Ozair
Re: SpaceX - Tests, Launches, Developments
Tue May 14, 2019 12:45 am
flyingturtle wrote:
In the very early hours of May 16th (GMT time), SpaceX will launch sixty Starlink communication satellites at once.
Whew.
And so it begins...
Have SpaceX indicated the launch frequency yet and this launch will have 60 satellites but given the intent is approx 12000 how many do you think they will be able to loft in a single launch?
Nomadd
Tue May 14, 2019 11:09 am
Ozair wrote:
Whew.
And so it begins...
Hard to say. Higher sats might need to be bigger, higher sats might need a Falcon Heavy, since this payload is maxing out the F9, the Starship will be operational who knows when, SpaceX has how many more tricks up their sleeve???...Lots of guessing going on.
People were surprised to hear they might launch 24 sats at once. 60 is crazy.
flyingturtle
Tue May 14, 2019 10:33 pm
In 2018, 4857 satellites were orbiting the earth, of which 1980 were active.
In 2019, SpaceX intends to launch four rokkits with Starlink satellites. So, an initial constellation of 180 satellites, which neatly compares to... well, the line above.
David
Reading accident reports is what calms me down
Ozair
Wed May 15, 2019 12:24 am
David
That is 2019 but SpaceX has made it clear the minimum constellation they need for “spotty service” is 800 and still have plans for that 12000 to provide coverage at the desired capability.
The launch will consist of the first 60 Starlink satellites, which appear to be experimental. SpaceX CEO Elon Musk tweeted that “much will likely go wrong on 1st mission. Also, 6 more launches of 60 sats needed for minor coverage, 12 for moderate.” The 60 satellites will join a couple of prototypes satellites called Tintin, which launched in 2018.
“This next batch of satellites will really be a demonstration set for us to see the deployment scheme and start putting our network together,” said SpaceX’s president and chief operating officer, Gwynne Shotwell, on May 7 at the Satellite 2019 conference, reports spacenews.com. “We start launching satellites for actual service later this year.”
At least a couple of years. According to Shotwell, there will be two more launches in 2019, possibly as many as six, though that depends on whether the initial 60 check-out. SpaceX needs about 800 up there to begin a spotty service, which it wants to happen by 2021, though the journey to having 12,000 up there could be a long one.
https://www.forbes.com/sites/jamiecarte ... 56ae165641
So compared to the 1980 operating satellites in 2018 by the end of 2021 the additions by SpaceX, and a few others, will likely take that total above 3000… a 50% increase in 3 years.
At 60 sats a launch that is 14 launches, plus a couple of extras being done today for the test system being launched shortly.
ZaphodHarkonnen
Wed May 15, 2019 1:35 am
For the moment the record still belongs to the ISRO with something like 104 satellites in one launch. The increase of planned stuff in LEO is pretty crazy. O_O
flyingturtle
Wed May 15, 2019 12:23 pm
https://spaceflight101.com/pslv-c37/psl ... h-success/ has nice images of a 88-satellite rack. I hope at least one of them was a SafetySat.
David
casinterest
Thu May 16, 2019 1:35 am
Spacex Starlink feed will go live at 02:15 UTC
https://www.youtube.com/watch?v=rT366GiQkP0
They are going to launch stacked satellites for internet coverage over rural areas over the next few years . This is the first mission.
Where ever you go, there you are.
jonnyclam123
Thu May 16, 2019 12:55 pm
Starlink launch now scheduled at 10:30 PM EDT tonight.
flyingturtle
Thu May 16, 2019 4:59 pm
Today's launch was scrubbed because of high wind speeds in the upper atmosphere.
Why is this a matter? The F9 comes roaring through the air at a much higher speed... :scratchchin:
flyingturtle
Fri May 17, 2019 10:34 am
Scrubbed because of winds in the upper atmosphere.
Then, scrubbed again because SpaceX wants to update the satellite software.
Those damn Windows updates always come at the worst possible time...
DarkKnight5
Fri May 17, 2019 4:36 pm
Wonder how long it’s going to take Nick Burns to install updates on 60 sats.
jonnyclam123
Wed May 22, 2019 1:02 pm
Now scheduled for the 24th at 10:30 PM again.
Francoflier
Fri May 24, 2019 6:12 am
Another successful mission.
The booster was also successfully recovered on OCISLY, which was its 3rd landing.
The satellite deployment was interesting and not quite what I expected. The cluster was released in one step. There was no deployment mechanism, the satellites were simply all 'dumped' and slowly separated from each other in a random fashion.
I suppose they will wait for them to be sufficiently far from each other and slowly bring them to their precise respective orbit?
william
Fri May 24, 2019 3:07 pm
Apparently all 60 satellites have phoned home and are working. I thought it was interesting how the satellites are designed at end of life to initiate a burn that will send it into earth's atmosphere, and is designed to disintegrate into 95% dust in the atmosphere. Speaking of Space Junk, the satellites are linked to a military database and is aware of space junk around and will move out of the way so as not to collide with it. A lot of common sense stuff that makes one wander why it took so long for some else to think about it.
https://www.youtube.com/watch?v=riBaVeDTEWI
william
Fri May 24, 2019 3:24 pm
https://www.starlink.com/
Starlink website up. Smart how they figured out how not to add to the space junk problem.
mxaxai
Fri May 24, 2019 7:04 pm
Because it adds weight and cost to the satellite. They probably did it because they otherwise wouldn't get the permits without a good plan for end of life disposal. 60 satellites is almost as large as the entire Iridium constellation.
william
Sat May 25, 2019 5:59 pm
https://www.youtube.com/watch?v=ytUygPqjXEc
How odd, was this through a telescope or naked eye? Will the satelltes pop up on my Skyview app?
DarkKnight5
Sun May 26, 2019 2:56 pm
I’m guessing it was made with a camera with a lense, which is sort of a telescope when you think about it.
Stitch
Wed Jun 12, 2019 11:03 pm
Vandenberg was socked-in with fog today which added some visual interest to the RADARSAT Constellation Mission launch and recovery footage.
Francoflier
Thu Jun 13, 2019 2:48 am
Sure did. The shot where we see it punching out of and sinking back into the fog layer are quite amazing.
Second flight and landing for that booster, which is the one which launched the Crew Dragon Demo-1 mission in March.
flyingturtle
Tue Jun 25, 2019 6:43 am
Core booster seems to have missed the boat... went for a drink.
Everything else looks OK.
MatthewDB
Tue Jun 25, 2019 6:47 am
I loved the crowd reaction. Dang... wait, we didn't have high hopes on this one so whooo hooo.
I'm hoping that we're going to get some good videos of the night double landing. This should be a good comparison to the two daytime double landings.
Francoflier
Tue Jun 25, 2019 8:05 am
Ouch. That's 1 for 3 on center core landings and 0 for 3 on overall recovery... (That last landing was particularly tricky anyway, they probably didn't have high hopes).
Oh well, no one said it was going to be easy.
At least they nailed fairing recovery this time.
Otherwise, another successful mission.
LightningZ71
Tue Jun 25, 2019 5:38 pm
Musk was fairly up front about the low likelihood of recovering the center core. The Max Q timing on this launch was rather extreme, and, as he said, it would be coming in quite hot. It was still extremely close as these things go.
aviationaware
Wed Jun 26, 2019 1:44 am
Considering how close it was to the boat it looks like a single engine went out a single digit amount of seconds too early. So by any measure that's incredibly close.
ZaphodHarkonnen
Wed Jun 26, 2019 2:00 am
Just like when they were first attempting to just catch the first core out at sea. Even getting close enough to see it splash is an amazing achievement. The sheer science and engineering team effort to just do that is impressive. Think back to the days of early ballistic missiles where being within a mile of what you were aiming at was a win. And for that you didn't even need it working after use. :P It's just a matter of time until they can recover such a high energy return.
And don't forget they managed to catch the centre core on their first attempt. It was the ocean state after that resulted in the booster loss.
GST
Wed Jun 26, 2019 6:44 am
I wonder if this is one of their less preferred failure types. The descent profile has the booster aiming for a spot some way from the intended landing spot (be it the barge or a landing pad - in the latter case the aim point is out to sea a bit) for the majority of the approach, before adjusting the trajectory in the very final descent phase to aiming for the actual landing spot. Therefore for most of the descent, a failure would result in the booster impacting a spot where it can do no harm to people, equipment, or infrastructure. But if a failure occurs once the final trajectory correction is under way or complete, there is a very high risk of a fireball somewhere you actually care about and having a hefty repair bill (like the times when they had a fireball actually on the droneship).
What I think would be really cool, is if what we saw yesterday turned out to be an actual programmed last-moment abort routine - the rocket has determined in the very final descent that for some reason it can no longer land on the barge, so shut down one side engine and max thrust the other side to get the rocket to crash some way abeam.
ZaphodHarkonnen
Wed Jun 26, 2019 11:42 am
I'd be surprised if that were the case. Even when done right the term you'll often here used is a hover-slam. As that's exactly what it is. It's still a big hit and arguably dicey when everything works as intended. Hence why the pads are well clear of anyone. Remember one of the earlier landings had one of the legs use all of the energy absorbing crush blocks in one of the legs. Another term that's used to describe the move is a suicide burn. If it doesn't go off perfectly it goes boom.
I expect SpaceX will mention why it didn't work at some point. Quite probably an engine running out of fuel or failing to relight. As you mention, the move to aim at the pad directly happens at the very last moment. The very last moment.
william
Wed Jun 26, 2019 4:40 pm
https://www.teslarati.com/spacex-ceo-el ... d-landing/
Good explanation why retrieving the center section was going to be dicey. It was falling, and falling fast!
Armadillo1
Tue Jul 09, 2019 7:29 pm
Is there topic about space junk? I think baloon (parachute/air brake) will be nice for any size satellite
flyingturtle
Wed Jul 24, 2019 10:40 pm
That poor rokkit, that roars along at more than the speed of sound, was afraid of a bit of high-altitude wind.
Launch is postponed to tomorrow, same time.
Trololzilla
Thu Jul 25, 2019 3:10 am
The Starhopper 20m test jump was also aborted just after the engines were ignited.
Armadillo1
Thu Jul 25, 2019 1:41 pm
https://twitter.com/i/web/status/1154261135245246465
Pc (chamber pressure) high due to colder than expected propellant
Nomadd
Fri Jul 26, 2019 3:09 am
The next hop try might happen in about 30 minutes.
zanl188
Fri Jul 26, 2019 3:58 am
Star hopper test successful, apparently. Brush fire at the pad.
GDB
Fri Jul 26, 2019 5:47 pm
A great day for SpaceX, not only Starhopper, (with Elon saying a 200m hop planned within weeks) but also another Falcon 9 launch to support the ISS. With a 3 x used Dragon, a used Falcon 9 with the now almost absurdly routine landing of the booster. Which is still an amazing sight.
Nomadd
Sat Jul 27, 2019 12:46 am
The brush fire burned for about a mile and a half and stopped 200 feet short of the village. I spent all night on the roof with a bottle of Glenlivet, watching it come.
zanl188
Sat Jul 27, 2019 1:34 pm
Did firefighters respond or did they keep their distance due to.haz mat?
Nomadd
Tue Jul 30, 2019 9:35 pm
Not hazmat as much as the marshy location of the fire. Trucks probably would have gotten stuck and there was no need to stop it right away since it had rained recently and wind was favorable. I guessed they'd stop it right where they did, since that was where the brush narrowed down.
If it had crossed the road after a month of drought, it could have been bad.
Tugger
Wed Aug 07, 2019 2:22 pm
Yesterday's launch of the AMOS17 satellite was successful, though no booster return (as planned). However at least one half of the fairing was recovered. Good video of it:
https://twitter.com/elonmusk/status/115 ... 69/video/1
Tugg
Productivity isn’t about getting more things done, rather it’s about getting the right things done, while doing less. - M. Oshin
AirPacific747
Thu Aug 08, 2019 1:33 pm
Tugg
Saw it from Orlando, and I saw the Atlas V rocket this morning too
Nomadd
Fri Aug 09, 2019 2:31 pm
With the SpaceX hopper program in Boca Chica running a little long and the Starship prototype almost ready for engine work, the 200 meter hop next week will be the last. A few dozen welders, plumbers and crane operators aren't enough to keep two operational rocket programs going at once.
The tiny crew building this thing (and a few people building the engines in Hawthorne) is one helluva contrast to the thousands supporting a conventional program.
(Image is mine)
flyingturtle
Fri Aug 09, 2019 6:20 pm
[quote="Nomadd"][/quote]
That's so amazing. If you have a good engine and some plumbing, any water tower is a rocket...
zanl188
Mon Aug 26, 2019 11:48 pm
Starhopper 200 meter attempt scrubbed for today. Try again tomorrow.
casinterest
Wed Aug 28, 2019 12:27 am
StarHopper hopped
https://youtu.be/m0MTtqzzf-U?t=8442
Wonder what debris went flying when landing?
Pretty awesome "Water Towers Can Fly"
Stitch
Wed Aug 28, 2019 12:32 am
Amazing.
Planeflyer
Wed Aug 28, 2019 4:01 am
Wow, sure is.
WIederling
Wed Aug 28, 2019 7:01 am
casinterest wrote:
StarHopper hopped
old:
https://www.youtube.com/watch?v=dQWbcyR ... .be&t=2525
( Tatort episode where they kill a Erich von Däniken templated Person
played by Raumpatrouille Orion Commander actor Dietmar Schönherr. )
Amusing and surprising outcome.
Murphy is an optimist
memphiX
Wed Aug 28, 2019 1:45 pm
short version:
https://www.youtube.com/watch?v=eZcQWf0YaCg
No wonder why people hate Musk so much, he makes it look easy.
Do you want space flights? Here is the EZ button.
wingman
Wed Aug 28, 2019 3:59 pm
Dense question, what exactly is this Hopper for? The name seems obvious but I'll be damed if I can understand how you'd ever tank enough fuel to do more than one take-off.
Users browsing this forum: jollo and 10 guests
