Quoting foxecho (Reply 6): The pilot has apparently been pulled out alive |
Quoting ferengi80 (Reply 14): This has been posted on twitter, taken from the side of the A27. It looks from this that the canopy is open. There is an object in the air on fire - could this be the ejector seat? |
Quoting flylku (Reply 17): What is strange to me is that the manoeuvre appears to be performed outside the boundaries of the airport and specifically not over the runway. I was under the impression that most air shows require, for the most part, that aerobatics are performed over the runway and that crowds are set back from the runway. I do not know this airport or the area so maybe it is just the angle in the video. |
Quoting lhrnue (Reply 13): Shocking videos. Looks like cars on the road been in a traffic jam. RIP |
Quoting notaxonrotax (Reply 27): Which aircraft was it?Is she in the data base?No Tax On Rotax |
Quoting maninch (Reply 1): Also, a pic of 'the Hunter' showed it to be WV372 which, I think, was based at North Weald. Didn't they also lose a Gnat last month? Dark times at NW; prayers for all concerned. |
![]() Photo © Phil Chaplin | ![]() Photo © Ad Vercruijsse |
Quoting petertenthije (Reply 25): Considering the flames surrounding it a drop tank seems more likely. |
Quoting Viper911 (Reply 20): RIP to anyone who perished in this sad event. In continuation to the picture, check this video out. https://www.youtube.com/watch?v=-lQiCyLZs2E Viper911 |
Quoting GDB (Reply 24): yet, if the investigation recommends changes to airshows, in particular smaller ones like Shoreham, that some might call 'nanny state', then so be it. |
Quoting G-CIVP (Reply 41): I suspect there will be changes to UK Airshows. There does come a point where you can not continue to fly vintage jets as the likelihood for an accident increases as the airframes and components therein age. |
Quoting winterlight (Reply 42): Vulcan looks a cert to be grounded now. |
Quoting TedToToe (Reply 44): Aerobatics in a 50 year old airframe? I agree, the risk of mechanical failure, especially if g forces are involved, is too great! |
Quoting F9Animal (Reply 43): does it look like the right wing stalled? |
Quoting TedToToe (Reply 44): Aerobatics in a 50 year old airframe? |
Quoting larshjort (Reply 46): How is the risk for mechanical failure higher in a well maintained 50 year old frame operating well within design specifications compared to a a well maintained 35 year old frontline fighter doing the same stuff? |
Quoting Aesma (Reply 40): I watched the video knowing it would crash (not knowing how), and found it to be too low from the start. I don't think I've ever seen a loop performed from such a low altitude. Some kind of Immelman turn would have been better advised. |
