Quote: Airbus is pulling Europe's A400M airlifter out of flying displays at next week's Farnborough Airshow due to continued engine problems, forcing it to sit out popular annual stunts for the second year running, industry sources said. |
Quoting KC135TopBoom (Reply 2): and reduction in capability by the equilly failed F-35 program. |
Quoting cmb56 (Reply 3): The standards today are much higher and the bar is being raised every day. In the past you would have simply changed the engine and continued on, now it is considered a failure. Not so, product develpment at this level and these standards is incredibly challenging. If the auto industry had to meet these standard we would all be walking or riding bicyles. A simply family car would cost a million dollars. |
Quoting autothrust (Reply 4): Quoting KC135TopBoom (Reply 2):and reduction in capability by the equilly failed F-35 program. On the A400M it remains to be seen. |
Quoting sweair (Reply 5): The biggest mistake was to develop the engine, the politicians went against Airbus on this and now Airbus is paying the price. This whole program smells of political stupidity, it will never get repaid. |
Quote: “We found metallic chips in one of the gearboxes and the origin is not yet identified,” said Maggie Bergsma, a spokeswoman for Airbus Military. The discovery of shavings has interrupted testing, pushing back a multi-week production trial required for the European Aviation Safety Agency to certify the aircraft. Airbus, a unit of European Aeronautics, Defence & Space Co., aimed to deliver its first A400M to France this year. Airbus already revised its delivery schedule to its lead customer to the end of March after initial setbacks. The latest gearbox problem arose on one of the four engines on the A400M undergoing a 300-hour function and reliability endurance flight test. Airbus has completed 160 hours of the program so far. The troubled engine has been replaced, though the test can only resume once the cause of the problem is determined. |
Quoting autothrust (Reply 4): Some people still don't understand how much new technology on the A400 can be found and how complex it is. |
Quoting MD11Engineer (Reply 8): AFAIK the A400M engine is one of the biggest, if not the biggest turboprop engine ever built. It is by far not trivial to design a gearbox, which on one hand can handle the torques and speeds involved and on the other hand be as light and compact as possible. |
Quoting MD11Engineer (Reply 8): AFAIK the A400M engine is one of the biggest, if not the biggest turboprop engine ever built. |
Quoting boeingfixer (Reply 10): Actually the Russian Kuznetsov NK-12MV used on the Tu-95 and Tu-142 is the most powerful turboprop engine ever produced. It is rated at 15,000 ehp. |
Quoting cmb56 (Reply 11): The EU partners decided to spend their people's money at home even if it ended up costing more in the end the money stayed in the EU. This is a very basic economic principle keep the money local don't spend it overseas or even the next town over. |
Quoting par13del (Reply 9): Let's see, this is still an engine turning a propellor, the basic of this is essentially unchanged since first designed, the biggest change has been turbines, so methinks they are trying to complicate things too much. |
Quoting par13del (Reply 9): Personally, I think engineers today want to prove their mettle with each and every thing that they do, imagine how easy it would be to design the Concorde or the SR-71 today with all the high speed computers and software available, should be out the gate within 12 months, the longest thing would be the actual building of the a/c and the engine. |
Quoting KC135TopBoom (Reply 2): |
Quoting Revelation (Reply 7): Now they have to pull out the A400M on the eve of the air show, just like they did last year at Paris. |
Quoting L-188 (Reply 13): Funny how they scream that the US is doing it with their tanker contract at the 767, but it is ok for them and the A400. |
Quoting Revelation (Reply 14): If you had noticed that high pitched vacuum cleaner noise when you were near a turbine, you might have thought that the gearbox needs to deal with a very big difference in revolutions per minute. |
Quoting Revelation (Reply 14): The main issues is that the bar has been raised. |
Quoting ebj1248650 (Reply 18): People seem to think that, because we have super computers, designing, building, testing, and then producing a new airplane ought to be pretty straightforward. |
Quoting par13del (Reply 20): Well if we follow the last two major aviation programs - A380 and 787 - the software worked like a charm, the folks using the software were the problem, none of the delays were due to the software having difficulty completing its tasks. |
Quoting kanban (Reply 19): it looks wet, so the problem (reported in a deleted thread) of landing on wet soils may be in play as well. |
Quoting B737200 (Reply 21): Yes because the software crunches numbers, the people using the software need to see if what is coming out is making any sense and if the assumptions taken are valid |
Quoting scbriml (Reply 15): Have they? One was flying at RIAT today and probably tomorrow. Don't see why it can't fly 100 miles to Farnborough on Monday |
Quoting EZYAirbus (Reply 22): was pissing down at RIAT yesterday but it still got airborne and did a flypast with the RAF heavies then did a couple of solo passes |
Quoting oykie (Reply 24): So the issue with the gearbox cannot be the that pressing. |
Quoting KC135TopBoom (Reply 6): It will never have the low level TFR Germany wanted for terrain following missions. It's tanker air refueling capability has been puch back several years, and to get that capability it needs more developement money. |
Quoting francoflier (Reply 25): Are the extra billions spent on the program really worth the relatively few jobs that were created? And since this is such a niche market, what will these companies gain from it when it is all over? |
Quoting scbriml (Reply 15): Quoting Revelation (Reply 7): Now they have to pull out the A400M on the eve of the air show, just like they did last year at Paris. Have they? One was flying at RIAT today and probably tomorrow. Don't see why it can't fly 100 miles to Farnborough on Monday |
Quoting katekebo (Thread starter): Airbus is pulling Europe's A400M airlifter out of flying displays at next week's Farnborough Airshow due to continued engine problems, forcing it to sit out popular annual stunts for the second year running, industry sources said. |
Quoting par13del (Reply 20): Quoting Revelation (Reply 14): If you had noticed that high pitched vacuum cleaner noise when you were near a turbine, you might have thought that the gearbox needs to deal with a very big difference in revolutions per minute. Well I did mention turbines in my initial post, guess it was missed. |
Quoting par13del (Reply 20): Yes, no new supersonic pax a/c and the SR-71 is still unmatched, and the advances on the 787 are in simple form scaling up existing tech. |
Quoting par13del (Reply 20): I have watched shows of sea planes in Alaska - Beavers - being converted to turbines, it is well established tech. How much are they raising the bar on the turbine engines being deployed in the A400M, will other a/c that presently use turbines be able to benefit from the new technology? |
Quoting Aesma (Reply 16): Besides, the A330 and 767 are much closer airplanes than the A400M is of either the C130 or C17. And do you think the US manufacturers/politicians would have agreed to put assembly lines in the EU, like Airbus was prepared to do in the US (and is actually doing anyway) ? |
Quoting Revelation (Reply 29): As per the thread starter: |
Quoting Revelation (Reply 29): So it shall be flying the 100 miles, but it shall not be doing the "popular annual stunts for the second year running", sayeth the "industry sources". |
Quoting scbriml (Reply 31): Yes, I did read that. ![]() |
Quoting scbriml (Reply 31): I also asked a perfectly reasonable question. If the A400M is performing "popular stunts" at another air show immediately before Farnborough, why it can't perform them at Farnborough? |
Quoting scbriml (Reply 31): One also has to question "industry sources" that don't know that Farnborough runs every other year (so is not an annual event) and that the A400M DID fly at the last Farnborough show. |
Quote: The move repeats a decision at last year's equivalent event outside Paris, but is not expected to disrupt plans to deliver it to its first customer, France, around the end of the year. |
Quoting nomadd22 (Reply 12): I'm not too sure about the name change either. Didn't Hercules make a fool out of Atlas? |
Quoting Revelation (Reply 32): Do you know if it did more than fly-bys at RAIT? |
Quoting kanban (Reply 19): looking at Farnborough pictures, it looks wet, so the problem (reported in a deleted thread) of landing on wet soils may be in play as well. |
Quote: The first production model of Airbus Military's A400M tactical airlifter is on display at the Farnborough Air Show in England. Airbus Military, headquartered in Spain, said the aircraft – designated the MSN6 – will be on static display, which will allow potential customers to view its cargo hold. The aircraft will not participate in flight demonstrations because of recent engine issues which are under investigation. Read more: http://www.upi.com/Business_News/Sec.../UPI-76621341850064/#ixzz20Dn1utKu |
Quoting flightsimer (Reply 30): Why would we build a plant in the EU just to build planes to then have to fly back to the US? Airbus isn't building this A320 plant for Asian or African or European airlines... They are building it for the airlines of the America's, but more importantly because of the greatly lower cost to build them here rather than in the EU. If a European customer wanted enough planes that an entire production plant could sustain the production plus others, I have no doubt a US company would do it... But the climate for that to happen isn't there... |
Quoting ZANL188 (Reply 33): Why did they change the name? |
Quoting ZANL188 (Reply 37): Grizzly was pretty official. Press releases etc. |
Quoting BigJKU (Reply 39): For a group of nations that really had not built a plane anything like this it just seems like building a jet-engined transport would likely have been a good bit simpler. |
Quote: The project began as the Future International Military Airlifter (FIMA) group, set up in 1982 by Aérospatiale, British Aerospace (BAe), Lockheed, and Messerschmitt-Bölkow-Blohm (MBB) to develop a replacement for the C-130 Hercules and Transall C-160.[10] Varying requirements and the complications of international politics caused slow progress. |
Quoting Revelation (Reply 38): Apparently she made it there and is sat on the tarmac. |
Quoting Revelation (Reply 41): So the starting point was replacing the C-130 (i.e. a intra-theater airlifter) rather than going for something like a C-141 or C-17 (inter-theater airlifter). At the time, the customer's primary needs were based on the NATO - Warsaw Pact type of cold war scenarios. Now they find themselves in the unhappy scenario of buying an system to fight the last war, not the next one, and there's no backing away from it (although they could have called Airbus's bluff to walk away from it a few years ago). |
Quoting scbriml (Reply 42): Yes, it didn't fly, which, given it's the very same aircraft that DID fly at RIAT two days ago, all the more confusing. In EADS position, I would have rather had it in the static at RIAT and flying at Farnborough. I don't know why they didn't ask me. |
Quoting scbriml (Reply 42): In the static display it was close by a C-130J and made it look pretty small. It does look a beast. |
Quoting BigJKU (Reply 43): Nah, I know what it was originally going to do but there were no orders until 2003 so up until then they could have respecified the thing. |
Quoting BigJKU (Reply 43): It was 2002 before they knew they were going to need a new, bigger engine at which point I would think one might ask the question of if we are approaching this right. |
Quoting BigJKU (Reply 43): The need to build a new and unique engine for the thing has caused a lot of problems. Once you went to that size I think you have to consider something with jet engines you could have bought off the shelf. |
Quoting KC135TopBoom (Reply 6): EADS originally wanted to put a Canadian built engine on the A-400M, but the French politicians wanted (demanded) the engine be buit in Europe. |
Quoting par13del (Reply 9): Let's see, this is still an engine turning a propellor, the basic of this is essentially unchanged since first designed, the biggest change has been turbines, so methinks they are trying to complicate things too much. ATR's and Bombadier props fly the world over every day, they appear to be re-inventing the technology rather than perfecting. |
Quoting par13del (Reply 9): The Russians had a very large turbo-pro pax a/c that did trans-continental runs with contra-rotating props to boot, it was probably just as large. |
Quoting par13del (Reply 9): Personally, I think engineers today want to prove their mettle with each and every thing that they do, imagine how easy it would be to design the Concorde or the SR-71 today with all the high speed computers and software available, should be out the gate within 12 months, the longest thing would be the actual building of the a/c and the engine. Today with all this technology the design phase takes just as long as long as building the initial a/c, go figure. |
Quoting Aesma (Reply 40): Well, we were talking about European customers buying a bunch of C-130 and C-17 instead of making the A400M. Airbus was going to build the tanker for the US in the US (and EADS is building copters in the US for the US), so my question is would Boeing and Lockheed have built C-130 and C-17 in Europe for Europe ? Because if not, then that's a non starter. |
Quoting Revelation (Reply 41): I think one of the reasons the UK is so happy with its C-17s is that their roles in the Middle East needed an inter-theater airlifter. Of course they're also happy that the USAF shook out all the bugs, unlike their unhappy early days with the C-130J. |
Quoting cmf (Reply 45): Several US fighters used by European air-forces have been built in Europe. Many in Netherlands, some in Finland. I expect there are more examples. |
Quoting gphoto (Reply 46): Boeing seem much more reluctant (as is their right). |
Quoting kanban (Reply 48): |
