connies4ever
RE: F-22 Raptor Revival?
Thu Oct 04, 2012 6:44 pm
Quoting wacopolumbo (Reply 46):
Hell, the Brits don't even fly them anymore
The Brits don't fly them anymore because they can't afford to, not because they don't want to.
Quoting connies4ever (Reply 45):
Quoting Powerslide (Reply 44):
Canada would probably end up with a bastardized Arrow made in Quebec because Canadians are generally dumb and pick the shiniest thing.
Your above quote uses a very broad brush - "Canadians" includes both civilians and military. Responding to that. When you want to make a point, be more precise.
wacopolumbo
Thu Oct 04, 2012 7:34 pm
Quoting connies4ever (Reply 50):
Part of my point. The Harrier is maintenance heavy and expensive to operate. What I find interesting is that they think they will be able to afford to fly the F-35 when they can't fly the Harrier. Then you have the F-35B to F-35C to F-35B decision.
The USMC jets are also long in the tooth. They Brit Harriers (not the Sea Harriers) were newer.
wacopolumbo
ThePointblank
Fri Oct 05, 2012 3:52 am
Remeber, we don't ALWAYs buy what's best, we buy what we are told to buy. The idea that one airplane can doo it all for all services has been tried before, The F-4 Phantom comes to mind. After that, SECDAF directed the USN and USAF to buy the F-111. The Navy realized the F-111 could not do it's mission and the F-14 was born, but not before a bunch of money was wasted on the Navy version of the F-111 (B Model).
Actually disagree, plenty of books were written about the topic, but the crux of the situation was that the Navy never wanted the F-111B in the first place. Inter-service rivalry reared its ugly head here as the Navy saw the F-111 as being an 'Air Force' aircraft as the project management staff was predominantly dominated by Air Force personnel, and tried to find ways of killing the project.
In fact, the Navy drastically redrafted the requirements so in essence, the F-14 would not have been able to meet the proposed specifications for the F-111B, and of course vice versa.
The specifications the Navy wrote for the F-111B was a totally unrealistic specification. Many think that the F-14A was far lighter than the F-111B, primarily because most comparisons neglect to do so using the F-111B’s design mission for both aircraft. The F-14A is still lighter, of course, because the Navy changed its requirements so that it would be. Deleted were the escape capsule, bomb bay, and swiveling wing pylon stations among other things. The Hughes Airborne Missile Control System, given a few more years of development, was lighter. The structure was designed for 6.5 gs at 49,548 lbs, about 10,000 pounds less than the F-111B’s design gross weight at that g level. In effect, the six Phoenixes and 3,800 lbs of fuel were treated as an overload for the design of the F-14A structure. At combat weight (13,800 lbs fuel and six Phoenix missiles) the F-111B therefore had a load limit of 5.8 g and the F-14A (12,000 lbs of fuel and six Phoenix missiles), a lower (but not particularly constraining) 5.2 g. The result, however, is a somewhat lower structural weight for the F-14A.
lso, the LO is VERY maintenance intensive. Its not like the old days of removing a panel, fix the problem and installing the panel. Removing and installing panels on stealth aircraft add a lot of time to the maintenance process. The F-35 and F-22 have more maintenance man hours per flight hour than the Super Hornet, Viper or Eagle.
F-35 does away with stealth coatings like on the F-22, B-2 and F-117. The stealth coating is instead baked directly into the skin of the aircraft in a stealth mat. There has been extensive durability studies of the F-35's skin to see how ordinary wear and tear and damage would do to the stealth signature, and to see how long the skin can last. Lockheed Martin, to make a point of how durable the skin is to wear and tear, actually has a piece of the stealth mat used as a floor mat at one of their labs and they occasionally pull it up and conduct tests to see how it fares. It can be argued that the F-22, B-2 and F-117 stealth coatings represent the first generation of stealth coatings. F-35's approach to stealth coatings represent the second generation of stealth coatings.
The biggest change with F-35's maintenance model is the switch from 'maintenance per schedule' to 'maintenance on demand'. The aircraft has a built in maintenance tracking system that can flag maintainers to fix problems as required while the jet is returning from a mission (say, as the aircraft is landing, the computer will uplink to the maintainer's computer systems and tell them that the F-35 returning right now is expected to require a oil change when it lands). ALIS will also capture data on the entire F-35 fleet and allows for pre-positioning of spare parts where they are needed and when using just-in-time logistics.
Quoting wacopolumbo (Reply 40):
ll I was trying to inject is a little real-world input into the dicussion. No I haven't flown it and don't want to. I come from an Eagle and Raptor background, with 20 years of service. Again, am NOT saying the F-35 is a bad platform. What I AM saying is that the F-35 is not the second coming. Having flown against Viper and Hornets (both legacy and Super), I can tell you the Viper is a much better BFM foe, except for the slower fight (below 330KIAS) and at lower altitudes (Below 15-18K) where the hornet can point its nose better, but struggles to regain energy.
F-35 from what the pilots are saying is that it can turn like a F/A-18, but has the ability to retain and gain more energy. Remember, F-35 is designed for operating around the transonic range, and realistically, the only fighters that can match or beat the F-35's acceleration is a clean F-16 Block 50 or a F-22.
sweair
Fri Oct 05, 2012 10:48 am
How many F22s would have been sold if there was no ban on sales? Japan and Australia really wanted it above the F35, that would have helped lower the frame cost for US Air Force as well. It´s not like its super alien tech anymore, maybe 10 years ago, but today others are catching up.
And why would the US not trust Japan and Australia with top notch tech? Have they ever been the least suspect like Israel has? Maybe Canada could have found a use for the F22 as well, long range patrols?
bigjku
Fri Oct 05, 2012 1:29 pm
Quoting sweair (Reply 53):
Australia never really wanted it. They had a vocal media segment that wanted it and they had a couple of politicians on their side. The F-22 does not really meet their needs either.
It would make sense for Japan I guess.
Powerslide
Fri Oct 05, 2012 1:40 pm
Just what Canada needs, a $250 million dollar air superiority fighter with poor reliability tooling around in the frozen Arctic. Ground radar is in place for a reason, no one does patrols any more.
wacopolumbo
Fri Oct 05, 2012 1:56 pm
Quoting ThePointblank (Reply 52):
The maintenance pains don't deal with coatings on the panels themselves.
[Edited 2012-10-05 07:21:08]
wacopolumbo
wacopolumbo
Fri Oct 05, 2012 2:11 pm
What pilots? All the Canadian pilots flying the F-35? You're right, I give up. The guys I went to school with who are in the F-35 program must be misleading me. The F-35 is the best fighter ever and will be able to perform every mission better than any other platform.
By the way, every operational tactical fighter except for the F-22 is designed to operate in the transonic regime. However, I will "remember" your advice when I am working the F-22/F-35 joint employment standards for our community. I will be sure to check back here to read how I should employ the Raptor in a joint enviornment. After 20 years of flying Eagles and Raptors, I guess I should see if I can get into that fancy pig with wings...
You have highlighted the reason why I occasionally read things here and don't post. Since I had input to the OPs thread, I thought I would share, but I should have known that my real-world experience would be no match for folks who read stuff and repeat it as fact.
Good day and check six.
wacopolumbo
sovietjet
Fri Oct 05, 2012 3:17 pm
Quoting ThePointblank (Reply 34):
long term lead items need to be ordered now otherwise the line is going to be shuttered in 2 years.
Long lead tools do not take 2 years to make. That's ridiculous.
And it should be noted of the US fighters, the F/A-18 is the most maneuverable fighter in the US inventory.
Says who? Define maneuverability. I'm interested to see what stats are being used to define how maneuverable an aircraft is.
F-35 is designed for the transonic regime while practically every other fighter designed (except for F-22) is designed for operating at subsonic speeds. They only visit the supersonic performance range and only briefly.
Transonic speed is roughly defined as between Mach 0.8-1.2 . Almost every fighter is designed for that. Hell, even commercial jetliners cruise at transonic speed. I seriously doubt the F-35 is designed to cruise at M1 as that would create unnecessary amounts of drag and increase fuel burn.
Quoting wacopolumbo (Reply 57):
I've enjoyed reading your posts but the Canadian F-35 fanbo....ahem...experts, usually dominate these threads. Don't let that turn you away, this is a discussion forum after all. I like the F-35, but I don't blindly think it is the greatest fighter ever. The F-22 is still a better air-to-air platform. the A-10 still better at air-to-ground and CAS IMO . The Harrier is frankly the only plane the F-35 vastly outperforms.
connies4ever
Fri Oct 05, 2012 3:53 pm
I'll give you that one, stealth coatings have definitely advanced in 30 or so years. Of course, so has radar technology and there is a rump of general staff officers who question the whole notion of stealth being an advantage if it is so expensive.
Which only makes sense. maintenance to schedule is essentially make-work.
Quoting Powerslide (Reply 55):
Quite. Any overwatch required can be handled by Global Hawk.
But tell us what you really think !
Powerslide
Fri Oct 05, 2012 5:57 pm
Quoting sovietjet (Reply 58):
I don't think that anyone who supports the F-35 thinks that.
I sure hope it is, considering they spent all those Billions developing the thing as one. Now if the damn thing could only drop bombs it wouldn't be completely useless in today's world.
BMI727
Fri Oct 05, 2012 7:35 pm
It would have been Japan, Australia, and then maybe Israel and a couple other wealthy Middle Eastern countries.
There's nothing wrong with having a pig with wings unless you're trying to run a horse race. Like you said before, the one plane fits all idea has been tried before and didn't work so hot. The best planes are built for one purpose and expanded.
That's basically the worst speed to cruise at. The Concorde would relight the afterburners to save fuel by spend less time in the transonic regime.
ThePointblank
Sat Oct 06, 2012 2:13 am
They do. Witness recent military aircraft purchases; the first contract for the ROKAF's F-15K's were signed in 2002 and first deliveries commenced in 2005; the RSAF's F-15SG's were first ordered in 2005, and first deliveries commenced in 2007; the RAAF's F/A-18E/F's were ordered 2007, with first deliveries in 2009; the PolAF's F-16 Block 52's were ordered in 2003, and deliveries commenced in 2006.
All four were in-production aircraft, and in the case of the F-15's, on a line that was essentially empty of orders.
Most fighters are actually fully subsonic aircraft when loaded with ordinance. They only reach supersonic speeds under very specific configurations and they rarely if ever hit their top speeds. For example, the entire time the world F-15 fleet has ever spent anywhere near the rated top speed since the introduction of the F-15 can be measured in a few hours, as the F-15 can only reach its top speeds very lightly loaded, and usually under Functional Check Flights. In fact, the F-15 fleet has rarely exceed the threshold of Mach 1.2 to Mach 1.3 during it's entire 30 year life span.
If you were to compare from a frontal aspect between a similarly loaded F-16 and a similarly loaded F-35, the F-35 will have a significant advantage in terms of how aerodynamically clean it is compared to the F-16.
What's important regarding F-35 is that it can hit its top speeds while carrying ordinance and a decent amount of fuel, much like the F-22 as it can carry ordinance internally, and can accelerate at a rate that is only matched by few aircraft.
Would Lockheed Martin's chief test pilot mean anything to you? If you have concerns regarding F-35's performance, bring them up to John Beesley, who made these claims. If he has stuck his head out and said that the F-35 is at minimum, on par with an F-16, then I doubt he's lying.
In the subsonic flight regime, the F-35 very nearly matches the performance of its' larger, more powerful cousin, the F-22 Raptor, Beesley explained. The "subsonic acceleration is about as good as a clean Block 50 F-16 or a Raptor- which is about as good as you can get." Beesley said.
The aircraft flies in "large measure like the F-22, but it's smaller, and stiffer" than the Raptor however, Beesley explained, adding that the aircraft handles superbly. The reason for the similar flight characteristics, explained the test pilot, is because the man who designed the flight control laws for the Raptor, is also the same man who is responsible for the flight control software for the F-35. As Beesley explains, the flight control laws of modern fighters determine to large extent the flight characteristics of a given aircraft. Beesley said that the aircraft is so stable and so comfortable that the test pilots find themselves inadvertently drifting too close to their wingmen in formation.
What Beesley expects will surprise future F-35 pilots is the jets' superb low speed handling characteristics and post-stall manoeuvrability. While the F-22 with its thrust vectored controls performs better at the slow speeds and high angle of attack (AOA) flight regime, the F-35 will be able match most of the same high AOA manoeuvres as the Raptor, although it will not be able to do so as quickly as the more powerful jet in some cases. Turning at the higher Gs and higher speed portions of the flight envelope, the F-35 will "almost exactly match a clean Block 50 F-16 and comes very close to the Raptor", Beesley said.
I will point out that he would be very well qualified to evaluate aircraft performance; He has more than 5,500 hours of flight time in over 50 different aircraft, including the F-16, F-117 and the F-22. He also flew Soviet-era fighters during a tour with the USAF “Red Hats” squadron in 1979-80.
connies4ever
Sat Oct 06, 2012 2:29 am
Quoting ThePointblank (Reply 62):
If not a shill for LockMart, Beesley is at least doing serious PR for the F-35. Ergo his statements need to be taken with a grain of salt.
Which is where some of the buffet problems remain, I believe.
I have no doubt Mr Beesley is a very well qualified pilot.
ThePointblank
Sat Oct 06, 2012 3:13 am
Quoting connies4ever (Reply 63):
I would also add the BAE test pilots as well to the mix; they are also very highly impressed with the F-35's ease of handling.
I will point out that the F-14, the F/A-18 and the F-15 all had buffeting problems, and they were resolved in one way or another; in the case of the F-14 for example, they just ignored the problem altogether during testing. The F/A-18's buffeting problems were extremely bad, and it caused severe structural life issues until it was resolved, FYI. Nothing new in terms of fighter development.
sweair
Sat Oct 06, 2012 8:13 am
There was a RAF pilot that got to fly the raptor, now if he would get to fly the F35 as well we would have a nice impartial source   Off topic I saw that a french air force pilot flew a A-10 in Afghanistan, quite cool IMO.
Oykie
Sat Oct 06, 2012 12:24 pm
As the OP I have enjoyed you real-world experience comments. With the U.S. election one month away from today, this topic will stay relevant for some time.
Your input to this thread has also been suggested by FlightGlobal in this blog:
http://www.flightglobal.com/blogs/th...omney-proposes-more-raptors-l.html
source of mine, who has the resume to back-up what he says, once suggested that the US Air Force would have been better off buying the F-22 as its high-end fighter while filling the low-end of the fleet with new-build Block 60+ F-16s.
Simply, the USAF would be better off with a good number of highly capable Raptors that could take down an enemy's air and surface-based defenses while relatively low-cost (compared to the F-35) new-build F-16s could add some needed bulk to the fleet. The Navy, he had argued, has a modern fleet of Boeing F/A-18E/F Super Hornets with active electronically scanned array radars and other goodies... which offer excellent capability for the price. He had asked, would the USAF not be better off in 10 years with say 400-ish F-22s and 1000 new Block 60 F-16s?
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
Oroka
Sat Oct 06, 2012 6:19 pm
There is nothing to say that in 10 years, the F-22 could be certified to fly ground attack the same as the F-15 became the Strike Eagle... the majority of the changes would be software for dropping some iron.
If the F-35 gets axed, and the F-22 line starts to reopen, there will be shit storm over the cost to open the line again, on top of the still quite high price of the gen 4.5 fighters that need to be ordered.
sweair
Sat Oct 06, 2012 8:14 pm
From like 3 or 4000 aircraft to 182 F22 and some hundred F35s.. Quite the reduction for US Airforce?!
Powerslide
Sat Oct 06, 2012 8:51 pm
Quoting sweair (Reply 68):
Reduction in numbers but an increase in capability. The days of 1000+ fleet of aircraft for the US is coming to an end.
sweair
Sun Oct 07, 2012 8:16 pm
Quoting Powerslide (Reply 69):
I think it will depend on the opposition, if China or Russia can amass 3000 fighters I think a few high tech fighters is as good as a white flag. The F35 IMO is not a top notch fighter, I bet gripen would run circles around it.
bigjku
Mon Oct 08, 2012 12:39 am
Quoting sweair (Reply 70):
Are we staging an air show or conducting an air campaign here? I struggle to see how a fighter carrying a less advanced radar that is going to be far more visible at range is going to cope effectively with a fighter with a better radar, low observability and the advantage of being able to operate in a networked fashion with its squadron mates. I think we need to be honest with criticism of the F-35. It is relying heavily on its 360 degree sensor system to compensate for what will be good but not world class agility. But I think it is massively overstating it to say the F-35 is not a top notch fighter. If that is the case than what qualifies? The F-22 and only the F-22?
I would not want to mess with an F-35 in a legacy airplane (non-lo) under any but the most favorable circumstances.
Powerslide
Mon Oct 08, 2012 3:09 am
The UK, Italy, Netherlands, Turkey, Canada, Australia, Denmark, Norway, Israel, Singapore and now Japan all disagree. If the Gripen is such a great fighter then why doesn't anyone buy it?
This is assuming 100% availability. All the US would have to do is take out the runways and then what. 100 or less Tomahawk missiles and all those numbers mean nothing.
fbwless
Mon Oct 08, 2012 12:38 pm
Quoting Powerslide (Reply 72):
Anyone? Try South Africa, Thailand and Czech R & Hungary as leases. Switzerland and Croatia are close to deals. Add to this the political influence and domestic market needed to design and manufacture 4G (and above) fighters. What other country of the size of Sweden has this ability? Maybe Canada?? As Sweden is a tiny political player in the world, Gripen has only its capability expressed as gain times price to warrant its existence. Sure there are other fighters with higher gains, but at what price?
Norwegian politicians and military had to lie about projected price of the F-35 and falsify Gripen capability (as well as trash talking the Gripen) to sell it to the public. That decision was so biased even EF pulled out early from the competition. The only positive outcome for SAAB was that the Gripen NG demonstrator could be built.
ThePointblank
Mon Oct 08, 2012 11:20 pm
Quoting FBWless (Reply 73):
Couple of problems:
1. Europe's fighter aviation industry is on the decline. SAAB, Dassault, BAE, all don't have a 5th generation fighter in development. It is expected that without a 5th generation fighter, the Europeans are going to struggle to stay alive in the fighter business. In all likelihood at least one, and likely two of the three will be effectively out of business by 2020. Saab will almost certainly disappear, followed by either Dassault, or the Eurofighter consortium (and it is most likely the Eurofighter consortium, as one of its participants, BAE is looking towards a merger with Airbus).
2. The Gripen as it exists today is simply nothing special. It is a modern but very small airframe with a minimal radar and EW suite. It has a datalink and more or less all of the other features one would expect in a passably modern 4th generation aircraft, but it isn't a world beater in any respect. It is small and cheap. It is reliant on the US for its engines, BVR weapon, and other key technologies which means it will always be competing head to head with the F-16, and as history has demonstrated, almost always losing.
The Gripen NG concept is a pretty impressive attempt to bring what is currently a more or less standard 4th generation aircraft up to the nebulous 4.5 generation level. It is essentially taking the Super Hornet approach to the Gripen. Grow the airframe, add fuel, add thrust, add an AESA and other modern avionics. The end result would be a nifty little plane, but one that would arrive on the scene rather late. It also has that one little issue of not actually having been ordered by anyone. There are a lot of concept planes floating around out there and most of them never get built. If the Gripen NG is going to become anything more than a footnote in history someone needs to come forward with enough cash to order 100+ of them.
There are bigger forces at play, one that affects Sweden. The Norwegian defence contractor Kongsberg, is now currently in the final development stages on a new fifth generation SSM ( Naval Strike Missile). They intend to compete internationally against Sweden in the SSM market, and try to push Sweden out of the market. Kongsberg has been developing a version of the NSM for internal carriage on F-35 (the Joint Strike Missile) with Lockheed Martin as the standard anti-shipping missile for F-35.
Obviously this has big ramifications; not only did Sweden lose a export customer for Gripen, but they will be facing a significant threat to their market for a huge share of the market for SSMs.
In addition, the Norwegian government is also very keen for Nammo to take a large portion of the market for ammunition for the F-35's 25mm gun as well.
Considering the planned procurement numbers for F-35, and the multitude of export and partner customers for F-35, it is not surprising that the weapon industry in Norway made a significant push for F-35.
wvsuperhornet
Tue Oct 09, 2012 12:28 am
Quoting morrisond (Reply 18):
Build another 200 for the Airforce - scrap the F35 and build another 1,000 or so F16's and restart A10 production while your at it for the Marines to replace the F-35B.
The A-10 was cut due to several cost over runs even worse than the F-35. The best option was to build a new and improved F-14 but was scrapped for political reasons, building and F-22 Naval verison is way too costly and would never be approved thats why it wasn't in the first place. Do I think we need to build more F-22's no, its no longer functional when Regan revived the B-1 a more improved and viable option was already on the table. There is no other options that have been worked on for the F-22, what it boils down to is the DOD put all of its eggs in 2 baskets by the same company and its now costing everyone. Realistically the aircraft we have no for the foreseable future are more than capable of handling any threats. For the long term they need to go back to the drawing board and design a new fighter. The F-35 (and you can say whatever you want) is an over costa nd over bloated F-16. The F-22 is a fantastic plane that is too difficult and expensive to operate is its only down fall. The F-35 "IS NOT" as capable as the F-22 and never will be. The F-23 proposed by Boeing and northrop grumman was the more viable option.
Quoting Powerslide (Reply 21):
People like the F-22 mostly due to fanboism. Never-mind facts.
But yet you two guys from Canada know more about the aircraft than a guys who worked on one. Go figure.
BMI727
Tue Oct 09, 2012 12:45 am
Quoting wvsuperhornet (Reply 75):
Still I think it is worth revisiting. Not the mention that the Air Force really doesn't have any love for the A-10. They'd just as soon get rid of them in favor of something faster.
That's what the Super Hornet could have been had the A-12 not been scrapped. When that happened they had to start making compromises.
To be fair, it's also far more capable. I find the whole idea of the JSF misguided and think the F-35 could have been a better overall package had it been designed more as an F-16 replacement than a catch-all airframe for everyone.
It was also more risky if I remember correctly. I haven't looked at it in too much detail, but I don't see how the F-23 would have rectified many of the shortcomings of the F-22.
sovietjet
Tue Oct 09, 2012 2:03 am
Isn't the F-15 fleet now limited to M1.6?
If you think America has too few planes then you should really take a closer look at Russia's air force. They don't even have 1500 aircraft of ALL types now with the latest severe cuts these past couple of years....let alone fighters. The Navy's air fleet is in shambles and barely has anything left now.
Second, even if China has 3000 fighters I 100% guarantee you there simply cannot be a 3000 aircraft vs 100 F-22s battle. It would be impossible to stage that many aircraft. Where would they even take off from?
ThePointblank
Tue Oct 09, 2012 5:03 am
Quoting sovietjet (Reply 77):
Pretty much... cracks and metal fatigue have taken their toll on the F-15 fleet.
Indeed. Not enough airfields in China to launch that many aircraft close to their borders... now imagine a number of those airfields unusable due to heavy attacks on them...
Quoting BMI727 (Reply 76):
The A-10s production line is *gone*. And you can be certain that if we built more today they'd cost a HELL of a lot more. It won't be like the first A-10 off the line with limited avionics; they are going to want to install all of the upgrades from the -C upgrade from the beginning. Add the costs to restart product, and you'd be *lucky* if it came in at less than $50 million.
To be fair, F-35 is going to be far more capable than the initial versions of the F-16. The first F-16's were essentially day fighters; no BVR capability, some dumb bombs at best. F-35 is going to IOC at a level very similar to the Block 30's (in terms of structural & avionics changes). The DoD decided to look at what it wanted the F-35 to do, what it needed, and went directly to Blk3 instead of a stripped down Blk1 (ala F-16A). This will obviously take longer but will save money in the long run due to not having the need to upgrade all those Blk1/2 airframes.
The plan for the F-35 is Hardware upgrades every two Blocks (starting with Blk2). These are called tech refreshes (TRs). So Even Blocks comprise a TR & Software and Odd Blocks are Software only (with small hardware upgrades where needed). With the F-35, it's easier to upgrade the aircraft one already has as opposed to the parking old ones in the desert as B/C/D/E/F/G variants come off the line.
[Edited 2012-10-08 22:50:50]
BMI727
Fri Oct 12, 2012 4:47 am
Quoting ThePointblank (Reply 78):
Compared to what the F-35 will cost and considering how well the A-10 does its job, I'd take that deal. I'd even take it if it came in somewhat more than that.
That's exactly my point: the F-16 was built with a singular mission in mind and was able to do that mission very well and also grew into something much more well rounded. Same with the F-15: all that talk of "not a pound for air to ground" didn't do a whole lot to stop the F-15E.
Generally, the best planes are designed to perform one job exceptionally well and then grown out from there. Designing a plane from day one to be all things to all people leads to a lot of costs and compromises.
ThePointblank
Fri Oct 12, 2012 5:15 am
Quoting BMI727 (Reply 79):
However, the A-10 is a one trick pony. All it can do is ground attack, and while it was okay to have one trick ponies during the Cold War, we don't have the manpower resources to support having singular mission aircraft for every mission.
Actually, the F-16 grew from the YF-16. The YF-16 was designed to be a single mission day fighter.
It should be noted that the USAF procured the F-16 as a fighter-bomber, in contradiction to its initial plans for the LWF as a lightweight day fighter. As a result, the F-16 was modified from the YF-16 in mind to be a multirole aircraft, but the initial versions of the F-16 lacked the capabilities that later blocks of the F-16 had. Through various blocks, MSIP stages, and OCU's, they progressively added more capabilities while parking older variants.
BMI727
Fri Oct 12, 2012 5:38 am
Quoting ThePointblank (Reply 80):
And it does an extraordinary job of it. The F-35 in a similar mission would be more vulnerable and not be in a position to utilize its low observable characteristics or ultramodern sensors which drive a significant portion of the costs.
Which happens to be exactly what the USMC needs.
ThePointblank
Fri Oct 12, 2012 6:39 am
Quoting BMI727 (Reply 81):
The A-10 will not fare well against a opponent with decent integrated air defence system. For the opponents and battles it has been sent in on, there was either negligible or very low risks to the aircraft.
The F-35 on a similar mission would be better able to take advantage of its sensors to get a better picture of the battlefield so the pilot can better plan their attacks. It also helps the the warfighters on the ground as you now have a eye in the sky that will provide superior situational awareness of the area around him.
With a 360 degree field of view from sensors, and supercomputer++ processing power, a human being piloting an airplane will never approach the F-35s see-all capability. All it takes to fool a human being is for someone to hide under some brush, or to hide a SAM under some form of camouflage. A F-35 can see a missile launch from a very long way away and pinpoint where it was launched. It can then pass the information along to other F-35's operating in the area, compare sensor information between all of them, and cooperatively engage a target, which of course is the real advance in the F-35: the fusion of sensors and platforms to maximize the usefulness of the information each sensor gathers. An A-10 will never do that.
I will point out that flying low and slow with the Mark 1 eyeball will not always allow you to reliably find targets. I will point out there is an instance during Gulf War II, 5 pairs of UK-issue Mk-1 eyeballs (3 on a Lynx and 2 on a Gazelle) were nearly at a loss to locate and neutralize a single Iraqi T-55 that was very happily taking potshots at the former, despite flying low and slow outside of Basra. The F-35's IR sensors may not detect targets, if the moisture content obscures signatures, but its SAR/GMTI should be able to see them. If one of these obscured weapon systems opens fire, then the EODAS will see that, and then all other F-35's in the area, will know the location. And if the F-35's sensors cannot find a target, then no Mark 1 eyeball will find the target.
The F-35 program was brought into existence in the first place because of budgetary limitations. Nobody doubts that in a perfect world a half dozen different specialized aircraft would be better.
In the real world we don't have the money to develop and sustain these hypothetical new designs and on the fastest possible timeline they would only be available sometime in the 2020s. (Depending how much concurrency, reliance on models and simulation, and risk you are willing to accept... )
BMI727
Fri Oct 12, 2012 7:51 am
Quoting ThePointblank (Reply 82):
You mean the ones the F-35 should have wiped out on the first day of the war?
A-10s don't work and get shot at from a long way away. There isn't much stealth that's going to be useful against an enemy looking into the sky and seeing a plane.
I'm not saying that the A-10 avionics and sensors shouldn't be upgraded. But along with the useful sensors, the F-35 is always going to be carrying a lot of sensors and equipment that is useless for a given mission.
...and we can see how that turned out. Not that much better than the last time we tried the one size fits all approach. Maybe next time we'll figure it out and skip right to the more capable platforms with fewer compromises.
sweair
Fri Oct 12, 2012 9:39 am
Who thinks the F35 would do a better job of CAS in Afghanistan than the A10? The F35 will have to be very good at 5 or 6 different roles, with one platform.. Call me a sceptic..
Revelation
Fri Oct 12, 2012 5:13 pm
Quoting ThePointblank (Reply 74):
Indeed, but:
BAE produces the aft fuselage, tails, fins, electronic warfare system, and various other sub-systems for the F-35 Lightning II
so I think they have skin in the game.
Adapt or die. Find a new challenge, like building a high capability UAV at a significantly lower price point than the US gold plated models.
It has flaws beyond these, and the expense one is the one that is going to be its downfall.
Ok, what are we talking about, A-10 or A-12?
Reality is that more compromises will be coming.
There's only so far the "paying the price of freedom" rhetoric will go.
The heart has it's beaches, it's homeland and thoughts of it's own
The heart has it's seasons, it's evenings and songs of it's own
connies4ever
Fri Oct 12, 2012 6:25 pm
Current display issue of AIR International has a lengthy feature on F-35, using pilot and mx crew interviews, as well as commentary from defense analysts. Of course the pilots defend the a/c. However, Pierre Sprey, Pentagon analyst, says "the aircraft has sluggish performance" and in a dogfight "would be destroyed by something like a MiG-21". As well, Sprey says "as a CAS platform, F-35 is laughable".
USMC Col Arthur "Turbo" Tomassetti, #2 in 33rd FW, concedes that compared to F-35, a mission-specific a/c will outperform it. Vol 83, #4, ppg 44-49.
These guys make their living at this, their opinions count for something.
Yes, well that has worked out well, hasn't it ?
Quoting sweair (Reply 84):
Count me in.
BMI727
Fri Oct 12, 2012 8:56 pm
Quoting Revelation (Reply 85):
I was talking about the A-10, but my thoughts on the A-12 are pretty well established at this point.
bigjku
Fri Oct 12, 2012 9:58 pm
Quoting connies4ever (Reply 86):
Sprey is not with the Pentagon anymore I don't believe and has not been for a long time. Frankly...and I recognize the guy had value at one point...he is bonkers. His ideas about what the F-16 should have been were laughable and he was pitching his doom and gloom before the 1st Gulf War. He is a guy who wants lots of cheap planes that point their nose quickly, beyond that I am not sure what he is contributing to the discussion anymore.
http://www.airforce-magazine.com/Mag...February%202008/0208reformers.aspx
I think that article is pretty telling on how extreme his group really was. They opposed the majority of the weapons that decisively won the 1st Gulf War.
On the CAS issue I would say it very much depends on what you are being asked to do. I would guess that for 90% of the missions the A-10 would be asked to do with Mavericks, LGB's, SDB's and Cluster Bombs the F-35 would be its equal or better at employing those weapons in a CAS environment. There will be a few missions the F-35 can't do as well, but as others have said, that is the price of a smaller defense budget. There is no way that straight replacements for the F-16, A-10, Harrier and F-18 would have been cheaper overall than the F-35. It would have been significantly more expensive. The downside of that is going to be a few compromises.
Powerslide
Sat Oct 13, 2012 12:21 am
Stopped reading after that.
Overall, I find it laughable that civilians are putting in their    regarding CAS and other military matters. You are not the experts (nor am I for that matter). There are always people who bitch and complain whenever there is a new military program.
The reality is, it doesn't matter what you think - that's not attacking you personally its just what it is. If you think you can do a better job fighting wars then I suggest you go enlist and make it up high enough in rank where you can start changing things. Until then, CAS will be handled by the professionals. They won't be using equipment that they think is not up to the task. If the F35 wasn't meeting combat performance goals set out by the DOD it would've been axed a long time ago. It's not the piece of crap everyone would like to think it is.
ThePointblank
Sat Oct 13, 2012 2:21 am
It has been argued that at best these companies will be parts suppliers to larger OEM's across the pond.
Quoting BMI727 (Reply 83):
While you can eliminated a good chunk of enemy air defences, you can't eliminate them all. Had we faced a opponent in Afghanistan and Iraq that was better equipped and more motivated, we would have lost a lot more A-10's. The Package Q Strike during Gulf War I is a clear reminder that despite achieving air superiority over a opponent, a well equipped enemy still has the ability to maul and inflict significant harm to your forces.
Unless the aircraft is flying high, and can still make out and determine targets from a higher altitude. Remember the majority of armour kills for the A-10 occurred using the Maverick missile, not the gun due to the very high Iraqi AAA threat.
Situational awareness is the game for F-35. Being able to use all of its sensors to put together a picture of the battlefield around him will allow the pilot to better coordinate his strikes in a quick and timely fashion, and allow mission planners to better allocate assets.
It will be a long while until other aircraft get the same level of sensor fusion and networking capabilities as F-35.
Cheaper than developing 3-4 separate platforms. At least with F-35, there is some commonality in systems and there the scale of production.
connies4ever
Sat Oct 13, 2012 1:29 pm
Quoting Powerslide (Reply 89):
Fine to criticize others as not being experts but still offering opinions. But if you admit you yourself are not an expert, then why are you still offering opinions ? Just a thought ...
Oykie
Wed Oct 31, 2012 7:27 pm
Hi all,
Just wanted to update you on this issue. According to the last week Aviation Week, (October 22nd 2012, page 22) Romney has shifted his stance on the fighter jet.
According to this article former Pentagon controller and Romney campaign defense maven, Dov Zakheim, adjusted the message in favor of the F-35. To quote the article:
But now, officially, Romney is keeping his options open when it comes to the Air Force's future fleet of tactical fighters. "Governor Romney is committed to maintaining American airpower that is second to none," campaign representative Andrea Saul tells Aviation Week, "He will keep any option to ensure our airmen are flying planes worthy of the incredible mission the perform on our behalf"
The latest statement is worthless of course as it does not commit Romney to anything at all. But the Doc Zakheim comment is more firm that the F-22 might be off the table.
Powerslide
Thu Nov 01, 2012 2:34 am
Quoting oykie (Reply 92):
Doesn't make a difference, Obama will win.
sweair
Thu Nov 01, 2012 3:32 pm
What role is the best of the many roles the F35 has. Is it a good bomber or fighter? Or is it just ok in any role? The F22 is mostly a fighter and I guess a good one.
HaveBlue
Thu Nov 01, 2012 5:26 pm
Quoting Powerslide (Reply 93):
You don't know that, and it'd be much better not have any superfluous political rhetoric in this thread... from either side.
Oroka
Thu Nov 01, 2012 6:01 pm
Quoting sweair (Reply 94):
The F-35 can easily match current F/A-18s for flight performance. The F-35 is the low part of the F-22/F-35 hi/lo mix... it was never ment to be an air dominance fighter, that is the F-22s job. Throw in stealth and the other electronic goodies, it has a large advantage over the F/A-18.
As stated, it will make a good fighter, and a good attack bomber, but not excellent at either.
wvsuperhornet
Fri Nov 02, 2012 5:05 am
Quoting Oroka (Reply 96):
Thats the problem with the F-35 its not excellent at either and was designed to work with the F-22, the problem is the F-22 was cut to 186 and now the US has to rely on the the F-35 for most of the combat missions. I believe thats why nobody has any faith in the F-35 and I am one of them. 186 air superiority fights is not enough for the US I don't care how good the aircraft is. The F-35 won't be able to fill the role.
[Edited 2012-11-01 22:07:07]
checksixx
Fri Nov 02, 2012 11:41 am
Quoting wvsuperhornet (Reply 97):
Kind of why we still have the F-15C/D/E's around, not to mention the F-16's and F-18C/D/E/F's...I'm pretty sure we have good coverage.
Oroka
Fri Nov 02, 2012 2:08 pm
Quoting checksixx (Reply 98):
F-16s and F/A-18s (any make) are not air superiority fighters.
The F-35 is a compromise. It is indeed better than 4.5 gen fighters, but it is not a F-22.
Would such a compromise of a fighter have worked in the 70s or 80s... no, but back then large fleets of specialized fighters were needed. Today, modern fighter forces are pretty much for putting out little flare-ups. 500 specialized strike bombers will be of limited usefulness in modern times.
If a F-35 came up against the best fighters out there, it could probably hold its own, but not completely out class a foe, but that is where a F-22 would be used.
186 is a somewhat small number for the F-22, but what is out there to challenge it? There is little out there that can challenge the current 4.5 gen force... a full 5th gen force will be unmatched for years. Worse comes to worst, there is a reason the F-22 jigs are in storage and not scrapped.
