FlyingSicilian
Dutch Astronaut accidentally calls 911 from ISS causing panic in Houston
Fri Jan 04, 2019 4:08 am
A funny story LOL Since calls from the ISS go through Houston to dial out from the station an astronaut must dial 9 first. Since the call would then originate from the U.S. they must then dial 011. A Dutch astronaut missed the 0 dialing 911 causing security to rush to mission control.
http://fortune.com/2019/01/03/astronaut ... rom-space/
https://www.dailymail.co.uk/news/articl ... space.html
https://www.newsweek.com/astronaut-acci ... ce-1276892
“Without seeing Sicily it is impossible to understand Italy.Sicily is the key of everything.”-Goethe "Journey to Italy"
zanl188
Re: Dutch Astronaut accidentally calls 911 from ISS causing panic in Houston
Fri Jan 04, 2019 5:52 am
What was the panic?
Nomadd
Fri Jan 04, 2019 6:10 am
Practicing for a journalism career at National Enquirer?
Flyingdevil737
Fri Jan 04, 2019 9:06 am
Well done.
What service do you require???
The thunder from Down Under
smithbs
Fri Jan 04, 2019 2:46 pm
At first I was wondering what security was thinking they were going to do - check for suspicious persons around the ISS? Welfare call on the ISS? It seems they thought 911 had been called from the room containing the phone patch, which makes more sense.
Erebus
Fri Jan 04, 2019 4:23 pm
Well, emergency services will take a while to reach him....
Dutchy
Sat Jan 05, 2019 12:23 am
André Kuipers, the Astronaut in question, was kind of disappointed that they didn't come-up to meet him. :lol:
Funny this has been picked up on international news. It was the radio show: met het oog op morgen. For anyone who understands Dutch, it was about the future of space exploration. Quite interesting to hear his thoughts, together with some other experts from the science community and from ESA.
Nomadd
Sat Jan 05, 2019 3:19 pm
Anybody who's ever worked on a private system where you have to dial 9 to get out realizes there's no perfect solution to avoid that and still allow 911 calls. You have to put warnings up that if you do accidentally do it, don't hang up, but explain your mistake to the 911 operator. They're use to it.
zanl188
Sat Jan 05, 2019 4:05 pm
To dial 911 from a PBX, where 9 needs to be dialed to get out, a person would have to dial 9911. Where this situation goes wrong is when the dialer skips the "0" of the "011" international access code.
FlyingSicilian
Sun Jan 06, 2019 4:20 am
zanl188 wrote:
What was the panic?
It is in the first paragraph and second of the various news articles on the topic... Security locked down MC for a time due to the mistakenly dialed 911 call.
FlyingSicilian
Sun Jan 06, 2019 4:21 am
https://www.npr.org/2019/01/04/68224728 ... from-space
https://www.foxnews.com/science/astrona ... o-a-frenzy
Not sure NPR and Fox would qualify...
