flyingturtle
Rocket Labs - Tests, Launches, Developments
Thu Aug 08, 2019 7:11 am
(I didn't find a thread dedicated to the Kiwis in Space, so I start one. Please remove if duplicated.)
Rocket Labs just announced that they want to reuse the first stage of their Electron launcher. With some clever aerobraking they want to manage heat, and a helicopter will fetch the first stage while it is descending on parachutes.
Adding the capability will eat 10 to 20 percent of the Electron's payload, but they want to recover that by developing the first stage further.
https://www.theregister.co.uk/2019/08/0 ... lab_reuse/
Reading accident reports is what calms me down
Trololzilla
Re: Rocket Labs - Tests, Launches, Developments
Thu Aug 08, 2019 7:26 am
Older thread here, but it probably makes more sense to have a general RocketLab thread from now on.
WKTaylor
Tue Aug 13, 2019 5:56 pm
I thought that their business concept was to build the 1st stages [and any boosters] cheap-enough that recovery and refurbishment was not 'value added' or 'value saved'.
WKTaylor
Tue Aug 13, 2019 6:57 pm
Tugger
Tue Aug 13, 2019 7:56 pm
Well, two things:
An aluminum can is really cheap, but it is still of value to recycle.
And, recovery allows designers to look at what they made and improve on it. Make it cheaper, more efficient, more effective, etc. One and done and you don't get to inspect the results of "what happened" vs "what was intended".
Tugg
There are many kinds of sentences that we think state facts about the world but that are really just expressions of our attitudes. - F. Ramsey
WKTaylor
Tue Aug 27, 2019 7:24 pm
Tugger...
IF inspecting and/or recycling, then let the 1st stage parachute into the ocean and pop-open flotation bags for water-recovery.
Speculation... Adding light-weight grid-fins [and/or] controllable speed-brakes [petals] [and/or] hypersonic 'ballute(s)' to the upper end of the stage would provide dramatic drag-rise and allow limited aerodynamic steering of the stage body to a guided landing 'spot'... much closer to shore... or the most 'tranquil' water-site... and-or landing close-to' a recovery ship.
HMmmmm.. I wonder if the trans-stage ring/fairing could be redesigned and dual-utilized to add drag and/or recovery guidance... instead of 'just' being jettisoned?
Using a heavy helo for 'airborne recovery' is a sketchy proposition.
GDB
Mon Aug 31, 2020 4:32 pm
After a failure on their 13th mission, Rocket Lab has rapidly isolated the problem (as mentioned below), fixed it and had a successful 14th launch;
https://www.youtube.com/watch?v=FPIhI5mRDRI
They are working towards parachute and helicopter recovery for future first stages.
Erebus
Mon Aug 31, 2020 9:35 pm
They name their missions with rather eccentric phrases. Sounds like a very SpaceX thing that SpaceX never does. :mischievous:
AirlineCritic
Tue Sep 01, 2020 12:54 pm
Indeed. I'll be interested to see how that goes.
Erebus
Tue Sep 01, 2020 2:16 pm
I think it should be doable. They've already tested the helicopter recovery part of it. Probably the bigger challenge is how to get the first stage to survive the stresses of reentry. This is a very compact rocket and they don't get a lot of weight margin to work with the payloads they launch.
Users browsing this forum: art, bikerthai and 11 guests
