Page 5 of 6
Re: Stratolaunch‘s Carrier Aircraft Production
Posted: Fri Jan 18, 2019 3:03 pm
by estorilm
parapente wrote:
Good spot.But weather does not look great.But any time next week will do!
Even if it ends up as the Worlds largest water bomber it would be fun ( California seems to need it these days).
Reading around the subject there does seem to be more than a whiff of the US military being interested as an instant response 'anywhere' sat' launcher.
I don't think it's even remotely capable of conducting any sort of maneuver that would be required by a water bomber. IMHO structural integrity (not so much overall lifting strength, but inherent weakness with the unsupported twin fuselage design) is going to limit this thing to a single specific task. I think she's forever going to be a straight/level (and zero turbulence) air frame.
At the end of the day, I still like the Spruce Goose analogy. It will likely be equally as epic to see her take to the skies though.
Posted: Fri Jan 18, 2019 10:26 pm
by parapente
Fair comment.
Posted: Sat Jan 19, 2019 11:54 am
by parapente
https://spacenews.com/stratolaunch-aban ... e-program/
As the title says they have abandoned building their own air launched rocket.Now relying only on a small and expensive rocket that is already air launched nad has never gained traction in the marketplace ( launching 3 won't make it better if anything less flexible).
But yet...They continue with the Stratolaunch development.Achieving first Flight must be very close indeed.
But why?
It may be in their founders will ' of wishes' which is known to exist.
Some others say the US military are involved in this programme so they can 'instantly' launch a small spy satellite whenever/wherever necessary.Its possible I suppose.
But other than that it's an answer without a question.Hard to know what else it could be used for.
Any suggestions?
Posted: Sat Jan 19, 2019 1:56 pm
by tapairbus370
The same information as the previous thread but in a different article.
It has a photo with the front wheels up during the high speed taxi test,
http://www.geekwire.com/2019/stratolaun ... R8fUdqe54c
Posted: Sun Jan 20, 2019 12:37 am
by EBJ68
It certainly appears the focus is now on the launch vehicle rather than producing vehicles to be launched. That seems to be the way the article pointed. If that's the case and the first example proves dependable and flexible in terms of the kinds of vehicles that can be launched, it "might" open the door to further examples being built.
Posted: Sun Jan 20, 2019 11:23 am
by parapente
Sorry to disagree.Whether it flies or not is somewhat immaterial if there is no ( Spruce Goose) market for it.I have been correctly corrected that it would not have the manoeuvrability to become a giagintic waterbomber ( which CA increasingly need). Can't think ( other than the summonsed military use) of what you would do with such an aircraft sadly.
If one is 'simply' lobbing' up the occasional small sat' one airacft is more than enough.Actually not sure they ever envisaged building more than one the way they built it.
Could be an oversized 'spare' for Richard Brandon's project I suppose,both built by the same people I believe.
Posted: Sun Jan 20, 2019 7:52 pm
by DarkKnight5
I suppose it depends on how much ground clearance you have for cargo. Can’t find many reliable specs. Perhaps it could be used for rocket transport. Moving Falcons from Hawthorne to TX to Florida or Falcon Heavy components. For that matter maybe it could transport Delta or Atlas/Vulcan rockets. It would cost a lot more than current transport methods, but maybe it would be less headache and certainly faster than a truck over land or a bardge through Panama.
Posted: Mon Jan 21, 2019 3:32 am
by parapente
That's a lateral thought.Hope it finds a use.I guess the fact that they appear to want to see it fly suggests they see it having a use.Just find it hard seeing they will use that little rocket.It already launches perfectly well off a Tristar ( which I imagine is cheaper too).
Regarding RB.It seems his tourist rocket is somewhat vertically challenged not making the Karman line.Perhaps this aircraft could give him an extra 10k feet altitude on T/O .Would make a hell of a difference overall.
Posted: Sat Jan 26, 2019 1:43 am
by LightningZ71
The TriStar won't be flying for a whole lot longer. That airframe has a lot of age and parts for that frame are getting hard to come by. I suspect that this can find some business covering for that platform.
I still think that they need to make a large cargo pod for it so that it can be used for moving outsized cargo in addition to rocket launches.
Posted: Sat Jan 26, 2019 3:41 am
by Tugger
Cargo would be great but I think it won't work. It is too limited in the facilities that it can work on:
385' wingspan
Fuselage/landing gear width of over 100' (can't find the exact dimension)
And a working runaway length of 12,000'
Tugg
Posted: Sat Jan 26, 2019 7:33 am
by DarkKnight5
385' wingspan
Tugg
That’s why I think the only viable cargo is out-sized stuff that can move more quickly theough the air than on the ground. If they can fly with an F9 booster (or atlas/Vulcan /delta) from Cali go TX to FL they might have a use for the plane. If the length of those booster stage makes it impossible, then this thing has no practical use at all.
Posted: Wed Feb 20, 2019 9:52 am
by Noshow
Is there any status update about their first flight available please? Their tweet is quiet for a month now after those high speed taxi tests. Anything happening right now?
Posted: Wed Feb 20, 2019 2:33 pm
by Aesma
If a rocket isn't made to be transported like that then its structure wouldn't resist being hanged by the middle.
Posted: Wed Feb 20, 2019 3:27 pm
by DarkKnight5
Fair point. Just spitballing ideas to come up with a use for this thing.
Posted: Wed Feb 20, 2019 4:33 pm
by WIederling
385' wingspan
ex WP:EN: Range: 1,000 nmi (1,151 mi; 1,852 km) radius[24]
stumbled over a predecessor design:
https://en.wikipedia.org/wiki/Conroy_Virtus
Posted: Wed Feb 20, 2019 9:36 pm
by estorilm
Par for the course - really worried about this thing getting scrapped at this point. :(
Maybe she takes off to set a record... but I think her commercial case is closed, hence the DRAMATICALLY slowed rate of testing. I still think they either discovered a catastrophic design issue and/or it just doesn't save enough $$ at a given payload to justify the program any longer. Lips sealed for PR and investor/legal reasons.
Posted: Thu Feb 21, 2019 9:02 am
by Noshow
Still hoping for the best and first flight. They seem to have reduced their staff significantly. Not a good sign during first flight preparations.
Posted: Wed Apr 03, 2019 2:15 pm
by Noshow
Good news. Looks like they do taxi tests again.
Posted: Sat Apr 13, 2019 2:39 pm
by wezgulf3
She flies!!
Posted: Sat Apr 13, 2019 4:58 pm
by DarkKnight5
wezgulf3 wrote:
She flies!!
Video: http://youtu.be/XfUy21HHtME
Still not sure it will ever carry something that will launch into space but hey, flight.
Posted: Sat Apr 13, 2019 5:31 pm
by JetBuddy
Congrats Stratolaunch! What a milestone.
Posted: Sat Apr 13, 2019 7:16 pm
by zanl188
Congrats!
Hopefully it will fly a complete test program and then move to something useful.
Posted: Sun Apr 14, 2019 12:27 am
by Gonzalo
Nice !! And not very relevant but yet interesting, from now on the world’s largest aircraft has a US flag instead the russian one. Will be weird to see the An-225 as ”just another big plane” but not the biggest.
Posted: Sun Apr 14, 2019 1:20 am
by Ozair
This thread needs a picture!
Posted: Sun Apr 14, 2019 2:16 am
by Nomadd
It's not even close to being as large as a 225 in anything but wingspan.
Posted: Sun Apr 14, 2019 5:28 am
by c933103
Antonov is not Russian anyway....
Posted: Sun Apr 14, 2019 6:58 am
by curlyheadboy
Impressive!
It just looked a little clumsy on landing touching down on the right gear and then the whole left fuselage coming down on the runway.
Posted: Sun Apr 14, 2019 8:57 am
by chornedsnorkack
An-225 never was the biggest plane. Stratolaunch is the first plane in 72 years to be bigger than Hercules, also an US plane. What was the biggest plane before the first (and only) flight of Hercules?
Posted: Sun Apr 14, 2019 10:17 am
by UA947
Although the Spruce Goose is higher and has a bigger wingspan than the An-225, the latter is over 17 meters longer. So, which is bigger?
Posted: Sun Apr 14, 2019 11:08 am
by chornedsnorkack
Stratolauch is also shorter than An-225.
Posted: Sun Apr 14, 2019 11:17 am
by Nomadd
I never considered the Goose a real airplane because it never got above ground effect level.
Posted: Mon Apr 15, 2019 1:53 am
by zanl188
Posted: Mon Apr 15, 2019 5:37 pm
by flyingturtle
zanl188 wrote:
Wow! That thing is from another world...
Landing Checklist
Touch down left or right of runway centerline......... determine
Posted: Mon Apr 15, 2019 7:13 pm
by hmmwv
I wish Paul had lived to see this day!
Posted: Thu Apr 18, 2019 10:30 pm
by HaveBlue
The 'largest' plane is always defined by max weight. The An-225 is the heaviest plane in the world, so it is the largest. The C-5 is longer than the An-124 so I didn't like it not being the 'largest' back in the day but the weight defines the largest, which makes sense in a way as in you can't have a 300' F-104 and say its the largest. The An-225 was at 1.3 million pounds but then so was the A380 but they strengthened the Antonov and at 1.4 million pounds it is the champ, like it or not.
Stratolaunch
Posted: Fri Apr 19, 2019 3:39 pm
by MileHFL400
Hey guys
I don’t know if this has been discussed yet,
But I literally hadn’t heard of this before today. It’s the largest all composite aircraft in the world and it seems to have completely escaped me. Is this aircraft even real?! How did it completely escape me?!
Re: Stratolaunch
Posted: Fri Apr 19, 2019 3:45 pm
by SpaceshipDC10
Yest, it IS. See here: viewtopic.php?f=10&t=1028393
Don't know
Re: Stratolaunch
Posted: Fri Apr 19, 2019 4:01 pm
by WayexTDI
Really have no clue. You can see articles posted on the web all over the place, even more on tech or aviation sites.
It's been discussed for years now.
Re: Stratolaunch
Posted: Fri Apr 19, 2019 6:43 pm
by Cunard
MileHFL400 wrote:
Hey guys
''How did it completely escape me?''
Only you can answer that question :-)
Just a guess but it could well be that you obviously haven't been keeping up to date with things!
Posted: Fri Apr 19, 2019 7:33 pm
by starrion
So what's next for this thing? It's been in the test phase for some time. With SpaceX going gangbusters, is there even a market for air launched rockets?
Re: Stratolaunch
Posted: Fri Apr 19, 2019 9:08 pm
by SheikhDjibouti
At great personal risk to my reputation here on a.net (ok, maybe that ship has already sailed....) I am going to sympathize.
I have been vaguely aware of the project for some years now, but I haven't been following it's progress, and so I was also shocked at the sheer size of the beast.
It hasn't been headline news, at least not in the papers I read. And it doesn't quite fit in civ av either.
I only found it by accident after visiting "Military Aviation & Space Flight". Plenty here don't. :shakehead:
On Civ Av, the 20 most up to date posts have all received contributions within the last 60 minutes
On Mil Av & Space, the 20 most recent posts are only there because they received contributions within the last nine days.... :lol:
Some people probably don't even know that forum exists..., and if it isn't Civ Av, Airbus, or Boeing, they ain't interested.
So, I doubt you are the only one here who has missed this project.
Posted: Fri Apr 19, 2019 9:10 pm
by Tugger
Actually there is. But I doubt it is big enough yet to support this project.
It really depends on what Mr. Allen left for the project. If he left funding for this and also development of the market etc. then it may survive. I have not heard anything as to what is supported.
The Pegasus system could use it but currently uses an L1011 and I doubt the Stratolaunch is cheaper than that but who knows.
I am hopeful but doubtful.
Tugg
Posted: Fri Apr 19, 2019 9:34 pm
by Nomadd
That's nonsense. Size and weight are two different things. A dust spec made out of neutron star material would weigh more than a 225, but nobody would call it larger.
Re: Stratolaunch
Posted: Fri Apr 19, 2019 10:06 pm
by tapairbus370
Lack of curiosity? Narrow minded? ....... Lots of reasons. I sometimes sail in the other forums, not the techical ones but the others and I usually find something interesting, Like this airplane that I found about 2 years now. If I can give you an advice.. Check the others foruns sometimes, at least the first 10 threads, the titles gives you a clube about the interest it may have to you.
Re: Stratolaunch
Posted: Fri May 31, 2019 11:03 pm
by tapairbus370
Re: Stratolaunch
Posted: Sat Jun 01, 2019 12:53 am
by TWA772LR
tapairbus370 wrote:
https://www.reuters.com/article/us-space-exploration-stratolaunch-exclus/exclusive-space-firm-founded-by-billionaire-paul-allen-closing-operations-sources-idUSKCN1T12FD?fbclid=IwAR2powjLJbbmaqe_93oV64lruOiQh4YIowuOI50R534z2Uh8BRsYm6MgjPw
The end?
If true, that really sucks. But its being proved that ground-based rockets are still the way to go instead of an aerial launch system so not too surprising.
I wonder what will happen to the aircraft.
Re: Stratolaunch
Posted: Sat Jun 01, 2019 1:23 am
by IAmGaroott
TWA772LR wrote:
The end?
I'll be keeping an eye out on Controller.com
Re: Stratolaunch
Posted: Sat Jun 01, 2019 1:39 am
by hOMSaR
IAmGaroott wrote:
TWA772LR wrote:
The end?
Any chance Southwest might buy it and convert it to passenger use to cover for the 737 MAX grounding?
Re: Stratolaunch
Posted: Sat Jun 01, 2019 4:30 am
by TWA772LR
EvanWSFO wrote:
This site is really going south. Are people so lazy they can't use the search function (not always helpful, but try it first), or Google? I can find virtually anything in the world with three clicks or less.
I hate when people say that. This site is as much of a resource as Google. And the search function could find a McDonald's with a GPS and a chauffeur.
/rant
Re: Stratolaunch
Posted: Sat Jun 01, 2019 4:41 am
by VirginFlyer
If you’ve been here for 15 years then you should know that people have always been posting questions with seemingly easy to find answers; it is not a new phenomenon. It is a shame that your prowess with Google didn’t prevent your unrecoverable email account.
V/F
