flyingturtle
Rocket Labs - Tests, Launches, Developments
Thu Aug 08, 2019 7:11 am
(I didn't find a thread dedicated to the Kiwis in Space, so I start one. Please remove if duplicated.)
Rocket Labs just announced that they want to reuse the first stage of their Electron launcher. With some clever aerobraking they want to manage heat, and a helicopter will fetch the first stage while it is descending on parachutes.
Adding the capability will eat 10 to 20 percent of the Electron's payload, but they want to recover that by developing the first stage further.
https://www.theregister.co.uk/2019/08/0 ... lab_reuse/
Reading accident reports is what calms me down
Trololzilla
Re: Rocket Labs - Tests, Launches, Developments
Thu Aug 08, 2019 7:26 am
Older thread here, but it probably makes more sense to have a general RocketLab thread from now on.
WKTaylor
Tue Aug 13, 2019 5:56 pm
I thought that their business concept was to build the 1st stages [and any boosters] cheap-enough that recovery and refurbishment was not 'value added' or 'value saved'.
WKTaylor
Tue Aug 13, 2019 6:57 pm
Tugger
Tue Aug 13, 2019 7:56 pm
Well, two things:
An aluminum can is really cheap, but it is still of value to recycle.
And, recovery allows designers to look at what they made and improve on it. Make it cheaper, more efficient, more effective, etc. One and done and you don't get to inspect the results of "what happened" vs "what was intended".
Tugg
Productivity isn’t about getting more things done, rather it’s about getting the right things done, while doing less. - M. Oshin
WKTaylor
Tue Aug 27, 2019 7:24 pm
Tugger...
IF inspecting and/or recycling, then let the 1st stage parachute into the ocean and pop-open flotation bags for water-recovery.
Speculation... Adding light-weight grid-fins [and/or] controllable speed-brakes [petals] [and/or] hypersonic 'ballute(s)' to the upper end of the stage would provide dramatic drag-rise and allow limited aerodynamic steering of the stage body to a guided landing 'spot'... much closer to shore... or the most 'tranquil' water-site... and-or landing close-to' a recovery ship.
HMmmmm.. I wonder if the trans-stage ring/fairing could be redesigned and dual-utilized to add drag and/or recovery guidance... instead of 'just' being jettisoned?
Using a heavy helo for 'airborne recovery' is a sketchy proposition.
Users browsing this forum: No registered users and 21 guests
