flyingturtle
Re: SpaceX - Tests, Launches, Developments
Wed Oct 02, 2019 9:14 pm
casinterest wrote:
Tim the Everyday Astronaut led a good interview.
It's so interesting that Elon Musk - in the beginning - just rehashes what is told in every business school. But rarely the companies actually heed that advice...
1. Never optimize what should not be done in the first place.
2. If design is taking too long, settle for another design.
3. Your product reflects your organization. If another department is setting constraints on what you're designing - be aware that these constraints may be faulty.
4. Ask whether the right questions are being asked.
Elon's role is interesting. He dedicated some years to read everything on rocket design and space exploration. He's as much a boss as he is an engineer.
Regarding the aerospike engine - which has high efficiencies across all air densities - he basically said that too much work is needed to make them as nearly as efficient as those inverted buckets where things are mixed and ignited.
Reading accident reports is what calms me down
casinterest
Wed Oct 02, 2019 9:18 pm
It's the time and money issue.
and although these issues are rehashed in business school, it doesn't get played out often, because too many people are too attached to their pet projects, and pleasing those on top, and are scared to take it to scrap and make it better. Having Musk at the top believing this makes an organization better and more organic. it's the old Steve Jobs vs. John Sculley fight.
Where ever you go, there you are.
Nomadd
Wed Oct 02, 2019 10:02 pm
texl1649 wrote:
From what I know stainless steel is vastly heavier than carbon fiber. Is this just for the test phase it will be built like a farm implement?
Everybody knew that. Everybody knew wrong. It doesn't matter how much a cubic inch of the material weighs. It matters how much the spaceship weighs. Carbon fiber would have needed so much heat shielding that the ship would have ended up weighing more than stainless steel in the end. Carbon fiber would also cost about fifty times as much and would have required a lot more infrastructure. Modifying and repairing would have been a lot more complicated and the time developing and building would have been much greater.
They're building these things almost for free compared to any other outfit. The engines are coming off the line for around a million dollars each compared to twenty times that much for comparable engines. They figured out that the great expense and difficulty of using any kind of composite to get another 20% payload just didn't make sense. And it looks like it wouldn't even have helped with payload.
They already have rolls of steel laying around for MK3. One piece hoops with a single vertical seam.
The guy is definitely an exceptional CEO. When he heard the locals were getting restless he got seven of them in a room and spent an hour talking to them after the presentation.
DarkKnight5
Thu Oct 03, 2019 5:31 am
texl1649 wrote:
Tugger wrote:
Nomadd wrote:
It's amazing what a focused, very intelligent billionaire, who's willing to spend billions and not hoard them into portfolio investments, can do.
We need more billionaires like him (and Bezos comes to mind of course) that just pour their wealth back into things like this (real world production and manufacturing and building etc.).
Tugg
Well, fortunately for humanity Warren/Sanders have a plan to deal with/eliminate those pesky billionaires. I do agree though, it takes a creative billionaire not beholden to a skeptical private equity/venture capital fund to make something like this even close to feasible.
There are myriad factors to consider, including mass, how much mass must be supported by that structural mass, how thick the structure needs to be to support that mass, how that structure holds up in both extremely hot and extremely cold environs, cost of material, and who knows how many others.
Very smart people at SpaceX have determined advanced stainless steel is the most efficient material for Starship when everything is factored.
Planeflyer
Thu Oct 03, 2019 12:58 pm
New space companies like SpaceX are entrepreneurial organizations rather than government contractors.
There is a lesson here for the pentagon. I hope someone over is there is trying to figure out how to redefine the weapons market as NASA did the space market.
dtw2hyd
Thu Oct 03, 2019 2:49 pm
I like the use of steel concept. The carbon fiber fabrication skill, time and cost seem to negate its benefit. $130K/lb vs $2.5k/lb and steel be welded outdoors, rather than getting it fabricated in a couple of places in the world and ship to launch site, I think Musk should be given a chance.
flyingturtle
Thu Oct 03, 2019 4:44 pm
Could they have built a stainless steel Space Shuttle if they had figured out how to do a deceleration burn high enough in order to avoid, err, the other burn?
Perhaps they could have settled on a main tank that is jettisoned just before de-orbiting.
Phosphorus
Thu Oct 03, 2019 5:48 pm
Before a single-orbit flight option was made mandatory -- requested by US DoD -- the original Space Shuttle design foresaw simpler materials, conventional (rather than delta-shaped) stubby wing shape, etc. The idea was to take advantage of a shockwave during re-entry, a bit like capsule re-entry profile, until getting closer to the surface -- where wings could be taken advantage of.
As DoD insisted on "snatch-and-run in a single orbit" option, Shuttle was made delta-shaped, with shallow and risky re-entry profile, and that necessitated deployment of most advanced, very expensive and often unorthodox materials and solutions.
If original shuttle shape was used, stainless steel would still not be as good for the underbelly. Look for capsules bottom (Gemini, Apollo, Soyuz) for inspiration -- what could be good shuttle underbelly material in this scenario. For the rest of the structure -- I don't know.
But if you do look for a rocket design to benefit from availability of modern stainless steel -- probably Sea Dragon would be a good candidate:
https://en.wikipedia.org/wiki/Sea_Dragon_(rocket)
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
mxaxai
Fri Oct 11, 2019 5:47 pm
After the recent talk with Elon, Everyday Astronaut got a conversation with NASA admin Jim Bridenstine. I'm amazed how far a YouTube career can take you. Bridenstine is very careful to show support for all three crewed launchers, and avoid a competitive "X is better than Y". Doesn't appear to be fully convinced of BFR/Starship yet, though. https://youtu.be/TU_vOt3wSDg
Nomadd
Sun Oct 13, 2019 5:22 am
It looks like they've started the third Starship prototype (MK 3) at Boca Chica. This time with single piece 6 foot hoops from rolls.
Tugger
Mon Oct 14, 2019 12:23 am
Bridenstine said it was “fly, test, fix” but isn't it actually "test fly fix"?
Test
Productivity isn’t about getting more things done, rather it’s about getting the right things done, while doing less. - M. Oshin
Trololzilla
Tue Oct 15, 2019 3:09 am
https://www.youtube.com/watch?v=C8JyvzU0CXU
Starship launch animation, courtesy of SpaceX.
Francoflier
Mon Nov 11, 2019 12:58 pm
It's been a while since SpaceX has launched anything into space, which feels a bit weird since they had gotten us used to a fairly breakneck pace of launches.
This dry spell should end today with a quintessential SpaceX mission:
https://spaceflightnow.com/2019/11/11/f ... -center-2/
https://spaceflightnow.com/2019/11/10/s ... or-launch/
60 Starlink satellites, a booster which has already flown and landed 3 times and a fairing piece which has also previously flown and been recovered.
Light-off around 1500 GMT, hopefully. :crossfingers:
zanl188
Mon Nov 11, 2019 3:08 pm
Best booster landing video I’ve seen from the drone ship!
zanl188
Mon Nov 11, 2019 3:47 pm
Not sure if this is new for this launch, however I like the fact that SpaceX ran 2 streaming services for this launch. One with the normal video and PR audio, and the other with Mission Control Audio.
zanl188
Mon Nov 11, 2019 4:10 pm
flyingturtle
Mon Nov 11, 2019 11:42 pm
In 2027, a bunch of nine Merlin engines are still waiting for their retirement...
ZaphodHarkonnen
Tue Nov 12, 2019 1:35 am
They've done it many times before. And yeah, sometimes it's nice to just listen in to the control room audio.
Tugger
Thu Nov 14, 2019 3:57 pm
SuperDraco Success!
Yesterday SpaceX had a successful test of the SuperDraco abort motors:
https://spaceflightnow.com/2019/11/13/v ... canaveral/
https://twitter.com/SpaceX/status/11947 ... 77/photo/1
So good news after the failure earlier this year. The redesign appears to have done its job.
Next up, the inflight test of the system.
Tugg
Francoflier
Thu Nov 21, 2019 4:06 am
And some not so good news...:
https://spacenews.com/spacex-starship-s ... g-setback/
Goodbye, Starship 1.
Extremely ambitious project, breakneck pace, limited budget... Something had to give if you ask me.
Francoflier
Thu Nov 21, 2019 6:38 am
Video of the RUD:
https://www.youtube.com/watch?v=4eBbKHufxdE
How hard is it to engineer a pressure bulkhead from a material with well defined characteristics? Isn't that rocket building 101?
I like how the local news now quote information from prominent Youtubers...
zanl188
Thu Nov 21, 2019 11:57 am
Could be system failure or test irregularity as well. Pressure regulator gone bad, etc
Prominent YouTubers these days typically apply for press credentials and are starting be considered as credible news sources. A new cottage industry....
ZaphodHarkonnen
Thu Nov 21, 2019 7:48 pm
Probably a weld that just wasn't quite right. I'm sure the SpaceX team prefers to learn from success, but failures highlight lessons too.
And it was noted that this version of Starship was already out of date and would be a one off. Still sad to see it go boom, but what a pretty boom.
Francoflier
Fri Nov 22, 2019 2:39 am
I'd also think more of a weld issue than testing or pressure valve issue.
But come on, a hastily built stainless steel rocket built outside using cherry pickers and construction cranes, in a dusty environment where any amount of impurities can get into the welds? And they want reliability and massive reusability?
I know SpaceX is trying to decomplexify and democratize space vehicles as much as possible, and I love them for that, but building the biggest rocket in the World in a backyard using early 20th century technology seems a step too far.
I've always been skeptical of the Starship project (or whatever name it's had along the years), however much I want to see it become reality, but to me it's always been one of these 'Theranos' kind of venture, one born of the Silicon Valley mentality and which just seems too good to be true. As we've seen lately, there's sometimes little between a brilliant tech idea and a complete scam.
I'm afraid the project is going to go against a lot setbacks like this one going forward. But I hope I'm wrong and they succeed.
Nomadd
Fri Nov 22, 2019 5:13 am
SpaceX said it was an overpressure issue.
Users browsing this forum: jetwet1 and 68 guests
