anthonycII
Does Air Force One stay with the president?
Fri Dec 21, 2018 11:04 am
When the President of the United States is away from Washington DC on non governmental trips (vacations, holidays etc) does the plane remain at the destination airport?
Reason: Non descriptive title
Boof02671
Re: Air Force One
Fri Dec 21, 2018 11:32 am
Yes usuallly
redcenterflyer
Re: Air Force One
I'm no expert, but there is at least one nat geo documentary on youtube, that indicates it does stay at the destination. I would assume , usually a near by military base. It'd have secret service protection. It would be needed to get the President out quick it something happens, for example 9/11
Boof02671
Re: Air Force One
Fri Dec 21, 2018 11:35 am
No it stays at the destination airport, they dont ferry it out to another destination
BobbyPSP
Re: Air Force One
Fri Dec 21, 2018 11:41 am
Whatever aircraft is designated AF1 (Air Force 1)will remain with the President. It has too as it functions as a flying White House and set up for emergency contingencies
Support aircraft, such as C5 C17, will position to another field if needed. When flying into Palm Springs, CA. They've gone to March AFB
Flighty
Re: Air Force One
Fri Dec 21, 2018 11:59 am
It is not uncommon IIRC for another VIP plane to be staged nearby to provide a quick getaway in case the VC-25 is disabled. So, there are some reasons why the VC-25 should retreat to a safer location. And if those reasons happen, then they have another aircraft to carry the POTUS.
RDUDDJI
Re: Air Force One
Fri Dec 21, 2018 12:12 pm
Actually it’s not an aircraft designation, whatever USAF aircraft the president is designated as AF1. Regardless of the type or registration. :).
Sometimes we don't realize the good times when we're in them
Channex757
Re: Does Air Force One stay with the president?
Fri Dec 21, 2018 12:24 pm
Apparently they do both. There are two VC-25s, one being the plane in use and the other as a 'hot' standby at a nearby military location. The actual details will be deliberately obscured from the 'wrong' eyes but there's a reason why this procedure is used. Especially on longhaul international trips.
They need to move the Prez out fast and have comms available instantly. The main jet might (for instance) go to a London airport and the backup to Mildenhall or Fairford.
COSPN
Fri Dec 21, 2018 2:40 pm
What callsign did UA used when they flew President Nixon IAD-LAX. He wanted to show he was “normal” AF1 has to follow United incase it had to divert .. as the United DC-10 has limited communication gear onboard
GalaxyFlyer
Fri Dec 21, 2018 2:54 pm
EXEC ONE is the call sign for non-military flights carrying the President, but I can’t say for sure it was used in Nicon’s flight.
GF
fry530
Fri Dec 21, 2018 4:24 pm
I saw one of the VC-25s at JFK in 2011. I have no idea if Obama was in NYC at the time since I was connecting through JFK from FCO to DEN, but I assumed that was the case. I had always thought it would stay wherever POTUS is.
319 320 32N 321 332 333 722 733 735 73G 738 739 744 752 763 772 77W CR2 CR7 Q400 E145 E170 DC10 MD80
AA BA BD CO DL EI F9 HP NW NZ UA U2 WN Y4
Moose135
Re: Air Force One
Fri Dec 21, 2018 9:23 pm
On a couple of occasions, when POTUS was in NYC for several days during the UN General Assembly meetings held in September, the VC-25 was ferried to Stewart (SWF), probably parked on the ANG ramp. I imagine it allowed for more security (and less disruption) to do that, rather than leave it parked at JFK for three or four days. When he was ready to depart back to Washington the plane came back (call sign SAM 29000) to pick him up. Since they would usually fly him between JFK and downtown Manhattan in the helicopter, I guess in an emergency they would just fly the choppers to SWF to get out of town quickly.
texl1649
Fri Dec 21, 2018 10:09 pm
The VC-25’s are used for various folks. Michelle used to take one separately to Martha’s Vinyard/Hawaii often. Sometimes she’d fly back with Barrack, but her entourage was also enormous (more than twice the staff of Melania).
A101
Sat Dec 22, 2018 11:40 pm
would the president ever use a Boeing E-4 Advanced Airborne Command Post and when would he if always tailed by AF1?
PC12Fan
Sun Dec 23, 2018 3:35 pm
GF
Not sure what the circumstances were for this particular flight, but EXEC ONE was used flying the first lady out of STL on a C-37 several years back.
Just when I think you've said the stupidest thing ever, you keep talkin'!
Moose135
Sun Dec 23, 2018 10:01 pm
Flights carrying the First Lady (without POTUS on board) use "Executive 1 Foxtrot". They used that just the other day, when they flew the current FLOTUS to Florida ahead of POTUS, then when they flew her back to DC after the government shut down.
cpd
Re: Air Force One
Tue Dec 25, 2018 8:45 am
I'm very sure that is not correct. It has ferried to another nearby airport before as well (because the original airport was too busy).
777PHX
Tue Dec 25, 2018 7:03 pm
For the most part, no. The FL usually takes one of the C32s(or C37s) when she's traveling without the POTUS.
Michelle took a C32 on that infamous super expensive vacation to South Africa back several years ago.
https://www.usnews.com/news/blogs/washi ... han-432142
Not likely. The E4 was needed back during the Cold War when the presidential aircraft had far less communication capabilities. Nowadays, you can run a war from SAM 28000/29000 which has greatly diminished the need for the E4s.
A101
Wed Dec 26, 2018 1:55 am
Your most likely correct as I saw a documentary on Foxtel a couple of months ago which showed the history of AF1 (I wish I recorded it now) must have been quite a recent documentary as ole Trump was in it, well anyway they were show GW Bush and 9/11 and were say that they had quite a bit of problems communicating with various departments, which became a vital lesson
rlwynn
Wed Dec 26, 2018 10:48 am
I remember when AF1 came to El Toro. Obviously it would stay but what was interesting that the APU stayed on the whole time. Maybe that is part of the quick escape rules.
I can drive faster than you
stratclub
Fri Dec 28, 2018 8:29 am
To cheap to call for ground services maybe? Probably not. When the POTUS flies anywhere, it is just horrifically expensive. When there is some sort of disaster, the worst thing the POTUS can do is survey the disaster area. Cost the tax payers millions upon millions of tax dollars and impacts the immediate area and relief efforts in an extremely negative way and does absolutely nothing in a positive way towards relief efforts.
A much better use of those millions upon millions of tax dollars would be for th POTUS to stay home and divert the money saved to actual relief effort activities.
GalaxyFlyer
Fri Dec 28, 2018 9:19 pm
Absolutely true, stratclub, now to get the media off the “callous President xxx won’t visit disasters area” meme.
GF
BobbyPSP
Re: Air Force One
Sat Dec 29, 2018 8:45 pm
Really? Isn’t that what I said?
DocLightning
Wed Jan 02, 2019 9:02 pm
When I was a Sophomore at Stanford, I was there when Chelsea (one year below me...her husband was in my freshman dorm), came for her first day.
The VC-25 flew into Moffit Field. However, President Clinton was then going to give a speech in San Francisco before returning to Washington, D.C., so they ferried the aircraft from Moffit to SFO. The aircraft will always be nearby. If there is some emergency and the President needs to return immediately to Washington, D.C., you can't have the President waiting for his aircraft to arrive from somewhere.
-Doc Lightning-
-Carl Sagan
trpmb6
Wed Jan 02, 2019 10:37 pm
Not exactly how I would characterize the E-4B's but not wrong about the VC-25 cababilities (and what their replacements will have). The E4-Bs have so much airframe life in them they'll be around for a long time. Secretary of Defense will fly on them. One is always on the runway ready to take off should a nuke go off some where. One is always down for a massive scrub, maintenance and equipment overhaul and repainting.
tmu101
Sat Jan 05, 2019 3:33 am
I think the E4 is a pretty cool looking airplane. There's a video of a crew member giving a tour of the airplane at Offut AFB on YouTube. Amazing how utilitarian it is on the inside compared to videos I've seen of the VC-25.
Speaking of VC-25 will the "A's" remain in the air force when the "B's" come online? Will they still serve the SAM role or will they be totally retired and removed from service?
BobbyPSP
Re: Air Force One
Sat Jan 19, 2019 12:51 am
Um, I didn’t infer anything different. But thank you
timh4000
Tue Jan 22, 2019 12:37 am
I believe there may still be scenarios where the potus could end up on a E4B should the shit it the fan. It was once the idea he would be on one well out of range, doing polar circles possibly for days, getting refueled. Now. The current VC-25's
have more comm capability and defensive capability. The next ones the 748's will be all the more capable of a nuclear/chem bio war. Still. I think there are scenarios where he could end up on an E4B, but far less likely. Remember too that besides the current 2 742's, occasionally the potus will ride on a C-32 for runways too short for the VC-25. Obama took one of the 742's into ALB I'm assuming 01/19 which is the longer of the two at 8500ft. Of course the best performance 742 flown by one of the best pilots on the planet would make that possible. Otherwise, ALB flys nothing larger than cargo versions of the 757. Pax planes nothing larger than a321's and the most current 737's. As these once short hoppers have been evolved, a320's and the modern 737's now have transcontinental capabilities. I ve flown a virgin American a320 from JFK-LAX back in 2011. All with what's needed, during my still current vacation I flew last week a 757-300 from DEN-SFO. And a few days ago trying to get home was rebooked to IAD from SFO on a 777-200. Mostly full.
Stitch
Tue Jan 22, 2019 11:09 pm
Protocol would have referred to the flight as "Executive One", but the FAA Administrator at the time claimed he was not informed of the President's presence on the airplane until it was taxiing to the Active at Dulles so for a time it might have been contacted by it's UA flight number until the ATC system was notified.
strfyr51
Thu Jan 24, 2019 3:02 am
The Airplane remains on Hot Standby when It's away from Joint Base Andrews.
Users browsing this forum: No registered users and 32 guests
