bikerthai
Re: New advertisement: B-52 re-engine back in the mix?
Fri May 22, 2020 8:32 pm
Are they not going from a turbojet to a higher bypass ratio turbo fan?
That would require new nacelles as the by-pass duct geometry is quite different.
New pylons should also be in the works.
Wonder if they would include thrust reversers?
bt
mmo
Fri May 22, 2020 9:05 pm
bt
After 2500 hours or so in the Buff, I can certainly guarantee you it won't happen. It's too much additional weight, too complex and most important of all, too much problems with directional control with asymmetrical reverse on a contaminated runway. A drag chute and anti-skid work just fine.
If you look at the KC-135R mod, they didn't add reverse on that mod. Will never happen.
LyleLanley
Fri May 22, 2020 9:18 pm
Not to be pedantic, but the KC-135 received thrust reversers when they were reengined from A to E.
The B-52 is, of course, a far different beast. TRs just aren’t worth the hassle to put on now.
"I've sold monorails to Brockway, Ogdenville, and North Haverbrook, and, by gum, it put them on the map!"
kc135topboom
Fri May 22, 2020 11:31 pm
Thrust reversers were offered with the KC-135R reengine program, the CFM-56 (F-108) engines were equipped with the mountings. SAC maintenance did not want them, fearing it would add to maintenance hours per tanker. So they were designed out of the modification. The modification did include new landing gear and 5 rotor brakes.
SAC KC-135 aircrews actually wanted TRs on thier airplanes, the extra weight was not a problem, and it would have opened KC-135R/T operations to many more airports than KC-135R/Ts without TRs.
The ANG was a little stuck with TRs for the KC-135E, but they wanted them anyway. The JT-3D (TF-33) engines were from donor B-707s that included the engine struts and horizontal stabilizers, throttle quadrant, engine instruments, and all associated mounting brackets and equipment. Everything came as a complete package. The "E" model included rebuilt landing gear and 5 rotor brakes.
Most KC-135 ANG pilots were also commercial airline pilots and a lot of the maintenance crews were also commercial airline maintenance people, TRs were less of a 'problem' for the maintenance people.
The "E" modification also found its way into some other air command's C-135 airplanes as well as a few SAC KC-135s based at OFF.
kc135topboom
Sat May 23, 2020 12:53 am
One of the engines considered for the B-52 reengining program is the GE CF-34-10E, with 20,360 lbs. of thrust (a modest increase over the current TF-33-P-3/-103, which has 17,000 lbs. of thrust), but has a dry weight nearly 1,000 lbs. lighter than the older engine (TF-33-P-3/-103 = 4,650 lbs. vs. CF-34-10E = 3,700 lbs.).
mmo
Sat May 23, 2020 5:59 am
Nothing wrong with being pedantic, but go back and read my thread. I specifically talked about the R model.
And at the end of the day, they weren' equipped with them.
747classic
Sat May 23, 2020 6:50 am
Thrust reversers on eight engines will add a lot of weight and maintenance and will not happen.
But I repeat it one more time :
Adding new engine pairs with different weights and/or different external aerodynamical pylon/engine shapes will require wing modifications due the changes in load distribution over the relative thin flexible wing.
IMHO the USAF has two options :
- Low risk option : adding of new aerodynamical identical engine cowlings /pylons for the new engines, with approx the same weight at each pylon. This configuration will not require a wing modification, but only the lower TSFC of the engines will be the gain + reduced maintenance costs.
- All new (high risk) option : adding optimal (different) shaped engine cowlings / pylons for the new engines and use the lower engine weights for increased payload. This modification will require extensive wing modifications and could introduce a lot of unknown issues (wing flutter). Also the certified external weapon loads will have to be re-certified. The extra gain will be : a little more fuel saving and/or increased payload.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
rlwynn
Sat May 23, 2020 7:02 am
No, That already happened when they got the TF-33.
I can drive faster than you
LyleLanley
Sat May 23, 2020 10:08 pm
mmo wrote:
LyleLanley wrote:
Not to be pedantic, but the KC-135 received thrust reversers when they were reengined from A to E...
I know. But when you bring forth examples of reengined aircraft and specifically reference the AF's refusal to add TRs I thought it was proper to mention when the AF did add TRs. Especially if its the same aircraft you mention - the KC-135.
giblets
Sun May 24, 2020 8:16 am
There was a video online where sales guys from the 3 different manufacturers gave some spiel about each of their offering. If it was solely based on those guys, RR would win it (the P&W just kept saying it was a great time to upgrade lol). Offering a fairly technical talk through.
RR had a model with a couple of their engines in a B52 style pod, it was essentially a lot shorter than the current pods, not sure if that was just for the show or whether that’s the pod design the propose (the imagine behind them also shows a similar pod, looks more like the pod for the jp57!
https://www.defensenews.com/video/2019/ ... 4-options/
146, ATR72, Q400, Saab 340, PA-46 Jetprop, Jetstream, E175/195, 707/727/737/747/757/767/777, DC-3/9/10, MD-11/80, A300/310/319/320/321/330/340/350/380 Tristar, BAC 1-11, Trident, Chipmunk, Bell 206/222, Chinook, Puma, Cessna 172, Fokker 70, 100, SRN4!
Users browsing this forum: No registered users and 48 guests
