sasd209
CH-53K First Flight!
Wed Oct 28, 2015 7:25 pm
What an impressive looking helicopter!!
~SASD209
From Flightglobal
http://www.flightglobal.com/news/art...s-off-after-troubled-start-418268/
"Sikorsky’s CH-53K King Stallion has finally reached “day one” of its 2,000h flight test programme after a maiden 30min flight this morning at the company’s development flight centre in West Palm Beach, Florida.
The flight comes about one year late, and nine years after Sikorsky received the system design and development contract from the Marine Corps to produce a replacement for the Sikorsky CH-53E Super Stallion.
The H-53K looks similar to its predecessor, but is actually a brand new fly-by-wire, glass cockpit aircraft that can lift 12.2t (27,000lbs), or triple the weight of the E-model...."
N328KF
RE: CH-53K First Flight!
Wed Oct 28, 2015 7:51 pm
Quoting sasd209 (Thread starter):
This trick is so goofy. Where else can we say that this has happened?
CH-53E -> CH-53K
F/A-18C/D -> F/A-18E/F
F8U2 Crusader -> F8U3 Crusader
Tu-22 'Blinder' -> Tu-22M 'Backfire'
Of course, there are examples of one aircraft being given a completely different designation for minor iterations (B-29 -> B-50, etc) but those are too numerous to list, I think.
“In the age of information, ignorance is a choice.”
-Donny Miller
ssteve
Wed Oct 28, 2015 8:15 pm
Quoting N328KF (Reply 1):
320neo, 737 MAX, 777-9...
N328KF
Thu Oct 29, 2015 2:08 am
Quoting SSTeve (Reply 2):
Not even close. The examples you cited are still largely based upon the originals. What I mentioned are completely different aircraft masquerading as the originals.
-Donny Miller
columba
Thu Oct 29, 2015 9:43 am
Hopefully something the German Air Force will acquire as well.
It will forever be a McDonnell Douglas MD 80 , Boeing MD 80 sounds so wrong
Max Q
Thu Oct 29, 2015 10:16 am
Amazing Aircraft.
27000 Pound payload, that means it could carry a fully loaded SF340 at max weight.
Impressive.
GGg
Norlander
Thu Oct 29, 2015 12:24 pm
Quoting N328KF (Reply 3):
There is not much in common between a 737-100 and a 737 MAX 9
Longtime Lurker
ptrjong
Thu Oct 29, 2015 1:43 pm
So the H-53K has new engines and a glass cockpit. How exactly it that a 'new aircraft masquerading a an H-53?' Just a major new variant, obviously not more extensive than all they did to the 737.
The only clean sheet design in your list is the Backfire compared to the Blinder.
seahawk
Thu Oct 29, 2015 1:58 pm
It also has a composite fuselage.
ssteve
Thu Oct 29, 2015 4:29 pm
You're right. I read your comments, not your list. I thought you were implying it was just marketing hyperbole and that the changes *weren't* substantial. Because I'm not sure I'd call it a "trick." I think it'd be more confusing to tick the version, like the B720, regardless of how radical the changes. Because it's not really clean-sheet either.
[Edited 2015-10-29 09:51:17]
A342
Thu Oct 29, 2015 8:09 pm
Quoting seahawk (Reply 8):
I've read this repeatly, but it looks exactly the same as the old versions. Sponsons, cockpit window frames etc...
Exceptions confirm the rule.
N328KF
Thu Oct 29, 2015 11:00 pm
Quoting ptrjong (Reply 7):
ptrjong, Sikorsky has said as much themselves with respect to the CH-53K.
The F/A-18E/F shares only some systems with the C/D, but the airframe and many of the other systems are new. Sure, it's not clean-sheet, but it's not the same aircraft. Just put two of them next to each other and that much is obvious.
As for the F8U2 Crusader and F8U3 Crusader, Barrett Tillman's book describes this exactly.
-Donny Miller
JohnM
Fri Oct 30, 2015 12:56 am
I find it interesting that the article lists the payload is tripled to 27,000 lbs. I'm not a CH-53 expert, but I'm pretty sure the legacy -53 can lift more than 9,000 lbs, even hot/ high. Hell a UH-60 can do that, not hot/high however. Seems like they are putting out the old CH-53 had such a poor payload, the new bird triples it. I remember from sling load school that the CH-53 was the top sling load lifter in the US military rotary wing fleet. Did a propaganda minister get involved with this news release?
ThePointblank
Fri Oct 30, 2015 1:36 am
Quoting JohnM (Reply 12):
You have a much increased MTOW, more powerful engines, a beefier transmission, a new 7 blade rotor, and an upgraded external hook. So, yes, expect payload to go up dramatically here.
ptrjong
Fri Oct 30, 2015 12:01 pm
Hi N328KF,
The CH-53K does seem to have large part of its airframe replaced by composite compenents, and it's obviously a major new variant. Still, I would call it an H-53 variant, and I wouldn't think that retaining that designation is a trick (to get funding more easily) as you are suggesting.
http://www.compositesworld.com/news/...ls-ch-53k-king-stallion-helicopter
Peter
Max Q
Sat Oct 31, 2015 11:53 am
I think its a bit wider as well
GGg
Users browsing this forum: integrator and 13 guests
