Quoting thomil13FRA (Reply 6): The Gripen-E, while a substantial, indeed radical improvement on the original design, carries much less risk. Then there is the political aspect. With the US political landscape being the way it is, you can expect US policy to get a lot more erratic once the mid-term elections are through. Sweden is more stable on that front, and from my limited perspective, the likelihood of relations between Bern and Stockholm turning sour are much lower than of a downturn in US-Swiss relations. |
Quoting thomil13FRA (Reply 6): The F/A 18 E/F come in at a wingspan of 13.62 meters, while the F-35 comes in at 10.7 meters. |
Quoting alfons (Reply 2): they would be as an addition to our F-18's, not replacement. Which even further tells me that additional fighters of same kind but newest iteration, would make more sense. |
Quoting flyingturtle (Reply 9): 32 F/A-18Cs and Ds are still enough air power for such a small country. |
Quoting SAS A340 (Reply 10): As i have understand it,it,s about having Gripen or no fighter at all? What does that meen? no Airforce after 2025? |
Quoting flyingturtle (Reply 11): There are conflicting numbers about the F/A-18C/D life span. Some earlier reports said that they will soldier on until 2030 or even 2035, but newer answers from our Secretary say that they'll be good until 2025. |
Quoting thunderboltdrgn (Reply 3): |
Quoting sandrozrh (Reply 13): Like, we still maintain a huge fleet of combat tanks! i mean, really?! |
Quoting thunderboltdrgn (Reply 3): The Gripen E cost will also be about 30% lower then for the Gripen C/D versions |
Quoting alfons (Thread starter): I'll need to vote on May 18th for a Gripen E (not built yet) for Switzerland, or no new fighter at all. |
Quoting flyingturtle (Reply 9): I will vote no. |
Quoting art (Reply 15): voting no because it seems unnecessary to buy more aircraft, how long will the F-5 aircraft last? If they run out of hours, will they not need to be replaced? Again, if the F-5 aircraft are not replaced that means more F-18 hours each year, shortening their lives (or requiring very costly rebuild much sooner). |
Quoting KC135TopBoom (Reply 16): Are you perfectly safe from a 9/11 style attack from terrorists? |
Quoting KC135TopBoom (Reply 16): After all, almost all Swiss citizens are subject to mandatory conscription. |
Quoting 9VSIO (Reply 18): I believe we saw the answer with the Ethiopian hijacking. |
Quoting flyingturtle (Reply 19): |
Quoting SAS A340 (Reply 10): The Swiss have yet anyway soon start thinking on what fighter that should replace the current F-18 when their lifetime expires in about 2025. |
Quoting prebennorholm (Reply 8): I think you can totally rule out the F/A-18E/F Super Hornet. |
Quoting flyingturtle (Reply 9): In all the interviews and news reports I've read, the army staff could not give a clear and stringent answer about *why* we need those Gripen. |
Quoting prebennorholm (Reply 21): Remember how long time the Swiss kept their Vampires flying. In Swiss hands those F-18s can last a hundred years. |
Quoting rheinwaldner (Reply 22): |
Quoting tommy1808 (Reply 24): a) a country that, worst case, takes 20 minutes to fly over for an airlines can never be protected against that by fighters. |
Quoting tommy1808 (Reply 24): b) shooting down an airliner with civilians on board? Does Switzerland even have a law permitting that? Does the constitution in Switzerland permit that at all. In Germany it sure doesn´t, government tried, supreme court struck it down. |
Quoting flyingturtle (Reply 23): It's ludicrous to think we could have something like a World War II scenario where we quite successfully engaged German Messerschmitts. |
Quoting flyingturtle (Reply 23): I wonder how fast our runways would be taken out by a determined and well-equipped enemy. |
Quoting flyingturtle (Reply 23): The air-ground-capability is long gone. |
Quoting rheinwaldner (Reply 26): Maybe the first would hit, but the 2nd, 3rd and 4th would be catched. |
Quoting KiwiRob (Reply 27): That would all depend on the time lines of the hyjackings |
Quoting rheinwaldner (Reply 28): In fact they would have to leave their normal, planned cruise path at exactly the same time, which is not possible to plan exactly. |
Quoting rheinwaldner (Reply 26): There are a lot of former airfields in the alps. I used to make a Flightsim flight departing from Emmen. And within less than 30 minutes I approached 18 (!) different active or former Air Force bases for a touch and go. |
Quoting rheinwaldner (Reply 26): It is there in the A-designation of the F/A-18 and also the Gripen would be used to train that capability again (IIRC). |
Quoting flyingturtle (Reply 29): But still, after the first attack each and every A/C in a specified area will be commanded to land ASAP. The air force will deal with the rest that does not comply. |
Quoting alfons (Reply 33): I don't like this attitude to simply try to take the cheapest one |
Quoting alfons (Reply 33): Little, strong and maneuvrable |
Quoting rheinwaldner (Reply 34): You might review your assessment here: http://www.aviatia.net/versus/gripen-vs-eurofighter/ Especially about the aircraft size and bang for buck... |
Quoting flyingturtle (Reply 19): AFAIK appropriating 30 million/year for establishing 24/7 combat alert readiness was discussed back in 2010, but was shelved. I don't know why... |
Quoting alfons (Reply 35): what comes out in this report is that the Gripen is almost in every job scope inferior to the old F/A-18. |
Quoting SAS A340 (Reply 38): Looks like the Swiss people says NO to Gripen..... |
Quoting Agill (Reply 40): |
Quoting seahawk (Reply 43): The best option is to make do the with the Hornet fleet until it runs out of service life and then re-consider the need for an Air Force. |
Quoting seahawk (Reply 43): The best option is to make do the with the Hornet fleet until it runs out of service life and then re-consider the need for an Air Force |
