Ozair
Re: SpaceX - Tests, Launches, Developments
Tue May 14, 2019 12:45 am
flyingturtle wrote:
In the very early hours of May 16th (GMT time), SpaceX will launch sixty Starlink communication satellites at once.
Whew.
And so it begins...
Have SpaceX indicated the launch frequency yet and this launch will have 60 satellites but given the intent is approx 12000 how many do you think they will be able to loft in a single launch?
Nomadd
Tue May 14, 2019 11:09 am
Ozair wrote:
Whew.
And so it begins...
Hard to say. Higher sats might need to be bigger, higher sats might need a Falcon Heavy, since this payload is maxing out the F9, the Starship will be operational who knows when, SpaceX has how many more tricks up their sleeve???...Lots of guessing going on.
People were surprised to hear they might launch 24 sats at once. 60 is crazy.
flyingturtle
Tue May 14, 2019 10:33 pm
In 2018, 4857 satellites were orbiting the earth, of which 1980 were active.
In 2019, SpaceX intends to launch four rokkits with Starlink satellites. So, an initial constellation of 180 satellites, which neatly compares to... well, the line above.
David
Reading accident reports is what calms me down
Ozair
Wed May 15, 2019 12:24 am
David
That is 2019 but SpaceX has made it clear the minimum constellation they need for “spotty service” is 800 and still have plans for that 12000 to provide coverage at the desired capability.
The launch will consist of the first 60 Starlink satellites, which appear to be experimental. SpaceX CEO Elon Musk tweeted that “much will likely go wrong on 1st mission. Also, 6 more launches of 60 sats needed for minor coverage, 12 for moderate.” The 60 satellites will join a couple of prototypes satellites called Tintin, which launched in 2018.
“This next batch of satellites will really be a demonstration set for us to see the deployment scheme and start putting our network together,” said SpaceX’s president and chief operating officer, Gwynne Shotwell, on May 7 at the Satellite 2019 conference, reports spacenews.com. “We start launching satellites for actual service later this year.”
At least a couple of years. According to Shotwell, there will be two more launches in 2019, possibly as many as six, though that depends on whether the initial 60 check-out. SpaceX needs about 800 up there to begin a spotty service, which it wants to happen by 2021, though the journey to having 12,000 up there could be a long one.
https://www.forbes.com/sites/jamiecarte ... 56ae165641
So compared to the 1980 operating satellites in 2018 by the end of 2021 the additions by SpaceX, and a few others, will likely take that total above 3000… a 50% increase in 3 years.
At 60 sats a launch that is 14 launches, plus a couple of extras being done today for the test system being launched shortly.
ZaphodHarkonnen
Wed May 15, 2019 1:35 am
For the moment the record still belongs to the ISRO with something like 104 satellites in one launch. The increase of planned stuff in LEO is pretty crazy. O_O
flyingturtle
Wed May 15, 2019 12:23 pm
https://spaceflight101.com/pslv-c37/psl ... h-success/ has nice images of a 88-satellite rack. I hope at least one of them was a SafetySat.
David
casinterest
Thu May 16, 2019 1:35 am
Spacex Starlink feed will go live at 02:15 UTC
https://www.youtube.com/watch?v=rT366GiQkP0
They are going to launch stacked satellites for internet coverage over rural areas over the next few years . This is the first mission.
Where ever you go, there you are.
jonnyclam123
Thu May 16, 2019 12:55 pm
Starlink launch now scheduled at 10:30 PM EDT tonight.
flyingturtle
Thu May 16, 2019 4:59 pm
Today's launch was scrubbed because of high wind speeds in the upper atmosphere.
Why is this a matter? The F9 comes roaring through the air at a much higher speed... :scratchchin:
flyingturtle
Fri May 17, 2019 10:34 am
Scrubbed because of winds in the upper atmosphere.
Then, scrubbed again because SpaceX wants to update the satellite software.
Those damn Windows updates always come at the worst possible time...
DarkKnight5
Fri May 17, 2019 4:36 pm
Wonder how long it’s going to take Nick Burns to install updates on 60 sats.
jonnyclam123
Wed May 22, 2019 1:02 pm
Now scheduled for the 24th at 10:30 PM again.
Francoflier
Fri May 24, 2019 6:12 am
Another successful mission.
The booster was also successfully recovered on OCISLY, which was its 3rd landing.
The satellite deployment was interesting and not quite what I expected. The cluster was released in one step. There was no deployment mechanism, the satellites were simply all 'dumped' and slowly separated from each other in a random fashion.
I suppose they will wait for them to be sufficiently far from each other and slowly bring them to their precise respective orbit?
william
Fri May 24, 2019 3:07 pm
Apparently all 60 satellites have phoned home and are working. I thought it was interesting how the satellites are designed at end of life to initiate a burn that will send it into earth's atmosphere, and is designed to disintegrate into 95% dust in the atmosphere. Speaking of Space Junk, the satellites are linked to a military database and is aware of space junk around and will move out of the way so as not to collide with it. A lot of common sense stuff that makes one wander why it took so long for some else to think about it.
https://www.youtube.com/watch?v=riBaVeDTEWI
william
Fri May 24, 2019 3:24 pm
https://www.starlink.com/
Starlink website up. Smart how they figured out how not to add to the space junk problem.
mxaxai
Fri May 24, 2019 7:04 pm
Because it adds weight and cost to the satellite. They probably did it because they otherwise wouldn't get the permits without a good plan for end of life disposal. 60 satellites is almost as large as the entire Iridium constellation.
william
Sat May 25, 2019 5:59 pm
https://www.youtube.com/watch?v=ytUygPqjXEc
How odd, was this through a telescope or naked eye? Will the satelltes pop up on my Skyview app?
DarkKnight5
Sun May 26, 2019 2:56 pm
I’m guessing it was made with a camera with a lense, which is sort of a telescope when you think about it.
Stitch
Wed Jun 12, 2019 11:03 pm
Vandenberg was socked-in with fog today which added some visual interest to the RADARSAT Constellation Mission launch and recovery footage.
Francoflier
Thu Jun 13, 2019 2:48 am
Sure did. The shot where we see it punching out of and sinking back into the fog layer are quite amazing.
Second flight and landing for that booster, which is the one which launched the Crew Dragon Demo-1 mission in March.
Users browsing this forum: rturner, YIMBY and 21 guests
