Quoting larshjort (Reply 2): Maybe they have issues getting overflight permission while carrying bombs similar to USAF attacking Libya in the 80'is? |
Quoting zanl188 (Reply 3): I'd think given recent events the Russians would have been cleared for French airspace?!? |
Quoting stealthz (Reply 4): You think? |
Quoting ptrjong (Reply 7): I think the routing is just a show of force/capability, just as the whole employment of the Tu-160. I mean, there don't seem to be that many targets suitable for cruise missiles in the desert caliphate. |
Quoting vkrymko (Reply 9): |
Quoting scbriml (Reply 11): Why would they need to use French airspace? It's a long way from the almost direct Russia to Syria (with a brief hop over Iran & Iraq) route. |
Quoting moo (Reply 8): The B-2 was used over Libya and the F-22 has seen action in Syria, so I dont see any particular issue with Russia using the Tu-160 |
Quoting ptrjong (Reply 7): I think the routing is just a show of force/capability. |
Quoting solarflyer22 (Reply 14): I think they took this route to fly by NATO. |
Quoting solarflyer22 (Reply 14): Did they us the B2 over Libya? This is the first I am hearing of that. I can't imagine they had anything that would have required using it though. |
Quoting dfwjim1 (Reply 12): 1). Where would Russia have positioned their air tankers to support this mission? |
Quoting dfwjim1 (Reply 12): 2). Do the TU-160s carry an extra pilot or pilots for these type of missions? |
Quoting dfwjim1 (Reply 12): 3). If the bombers had flown into Britain's airspace what would have happened? |
Quoting sovietjet (Reply 19): Intercepted and forced to land would be my guess. |
Quoting TheSonntag (Reply 20): Start of WW3. |
Quoting moo (Reply 24): Not when you consider that its the only route a Russian aircraft could take if there was a goal to not overfly foreign airspace while the aircraft has live ordnance onboard... |
Quoting JetBuddy (Reply 25): They've flown the southern route to Syria in the past, with live munitions onboard. |
Quoting bikerthai (Reply 26): Tactically, does make sense to fly over sea on the in-bound to avoid ISIS spies from spotting them coming in? Not that you can pick-out a couple of flights at altitude among the various flights around the world now a day. |
Quoting JetBuddy (Reply 23): A very long detour and pure showoff of air power from the Russians. |
Quoting TheSonntag (Reply 22): Probably right. But obviously, the russians so far have proven they are able to navigate (except their soldiers who entered Ukraine by accident). |
Quoting WIederling (Reply 28): Maybe finding out who snitches to ISIS when bombs are to be expected? |
Quoting moo (Reply 33): No, but there have been a lot of back and forth between Iraq and the US in recent weeks over the allowance of Russia and Iran to overfly Iraq - I personally wouldn't be surprised if Iraq has had to change its stance as a result. |
Quoting celestar (Reply 35): I am a bit confused. The Turks stated it was shot down by F-16 and the Russian stated it was ground fire. |
Quoting celestar (Reply 35): Is this the first known instance of F-16 shooting down a Su-24? Just for my presonal record purpose |
Quoting moo (Reply 17): They did, google Operation Odyssey Dawn and check out the missions flown by B-2s from Whitman AFB. The B-2 was also used over Serbia and Kosovo in the 1990s and 2000s. |
Quoting celestar (Reply 35): I am a bit confused. The Turks stated it was shot down by F-16 and the Russian stated it was ground fire. Is this the first known instance of F-16 shooting down a Su-24? Just for my presonal record purpose |
Quoting Spudh (Reply 38): Quoting celestar (Reply 35): I am a bit confused. The Turks stated it was shot down by F-16 and the Russian stated it was ground fire. Is this the first known instance of F-16 shooting down a Su-24? Just for my presonal record purpose Maybe the F-16 fired while on its take off run and both accounts are correct |
Quoting celestar (Reply 39): Turks are coming back to say if they knew the jets are Russian, they would probably take different action.... Wonder what does that means, are they saying they think ISIS has an airforce. I love Putin's answer, "our Russian planes are easy to tell" This whole situation is so confusing with every entity trying to get their slice of the pie... |
Quoting ThePointblank (Reply 40): More precisely, the Syrian Air Force operates Su-24's, and the Syrian Su-24's were recently upgraded between 2009 and 2013. More than likely that the Turks, who probably knew the aircraft they had detected were Su-24's, thought the aircraft were Syrian. |
Quoting SSTeve (Reply 10): ISIS is not often the Russian's target. Which is why it was perhaps stupid of them to bomb that airliner. |
Quoting angad84 (Reply 41): Knowing that there are also Russian Fencers in theater, they should (going by their own statements) have been more circumspect. |
