
Wed Mar 20, 2013 10:29 pm
Glad to hear some of it is coming to the Museum of Flight. They have a lot of room left in that building the shuttle trainer got displayed.
zanl188
Wed Mar 20, 2013 10:51 pm
Brought up parts for two engines. Also found portions of the S-1C structure, not clear if that was recovered or not...
Won't be able to confirm they're from Apollo 11 until hardware is stabilized...
http://www.bezosexpeditions.com/updates.html
zanl188
Wed Mar 20, 2013 11:30 pm
Looks like you called it. I don't see anything in the photos that appears to be the nozzle extensions, just the thrust chamber and upper bits of the engine. The injector plate appears undamaged! Though I'm sure that's not true...
zanl188
Wed May 22, 2013 12:13 am
Some pix from the Cosmosphere in Wichita showing the engines undergoing conservation.
http://www.collectspace.com/news/news-052113b.html
A bit surprised they have not made a determination as to which mission these engines supported.
[Edited 2013-05-21 17:27:28]
rwessel
Thu May 23, 2013 6:40 pm
Quoting zanl188 (Reply 26):
Apollo 11.
11Bravo
Thu May 23, 2013 7:00 pm
Quoting rwessel (Reply 27):
Quoting zanl188 (Reply 26):A bit surprised they have not made a determination as to which mission these engines supported.
Apollo 11.
I believe they are still looking for serial numbers or other marks to confirm the engines are from Apollo 11 rather than some other Saturn V booster.
WhaleJets Rule!
zanl188
Thu May 23, 2013 9:05 pm
Bezos backed off the Apollo 11 claim when they hauled them up.
Given that NASA had a part # and paper trail for all the hardware in a Saturn V I'd think they'd have an ID by now... Or perhaps Bezos is just playing coy...
hangarrat
Fri May 24, 2013 4:07 am
So, in the video you posted, there's a white object that breaks away from the vehicle at 3:35. This appears well after the first stage has separated and it appears to be pulsing or tumbling. Any idea what that is?
Spell check is a false dog
Scooter01
Fri May 24, 2013 5:39 am
Quoting hangarrat (Reply 30):
Most likely the Interstage structure(ring) falling away as seen at 50seconds in this clip:
http://www.youtube.com/watch?v=q1vy4xXZynI
Scooter01
zanl188
Fri Jul 19, 2013 10:28 pm
Bezos confirms they found an Apollo 11 engine...
[Edited 2013-07-19 15:32:56]
Tugger
Sat Jul 20, 2013 8:16 am
Quoting zanl188 (Reply 32):
Wow, to hit one from that mission, the one that launched the first humans to step foot on the moon, is pretty impressive.... and blind lucky.
Tugg
There are many kinds of sentences that we think state facts about the world but that are really just expressions of our attitudes. - F. Ramsey
rwy04lga
Sat Jul 20, 2013 1:07 pm
Thanks for the link! I was there for the launch of Apollo 8. I also attended the STS-3 launch.
Just accept that some days, you're the pigeon, and other days the statue
zanl188
Sat Jul 20, 2013 10:40 pm
Quoting tugger (Reply 33):
Not much has been revealed about Bezo's initial recon expedition. I expect he had more going for him than blind luck though...
zanl188
Mon Mar 17, 2014 11:11 pm
F-1 Engine Recovery Team wins award from the Explorers Club. Buzz Aldrin presents award!
Video from the recovery here:
http://youtu.be/mUqp0ppKxJ8
zanl188
Sat Nov 21, 2015 1:43 pm
Flown F-1 components arrive at Museum of Flight.
Bezos recovered components from Apollos 12 & 16 as well as 11.
http://www.collectspace.com/news/new...015a-bezos-f1-engines-seattle.html
JetBuddy
Sun Nov 22, 2015 7:41 am
Amazing piece of history. Would be fun to see.
